[PATCH 02/15] score: Use _RBTree_Insert_inline()
Fri May 20 13:33:39 UTC 2016
Use _RBTree_Insert_inline() for priority thread queues.
Update #2556.
 cpukit/score/include/rtems/score/threadqimpl.h | 15 --------------
 cpukit/score/src/threadq.c                     | 21 -------------------
 cpukit/score/src/threadqops.c                  | 28 ++++++++++++++++++++------
 3 files changed, 22 insertions(+), 42 deletions(-)
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index ec222bd..03879fc 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -826,21 +826,6 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Boost_priority(
 #endif
- * @brief Compare two thread's priority for RBTree Insertion.
- * @param[in] left points to the left thread's RBnode
- * @param[in] right points to the right thread's RBnode
- * @retval 1 The @a left node is more important than @a right node.
- * @retval 0 The @a left node is of equal importance with @a right node.
- * @retval 1 The @a left node is less important than @a right node.
-RBTree_Compare_result _Thread_queue_Compare_priority(
-  const RBTree_Node *left,
-  const RBTree_Node *right
 #if defined(RTEMS_MULTIPROCESSING)
 void _Thread_queue_MP_callout_do_nothing(
   Thread_Control *the_proxy,
diff --git a/cpukit/score/src/threadq.c b/cpukit/score/src/threadq.c
index fdb2bee..ca2b900 100644
--- a/cpukit/score/src/threadq.c
+++ b/cpukit/score/src/threadq.c
@@ -64,27 +64,6 @@ RTEMS_STATIC_ASSERT(
 #endif /* HAVE_STRUCT__THREAD_QUEUE_QUEUE */
-  const Thread_Control *left_thread;
-  const Thread_Control *right_thread;
-  Priority_Control      left_prio;
-  Priority_Control      right_prio;
-  left_thread = THREAD_RBTREE_NODE_TO_THREAD( left );
-  right_thread = THREAD_RBTREE_NODE_TO_THREAD( right );
-  left_prio = left_thread->current_priority;
-  right_prio = right_thread->current_priority;
-   * SuperCore priorities use lower numbers to indicate greater importance.
-  return ( left_prio > right_prio ) - ( left_prio < right_prio );
 void _Thread_queue_Initialize( Thread_queue_Control *the_thread_queue )
   _Thread_queue_Queue_initialize( &the_thread_queue->Queue );
diff --git a/cpukit/score/src/threadqops.c b/cpukit/score/src/threadqops.c
index 5a82aaa..c3221b9 100644
--- a/cpukit/score/src/threadqops.c
+++ b/cpukit/score/src/threadqops.c
@@ -167,6 +167,20 @@ static Thread_queue_Priority_queue *_Thread_queue_Priority_queue(
 #endif
+static bool _Thread_queue_Priority_less(
+  const void        *left,
+  const RBTree_Node *right
+  const Priority_Control *the_left;
+  const Thread_Control   *the_right;
+  the_left = left;
+  the_right = THREAD_RBTREE_NODE_TO_THREAD( right );
+  return *the_left < the_right->current_priority;
 static void _Thread_queue_Priority_priority_change(
   Thread_Control     *the_thread,
   Priority_Control    new_priority,
@@ -184,11 +198,11 @@ static void _Thread_queue_Priority_priority_change(
     &priority_queue->Queue,
     &the_thread->Wait.Node.RBTree
-  _RBTree_Insert(
+  _RBTree_Insert_inline(
     &the_thread->Wait.Node.RBTree,
-    _Thread_queue_Compare_priority,
-    false
+    &new_priority,
+    _Thread_queue_Priority_less
@@ -210,6 +224,7 @@ static void _Thread_queue_Priority_do_enqueue(
   Thread_queue_Priority_queue *priority_queue =
     _Thread_queue_Priority_queue( heads, the_thread );
+  Priority_Control current_priority;
 #if defined(RTEMS_SMP)
   if ( _RBTree_Is_empty( &priority_queue->Queue ) ) {
@@ -217,11 +232,12 @@ static void _Thread_queue_Priority_do_enqueue(
 #endif
-  _RBTree_Insert(
+  current_priority = the_thread->current_priority;
-    false
+    &current_priority,
1.8.4.5
