[PATCH 3/4] testsuite: Add test for getnameinfo().
Tue May 3 02:05:45 UTC 2016
On 02/05/2016 22:49, Christian Mauderer wrote:
> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>   testsuites/libtests/libnetworking01/Makefile.am    |  22 +++
Should this be testsuites/libtests/networking01/ to follow the naming of
the other tests in libtest, eg block01, dl01 etc?
> diff --git a/testsuites/libtests/libnetworking01/libnetworking01.doc b/testsuites/libtests/libnetworking01/libnetworking01.doc
> new file mode 100644
> index 0000000..1bc87d2
> --- /dev/null
> +++ b/testsuites/libtests/libnetworking01/libnetworking01.doc
May I suggest a note explaining no actual network set up is required for
this test?
Tests needing a real network will be more difficult to detail.
Thanks
