[PATCH] arm/raspberrypi: ensure that RTEMS application image can be started by U-boot.
Pavel Pisa ppisa4lists at pikron.com
Wed May 18 00:15:34 UTC 2016
The current versions of U-boot start kernel/RTEMS application image
with instruction and data caches enabled and it sets exception
base register to new address after its self-relocation.
        ldr     r0, [r9, #GD_RELOCADDR] /* r0 = gd->relocaddr */
        mcr     p15, 0, r0, c12, c0, 0  /* Set VBAR */
Included changes in bsp_start_hook_0 restore default state to
allow RTEMS image to run after startup from newer U-boot version
on Raspberry Pi.
Signed-off-by: Pavel Pisa <ppisa at pikron.com>
 .../libbsp/arm/raspberrypi/startup/bspstarthooks.c | 48 +++++++++++++++++++++-
 1 file changed, 47 insertions(+), 1 deletion(-)
 If there is no objection I commit the patch to mainline and it should be
 considered for 4.11 as well. Generalization and use for all ARMv6+ targets
 should be considered in the future as well. But to not block RPi
 related GSoC projects I suggest to not start with generalization
 at this moment because this problem is a blocker to development
 without instant SD card manipulation.
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
index 047c8ad..fbd13be 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
@@ -26,11 +26,57 @@
 #include <bsp/start.h>
 #include <bsp/raspberrypi.h>
 #include <bsp/mm.h>
+#include <libcpu/arm-cp15.h>
 void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
+  uint32_t sctlr_val;
+  char s[32];
+  sctlr_val = arm_cp15_get_control();
+   * Current U-boot loader seems to start kernel image
+   * with I and D caches on and MMU enabled.
+   * If RTEMS application image finds that cache is on
+   * during startup then disable caches.
+  if (sctlr_val & (ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M)) {
+    if (sctlr_val & (ARM_CP15_CTRL_C | ARM_CP15_CTRL_M)) {
+       * If the data cache is on then ensure that it is clean
+       * before switching off to be extra carefull.
+      /* Flush Prefetch Buffer */
+      asm volatile ("mcr p15, 0, %0, c7, c5,  4" :: "r" (0) : "memory");
+      /* Clean Entire Data Cache */
+      asm volatile ("mcr p15, 0, %0, c7, c10,  0" :: "r" (0) : "memory");
+    sctlr_val &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M | ARM_CP15_CTRL_A);
+    arm_cp15_set_control(sctlr_val);
+    arm_cp15_tlb_invalidate();
+    /* Invalidate Entire Data Cache */
+    asm volatile ("mcr p15, 0, %0, c7, c6,  0" :: "r" (0) : "memory");
+    /* Invalidate Entire Instruction Cache */
+    asm volatile ("mcr p15, 0, %0, c7, c5,  0" :: "r" (0) : "memory");
+  /* Clear Translation Table Base Control Register */
+  asm volatile ("mcr p15, 0, %0, c2, c0,  2" :: "r" (0) : "memory");
+  /* Clear Secure or Non-secure Vector Base Address Register */
+  asm volatile ("mcr p15, 0, %0, c12, c0, 0" :: "r" (0) : "memory");
+  /* Clear Monitor Vector Base Address Register */
+  asm volatile ("mcr p15, 0, %0, c12, c0, 1" :: "r" (0) : "memory");
 void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
1.9.1
