Require help with running Xilinx Zynq Qemu BSP
    vivek kukreja
    vivekkukreja5 at gmail.com
    Wed May 11 08:02:51 UTC 2016
Hello Chris,
I am preparing for the next phase of my project where I will implement live-tracing over transport. For that drivers for USB and Ethernet have to be loaded in qemu. How will that work?
Regards,
Vivek
> On 11-May-2016, at 05:30, Chris Johns <chrisj at rtems.org> wrote:
>> On 11/05/2016 02:57, vivek kukreja wrote:
>> Hello,
>> Sorry for not framing the question properly.
>> I know how to run an application on the baremetal, with the command you
>> have mentioned. But I want to know how to run a complete RTEMS boot
>> image, along with OS components on the emulator.
>> In the document that I have given a link above, the steps for running a
>> boot image for i386 have been mentioned.
> Those instructions are for a PC and assume PC type hardware.
>> Is the similar possible for the Xilinx Zynq too?
> With the Zynq all you need to pass to qemu is the kernel image.
> What are wanting to do with the qemu and the Zynq BSP?
> Chris
