Multiple Failures on GCC Master
Tue May 10 15:05:55 UTC 2016
Should be fixed already.
----- Joel Sherrill <joel at rtems.org> schrieb:
> Hi
> With a newlib snapshot approaching, I thought I would build tools off the
> master for binutils, gdb, gcc, and newlib.  Some failures:
> It looks like most targets fail looking for lock.c. This is from
> sparc-rtems4.12
> but there are others.
> make[4]: Entering directory
> `/data/home/joel/test-gcc/b-sparc-rtems4.12-gcc/sparc-rtems4.12/libatomic'
> make[4]: *** No rule to make target `lock.c', needed by `lock.lo'.  Stop.
> make[4]: Leaving directory
> Looks like a tiny bit is missing on the gcc master.
> --joel
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
