[rtems-libbsd commit] Add nexus devices for default-init.
Wed May 4 10:53:31 UTC 2016
On 4/05/2016 8:02 PM, Sebastian Huber wrote:
> The <rtems/bsd/test/default-init.h> was intended for tests that are
> device independent. For which purpose did you add it?
I do not understand what you mean by device independent and so what
commands you can run. For example ifconfig does nothing because there
are no devices.
The patch can be reverted if it is wrong.
