[PATCH] bsp/pc386: Fix --console=/--printk argument parsing.
Wed Mar 30 11:33:13 UTC 2016
What was broken? It worked fine in my testing.
On Mar 29, 2016 11:57 PM, "Chris Johns" <chrisj at rtems.org> wrote:
>  .../lib/libbsp/i386/pc386/console/console_select.c | 62
>  1 file changed, 41 insertions(+), 21 deletions(-)
> diff --git a/c/src/lib/libbsp/i386/pc386/console/console_select.c
> b/c/src/lib/libbsp/i386/pc386/console/console_select.c
> index 3fb31ec..7b40f97 100644
> --- a/c/src/lib/libbsp/i386/pc386/console/console_select.c
> +++ b/c/src/lib/libbsp/i386/pc386/console/console_select.c
> @@ -33,6 +33,8 @@
>    #include <crt.h>
>  #endif
> +#include <bsp/bspimpl.h>
>   * Forward prototype
> @@ -137,14 +139,19 @@ static void parse_com1_com4_enable(void)
> +extern char* bsp_boot_cmdline;
>  static bool parse_printk_or_console(
>    const char                *param,
>    rtems_device_minor_number *minor_out
> -  static const char *opt;
> -  char               working[64] = "";
> -  char              *p;
> +  static const char         *opt;
> +  const char                *option;
> +  const char                *comma;
> +  size_t                     length;
> +  size_t                     index;
> +  rtems_device_minor_number  minor;
>     * Check the command line for the type of mode the console is.
> @@ -155,30 +162,43 @@ static bool parse_printk_or_console(
> -   * bsp_cmdline_arg() returns pointer to a string. It may not be the
> -   * last string on the command line.
> +   * Fine the length, there can be more command line visible.
> -  strncpy( working, opt, sizeof(working) );
> -  p = strchr( working, ' ' );
> -  if ( p ) {
> -    *p = '\0';
> +  length = 0;
> +  while ((opt[length] != ' ') && (opt[length] != '\0')) {
> +    ++length;
> +    if (length > NAME_MAX) {
> +      printk("invalid option (%s): too long\n", param);
> +      return false;
> -  const char                *comma;
> -  size_t                     length = NAME_MAX;
> -  rtems_device_minor_number  minor;
> -  char                      *option = working;
>     * Only match up to a comma or NULL
> -  comma = strchr (option, ',');
> +  index = 0;
> +  while ((opt[index] != '=') && (index < length)) {
> +    ++index;
> +  if (opt[index] != '=') {
> +    printk("invalid option (%s): no equals\n", param);
> +    return false;
> +  ++index;
> +  option = &opt[index];
> -  if ( comma ) {
> -    length = comma - option;
> +  while ((opt[index] != ',') && (index < length)) {
> +    ++index;
> -  option += strnlen(param, 32);
> +  if (opt[index] == ',')
> +    comma = &opt[index];
> +  else
> +    comma = NULL;
> +  length = &opt[index] - option;
>    if ( !bsp_find_console_entry( option, length, &minor ) ) {
>      return false;
> @@ -186,10 +206,10 @@ static bool parse_printk_or_console(
>    *minor_out = minor;
>    if (comma) {
> -    console_tbl *conscfg;
> +    console_tbl *conscfg = &Console_Configuration_Ports[minor];
> +    option = comma + 1;
> -    comma += 1;
> -    conscfg = &Console_Configuration_Ports[minor];
>      if (strncmp (option, "115200", sizeof ("115200") - 1) == 0)
>        conscfg->pDeviceParams = (void *)115200;
>      else if (strncmp (option, "57600", sizeof ("57600") - 1) == 0)
> 2.3.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160330/3a5e50b3/attachment-0002.html>
