[PATCH 11/11] score: Simplify _Thread_Get_interrupt_disable()
Tue May 3 12:49:47 UTC 2016
Remove the object location parameter.
 cpukit/rtems/include/rtems/rtems/eventmp.h    | 31 ++--------
 cpukit/rtems/src/eventmp.c                    | 89 ++++++++++++++-------------
 cpukit/rtems/src/eventsend.c                  | 43 +++++--------
 cpukit/rtems/src/systemeventsend.c            | 46 ++++++--------
 cpukit/score/include/rtems/score/threadimpl.h |  3 +-
 cpukit/score/src/threadget.c                  |  5 +-
 6 files changed, 87 insertions(+), 130 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/eventmp.h b/cpukit/rtems/include/rtems/rtems/eventmp.h
index fdcdf4d..a80e60c 100644
--- a/cpukit/rtems/include/rtems/rtems/eventmp.h
+++ b/cpukit/rtems/include/rtems/rtems/eventmp.h
@@ -41,25 +41,6 @@ extern "C" {
- *  The following enumerated type defines the list of
- *  remote event operations.
-typedef enum {
-  EVENT_MP_SEND_REQUEST  =  0,
-  EVENT_MP_SEND_RESPONSE =  1
-}   Event_MP_Remote_operations;
- *  The following data structure defines the packet used to perform
-typedef struct {
-  rtems_packet_prefix         Prefix;
-  Event_MP_Remote_operations  operation;
-  rtems_event_set             event_in;
-}   Event_MP_Packet;
  *  @brief Event_MP_Send_process_packet
@@ -71,15 +52,11 @@ typedef struct {
- *  @brief Event MP Send Packet Request
- *  This routine performs a remote procedure call so that a
- *  directive operation can be initiated on another node.
+ * @brief Issues a remote rtems_event_send() request.
-rtems_status_code _Event_MP_Send_request_packet (
-  Event_MP_Remote_operations operation,
-  Objects_Id                 event_id,
+rtems_status_code _Event_MP_Send(
+  rtems_id        id,
+  rtems_event_set event_in
diff --git a/cpukit/rtems/src/eventmp.c b/cpukit/rtems/src/eventmp.c
index 74fe1ff..83e1384 100644
--- a/cpukit/rtems/src/eventmp.c
+++ b/cpukit/rtems/src/eventmp.c
@@ -19,66 +19,67 @@
 #endif
 #include <rtems/rtems/eventimpl.h>
-#include <rtems/score/objectimpl.h>
+#include <rtems/score/threadimpl.h>
+ *  The following enumerated type defines the list of
+ *  remote event operations.
+typedef enum {
+  EVENT_MP_SEND_REQUEST  =  0,
+  EVENT_MP_SEND_RESPONSE =  1
+}   Event_MP_Remote_operations;
+ *  The following data structure defines the packet used to perform
+typedef struct {
+  rtems_packet_prefix         Prefix;
+  Event_MP_Remote_operations  operation;
+  rtems_event_set             event_in;
+}   Event_MP_Packet;
 RTEMS_STATIC_ASSERT(
   sizeof(Event_MP_Packet) <= MP_PACKET_MINIMUM_PACKET_SIZE,
   Event_MP_Packet
-static Event_MP_Packet *_Event_MP_Get_packet( void )
+static Event_MP_Packet *_Event_MP_Get_packet( Objects_Id id )
+  if ( !_Thread_MP_Is_remote( id ) ) {
+    return NULL;
   return (Event_MP_Packet *) _MPCI_Get_packet();
- *  _Event_MP_Send_process_packet
- *  This subprogram is not needed since there are no process
- *  packets to be sent by this manager.
+  rtems_id        id,
   Event_MP_Packet *the_packet;
-  switch ( operation ) {
-    case EVENT_MP_SEND_REQUEST:
-      the_packet                    = _Event_MP_Get_packet();
-      the_packet->Prefix.the_class  = MP_PACKET_EVENT;
-      the_packet->Prefix.length     = sizeof ( Event_MP_Packet );
-      the_packet->Prefix.to_convert = sizeof ( Event_MP_Packet );
-      the_packet->operation         = operation;
-      the_packet->Prefix.id         = event_id;
-      the_packet->event_in          = event_in;
-      return (rtems_status_code)
-        _MPCI_Send_request_packet(
-          _Objects_Get_node( event_id ),
-          &the_packet->Prefix,
-          STATES_READY,
-          RTEMS_TIMEOUT
-      break;
-    case EVENT_MP_SEND_RESPONSE:
-      break;
+  the_packet = _Event_MP_Get_packet( id );
+  if ( the_packet == NULL ) {
+    return RTEMS_INVALID_ID;
-   *  The following line is included to satisfy compilers which
-   *  produce warnings when a function does not end with a return.
-  return RTEMS_SUCCESSFUL;
+  the_packet->Prefix.the_class  = MP_PACKET_EVENT;
+  the_packet->Prefix.length     = sizeof ( *the_packet );
+  the_packet->Prefix.to_convert = sizeof ( *the_packet );
+  the_packet->operation         = EVENT_MP_SEND_REQUEST;
+  the_packet->Prefix.id         = id;
+  the_packet->event_in          = event_in;
+  return (rtems_status_code) _MPCI_Send_request_packet(
+    _Objects_Get_node( id ),
+    &the_packet->Prefix,
+    STATES_READY,
+    RTEMS_TIMEOUT
 static void _Event_MP_Send_response_packet (
diff --git a/cpukit/rtems/src/eventsend.c b/cpukit/rtems/src/eventsend.c
index a6476a2..087ebb8 100644
--- a/cpukit/rtems/src/eventsend.c
+++ b/cpukit/rtems/src/eventsend.c
@@ -27,37 +27,26 @@ rtems_status_code rtems_event_send(
-  rtems_status_code  sc;
-  Thread_Control    *thread;
-  Objects_Locations  location;
+  Thread_Control    *the_thread;
   RTEMS_API_Control *api;
   ISR_lock_Context   lock_context;
-  thread = _Thread_Get_interrupt_disable( id, &location, &lock_context );
-  switch ( location ) {
-    case OBJECTS_LOCAL:
-      api = thread->API_Extensions[ THREAD_API_RTEMS ];
-      sc = _Event_Surrender(
-        thread,
-        event_in,
-        &api->Event,
-        THREAD_WAIT_CLASS_EVENT,
-        &lock_context
-      break;
-#ifdef RTEMS_MULTIPROCESSING
-    case OBJECTS_REMOTE:
-      sc = _Event_MP_Send_request_packet(
-        EVENT_MP_SEND_REQUEST,
-        id,
-        event_in
-      break;
+  the_thread = _Thread_Get_interrupt_disable( id, &lock_context );
+  if ( the_thread == NULL ) {
+#if defined(RTEMS_MULTIPROCESSING)
+    return _Event_MP_Send( id, event_in );
+#else
 #endif
-    default:
-      sc = RTEMS_INVALID_ID;
-      break;
-  return sc;
+  api = the_thread->API_Extensions[ THREAD_API_RTEMS ];
+  return _Event_Surrender(
+    the_thread,
+    event_in,
+    &api->Event,
+    THREAD_WAIT_CLASS_EVENT,
+    &lock_context
diff --git a/cpukit/rtems/src/systemeventsend.c b/cpukit/rtems/src/systemeventsend.c
index 5b2116c..97bcabd 100644
--- a/cpukit/rtems/src/systemeventsend.c
+++ b/cpukit/rtems/src/systemeventsend.c
@@ -7,10 +7,10 @@
- * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2012, 2016 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
- *  Obere Lagerstr. 30
+ *  Dornierstr. 4
  *  82178 Puchheim
  *  Germany
  *  <rtems at embedded-brains.de>
@@ -33,34 +33,28 @@ rtems_status_code rtems_event_system_send(
-        thread,
-        event_in,
-        &api->System_event,
-        THREAD_WAIT_CLASS_SYSTEM_EVENT,
-        &lock_context
-      break;
-      _Thread_Dispatch();
-      sc = RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
-      break;
+    if ( _Thread_MP_Is_remote( id ) ) {
+      return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
 #endif
-    default:
-      break;
-  return sc;
+    the_thread,
+    event_in,
+    &api->System_event,
+    THREAD_WAIT_CLASS_SYSTEM_EVENT,
+    &lock_context
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 1fea4da6c..1d0421f 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -532,11 +532,10 @@ Thread_Control *_Thread_Get (
  * @brief Gets a thread by its identifier.
- * @see _Objects_Get_isr_disable().
+ * @see _Objects_Get_local().
 Thread_Control *_Thread_Get_interrupt_disable(
   Objects_Id         id,
-  Objects_Locations *location,
   ISR_lock_Context  *lock_context
diff --git a/cpukit/score/src/threadget.c b/cpukit/score/src/threadget.c
index 7e3963d..c650499 100644
--- a/cpukit/score/src/threadget.c
+++ b/cpukit/score/src/threadget.c
@@ -45,24 +45,21 @@ Thread_Control *_Thread_Get(
   Objects_Id         id,
   Objects_Information *information;
   if ( _Objects_Are_ids_equal( id, OBJECTS_ID_OF_SELF ) ) {
-    *location = OBJECTS_LOCAL;
     _ISR_lock_ISR_disable( lock_context );
     return _Thread_Executing;
   information = _Thread_Get_objects_information( id );
   if ( information == NULL ) {
-    *location = OBJECTS_ERROR;
     return NULL;
   return (Thread_Control *)
-    _Objects_Get_isr_disable( information, id, location, lock_context );
+    _Objects_Get_local( id, lock_context, information );
1.8.4.5
