[PATCH 27/32] testsuites: Avoid Giant lock
Wed May 18 09:20:46 UTC 2016
Replace _Thread_Disable_dispatch() with _Thread_Dispatch_disable().
Replace _Thread_Enable_dispatch() with _Thread_Dispatch_enable().
This is a preparation to remove the Giant lock.
Update #2555.
 testsuites/libtests/malloctest/init.c      |  8 +--
 testsuites/smptests/smpcache01/init.c      | 17 +++---
 testsuites/smptests/smpfatal03/init.c      |  4 +-
 testsuites/smptests/smpmigration02/init.c  |  6 +-
 testsuites/smptests/smpscheduler01/init.c  | 10 +--
 testsuites/smptests/smpthreadlife01/init.c |  4 +-
 testsuites/sptests/sp37/init.c             |  9 +--
 testsuites/sptests/sp75/init.c             |  9 +--
 testsuites/sptests/spfatal01/testcase.h    |  2 +-
 testsuites/sptests/spfatal03/testcase.h    |  6 +-
 testsuites/sptests/spintrcritical20/init.c |  5 +-
 testsuites/sptests/spthreadlife01/init.c   |  9 +--
 testsuites/sptests/spthreadq01/init.c      |  4 +-
 testsuites/tmtests/tm26/task1.c            | 98 +++++-------------------------
 testsuites/tmtests/tm27/task1.c            |  4 +-
 15 files changed, 65 insertions(+), 130 deletions(-)
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index 6123977..fb22e4d 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -95,10 +95,10 @@ static void test_realloc(void)
   rtems_test_assert( malloc_walk_ok );
   puts( "malloc_walk - in critical section path" );
-  _Thread_Disable_dispatch();
+  _Thread_Dispatch_disable();
   malloc_walk_ok = malloc_walk( 1234, false );
-  _Thread_Enable_dispatch();
+  _Thread_Dispatch_enable( _Per_CPU_Get() );
    *  Realloc with a bad pointer to force a point
@@ -1142,9 +1142,9 @@ static void test_rtems_heap_allocate_aligned_with_boundary(void)
   rtems_test_assert( p != NULL );
   free(p);
   p = rtems_heap_allocate_aligned_with_boundary(1, 1, 1);
   rtems_test_assert( p == NULL );
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index d8995e8..52ee997 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -166,19 +166,19 @@ static void call_tests_isr_disabled( size_t set_size,
-static void call_tests_with_giant_acquired( size_t set_size,
+static void call_tests_with_thread_dispatch_disabled( size_t set_size,
     const cpu_set_t *cpu_set, SMP_barrier_State *bs )
   size_t i;
   for (i = 0; i < RTEMS_ARRAY_SIZE( test_cases ); ++i) {
-    if ( rtems_get_current_processor() == 0)
+    Per_CPU_Control *cpu_self;
+    cpu_self = _Thread_Dispatch_disable();
     call_test( set_size, cpu_set, bs, i );
+    _Thread_Dispatch_enable( cpu_self );
@@ -208,10 +208,9 @@ static void all_tests( void )
   call_tests_isr_disabled( set_size, cpu_set, &bs );
   cmlog( "Done!\n" );
-  /* Call test cases with core 0 holding the giant lock */
-  cmlog( "Calling test cases with CPU0 holding "
-      "the giant lock. " );
-  call_tests_with_giant_acquired( set_size, cpu_set, &bs );
+  /* Call test cases with thread dispatch disabled */
+  cmlog( "Calling test cases with thread_dispatch_disabled. ");
+  call_tests_with_thread_dispatch_disabled( set_size, cpu_set, &bs );
   cmlog( "Done!\n");
   /* Done. Free up memory. */
diff --git a/testsuites/smptests/smpfatal03/init.c b/testsuites/smptests/smpfatal03/init.c
index 788b071..2f3980b 100644
--- a/testsuites/smptests/smpfatal03/init.c
+++ b/testsuites/smptests/smpfatal03/init.c
@@ -42,7 +42,7 @@ static void acquire_giant_and_fatal_task(rtems_task_argument arg)
   int i;
   for (i = 0; i < 13; ++i) {
+    _Giant_Acquire();
   _SMP_barrier_Wait(&giant_barrier, &state, CPU_COUNT);
@@ -62,7 +62,7 @@ static void wait_for_giant(void)
+  _Giant_Release();
 static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmigration02/init.c b/testsuites/smptests/smpmigration02/init.c
index 40ac8ff..ed10c2b 100644
--- a/testsuites/smptests/smpmigration02/init.c
+++ b/testsuites/smptests/smpmigration02/init.c
@@ -140,6 +140,7 @@ static void test_double_migration(test_context *ctx)
     uint32_t cpu_other_index = 1;
     Per_CPU_Control *cpu_self = _Per_CPU_Get_by_index(cpu_self_index);
     Per_CPU_Control *cpu_other = _Per_CPU_Get_by_index(cpu_other_index);
+    Per_CPU_Control *cpu_self_dispatch_disabled;
     Thread_Control *self;
     Thread_Control *other;
@@ -173,7 +174,8 @@ static void test_double_migration(test_context *ctx)
       /* Wait */
+    cpu_self_dispatch_disabled = _Thread_Dispatch_disable();
+    rtems_test_assert(cpu_self == cpu_self_dispatch_disabled);
     self = _Thread_Executing;
@@ -215,7 +217,7 @@ static void test_double_migration(test_context *ctx)
     rtems_test_assert(cpu_other->heir == other);
+    _Thread_Dispatch_enable(cpu_self_dispatch_disabled);
     while (!_Thread_Is_executing_on_a_processor(other)) {
       /* Wait */
diff --git a/testsuites/smptests/smpscheduler01/init.c b/testsuites/smptests/smpscheduler01/init.c
index db61933..9518a4d 100644
--- a/testsuites/smptests/smpscheduler01/init.c
+++ b/testsuites/smptests/smpscheduler01/init.c
@@ -103,8 +103,9 @@ static bool is_per_cpu_state_ok(void)
 static void test_scheduler_cross(void)
   bool per_cpu_state_ok;
   suspend(0);
   suspend(1);
@@ -113,7 +114,7 @@ static void test_scheduler_cross(void)
   per_cpu_state_ok = is_per_cpu_state_ok();
   rtems_test_assert(per_cpu_state_ok);
@@ -121,8 +122,9 @@ static void test_scheduler_cross(void)
 static void test_scheduler_move_heir(void)
   suspend(2);
   suspend(3);
@@ -136,7 +138,7 @@ static void test_scheduler_move_heir(void)
   resume(1);
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index bd4c88d..5bfa3bc 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -212,7 +212,7 @@ static void delay_ipi_task(rtems_task_argument variant)
   rtems_counter_delay_nanoseconds(100000000);
   if (variant != 0) {
   _ISR_Enable_without_giant(level);
@@ -224,7 +224,7 @@ static void delay_ipi_task(rtems_task_argument variant)
   _Thread_Set_life_protection( THREAD_LIFE_PROTECTED );
   if (variant != 0) {
   rtems_test_assert(0);
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index cec6d06..68b28a6 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -402,8 +402,9 @@ rtems_timer_service_routine test_unblock_task(
   void     *arg
-  bool              in_isr;
-  rtems_status_code status;
+  bool               in_isr;
+  rtems_status_code  status;
   in_isr = rtems_interrupt_is_in_progress();
   status = rtems_task_is_suspended( blocked_task_id );
@@ -420,9 +421,9 @@ rtems_timer_service_routine test_unblock_task(
   blocked_task_status = 2;
   status = rtems_task_resume( blocked_task_id );
-  _Thread_Unnest_dispatch();
   directive_failed( status, "rtems_task_resume" );
diff --git a/testsuites/sptests/sp75/init.c b/testsuites/sptests/sp75/init.c
index 2822586..e699e76 100644
--- a/testsuites/sptests/sp75/init.c
+++ b/testsuites/sptests/sp75/init.c
@@ -23,8 +23,9 @@ rtems_task Init(
   rtems_task_argument argument
-  rtems_status_code sc;
-  rtems_id          mutex;
+  rtems_status_code  sc;
+  rtems_id           mutex;
   TEST_BEGIN();
@@ -43,9 +44,9 @@ rtems_task Init(
    *  directive_failed() checks for dispatching being enabled.
   puts( "rtems_semaphore_obtain - with dispatching disabled" );
     sc = rtems_semaphore_obtain(mutex, RTEMS_NO_WAIT, RTEMS_NO_TIMEOUT);
+  _Thread_Dispatch_enable(cpu_self);
   directive_failed(sc, "rtems_semaphore_obtain");
   TEST_END();
diff --git a/testsuites/sptests/spfatal01/testcase.h b/testsuites/sptests/spfatal01/testcase.h
index 2bde3fa..9ac322a 100644
--- a/testsuites/sptests/spfatal01/testcase.h
+++ b/testsuites/sptests/spfatal01/testcase.h
@@ -33,7 +33,7 @@ void force_error()
  *  Case 2: Null entry
  *  Case 3: semaphore_create
- *          _Thread_Disable_dispatch
+ *          _Thread_Dispatch_disable
  *          semaphore_obtain
diff --git a/testsuites/sptests/spfatal03/testcase.h b/testsuites/sptests/spfatal03/testcase.h
index b9f1c22..86b3003 100644
--- a/testsuites/sptests/spfatal03/testcase.h
+++ b/testsuites/sptests/spfatal03/testcase.h
@@ -36,12 +36,10 @@ void force_error(void)
   printk("Create semaphore S0\n");
   printk("Obtain semaphore in dispatching critical section\n");
   status = rtems_semaphore_obtain( mutex, RTEMS_DEFAULT_OPTIONS, 0 );
   /* !!! SHOULD NOT RETURN FROM THE ABOVE CALL */
-  printk("ERROR -- Obtain semaphore should not have returned\n");
+  rtems_test_assert( 0 );
   /* we will not run this far */
diff --git a/testsuites/sptests/spintrcritical20/init.c b/testsuites/sptests/spintrcritical20/init.c
index 85c1645..9c9b5f0 100644
--- a/testsuites/sptests/spintrcritical20/init.c
+++ b/testsuites/sptests/spintrcritical20/init.c
@@ -71,8 +71,9 @@ static bool test_body(void *arg)
   test_context *ctx = arg;
   int busy;
   rtems_test_assert(
     ctx->semaphore_task_tcb->Wait.return_code
@@ -105,7 +106,7 @@ static bool test_body(void *arg)
       break;
   return ctx->thread_queue_was_null
     && ctx->status_was_successful
diff --git a/testsuites/sptests/spthreadlife01/init.c b/testsuites/sptests/spthreadlife01/init.c
index 7724635..8bf26b9 100644
--- a/testsuites/sptests/spthreadlife01/init.c
+++ b/testsuites/sptests/spthreadlife01/init.c
@@ -232,6 +232,7 @@ static void worker_task(rtems_task_argument arg)
     test_state state = ctx->current;
     Thread_Life_state previous_thread_life_state;
     switch (state) {
       case SET_PRIO:
@@ -272,22 +273,22 @@ static void worker_task(rtems_task_argument arg)
         assert_priority(PRIO_HIGH);
         break;
       case SET_PROTECTION:
         previous_thread_life_state =
           _Thread_Set_life_protection(THREAD_LIFE_PROTECTED);
         rtems_test_assert(
           (previous_thread_life_state & THREAD_LIFE_PROTECTED) == 0
         break;
       case CLEAR_PROTECTION:
         previous_thread_life_state = _Thread_Set_life_protection(0);
         rtems_test_assert(
           (previous_thread_life_state & THREAD_LIFE_PROTECTED) != 0
         ctx->current = DELETE_4;
         break;
       case DELETE_SELF:
         ctx->current = DELETE_7;
diff --git a/testsuites/sptests/spthreadq01/init.c b/testsuites/sptests/spthreadq01/init.c
index cb8d495..85df6bd 100644
--- a/testsuites/sptests/spthreadq01/init.c
+++ b/testsuites/sptests/spthreadq01/init.c
@@ -353,9 +353,7 @@ static rtems_task Init(
   TEST_BEGIN();
   puts( "Init - _Thread_queue_Extract - thread not blocked on a thread queue" );
-  _Thread_queue_Extract( _Thread_Executing );
+  _Thread_queue_Extract( _Thread_Get_executing() );
   /* is there more to check? */
   test_context_init(ctx);
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index babd240..0eb7554 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -138,73 +138,9 @@ static void set_thread_executing( Thread_Control *thread )
 #endif
-static void thread_disable_dispatch( void )
-/* Yes, RTEMS_SMP and not PREVENT_SMP_ASSERT_FAILURES */
-#if defined( RTEMS_SMP )
-  Per_CPU_Control *self_cpu;
-  ISR_Level level;
-  _ISR_Disable_without_giant( level );
-  ( void ) level;
-  self_cpu = _Per_CPU_Get();
-  self_cpu->thread_dispatch_disable_level = 1;
-#else
-#endif
-static void thread_set_state( Thread_Control *thread, States_Control state )
-#if defined( PREVENT_SMP_ASSERT_FAILURES )
-#endif
-  _Thread_Set_state( thread, state );
-#endif
 static void thread_resume( Thread_Control *thread )
-#endif
   _Thread_Clear_state( thread, STATES_SUSPENDED );
-#endif
-static void thread_unblock( Thread_Control *thread )
-#endif
-  _Thread_Unblock( thread );
-#endif
-static void thread_clear_state( Thread_Control *thread, States_Control state  )
-#endif
-  _Thread_Clear_state( thread, state );
-#endif
 rtems_task null_task(
@@ -338,7 +274,7 @@ rtems_task High_task(
   rtems_interrupt_level level;
   benchmark_timer_initialize();
     rtems_interrupt_local_disable( level );
@@ -357,18 +293,18 @@ rtems_task High_task(
     rtems_interrupt_local_enable( level );
   isr_enable_time = benchmark_timer_read();
   thread_disable_dispatch_time = benchmark_timer_read();
   thread_enable_dispatch_time = benchmark_timer_read();
-    thread_set_state( _Thread_Get_executing(), STATES_SUSPENDED );
+    _Thread_Set_state( _Thread_Get_executing(), STATES_SUSPENDED );
   thread_set_state_time = benchmark_timer_read();
   set_thread_dispatch_necessary( true );
@@ -386,7 +322,7 @@ rtems_task Middle_task(
   thread_dispatch_no_fp_time = benchmark_timer_read();
   Middle_tcb   = _Thread_Get_executing();
@@ -398,7 +334,7 @@ rtems_task Middle_task(
   set_thread_dispatch_necessary( false );
-  thread_disable_dispatch();
     _Context_Switch(
@@ -441,7 +377,7 @@ rtems_task Low_task(
     _Context_Switch(
@@ -471,7 +407,7 @@ rtems_task Floating_point_task_1(
 #if (CPU_HARDWARE_FP == 1) || (CPU_SOFTWARE_FP == 1)
@@ -551,16 +487,16 @@ void complete_test( void )
     thread_resume( Middle_tcb );
   thread_resume_time = benchmark_timer_read();
-  thread_set_state( Middle_tcb, STATES_WAITING_FOR_MESSAGE );
+  _Thread_Set_state( Middle_tcb, STATES_WAITING_FOR_MESSAGE );
-    thread_unblock( Middle_tcb );
+    _Thread_Unblock( Middle_tcb );
   thread_unblock_time = benchmark_timer_read();
-    thread_clear_state( Middle_tcb, STATES_WAITING_FOR_MESSAGE );
+    _Thread_Clear_state( Middle_tcb, STATES_WAITING_FOR_MESSAGE );
   thread_ready_time = benchmark_timer_read();
@@ -603,10 +539,6 @@ void complete_test( void )
   set_thread_heir( _Thread_Get_executing() );
-  for (index = 0; index < OPERATION_COUNT; ++index) {
    *  Now dump all the times
@@ -636,7 +568,7 @@ void complete_test( void )
   put_time(
-    "rtems internal: _Thread_Disable_dispatch",
+    "rtems internal: _Thread_Dispatch_disable",
     thread_disable_dispatch_time,
     1,
     0,
@@ -644,7 +576,7 @@ void complete_test( void )
   put_time(
-    "rtems internal: _Thread_Enable_dispatch",
+    "rtems internal: _Thread_Dispatch_enable",
     thread_enable_dispatch_time,
     1,
     0,
diff --git a/testsuites/tmtests/tm27/task1.c b/testsuites/tmtests/tm27/task1.c
index 77072bb..cae778f 100644
--- a/testsuites/tmtests/tm27/task1.c
+++ b/testsuites/tmtests/tm27/task1.c
@@ -151,7 +151,7 @@ rtems_task Task_1(
    *  No preempt .. nested
   Interrupt_nest = 1;
@@ -165,7 +165,7 @@ rtems_task Task_1(
 #endif
   Interrupt_return_time = benchmark_timer_read();
   put_time(
     "rtems interrupt: entry overhead returns to nested interrupt",
1.8.4.5
