[PATCH 1/7] bsps/arm: CP15 support for flush prefetch buffer and table base control.
ppisa4lists at pikron.com
Thu May 19 11:16:11 UTC 2016
c/src/lib/libcpu/arm/shared/include/arm-cp15.h | 48 ++++++++++++++++++++++++++
1 file changed, 48 insertions(+)
diff --git a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
index 76b0582..4c1966d 100644
--- a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
+++ b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
@@ -358,6 +358,37 @@ arm_cp15_set_translation_table_base(uint32_t *base)
+/* Translation Table Base Control Register - DDI0301H arm1176jzfs TRM 3.2.15 */
+ARM_CP15_TEXT_SECTION static inline uint32_t
+*arm_cp15_get_translation_table_base_control_register(void)
+ ARM_SWITCH_REGISTERS;
+ uint32_t ttb_cr;
+ __asm__ volatile (
+ ARM_SWITCH_TO_ARM
+ "mrc p15, 0, %[ttb_cr], c2, c0, 2\n"
+ ARM_SWITCH_BACK
+ : [ttb_cr] "=&r" (ttb_cr) ARM_SWITCH_ADDITIONAL_OUTPUT
+ return ttb_cr;
+ARM_CP15_TEXT_SECTION static inline void
+arm_cp15_set_translation_table_base_control_register(uint32_t ttb_cr)
+ ARM_SWITCH_TO_ARM
+ "mcr p15, 0, %[ttb_cr], c2, c0, 2\n"
+ ARM_SWITCH_BACK
+ : ARM_SWITCH_OUTPUT
+ : [ttb_cr] "r" (ttb_cr)
arm_cp15_get_domain_access_control(void)
@@ -858,6 +889,23 @@ arm_cp15_branch_predictor_invalidate_all(void)
+/* Flush Prefetch Buffer - DDI0301H arm1176jzfs TRM 3.2.22 */
+arm_cp15_flush_prefetch_buffer(void)
+ uint32_t sbz = 0;
+ ARM_SWITCH_TO_ARM
+ "mcr p15, 0, %[sbz], c7, c5, 4\n"
+ ARM_SWITCH_BACK
+ : [sbz] "r" (sbz)
+ : "memory"
arm_cp15_instruction_cache_invalidate(void)
1.9.1
