[PATCH 2/8] bsp/shared: Print the exception stack frame before the shut down message.
Fri May 6 22:23:46 UTC 2016
This lets you see the exception otherwise the key press clears the screen
on the reboot on a PC BSP.
Also state there has been a fatal error.
 c/src/lib/libbsp/shared/bspclean.c | 14 +++++++-------
 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/c/src/lib/libbsp/shared/bspclean.c b/c/src/lib/libbsp/shared/bspclean.c
index 2262c9d..4265f11 100644
--- a/c/src/lib/libbsp/shared/bspclean.c
+++ b/c/src/lib/libbsp/shared/bspclean.c
@@ -17,8 +17,14 @@ void bsp_fatal_extension(
   rtems_fatal_code code
+  #if (BSP_PRINT_EXCEPTION_CONTEXT)
+    if ( source == RTEMS_FATAL_SOURCE_EXCEPTION ) {
+      rtems_exception_frame_print( (const rtems_exception_frame *) code );
+  #endif
   #if (BSP_PRESS_KEY_FOR_RESET)
-    printk( "\nEXECUTIVE SHUTDOWN! Any key to reboot..." );
+    printk( "\nFATAL ERROR - Executive shutdown! Any key to reboot..." );
      * Wait for a key to be pressed
@@ -29,12 +35,6 @@ void bsp_fatal_extension(
     printk("\n");
   #endif
-  #if (BSP_PRINT_EXCEPTION_CONTEXT)
-    if ( source == RTEMS_FATAL_SOURCE_EXCEPTION ) {
-      rtems_exception_frame_print( (const rtems_exception_frame *) code );
-  #endif
    *  Check both conditions -- if you want to ask for reboot, then
    *  you must have meant to reset the board.
2.4.6
