Updates and Issues
Fri May 6 11:55:15 UTC 2016
Should be fixed already.
On 06/05/16 12:11, Mudit Jain wrote:
> Hi everyone,
> GSOC Updates :
> As per Gedare's mail I have set up the blog, calendar, wiki and have
> forked the rtems-libbsd on github. I had set-up rtems for rpi
> following alan's blog and now have built rtems libbsd for rpi. My
> first blog post is regarding the same- Blog
> <http://rtemsgsoc2016-mudit.blogspot.in/>.
> Issues faced :
> Before building it for raspberry pi, I tried to build the latest
> master [ libbsd ] for arm/realview_pbx_a9_qemu however this failed
> with the following error message
> [802/849] Compiling testsuite/ping01/test_main.c
> ../../testsuite/ping01/test_main.c:40:43: fatal error:
> rtems/bsd/test/network-config.h: No such file or directory
>  #include <rtems/bsd/test/network-config.h>              ^
> compilation terminated.
> I guess this is due to the recent change by chris. I did check out the
> previous commit and it worked fine for that.
> Thanks
> Mudit
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
