[PATCH 7/8] bsp/motorola_powerpc: Add MPCI support for Qemu
Thu Mar 24 16:43:17 UTC 2016
On Thu, Mar 24, 2016 at 11:25 AM, Sebastian Huber <
> Ok, I should not send patches five minutes before a long weekend.
:) I hope to do a little of the same before I run out. :)
> ----- Joel Sherrill <joel at rtems.org> schrieb:
> > Are there any instructions on how you run mptests on this BSP?
> I will update the RTEMS testing scripts. You can run two Qemu instances
> connected via a virtual network.  Works pretty good.
> I expected that much from the patches.
It looks like this depends on old networking and multiprocessing being
enabled at the same time.
Is that check through the code/build system?
I have a script (rtems-testing/rtems/bit_all_confs) to vary a number of
build flags and build a
BSP over and over. I can try that on it when it is all committed.
FWIW I ran that on psim and leon3 recently.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160324/5cd4cf62/attachment-0002.html>
