[PATCH 4/7] arm/raspberrypi: add locking around GPIO pin function selection.
ppisa4lists at pikron.com ppisa4lists at pikron.com
Thu May 19 11:16:14 UTC 2016
This is required if function or direction is changed by some driver
after start of thread multitasking or in interrupts drivers.
There can be problem with calling GPIO function selection before
data section is initialized. But actual ticket lock implementation
seems to be compatible even with memory initialized to zero oven
on SMP.
 c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c | 5 +++++
 1 file changed, 5 insertions(+)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
index 40acd84..2788d36 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
@@ -21,6 +21,8 @@
+RTEMS_INTERRUPT_LOCK_DEFINE( static, rtems_gpio_bsp_lock, "rtems_gpio_bsp_lock" );
 /* Calculates a bitmask to assign an alternate function to a given pin. */
 #define SELECT_PIN_FUNCTION(fn, pn) (fn << ((pn % 10) * 3))
@@ -56,11 +58,14 @@ static rtems_status_code rpi_select_pin_function(
                                              (pin / 10);
   uint32_t reg_old;
   uint32_t reg_new;
+  rtems_interrupt_lock_context lock_context;
+  rtems_interrupt_lock_acquire(&rtems_gpio_bsp_lock, &lock_context);
   reg_new = reg_old = *pin_addr;
   reg_new &= ~SELECT_PIN_FUNCTION(RPI_ALT_FUNC_MASK, pin);
   reg_new |= SELECT_PIN_FUNCTION(type, pin);
   *pin_addr = reg_new;
+  rtems_interrupt_lock_release(&rtems_gpio_bsp_lock, &lock_context);
   return RTEMS_SUCCESSFUL;
1.9.1
