[PATCH 08/11] score: Simplify _Thread_Get_objects_information()
Tue May 3 12:49:44 UTC 2016
 cpukit/score/src/threadget.c | 17 +++++++++--------
 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/cpukit/score/src/threadget.c b/cpukit/score/src/threadget.c
index 8731ab5..24773fa 100644
--- a/cpukit/score/src/threadget.c
+++ b/cpukit/score/src/threadget.c
@@ -25,20 +25,21 @@ static Objects_Information *_Thread_Get_objects_information(
   Objects_Id id
-  uint32_t             the_api;
-  uint32_t             the_class;
+  uint32_t the_api;
   the_api = _Objects_Get_API( id );
-  if ( !_Objects_Is_api_valid( the_api ) ) {
-    return NULL;
-  the_class = _Objects_Get_class( id );
-  if ( the_class != 1 ) {       /* threads are always first class :) */
+  if ( !_Objects_Is_api_valid( the_api ) ) {
     return NULL;
-  return _Objects_Information_table[ the_api ][ the_class ];
+   * Threads are always first class :)
+   * There is no need to validate the object class of the object identifier,
+   * since this will be done by the object get methods.
+  return _Objects_Information_table[ the_api ][ 1 ];
 Thread_Control *_Thread_Get(
1.8.4.5
