GSOC 2016 Aspirant
    Mudit Jain
    muditjain18011995 at gmail.com
    Fri Mar 25 15:25:48 UTC 2016
PFA patch and a screen shot as a proof of having completed the environment
setup.
I have made an initial draft of the application. Will be updating the
google portal and the site soon.
Thanks
Mudit
On Fri, Mar 25, 2016 at 6:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
> OK, that should be a good set for your proposal. I'm not sure what the
> status is for Pi2 now. It may need some cleanup. Make sure you get
> your final PDF and enrollment submitted today.
> Please keep devel on any emails of non-private nature.
> On Fri, Mar 25, 2016 at 8:33 AM, Mudit Jain <muditjain18011995 at gmail.com>
> wrote:
> > Hi Gedare,
> > I have read the link that you have suggested and it has provided me a
> good
> > insight into the matter.
> > I planned on implementing the support for Pi 2/B
> > In addition to the SD file system support I also plan on adding DMA
> support
> > for I2C and SPI,
> > support for second SPI device and model identification, detection and
> > reporting.
> > Thanks
> > On Fri, Mar 25, 2016 at 5:23 PM, Gedare Bloom <gedare at rtems.org> wrote:
> >> For prior effort on SD card see
> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
> >> There is another student that is planning to add USB/NIC support. You
> >> would be best served to avoid too much overlap, but if you go for a
> >> different RPi model that may not matter. What specific RPi board do
> >> you plan to use?
> >> I would guess SD card is only good for the first half of GSoC, so
> >> you'll need to identify what else you could do. The other periperhals
> >> (GPIO, i2c, SPI) support have been merged by Andre.
> >> On Fri, Mar 25, 2016 at 6:01 AM, Mudit Jain <
> >> wrote:
> >> > Hi everyone,
> >> > I am Mudit Jain, a final year undergraduate student in Electronics and
> >> > Communication Engineering at BITS Pilani Hyderabad Campus.
> >> > I wish to apply for GSOC 2016, with RTEMS as the mentoring
> organization.
> >> > I have gone through your website for details regarding the development
> >> > process and the projects that could be done.
> >> > I am interested in working on the project titled "Low Level
> Peripherals
> >> > and
> >> > SD Card Support for Raspberry PI " [ Project group 1  - Improving
> >> > Raspberry
> >> > PI BSP ] under Alan Cudmore as the mentor.
> >> > Given the limited time I have for the application process, I have
> >> > parallelly
> >> > started to set up the RTEMS environment and also write my proposal for
> >> > the
> >> > project that I am interested in.
> >> > I will be updating this email thread once I have set up the env.
> >> > I understand that I am applying at the last moment, however I request
> >> > you to
> >> > consider my application.
> >> > It would be great if people could suggest any good points that I need
> to
> >> > account for, in my application.
> >> > Thanks
> >> > Cheers
> >> > Mudit Jain
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160325/9e3fa843/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160325/9e3fa843/attachment-0002.bin>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160325/9e3fa843/attachment-0002.png>
