Advice Wanted on sonic.c Indentation Warning
Martin Galvan martin.galvan at tallertechnologies.com
Fri May 6 20:15:54 UTC 2016
Thanks. Here's what I committed:
https://git.rtems.org/rtems/commit/?id=b4d7d5d52e6459ed4fe490ca272fb6cb83e512aa
However, I got an error when I did the push. Here's the output:
$ git push
Counting objects: 7, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (7/7), done.
Writing objects: 100% (7/7), 910 bytes | 0 bytes/s, done.
Total 7 (delta 6), reused 0 (delta 0)
remote: 1: mail vc at rtems.org
remote: 2: update github
remote: 3: update trac
remote: 4: IRC
remote: 5: Buildbot
remote: git_buildbot: ERROR: Could not connect to
buildbot.int.rtems.org:9899: Connection was refused by other side: 61:
Connection refused.
To ssh://marting@dispatch.rtems.org/data/git/rtems.git
   f65f803..b4d7d5d  master -> master
I don't remember seeing that when I added myself to MAINTAINERS. Has
this happened to anybody else?
