[PATCH 01/15] score: Add per scheduler instance maximum priority
Fri May 20 13:33:38 UTC 2016
The priority values are only valid within a scheduler instance.  Thus,
the maximum priority value must be defined per scheduler instance.  The
first scheduler instance defines PRIORITY_MAXIMUM.  This implies that
RTEMS_MAXIMUM_PRIORITY and POSIX_SCHEDULER_MAXIMUM_PRIORITY are only
valid for threads of the first scheduler instance.  Further
API/implementation changes are necessary to fix this.
Update #2556.
 cpukit/posix/include/rtems/posix/priorityimpl.h       |  2 +-
 cpukit/rtems/include/rtems/rtems/tasks.h              |  1 +
 cpukit/sapi/include/confdefs.h                        | 13 +------------
 cpukit/sapi/include/rtems/scheduler.h                 | 18 +++++++++++++++++-
 cpukit/score/include/rtems/score/priority.h           |  8 --------
 cpukit/score/include/rtems/score/scheduler.h          | 14 ++++++++++++++
 cpukit/score/include/rtems/score/schedulercbs.h       |  2 ++
 cpukit/score/include/rtems/score/scheduleredf.h       |  2 ++
 cpukit/score/include/rtems/score/schedulersimple.h    |  2 ++
 cpukit/score/include/rtems/score/schedulersimplesmp.h |  2 ++
 10 files changed, 42 insertions(+), 22 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/priorityimpl.h b/cpukit/posix/include/rtems/posix/priorityimpl.h
index 169254d..3835ee9 100644
--- a/cpukit/posix/include/rtems/posix/priorityimpl.h
+++ b/cpukit/posix/include/rtems/posix/priorityimpl.h
@@ -19,7 +19,7 @@
 #ifndef _RTEMS_POSIX_PRIORITYIMPL_H
 #define _RTEMS_POSIX_PRIORITYIMPL_H
-#include <rtems/score/priority.h>
+#include <rtems/score/scheduler.h>
 #ifdef __cplusplus
 extern "C" {
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 5f33e0b..84ea806 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -38,6 +38,7 @@
 #define _RTEMS_RTEMS_TASKS_H
 #include <rtems/rtems/event.h>
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index b7c2f44..95f29fd 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -883,6 +883,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
         CONFIGURE_MAXIMUM_PRIORITY + 1 \
+    /** Configure the controls for this scheduler instance */
     #define CONFIGURE_SCHEDULER_CONTROLS \
       RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( \
         dflt, \
@@ -3350,18 +3351,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     CONFIGURE_MINIMUM_TASK_STACK_SIZE;
-   * This variable specifies the maximum priority value that
-   * a task may have.  This must be a power of 2 between 4
-   * and 256 and is specified in terms of Classic API
-   * priority values.
-   * NOTE: This is left as a simple uint8_t so it can be externed as
-   *       needed without requring being high enough logical to
-   *       include the full configuration table.
-  uint8_t rtems_maximum_priority = CONFIGURE_MAXIMUM_PRIORITY;
    * This is the primary Configuration Table for this application.
   const rtems_configuration_table Configuration = {
diff --git a/cpukit/sapi/include/rtems/scheduler.h b/cpukit/sapi/include/rtems/scheduler.h
index 39dff90..0b20aab 100644
--- a/cpukit/sapi/include/rtems/scheduler.h
+++ b/cpukit/sapi/include/rtems/scheduler.h
@@ -5,7 +5,7 @@
- * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2014, 2016 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -70,6 +70,7 @@
       &RTEMS_SCHEDULER_CONTEXT_CBS_NAME( name ).Base, \
       SCHEDULER_CBS_ENTRY_POINTS, \
+      SCHEDULER_CBS_MAXIMUM_PRIORITY, \
       ( obj_name ) \
 #endif
@@ -87,6 +88,7 @@
       &RTEMS_SCHEDULER_CONTEXT_EDF_NAME( name ).Base, \
       SCHEDULER_EDF_ENTRY_POINTS, \
+      SCHEDULER_EDF_MAXIMUM_PRIORITY, \
       ( obj_name ) \
 #endif
@@ -107,6 +109,9 @@
       &RTEMS_SCHEDULER_CONTEXT_PRIORITY_NAME( name ).Base.Base, \
       SCHEDULER_PRIORITY_ENTRY_POINTS, \
+      RTEMS_ARRAY_SIZE( \
+        RTEMS_SCHEDULER_CONTEXT_PRIORITY_NAME( name ).Ready \
+      ) - 1, \
       ( obj_name ) \
 #endif
@@ -127,6 +132,9 @@
       &RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP_NAME( name ).Base.Base.Base, \
       SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS, \
+        RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP_NAME( name ).Ready \
+      ) - 1, \
       ( obj_name ) \
 #endif
@@ -147,6 +155,9 @@
       &RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP_NAME( name ).Base.Base.Base, \
       SCHEDULER_PRIORITY_SMP_ENTRY_POINTS, \
+        RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP_NAME( name ).Ready \
+      ) - 1, \
       ( obj_name ) \
 #endif
@@ -167,6 +178,9 @@
       &RTEMS_SCHEDULER_CONTEXT_STRONG_APA_NAME( name ).Base.Base.Base, \
       SCHEDULER_STRONG_APA_ENTRY_POINTS, \
+        RTEMS_SCHEDULER_CONTEXT_STRONG_APA_NAME( name ).Ready \
+      ) - 1, \
       ( obj_name ) \
 #endif
@@ -185,6 +199,7 @@
       &RTEMS_SCHEDULER_CONTEXT_SIMPLE_NAME( name ).Base, \
       SCHEDULER_SIMPLE_ENTRY_POINTS, \
+      SCHEDULER_SIMPLE_MAXIMUM_PRIORITY, \
       ( obj_name ) \
 #endif
@@ -203,6 +218,7 @@
       &RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP_NAME( name ).Base.Base, \
       SCHEDULER_SIMPLE_SMP_ENTRY_POINTS, \
+      SCHEDULER_SIMPLE_SMP_MAXIMUM_PRIORITY, \
       ( obj_name ) \
 #endif
diff --git a/cpukit/score/include/rtems/score/priority.h b/cpukit/score/include/rtems/score/priority.h
index 0a772f6..38f3995 100644
--- a/cpukit/score/include/rtems/score/priority.h
+++ b/cpukit/score/include/rtems/score/priority.h
@@ -72,14 +72,6 @@ typedef uint32_t   Priority_Control;
   #define PRIORITY_DEFAULT_MAXIMUM      255
 #endif
-/** This defines the lowest (least important) thread priority. */
-#define PRIORITY_MAXIMUM      rtems_maximum_priority
- *  This variable contains the configured number of priorities
-extern uint8_t rtems_maximum_priority;
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index 5296644..1e6236f 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -201,6 +201,14 @@ struct Scheduler_Control {
   Scheduler_Operations Operations;
+   * @brief The maximum priority value of this scheduler.
+   * It defines the lowest (least important) thread priority for this
+   * scheduler.  For example the idle threads have this priority.
+  Priority_Control maximum_priority;
    * @brief The scheduler name.
   uint32_t name;
@@ -555,6 +563,12 @@ void _Scheduler_default_Start_idle(
   #define SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY
 #endif
+ * @brief This defines the lowest (least important) thread priority of the
+ * first scheduler instance.
+#define PRIORITY_MAXIMUM ( _Scheduler_Table[ 0 ].maximum_priority )
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulercbs.h b/cpukit/score/include/rtems/score/schedulercbs.h
index 5558d6e..e390532 100644
--- a/cpukit/score/include/rtems/score/schedulercbs.h
+++ b/cpukit/score/include/rtems/score/schedulercbs.h
@@ -39,6 +39,8 @@ extern "C" {
+#define SCHEDULER_CBS_MAXIMUM_PRIORITY SCHEDULER_EDF_MAXIMUM_PRIORITY
  *  Entry points for the Constant Bandwidth Server Scheduler.
diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
index 9b0d1b4..137ea3a 100644
--- a/cpukit/score/include/rtems/score/scheduleredf.h
+++ b/cpukit/score/include/rtems/score/scheduleredf.h
@@ -35,6 +35,8 @@ extern "C" {
+#define SCHEDULER_EDF_MAXIMUM_PRIORITY 255
  *  Entry points for the Earliest Deadline First Scheduler.
diff --git a/cpukit/score/include/rtems/score/schedulersimple.h b/cpukit/score/include/rtems/score/schedulersimple.h
index 201c1b6..a546ed6 100644
--- a/cpukit/score/include/rtems/score/schedulersimple.h
+++ b/cpukit/score/include/rtems/score/schedulersimple.h
@@ -32,6 +32,8 @@ extern "C" {
+#define SCHEDULER_SIMPLE_MAXIMUM_PRIORITY 255
  *  Entry points for Scheduler Simple
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index 11310c6..342a574 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -54,6 +54,8 @@ typedef struct {
   Chain_Control         Ready;
 } Scheduler_simple_SMP_Context;
+#define SCHEDULER_SIMPLE_SMP_MAXIMUM_PRIORITY 255
  * @brief Entry points for the Simple SMP Scheduler.
1.8.4.5
