[PATCH 4/4] score: Adjust thread queue layout
Wed May 11 13:19:58 UTC 2016
Adjust thread queue layout according to Newlib.  This makes it possible
to use the same implementation for <sys/lock.h> and CORE mutexes in the
future.
 cpukit/score/include/rtems/score/threadq.h     | 37 +++++++++++++++---------
 cpukit/score/include/rtems/score/threadqimpl.h |  4 +--
 cpukit/score/src/mutex.c                       | 39 +++++++++++---------------
 cpukit/score/src/threadq.c                     | 18 ++++++++----
 4 files changed, 54 insertions(+), 44 deletions(-)
diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
index fb20148..4fddb25 100644
--- a/cpukit/score/include/rtems/score/threadq.h
+++ b/cpukit/score/include/rtems/score/threadq.h
@@ -143,26 +143,31 @@ typedef struct _Thread_queue_Heads {
 typedef struct {
-   * @brief The thread queue heads.
-   * This pointer is NULL, if and only if no threads are enqueued.  The first
-   * thread to enqueue will give its spare thread queue heads to this thread
-   * queue.
-  Thread_queue_Heads *heads;
    * @brief Lock to protect this thread queue.
    * It may be used to protect additional state of the object embedding this
    * thread queue.
+   * Must be the first component of this structure to be able to re-use
+   * implementation parts for structures defined by Newlib <sys/lock.h>.
    * @see _Thread_queue_Acquire(), _Thread_queue_Acquire_critical() and
    * _Thread_queue_Release().
 #if defined(RTEMS_SMP)
   SMP_ticket_lock_Control Lock;
 #endif
+   * @brief The thread queue heads.
+   * This pointer is NULL, if and only if no threads are enqueued.  The first
+   * thread to enqueue will give its spare thread queue heads to this thread
+   * queue.
+  Thread_queue_Heads *heads;
+  Thread_Control *owner;
 } Thread_queue_Queue;
@@ -264,14 +269,20 @@ typedef struct {
  *  waiting to acquire a resource.
 typedef struct {
+#if defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
-   * @brief The actual thread queue.
+   * @brief SMP lock statistics in case SMP and profiling are enabled.
-  Thread_queue_Queue Queue;
-#if defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
   SMP_lock_Stats Lock_stats;
 #endif
+   * @brief The actual thread queue.
+  Thread_queue_Queue Queue;
 } Thread_queue_Control;
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index a31b4c3..0247842 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -39,8 +39,6 @@ extern "C" {
  * defined in Newlib <sys/lock.h>.
 typedef struct {
 #if !defined(RTEMS_SMP)
    * The struct _Thread_queue_Queue definition is independent of the RTEMS
@@ -50,6 +48,8 @@ typedef struct {
   unsigned int reserved[2];
 #endif
 } Thread_queue_Syslock_queue;
 RTEMS_INLINE_ROUTINE void _Thread_queue_Heads_initialize(
diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
index 5588926..28b20b7 100644
--- a/cpukit/score/src/mutex.c
+++ b/cpukit/score/src/mutex.c
@@ -30,7 +30,6 @@
 typedef struct {
   Thread_queue_Syslock_queue Queue;
-  Thread_Control *owner;
 } Mutex_Control;
 RTEMS_STATIC_ASSERT(
@@ -40,12 +39,6 @@ RTEMS_STATIC_ASSERT(
-  offsetof( Mutex_Control, owner )
-    == offsetof( struct _Mutex_Control, _owner ),
-  MUTEX_CONTROL_OWNER
-RTEMS_STATIC_ASSERT(
   sizeof( Mutex_Control ) == sizeof( struct _Mutex_Control ),
   MUTEX_CONTROL_SIZE
@@ -140,7 +133,7 @@ static void _Mutex_Release_slow(
     operations = MUTEX_TQ_OPERATIONS;
     first = ( *operations->first )( heads );
-    mutex->owner = first;
+    mutex->Queue.Queue.owner = first;
     ++first->resource_count;
     unblock = _Thread_queue_Extract_locked(
       &mutex->Queue.Queue,
@@ -180,7 +173,7 @@ static void _Mutex_Release_critical(
   bool keep_priority;
-  mutex->owner = NULL;
+  mutex->Queue.Queue.owner = NULL;
   --executing->resource_count;
@@ -218,10 +211,10 @@ void _Mutex_Acquire( struct _Mutex_Control *_mutex )
   mutex = _Mutex_Get( _mutex );
   executing = _Mutex_Queue_acquire( mutex, &lock_context );
-  owner = mutex->owner;
+  owner = mutex->Queue.Queue.owner;
   if ( __predict_true( owner == NULL ) ) {
-    mutex->owner = executing;
+    mutex->Queue.Queue.owner = executing;
     ++executing->resource_count;
     _Mutex_Queue_release( mutex, &lock_context );
   } else {
@@ -242,10 +235,10 @@ int _Mutex_Acquire_timed(
@@ -283,10 +276,10 @@ int _Mutex_Try_acquire( struct _Mutex_Control *_mutex )
     eno = 0;
   } else {
@@ -307,7 +300,7 @@ void _Mutex_Release( struct _Mutex_Control *_mutex )
-  _Assert( mutex->owner == executing );
+  _Assert( mutex->Queue.Queue.owner == executing );
   _Mutex_Release_critical( mutex, executing, &lock_context );
@@ -329,10 +322,10 @@ void _Mutex_recursive_Acquire( struct _Mutex_recursive_Control *_mutex )
   mutex = _Mutex_recursive_Get( _mutex );
   executing = _Mutex_Queue_acquire( &mutex->Mutex, &lock_context );
-  owner = mutex->Mutex.owner;
+  owner = mutex->Mutex.Queue.Queue.owner;
-    mutex->Mutex.owner = executing;
+    mutex->Mutex.Queue.Queue.owner = executing;
     _Mutex_Queue_release( &mutex->Mutex, &lock_context );
   } else if ( owner == executing ) {
@@ -356,10 +349,10 @@ int _Mutex_recursive_Acquire_timed(
@@ -408,10 +401,10 @@ int _Mutex_recursive_Try_acquire( struct _Mutex_recursive_Control *_mutex )
     eno = 0;
@@ -436,7 +429,7 @@ void _Mutex_recursive_Release( struct _Mutex_recursive_Control *_mutex )
-  _Assert( mutex->Mutex.owner == executing );
+  _Assert( mutex->Mutex.Queue.Queue.owner == executing );
   nest_level = mutex->nest_level;
diff --git a/cpukit/score/src/threadq.c b/cpukit/score/src/threadq.c
index b3ccbd6..fdb2bee 100644
--- a/cpukit/score/src/threadq.c
+++ b/cpukit/score/src/threadq.c
@@ -25,12 +25,6 @@
 #if HAVE_STRUCT__THREAD_QUEUE_QUEUE
-  offsetof( Thread_queue_Syslock_queue, Queue.heads )
-    == offsetof( struct _Thread_queue_Queue, _heads ),
-  THREAD_QUEUE_SYSLOCK_QUEUE_HEADS
   offsetof( Thread_queue_Syslock_queue, Queue.Lock.next_ticket )
 #else
@@ -51,6 +45,18 @@ RTEMS_STATIC_ASSERT(
+  offsetof( Thread_queue_Syslock_queue, Queue.heads )
+    == offsetof( struct _Thread_queue_Queue, _heads ),
+  THREAD_QUEUE_SYSLOCK_QUEUE_HEADS
+RTEMS_STATIC_ASSERT(
+  offsetof( Thread_queue_Syslock_queue, Queue.owner )
+    == offsetof( struct _Thread_queue_Queue, _owner ),
+  THREAD_QUEUE_SYSLOCK_QUEUE_OWNER
   sizeof( Thread_queue_Syslock_queue )
     == sizeof( struct _Thread_queue_Queue ),
   THREAD_QUEUE_SYSLOCK_QUEUE_SIZE
1.8.4.5
