Validity of a patch on newlib
Thu May 19 22:12:47 UTC 2016
I believe those patches aren't needed any more, as we have worked to
submit our patches upstream and use newlib snapshots and releases
directly. You should refer to the source versions identified by the
RSB, and see whether it applies any patches, to understand what source
it compiles to build a tool chain.
Gedare
On Thu, May 19, 2016 at 7:23 AM, Sambeet Panigrahi
<sambeet161616 at gmail.com> wrote:
> Hi,
> I was going through the old scripts o porting Rock on RTEMS.While building
> the rtems version 4.10.1  a patch was used namely
> http://www.rtems.com/ftp/pub/rtems/SOURCES/4.10/newlib-1.18.0-rtems4.10-20110518.diff
> This url gives a page not found error now. I am now modifying the scripts
> for rtems4.11.Where can I find the necessary patches? I don't want to use th
> RSB now so that i understand the building procedure step by step. Can
> someone help?
> regards
> Sambeet
