[PATCH 14/32] score: Rework _Thread_Restart_other()
Wed May 18 09:20:33 UTC 2016
Rework _Thread_Restart_other() to use _Thread_Change_life_locked().
Cope with concurrent change requests by means of a pending request
counter.
Update #2555.
Update #2626.
 cpukit/libmisc/monitor/mon-prmisc.c           |  2 +-
 cpukit/score/include/rtems/score/statesimpl.h |  4 +-
 cpukit/score/include/rtems/score/thread.h     |  5 ++
 cpukit/score/src/threadrestart.c              | 88 ++++++++++++++++++++++++---
 4 files changed, 87 insertions(+), 12 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-prmisc.c b/cpukit/libmisc/monitor/mon-prmisc.c
index 4c7ee9d..a49b084 100644
--- a/cpukit/libmisc/monitor/mon-prmisc.c
+++ b/cpukit/libmisc/monitor/mon-prmisc.c
@@ -116,7 +116,7 @@ rtems_monitor_dump_priority(rtems_task_priority priority)
 static const rtems_assoc_t rtems_monitor_state_assoc[] = {
     { "DELAY",  STATES_DELAYING, 0 },
     { "DORM",   STATES_DORMANT, 0 },
-    { "RESTA",  STATES_RESTARTING, 0 },
+    { "LIFE",   STATES_LIFE_IS_CHANGING, 0 },
     { "SUSP",   STATES_SUSPENDED, 0 },
     { "Wbar",   STATES_WAITING_FOR_BARRIER, 0 },
     { "Wbuf",   STATES_WAITING_FOR_BUFFER, 0 },
diff --git a/cpukit/score/include/rtems/score/statesimpl.h b/cpukit/score/include/rtems/score/statesimpl.h
index 8aebba0..a560329 100644
--- a/cpukit/score/include/rtems/score/statesimpl.h
+++ b/cpukit/score/include/rtems/score/statesimpl.h
@@ -78,8 +78,8 @@ extern "C" {
 #define STATES_WAITING_FOR_BSD_WAKEUP          0x80000
 /** This macro corresponds to a task being a zombie. */
 #define STATES_ZOMBIE                          0x200000
-/** This macro corresponds to a task restarting. */
-#define STATES_RESTARTING                      0x800000
+/** This macro corresponds to a task those life is changing. */
+#define STATES_LIFE_IS_CHANGING                0x800000
 /** This macro corresponds to a task waiting for a join. */
 #define STATES_WAITING_FOR_JOIN                0x1000000
 /** This macro corresponds to a task waiting for a <sys/lock.h> mutex. */
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 5103b58..ac68e0f 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -540,6 +540,11 @@ typedef struct {
    * @brief The current thread life state.
   Thread_Life_state  state;
+   * @brief The count of pending life change requests.
+  uint32_t pending_life_change_requests;
 } Thread_Life_control;
 #if defined(RTEMS_SMP)
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 1ebefa7..a20202e 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -350,7 +350,7 @@ static void _Thread_Start_life_change(
   the_thread->budget_algorithm = the_thread->Start.budget_algorithm;
   the_thread->budget_callout   = the_thread->Start.budget_callout;
-  _Thread_Set_state( the_thread, STATES_RESTARTING );
+  _Thread_Set_state( the_thread, STATES_LIFE_IS_CHANGING );
   _Thread_queue_Extract_with_proxy( the_thread );
   _Thread_Timer_remove( the_thread );
   _Thread_Raise_real_priority( the_thread, priority );
@@ -389,6 +389,64 @@ static void _Thread_Request_life_change(
+static void _Thread_Add_life_change_request( Thread_Control *the_thread )
+  uint32_t pending_requests;
+  _Assert( _Thread_State_is_owner( the_thread ) );
+  pending_requests = the_thread->Life.pending_life_change_requests;
+  the_thread->Life.pending_life_change_requests = pending_requests + 1;
+  if ( pending_requests == 0 ) {
+    _Thread_Set_state_locked( the_thread, STATES_LIFE_IS_CHANGING );
+static void _Thread_Remove_life_change_request( Thread_Control *the_thread )
+  ISR_lock_Context lock_context;
+  _Thread_State_acquire( the_thread, &lock_context );
+  the_thread->Life.pending_life_change_requests = pending_requests - 1;
+  if ( pending_requests == 1 ) {
+     * Do not remove states used for thread queues to avoid race conditions on
+     * SMP configurations.  We could interrupt an extract operation on another
+     * processor disregarding the thread wait flags.  Rely on
+     * _Thread_queue_Extract_with_proxy() for removal of these states.
+    _Thread_Clear_state_locked(
+      the_thread,
+      STATES_LIFE_IS_CHANGING | STATES_SUSPENDED
+        | ( STATES_BLOCKED & ~STATES_LOCALLY_BLOCKED )
+  _Thread_State_release( the_thread, &lock_context );
+static void _Thread_Finalize_life_change(
+  Thread_Control   *the_thread,
+  Priority_Control  priority
+  _Thread_queue_Extract_with_proxy( the_thread );
+  _Thread_Timer_remove( the_thread );
+  _Thread_Change_priority(
+    the_thread,
+    priority,
+    NULL,
+    _Thread_Raise_real_priority_filter,
+    false
+  _Thread_Remove_life_change_request( the_thread );
 void _Thread_Join(
   States_Control     waiting_for_join,
@@ -468,7 +526,8 @@ bool _Thread_Restart_other(
   ISR_lock_Context               *lock_context
-  Per_CPU_Control *cpu_self;
+  Thread_Life_state  previous;
+  Per_CPU_Control   *cpu_self;
   _Thread_State_acquire_critical( the_thread, lock_context );
@@ -478,16 +537,27 @@ bool _Thread_Restart_other(
   the_thread->Start.Entry = *entry;
+  previous = _Thread_Change_life_locked(
+    the_thread,
+    0,
+    THREAD_LIFE_RESTARTING,
+    0
   cpu_self = _Thread_Dispatch_disable_critical( lock_context );
-  _Thread_State_release( the_thread, lock_context );
-  _Thread_Request_life_change(
-    the_thread,
-    NULL,
-    the_thread->Start.initial_priority,
-    THREAD_LIFE_RESTARTING
+  if ( _Thread_Is_life_change_allowed( previous ) ) {
+    _Thread_Add_life_change_request( the_thread );
+    _Thread_State_release( the_thread, lock_context );
+    _Thread_Finalize_life_change(
+      the_thread,
+      the_thread->Start.initial_priority
+  } else {
+    _Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
   _Thread_Dispatch_enable( cpu_self );
   return true;
1.8.4.5
