[PATCH 01/32] psxclassic01: Assume correct pthread_detach()
Wed May 18 09:20:20 UTC 2016
Update #2714.
 testsuites/psxtests/psxclassic01/init.c           | 35 +++++++++++++++++------
 testsuites/psxtests/psxclassic01/psxclassic01.scn |  6 ++--
 2 files changed, 31 insertions(+), 10 deletions(-)
diff --git a/testsuites/psxtests/psxclassic01/init.c b/testsuites/psxtests/psxclassic01/init.c
index 3ffbd3c..924224c 100644
--- a/testsuites/psxtests/psxclassic01/init.c
+++ b/testsuites/psxtests/psxclassic01/init.c
@@ -99,17 +99,14 @@ rtems_task test_task(rtems_task_argument arg)
   puts( "test_task exiting thread" );
-  pthread_exit( 0 );
+  pthread_exit( (void *) 123 );
-rtems_task Init(rtems_task_argument arg)
+static rtems_id create_task( void )
   rtems_status_code sc;
   rtems_id          task_id;
-  int               status;
-  void             *retval;
-  TEST_BEGIN();
   sc = rtems_task_create(
     rtems_build_name('T','E','S','T'),
@@ -124,6 +121,18 @@ rtems_task Init(rtems_task_argument arg)
   sc = rtems_task_start( task_id,  test_task, 0 );
   rtems_test_assert( sc == RTEMS_SUCCESSFUL );
+  return task_id;
+rtems_task Init( rtems_task_argument arg )
+  rtems_id  task_id;
+  int       status;
+  void     *retval;
+  TEST_BEGIN();
+  task_id = create_task();
   puts( "Init - pthread_equal on Classic Ids" );
   status = pthread_equal( task_id, task_id );
@@ -136,13 +145,23 @@ rtems_task Init(rtems_task_argument arg)
   status = pthread_detach( task_id );
   rtems_test_assert( status == 0 );
+  retval = (void *) 456;
   status = pthread_join( task_id, &retval );
-  if ( status != EINVAL ) printf( "JOIN %s\n", strerror( status ) );
-  rtems_test_assert( status == EINVAL );
+  rtems_test_assert( status == ESRCH );
+  rtems_test_assert( retval == (void *) 456 );
+  status = pthread_kill( task_id, SIGUSR1 );
+  status = pthread_join( task_id, &retval );
+  rtems_test_assert( status == 0 );
+  rtems_test_assert( retval == (void *) 123 );
   TEST_END();
   exit(0);
diff --git a/testsuites/psxtests/psxclassic01/psxclassic01.scn b/testsuites/psxtests/psxclassic01/psxclassic01.scn
index 1d7c4dd..a783750 100644
--- a/testsuites/psxtests/psxclassic01/psxclassic01.scn
+++ b/testsuites/psxtests/psxclassic01/psxclassic01.scn
@@ -1,8 +1,10 @@
-*** START OF CLASSIC API TEST OF POSIX 01 ***
+*** BEGIN OF TEST PSXCLASSIC 1 ***
 test_task starting...
 test_task waiting for signal...
 Init - pthread_cancel on Classic Task
+test_task starting...
+test_task waiting for signal...
 Signal_info: 25 si_signo= 0 si_code= 0 value= 0
-*** END OF CLASSIC API TEST OF POSIX 01 ***
+*** END OF TEST PSXCLASSIC 1 ***
1.8.4.5
