[PATCH 23/32] testsuites: Replace _Thread_Get()
Wed May 18 09:20:42 UTC 2016
Replace _Thread_Get() with _Thread_Get_interrupt_disable() to avoid the
Giant lock.
Update #2555.
 testsuites/smptests/smpmigration02/init.c  |  8 ++++----
 testsuites/smptests/smpscheduler03/init.c  |  8 ++++----
 testsuites/sptests/spintrcritical23/init.c |  9 ++++-----
 testsuites/tmtests/tm26/task1.c            | 25 ++++++++++++++-----------
 4 files changed, 26 insertions(+), 24 deletions(-)
diff --git a/testsuites/smptests/smpmigration02/init.c b/testsuites/smptests/smpmigration02/init.c
index 9af7752..40ac8ff 100644
--- a/testsuites/smptests/smpmigration02/init.c
+++ b/testsuites/smptests/smpmigration02/init.c
@@ -118,12 +118,12 @@ static void busy_loop_task(rtems_task_argument arg)
 static Thread_Control *get_thread_by_id(rtems_id task_id)
-  Objects_Locations location;
+  ISR_lock_Context lock_context;
   Thread_Control *thread;
-  thread = _Thread_Get(task_id, &location);
-  rtems_test_assert(location == OBJECTS_LOCAL);
-  _Thread_Enable_dispatch();
+  thread = _Thread_Get_interrupt_disable(task_id, &lock_context);
+  rtems_test_assert(thread != NULL);
+  _ISR_lock_ISR_enable(&lock_context);
   return thread;
diff --git a/testsuites/smptests/smpscheduler03/init.c b/testsuites/smptests/smpscheduler03/init.c
index 1888048..5473500 100644
--- a/testsuites/smptests/smpscheduler03/init.c
+++ b/testsuites/smptests/smpscheduler03/init.c
@@ -100,12 +100,12 @@ static rtems_id start_task(rtems_task_priority prio)
   return thread;
diff --git a/testsuites/sptests/spintrcritical23/init.c b/testsuites/sptests/spintrcritical23/init.c
index 89fea25..4857d99 100644
--- a/testsuites/sptests/spintrcritical23/init.c
+++ b/testsuites/sptests/spintrcritical23/init.c
@@ -42,13 +42,12 @@ static test_context ctx_instance;
 static Thread_Control *get_tcb(rtems_id id)
   Thread_Control *tcb;
-  tcb = _Thread_Get(id, &location);
-  _Objects_Put(&tcb->Object);
-  rtems_test_assert(tcb != NULL && location == OBJECTS_LOCAL);
+  tcb = _Thread_Get_interrupt_disable(id, &lock_context);
+  rtems_test_assert(tcb != NULL);
   return tcb;
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index 66bd409..babd240 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -543,8 +543,9 @@ rtems_task Floating_point_task_2(
 void complete_test( void )
-  uint32_t    index;
-  rtems_id          task_id;
+  uint32_t         index;
+  rtems_id         task_id;
   benchmark_timer_initialize();
     thread_resume( Middle_tcb );
@@ -570,14 +571,14 @@ void complete_test( void )
   task_id = Middle_tcb->Object.id;
-    for ( index=1 ; index <= OPERATION_COUNT ; index++ )
-      (void) _Thread_Get( task_id, &location );
+    for ( index=1 ; index <= OPERATION_COUNT ; index++ ) {
+      (void) _Thread_Get_interrupt_disable( task_id, &lock_context );
+      _ISR_lock_ISR_enable( &lock_context );
   thread_get_time = benchmark_timer_read();
-      ISR_lock_Context lock_context;
       (void) _Semaphore_Get_interrupt_disable(
         Semaphore_id,
         &location,
@@ -588,8 +589,10 @@ void complete_test( void )
   semaphore_get_time = benchmark_timer_read();
-      (void) _Thread_Get( 0x3, &location );
+      (void) _Thread_Get_interrupt_disable( 0x3, &lock_context );
   thread_get_invalid_time = benchmark_timer_read();
@@ -755,7 +758,7 @@ void complete_test( void )
   put_time(
-    "rtems internal: _Thread_Get",
+    "rtems internal: _Thread_Get_interrupt_disable",
     thread_get_time,
     OPERATION_COUNT,
     0,
@@ -763,7 +766,7 @@ void complete_test( void )
   put_time(
-    "rtems internal: _Semaphore_Get",
+    "rtems internal: _Semaphore_Get_interrupt_disable",
     semaphore_get_time,
     OPERATION_COUNT,
     0,
@@ -771,7 +774,7 @@ void complete_test( void )
   put_time(
-    "rtems internal: _Thread_Get: invalid id",
+    "rtems internal: _Thread_Get_interrupt_disable: invalid id",
     thread_get_invalid_time,
     OPERATION_COUNT,
     0,
1.8.4.5
