[PATCH 14/14] score: Avoid Giant lock for scheduler set/get
Wed May 11 13:23:41 UTC 2016
Update #2555.
 cpukit/rtems/src/taskgetscheduler.c              | 52 +++++++++++-------------
 cpukit/rtems/src/tasksetscheduler.c              | 50 +++++++++++++----------
 cpukit/score/include/rtems/score/schedulerimpl.h | 42 ++++++++++++++-----
 cpukit/score/include/rtems/score/threadimpl.h    |  8 ++++
 cpukit/score/include/rtems/score/threadqimpl.h   | 26 ++++++++++--
 5 files changed, 113 insertions(+), 65 deletions(-)
diff --git a/cpukit/rtems/src/taskgetscheduler.c b/cpukit/rtems/src/taskgetscheduler.c
index 47895a4..9d8bbb6 100644
--- a/cpukit/rtems/src/taskgetscheduler.c
+++ b/cpukit/rtems/src/taskgetscheduler.c
@@ -24,37 +24,31 @@ rtems_status_code rtems_task_get_scheduler(
   rtems_id *scheduler_id
-  rtems_status_code sc;
-  if ( scheduler_id != NULL ) {
-    Thread_Control          *the_thread;
-    Objects_Locations        location;
-    const Scheduler_Control *scheduler;
-    the_thread = _Thread_Get( task_id, &location );
-    switch ( location ) {
-      case OBJECTS_LOCAL:
-        scheduler = _Scheduler_Get( the_thread );
-        *scheduler_id = _Scheduler_Build_id(
-          _Scheduler_Get_index( scheduler )
-        _Objects_Put( &the_thread->Object );
-        sc = RTEMS_SUCCESSFUL;
-        break;
+  Thread_Control          *the_thread;
+  ISR_lock_Context         lock_context;
+  const Scheduler_Control *scheduler;
+  if ( scheduler_id == NULL ) {
+    return RTEMS_INVALID_ADDRESS;
+  the_thread = _Thread_Get_interrupt_disable( task_id, &lock_context );
+  if ( the_thread == NULL ) {
 #if defined(RTEMS_MULTIPROCESSING)
-      case OBJECTS_REMOTE:
-        _Thread_Dispatch();
-        sc = RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
-        break;
-#endif
-      default:
-        sc = RTEMS_INVALID_ID;
-        break;
+    if ( _Thread_MP_Is_remote( task_id ) ) {
+      return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
-  } else {
-    sc = RTEMS_INVALID_ADDRESS;
+#endif
+    return RTEMS_INVALID_ID;
-  return sc;
+  _Thread_State_acquire_critical( the_thread, &lock_context );
+  scheduler = _Scheduler_Get( the_thread );
+  *scheduler_id = _Scheduler_Build_id( _Scheduler_Get_index( scheduler ) );
+  _Thread_State_release( the_thread, &lock_context );
+  return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/tasksetscheduler.c b/cpukit/rtems/src/tasksetscheduler.c
index e055530..428ef3d 100644
--- a/cpukit/rtems/src/tasksetscheduler.c
+++ b/cpukit/rtems/src/tasksetscheduler.c
@@ -24,34 +24,40 @@ rtems_status_code rtems_task_set_scheduler(
   rtems_id scheduler_id
+  ISR_lock_Context         state_lock_context;
+  Per_CPU_Control         *cpu_self;
+  void                    *lock;
+  bool                     ok;
-  if ( _Scheduler_Get_by_id( scheduler_id, &scheduler ) ) {
+  if ( !_Scheduler_Get_by_id( scheduler_id, &scheduler ) ) {
-        _Scheduler_Set( scheduler, the_thread );
-        break;
-        break;
-#endif
-      default:
-        break;
-  } else {
+#endif
-  return sc;
+  cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
+  _ISR_lock_ISR_enable( &lock_context );
+  lock = _Thread_Lock_acquire( the_thread, &lock_context );
+  _Thread_State_acquire_critical( the_thread, &state_lock_context );
+  ok = _Scheduler_Set( scheduler, the_thread );
+  _Thread_State_release_critical( the_thread, &state_lock_context );
+  _Thread_Lock_release( lock, &lock_context );
+  _Thread_Dispatch_enable( cpu_self );
+  return ok ? RTEMS_SUCCESSFUL : RTEMS_INCORRECT_STATE;
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index c149a9e..2e5b025 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -599,25 +599,45 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_Has_processor_ownership(
 #endif
-RTEMS_INLINE_ROUTINE void _Scheduler_Set(
+RTEMS_INLINE_ROUTINE bool _Scheduler_Set(
   const Scheduler_Control *scheduler,
 #if defined(RTEMS_SMP)
-  const Scheduler_Control *current_scheduler = _Scheduler_Get( the_thread );
-  if ( current_scheduler != scheduler ) {
-    _Thread_Set_state( the_thread, STATES_MIGRATING );
-    _Scheduler_Node_destroy( current_scheduler, the_thread );
-    the_thread->Scheduler.own_control = scheduler;
-    the_thread->Scheduler.control = scheduler;
-    _Scheduler_Node_initialize( scheduler, the_thread );
-    _Scheduler_Update_priority( the_thread, the_thread->current_priority );
-    _Thread_Clear_state( the_thread, STATES_MIGRATING );
+  const Scheduler_Control *current_scheduler;
+  States_Control           current_state;
+  current_scheduler = _Scheduler_Get( the_thread );
+  if ( current_scheduler == scheduler ) {
+    return true;
+  if ( _Thread_Owns_resources( the_thread ) ) {
+    return false;
+  current_state = the_thread->current_state;
+  if ( _States_Is_ready( current_state ) ) {
+    _Scheduler_Block( the_thread );
+  _Scheduler_Node_destroy( current_scheduler, the_thread );
+  the_thread->Scheduler.own_control = scheduler;
+  the_thread->Scheduler.control = scheduler;
+  _Scheduler_Node_initialize( scheduler, the_thread );
+  _Scheduler_Update_priority( the_thread, the_thread->current_priority );
+    _Scheduler_Unblock( the_thread );
+  return true;
 #else
   (void) scheduler;
+  return true;
 #endif
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 931eec0..1ea49dd 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -359,6 +359,14 @@ RTEMS_INLINE_ROUTINE Thread_Control *_Thread_State_acquire_for_executing(
   return executing;
+RTEMS_INLINE_ROUTINE void _Thread_State_release_critical(
+  Thread_Control   *the_thread,
+  ISR_lock_Context *lock_context
+  _Thread_queue_Release_critical( &the_thread->Join_queue, lock_context );
 RTEMS_INLINE_ROUTINE void _Thread_State_release(
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index e6cd401..ec222bd 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -108,7 +108,7 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_do_acquire_critical(
     _Thread_queue_Queue_do_acquire_critical( queue, lock_context )
 #endif
-RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release(
+RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release_critical(
   Thread_queue_Queue *queue,
@@ -118,7 +118,18 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release(
     &queue->Lock,
     &lock_context->Lock_context.Stats_context
+#else
+  (void) queue;
+  (void) lock_context;
 #endif
+RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release(
+  Thread_queue_Queue *queue,
+  _Thread_queue_Queue_release_critical( queue, lock_context );
   _ISR_lock_ISR_enable( lock_context );
@@ -159,7 +170,7 @@ RTEMS_INLINE_ROUTINE bool _Thread_queue_Is_lock_owner(
 #endif
-RTEMS_INLINE_ROUTINE void _Thread_queue_Release(
+RTEMS_INLINE_ROUTINE void _Thread_queue_Release_critical(
   Thread_queue_Control *the_thread_queue,
@@ -170,12 +181,21 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Release(
   the_thread_queue->owner = SMP_LOCK_NO_OWNER;
 #endif
 #endif
-  _Thread_queue_Queue_release(
     &the_thread_queue->Queue,
     lock_context
+RTEMS_INLINE_ROUTINE void _Thread_queue_Release(
+  Thread_queue_Control *the_thread_queue,
+  _Thread_queue_Release_critical( the_thread_queue, lock_context );
+  _ISR_lock_ISR_enable( lock_context );
 Thread_Control *_Thread_queue_Do_dequeue(
   const Thread_queue_Operations *operations
1.8.4.5
