[rtems-libbsd commit] Add nexus devices for default-init.
Wed May 4 10:02:01 UTC 2016
The <rtems/bsd/test/default-init.h> was intended for tests that are
device independent. For which purpose did you add it?
On 04/05/16 08:03, Chris Johns wrote:
> Module:    rtems-libbsd
> Branch:    master
> Commit:    f3f816cc7605b6e7b1491d99ef317ebd28d97b88
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=f3f816cc7605b6e7b1491d99ef317ebd28d97b88
> Author:    Chris Johns <chrisj at rtems.org>
> Date:      Thu Apr 28 13:34:11 2016 +1000
>   testsuite/include/rtems/bsd/test/default-init.h | 2 ++
>   1 file changed, 2 insertions(+)
> diff --git a/testsuite/include/rtems/bsd/test/default-init.h b/testsuite/include/rtems/bsd/test/default-init.h
> index f38ca5d..73a1d6f 100644
> --- a/testsuite/include/rtems/bsd/test/default-init.h
> +++ b/testsuite/include/rtems/bsd/test/default-init.h
> @@ -73,6 +73,8 @@ SYSINIT_NEED_NET_PF_UNIX;
>   SYSINIT_NEED_NET_IF_LAGG;
>   SYSINIT_NEED_NET_IF_VLAN;
> +#include <bsp/nexus-devices.h>
>   #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>   #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>   #define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
