[PATCH 7/7] arm/raspberrypi: add cmdline support for rpi bsp.
ppisa4lists at pikron.com ppisa4lists at pikron.com
Thu May 19 11:16:17 UTC 2016
 c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  1 +
 c/src/lib/libbsp/arm/raspberrypi/include/bsp.h     |  6 +++
 c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c | 47 ++++++++++++++++++++++
 3 files changed, 54 insertions(+)
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 91f327e..258f8a0 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -95,6 +95,7 @@ libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
 # Startup
 libbsp_a_SOURCES += ../../shared/bspreset_loop.c
 libbsp_a_SOURCES += startup/bspstart.c
+libbsp_a_SOURCES += startup/cmdline.c
 # IRQ
 libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
index 0abeed6..18a94ea 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
@@ -7,6 +7,7 @@
+ * Copyright (c) 2015 Yang Qiao
  * Copyright (c) 2013 Alan Cudmore
  *  The license and distribution terms for this file may be
@@ -35,6 +36,11 @@ extern "C" {
 #define BSP_GPIO_PINS_PER_BANK 32
 #define BSP_GPIO_PINS_PER_SELECT_BANK 10
+void rpi_init_cmdline(void);
+const char *rpi_cmdline_get_cached(void);
+const char *rpi_cmdline_get_raw(void);
+const char *rpi_cmdline_get_arg(const char* arg);
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c b/c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c
new file mode 100644
index 0000000..f8a7182
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c
@@ -0,0 +1,47 @@
+ * @file
+ * @ingroup raspberrypi
+ * @brief mailbox support.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE
+#include <bsp.h>
+#include <bsp/vc.h>
+#define MAX_CMDLINE_LENGTH 1024
+static int rpi_cmdline_ready;
+static char rpi_cmdline_cached[MAX_CMDLINE_LENGTH];
+static bcm2835_get_cmdline_entries rpi_cmdline_entries;
+  memset(&rpi_cmdline_entries, 0, sizeof(rpi_cmdline_entries));
+  bcm2835_mailbox_get_cmdline(&rpi_cmdline_entries);
+  return rpi_cmdline_entries.cmdline;
+  if (!rpi_cmdline_ready) {
+    const char *line = rpi_cmdline_get_raw();
+    strncpy(rpi_cmdline_cached, line, MAX_CMDLINE_LENGTH - 1);
+    rpi_cmdline_cached[MAX_CMDLINE_LENGTH - 1] = 0;
+    rpi_cmdline_ready = 1;
+  return rpi_cmdline_cached;
+  return strstr (rpi_cmdline_get_cached(), arg);
1.9.1
