[PATCH 29/32] score: Rename _ISR_Disable_without_giant()
Wed May 18 09:20:48 UTC 2016
Rename _ISR_Disable_without_giant() into _ISR_Local_disable().  Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
This is a preparation to remove the Giant lock.
Update #2555.
 .../powerpc/shared/include/powerpc-utility.h       | 24 +++++++++++-----------
 cpukit/rtems/include/rtems/rtems/intr.h            |  4 ++--
 cpukit/score/include/rtems/score/isrlevel.h        |  4 ++--
 cpukit/score/include/rtems/score/isrlock.h         |  4 ++--
 cpukit/score/include/rtems/score/mrspimpl.h        |  8 ++++----
 cpukit/score/include/rtems/score/percpu.h          | 12 +++++------
 cpukit/score/include/rtems/score/smplock.h         |  4 ++--
 cpukit/score/include/rtems/score/threaddispatch.h  |  8 ++++----
 cpukit/score/include/rtems/score/threadimpl.h      |  4 ++--
 cpukit/score/src/debugisthreaddispatchingallowed.c |  4 ++--
 cpukit/score/src/interr.c                          |  2 +-
 cpukit/score/src/isrisinprogress.c                 |  4 ++--
 cpukit/score/src/libatomic.c                       |  4 ++--
 cpukit/score/src/smplock.c                         |  2 +-
 cpukit/score/src/smpmulticastaction.c              |  4 ++--
 cpukit/score/src/threaddispatch.c                  |  6 +++---
 cpukit/score/src/threaddispatchdisablelevel.c      | 16 +++++++--------
 cpukit/score/src/threadhandler.c                   |  2 +-
 testsuites/smptests/smpcache01/init.c              |  4 ++--
 testsuites/smptests/smpload01/init.c               |  4 ++--
 testsuites/smptests/smpthreadlife01/init.c         |  8 ++++----
 testsuites/tmtests/tm26/task1.c                    | 12 +++++------
 testsuites/tmtests/tm27/task1.c                    |  4 ++--
 23 files changed, 74 insertions(+), 74 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h b/c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h
index b8dc5f4..ce4068f 100644
--- a/c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h
+++ b/c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h
@@ -588,11 +588,11 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     ISR_Level level; \
     uint32_t val; \
     uint32_t mybits = bits; \
-    _ISR_Disable_without_giant(level); \
+    _ISR_Local_disable(level); \
     val = PPC_SPECIAL_PURPOSE_REGISTER(spr); \
     val |= mybits; \
     PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
-    _ISR_Enable_without_giant(level); \
+    _ISR_Local_enable(level); \
   } while (0)
@@ -608,12 +608,12 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     uint32_t val; \
     uint32_t mymask = mask; \
     val &= ~mymask; \
     val |= mybits; \
   } while (0)
@@ -627,11 +627,11 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     ISR_Level level; \
     uint32_t val; \
     val &= ~mybits; \
   } while (0)
@@ -705,11 +705,11 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     ISR_Level level; \
     uint32_t val; \
     val = PPC_DEVICE_CONTROL_REGISTER(dcr); \
     val |= mybits; \
     PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val); \
   } while (0)
@@ -725,12 +725,12 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     uint32_t val; \
     val &= ~mymask; \
     val |= mybits; \
   } while (0)
@@ -744,11 +744,11 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     ISR_Level level; \
     uint32_t val; \
     val &= ~mybits; \
   } while (0)
 static inline uint32_t ppc_time_base(void)
diff --git a/cpukit/rtems/include/rtems/rtems/intr.h b/cpukit/rtems/include/rtems/rtems/intr.h
index f9c601b..ebf7a58 100644
--- a/cpukit/rtems/include/rtems/rtems/intr.h
+++ b/cpukit/rtems/include/rtems/rtems/intr.h
@@ -139,7 +139,7 @@ rtems_status_code rtems_interrupt_catch(
  * @see rtems_interrupt_local_enable().
 #define rtems_interrupt_local_disable( _isr_cookie ) \
-  _ISR_Disable_without_giant( _isr_cookie )
+  _ISR_Local_disable( _isr_cookie )
  * @brief This macro restores the previous interrupt level on the current
@@ -149,7 +149,7 @@ rtems_status_code rtems_interrupt_catch(
  *   rtems_interrupt_local_disable().
 #define rtems_interrupt_local_enable( _isr_cookie ) \
-  _ISR_Enable_without_giant( _isr_cookie )
+  _ISR_Local_enable( _isr_cookie )
  *  @brief RTEMS Interrupt Is in Progress
diff --git a/cpukit/score/include/rtems/score/isrlevel.h b/cpukit/score/include/rtems/score/isrlevel.h
index 2823df7..cf8712a 100644
--- a/cpukit/score/include/rtems/score/isrlevel.h
+++ b/cpukit/score/include/rtems/score/isrlevel.h
@@ -136,13 +136,13 @@ typedef uint32_t   ISR_Level;
     RTEMS_COMPILER_MEMORY_BARRIER();  \
   } while (0)
-#define _ISR_Disable_without_giant( _level ) \
+#define _ISR_Local_disable( _level ) \
   do { \
     _CPU_ISR_Disable( _level ); \
   } while (0)
-#define _ISR_Enable_without_giant( _level ) \
+#define _ISR_Local_enable( _level ) \
   do { \
     _CPU_ISR_Enable( _level ); \
diff --git a/cpukit/score/include/rtems/score/isrlock.h b/cpukit/score/include/rtems/score/isrlock.h
index f87f555..2af75c9 100644
--- a/cpukit/score/include/rtems/score/isrlock.h
+++ b/cpukit/score/include/rtems/score/isrlock.h
@@ -351,7 +351,7 @@ typedef struct {
 #if defined( RTEMS_SMP )
   #define _ISR_lock_ISR_disable( _context ) \
     do { \
-      _ISR_Disable_without_giant( ( _context )->Lock_context.isr_level ); \
+      _ISR_Local_disable( ( _context )->Lock_context.isr_level ); \
       _ISR_lock_ISR_disable_profile( _context ) \
     } while ( 0 )
 #else
@@ -374,7 +374,7 @@ typedef struct {
   #define _ISR_lock_ISR_enable( _context ) \
-    _ISR_Enable_without_giant( ( _context )->Lock_context.isr_level )
+    _ISR_Local_enable( ( _context )->Lock_context.isr_level )
 #else
     _ISR_Enable( ( _context )->isr_level )
diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
index f2570eb..d5cf55d 100644
--- a/cpukit/score/include/rtems/score/mrspimpl.h
+++ b/cpukit/score/include/rtems/score/mrspimpl.h
@@ -251,9 +251,9 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
   if ( timeout > 0 ) {
     _Watchdog_Preinitialize( &rival.Watchdog, cpu_self );
     _Watchdog_Initialize( &rival.Watchdog, _MRSP_Timeout );
-    _ISR_Disable_without_giant( level );
+    _ISR_Local_disable( level );
     _Watchdog_Per_CPU_insert_relative( &rival.Watchdog, cpu_self, timeout );
-    _ISR_Enable_without_giant( level );
+    _ISR_Local_enable( level );
   life_state = _Thread_Set_life_protection( THREAD_LIFE_PROTECTED );
@@ -269,13 +269,13 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
   _Thread_Set_life_protection( life_state );
     _Watchdog_Per_CPU_remove(
       &rival.Watchdog,
       cpu_self,
       &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ]
     if ( status == MRSP_TIMEOUT ) {
       _MRSP_Restore_priority( executing, initial_priority );
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index a4a8ffb..fa0c289 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -493,7 +493,7 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
 #define _Per_CPU_ISR_disable_and_acquire( cpu, isr_cookie ) \
   do { \
-    _ISR_Disable_without_giant( isr_cookie ); \
+    _ISR_Local_disable( isr_cookie ); \
     _Per_CPU_Acquire( cpu ); \
   } while ( 0 )
 #else
@@ -508,7 +508,7 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
 #define _Per_CPU_Release_and_ISR_enable( cpu, isr_cookie ) \
   do { \
     _Per_CPU_Release( cpu ); \
-    _ISR_Enable_without_giant( isr_cookie ); \
+    _ISR_Local_enable( isr_cookie ); \
   } while ( 0 )
 #else
@@ -523,7 +523,7 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
   do { \
     uint32_t ncpus = _SMP_Get_processor_count(); \
     uint32_t cpu; \
     for ( cpu = 0 ; cpu < ncpus ; ++cpu ) { \
       _Per_CPU_Acquire( _Per_CPU_Get_by_index( cpu ) ); \
@@ -541,7 +541,7 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
       _Per_CPU_Release( _Per_CPU_Get_by_index( cpu ) ); \
   } while ( 0 )
 #else
 #define _Per_CPU_Release_all( isr_cookie ) \
@@ -709,13 +709,13 @@ RTEMS_INLINE_ROUTINE struct _Thread_Control *_Thread_Get_executing( void )
     ISR_Level level;
   #endif
   executing = _Thread_Executing;
   #endif
   return executing;
diff --git a/cpukit/score/include/rtems/score/smplock.h b/cpukit/score/include/rtems/score/smplock.h
index 47797d3..dc6604a 100644
--- a/cpukit/score/include/rtems/score/smplock.h
+++ b/cpukit/score/include/rtems/score/smplock.h
@@ -565,7 +565,7 @@ static inline void _SMP_lock_ISR_disable_and_acquire(
   SMP_lock_Context *context
-  _ISR_Disable_without_giant( context->isr_level );
+  _ISR_Local_disable( context->isr_level );
   _SMP_lock_Acquire( lock, context );
@@ -588,7 +588,7 @@ static inline void _SMP_lock_Release_and_ISR_enable(
   _SMP_lock_Release( lock, context );
-  _ISR_Enable_without_giant( context->isr_level );
+  _ISR_Local_enable( context->isr_level );
 #endif
diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
index b0dd64c..ac8855b 100644
--- a/cpukit/score/include/rtems/score/threaddispatch.h
+++ b/cpukit/score/include/rtems/score/threaddispatch.h
@@ -54,13 +54,13 @@ RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled(void)
 #if defined(RTEMS_SMP)
   ISR_Level level;
 #endif
   enabled = _Thread_Dispatch_disable_level == 0;
 #endif
   return enabled;
@@ -325,7 +325,7 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
   if ( disable_level == 1 ) {
     ISR_Level level;
     if ( cpu_self->dispatch_necessary ) {
       _Thread_Do_dispatch( cpu_self, level );
@@ -334,7 +334,7 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
       _Profiling_Thread_dispatch_enable( cpu_self, 0 );
   } else {
     cpu_self->thread_dispatch_disable_level = disable_level - 1;
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index a33b115..4a6a6bf 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -1396,7 +1396,7 @@ RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change(
 #if !defined(RTEMS_SMP)
   ISR_Level level;
 #endif
   success = _Thread_Wait_flags_try_change_critical(
@@ -1406,7 +1406,7 @@ RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change(
 #endif
   return success;
diff --git a/cpukit/score/src/debugisthreaddispatchingallowed.c b/cpukit/score/src/debugisthreaddispatchingallowed.c
index 0f1580c..81ac877 100644
--- a/cpukit/score/src/debugisthreaddispatchingallowed.c
+++ b/cpukit/score/src/debugisthreaddispatchingallowed.c
@@ -26,10 +26,10 @@
     ISR_Level level;
     Per_CPU_Control *cpu_self;
     cpu_self = _Per_CPU_Get_snapshot();
     dispatch_allowed = cpu_self->thread_dispatch_disable_level == 0;
     return dispatch_allowed;
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index f7d6274..24ac9a4 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -36,7 +36,7 @@ void _Terminate(
   ISR_Level level;
   (void) level;
   _SMP_Request_shutdown();
diff --git a/cpukit/score/src/isrisinprogress.c b/cpukit/score/src/isrisinprogress.c
index 7607cfe..e2f210a 100644
--- a/cpukit/score/src/isrisinprogress.c
+++ b/cpukit/score/src/isrisinprogress.c
@@ -36,13 +36,13 @@ bool _ISR_Is_in_progress( void )
     ISR_Level level;
   #endif
   isr_nest_level = _ISR_Nest_level;
   #endif
   return isr_nest_level != 0;
diff --git a/cpukit/score/src/libatomic.c b/cpukit/score/src/libatomic.c
index 871b2c2..bfa3e6f 100644
--- a/cpukit/score/src/libatomic.c
+++ b/cpukit/score/src/libatomic.c
@@ -35,7 +35,7 @@ __uint32_t _Libatomic_Protect_start( void *ptr )
   ISR_Level isr_level;
   (void) ptr;
-  _ISR_Disable_without_giant( isr_level );
+  _ISR_Local_disable( isr_level );
   while (
@@ -56,7 +56,7 @@ void _Libatomic_Protect_end( void *ptr, __uint32_t isr_level )
   _Atomic_Flag_clear( &_Libatomic_The_one_lock, ATOMIC_ORDER_SEQ_CST );
 #endif
-  _ISR_Enable_without_giant( isr_level );
+  _ISR_Local_enable( isr_level );
diff --git a/cpukit/score/src/smplock.c b/cpukit/score/src/smplock.c
index e426c2a..f6cc8b6 100644
--- a/cpukit/score/src/smplock.c
+++ b/cpukit/score/src/smplock.c
@@ -89,7 +89,7 @@ void _SMP_lock_Release_and_ISR_enable(
   lock->owner = SMP_LOCK_NO_OWNER;
 #endif
   _SMP_lock_Release_body( lock, context );
 #if defined(RTEMS_DEBUG)
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index d5d0064..10a4929 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -74,7 +74,7 @@ _SMP_Multicast_actions_try_process( void )
   cpu_self = _Per_CPU_Get();
@@ -88,7 +88,7 @@ _SMP_Multicast_actions_try_process( void )
 void _SMP_Multicast_action(
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index a1f4c54..4d840bf 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -137,7 +137,7 @@ post_switch:
   cpu_self->thread_dispatch_disable_level = 0;
   _Thread_Run_post_switch_actions( executing );
@@ -147,7 +147,7 @@ void _Thread_Dispatch( void )
   ISR_Level        level;
@@ -156,6 +156,6 @@ void _Thread_Dispatch( void )
     cpu_self->thread_dispatch_disable_level = 1;
   } else {
diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
index 07201a5..826d5b2 100644
--- a/cpukit/score/src/threaddispatchdisablelevel.c
+++ b/cpukit/score/src/threaddispatchdisablelevel.c
@@ -77,7 +77,7 @@ uint32_t _Thread_Dispatch_increment_disable_level( void )
   uint32_t disable_level;
    * We must obtain the processor after interrupts are disabled to prevent
@@ -92,7 +92,7 @@ uint32_t _Thread_Dispatch_increment_disable_level( void )
   ++disable_level;
   cpu_self->thread_dispatch_disable_level = disable_level;
   return disable_level;
@@ -103,7 +103,7 @@ uint32_t _Thread_Dispatch_decrement_disable_level( void )
   disable_level = cpu_self->thread_dispatch_disable_level;
@@ -114,7 +114,7 @@ uint32_t _Thread_Dispatch_decrement_disable_level( void )
   _Giant_Do_release( cpu_self );
   _Profiling_Thread_dispatch_enable( cpu_self, disable_level );
@@ -123,20 +123,20 @@ void _Giant_Acquire( Per_CPU_Control *cpu_self )
   _Assert( _Thread_Dispatch_disable_level != 0 );
   _Giant_Do_acquire( cpu_self );
 void _Giant_Release( Per_CPU_Control *cpu_self )
 #if defined( RTEMS_DEBUG )
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index 2429de5..2fa6d07 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -69,7 +69,7 @@ void _Thread_Handler( void )
    * Do not use the level of the thread control block, since it has a
    * different format.
    *  At this point, the dispatch disable level BETTER be 1.
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index 52ee997..b8a7b71 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -158,11 +158,11 @@ static void call_tests_isr_disabled( size_t set_size,
   for (i = 0; i < RTEMS_ARRAY_SIZE( test_cases ); ++i) {
     call_test( set_size, cpu_set, bs, i );
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/smpload01/init.c
index 2a4e955..d4c303d 100644
--- a/testsuites/smptests/smpload01/init.c
+++ b/testsuites/smptests/smpload01/init.c
@@ -225,7 +225,7 @@ static void get_obtain_delay_estimate(test_context *ctx)
   _SMP_lock_Initialize(&lock, "test");
   for (i = 0; i < n; ++i) {
     SMP_lock_Context lock_context;
@@ -240,7 +240,7 @@ static void get_obtain_delay_estimate(test_context *ctx)
     t[i] = rtems_counter_difference(b, a);
   _SMP_lock_Destroy(&lock);
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index 5bfa3bc..2867be7 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -200,7 +200,7 @@ static void delay_ipi_task(rtems_task_argument variant)
   test_context *ctx = &test_instance;
   ISR_Level level;
   /* (C) */
   barrier(ctx, &ctx->worker_barrier_state);
@@ -215,7 +215,7 @@ static void delay_ipi_task(rtems_task_argument variant)
     _Thread_Dispatch_disable();
    * We get deleted as a side effect of enabling the thread life protection or
@@ -267,7 +267,7 @@ static void delay_switch_task(rtems_task_argument arg)
   rtems_status_code sc;
   ISR_Level level;
   (void) level;
   ctx->delay_switch_for_executing = _Thread_Get_executing();
@@ -403,7 +403,7 @@ static void op_worker_task(rtems_task_argument arg)
   test_op op = arg;
   ISR_Level level;
   (void) level;
   /* (E) */
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index 0eb7554..8463cd3 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -94,7 +94,7 @@ static void set_thread_dispatch_necessary( bool dispatch_necessary )
 #if defined( PREVENT_SMP_ASSERT_FAILURES )
   ISR_Level level;
 #endif
   _Thread_Dispatch_necessary = dispatch_necessary;
@@ -104,7 +104,7 @@ static void set_thread_dispatch_necessary( bool dispatch_necessary )
 #endif
@@ -113,13 +113,13 @@ static void set_thread_heir( Thread_Control *thread )
   ISR_Level level;
 #endif
   _Thread_Heir = thread;
 #endif
@@ -128,13 +128,13 @@ static void set_thread_executing( Thread_Control *thread )
   ISR_Level level;
 #endif
   _Thread_Executing = thread;
 #endif
diff --git a/testsuites/tmtests/tm27/task1.c b/testsuites/tmtests/tm27/task1.c
index cae778f..aba835c 100644
--- a/testsuites/tmtests/tm27/task1.c
+++ b/testsuites/tmtests/tm27/task1.c
@@ -188,7 +188,7 @@ rtems_task Task_1(
 #endif
   _Thread_Executing =
@@ -197,7 +197,7 @@ rtems_task Task_1(
   _Thread_Dispatch_necessary = 1;
 #endif
   Interrupt_occurred = 0;
1.8.4.5
