[PATCH 03/15] posix: Add and use _POSIX_Get_object_body()
    Gedare Bloom
    gedare at rtems.org
    Fri May 20 14:04:32 UTC 2016
Will doxygen pick up comments for macros? if so, the new "function"
should be documented properly.
On Fri, May 20, 2016 at 9:33 AM, Sebastian Huber
>  cpukit/posix/include/rtems/posix/posixapi.h | 29 +++++++++++++++++++
>  cpukit/posix/src/condget.c                  | 43 +++++----------------------
>  cpukit/posix/src/mutexget.c                 | 45 +++++------------------------
>  cpukit/posix/src/prwlockinit.c              | 44 +++++-----------------------
>  4 files changed, 50 insertions(+), 111 deletions(-)
> diff --git a/cpukit/posix/include/rtems/posix/posixapi.h b/cpukit/posix/include/rtems/posix/posixapi.h
> index 0348e28..0001d98 100644
> --- a/cpukit/posix/include/rtems/posix/posixapi.h
> +++ b/cpukit/posix/include/rtems/posix/posixapi.h
> @@ -21,6 +21,7 @@
>  #include <rtems/config.h>
>  #include <rtems/score/assert.h>
> +#include <rtems/score/apimutex.h>
>  #include <rtems/score/objectimpl.h>
> @@ -59,6 +60,34 @@ RTEMS_INLINE_ROUTINE int _POSIX_Get_by_name_error(
>    return _POSIX_Get_by_name_error_table[ error ];
> + * Function body to get the object for the specified indentifier.  Performs
> + * automatic initialization if requested and necessary.  This is an ugly macro,
> + * since C lacks support for templates.
> +#define _POSIX_Get_object_body( \
> +  type, \
> +  id, \
> +  lock_context, \
> +  info, \
> +  initializer, \
> +  init \
> +  Objects_Control *the_object; \
> +  if ( id == NULL ) { \
> +    return NULL; \
> +  the_object = _Objects_Get_local( (Objects_Id) *id, lock_context, info ); \
> +  if ( the_object == NULL ) { \
> +    _Once_Lock(); \
> +    if ( *id == initializer ) { \
> +      init( id, NULL ); \
> +    _Once_Unlock(); \
> +  return (type *) the_object
>  #endif
> diff --git a/cpukit/posix/src/condget.c b/cpukit/posix/src/condget.c
> index b89566a..5676de8 100644
> --- a/cpukit/posix/src/condget.c
> +++ b/cpukit/posix/src/condget.c
> @@ -12,48 +12,19 @@
>  #endif
>  #include <rtems/posix/condimpl.h>
> -static bool _POSIX_Condition_variables_Check_id_and_auto_init(
> -  pthread_cond_t *cond
> -  if ( cond == NULL ) {
> -    return false;
> -  if ( *cond == PTHREAD_COND_INITIALIZER ) {
> -    int eno;
> -    _Once_Lock();
> -      eno = pthread_cond_init( cond, NULL );
> -    } else {
> -      eno = 0;
> -    _Once_Unlock();
> -    if ( eno != 0 ) {
> -      return false;
> -  return true;
> +#include <rtems/posix/posixapi.h>
>  POSIX_Condition_variables_Control *_POSIX_Condition_variables_Get(
>    pthread_cond_t   *cond,
>    ISR_lock_Context *lock_context
> -  if ( !_POSIX_Condition_variables_Check_id_and_auto_init( cond ) ) {
> -    return NULL;
> -  return (POSIX_Condition_variables_Control *) _Objects_Get_local(
> -    (Objects_Id) *cond,
> +  _POSIX_Get_object_body(
> +    POSIX_Condition_variables_Control,
> +    cond,
>      lock_context,
> -    &_POSIX_Condition_variables_Information
> +    &_POSIX_Condition_variables_Information,
> +    PTHREAD_COND_INITIALIZER,
> +    pthread_cond_init
> diff --git a/cpukit/posix/src/mutexget.c b/cpukit/posix/src/mutexget.c
> index 9d34ecb..97d6dff 100644
> --- a/cpukit/posix/src/mutexget.c
> +++ b/cpukit/posix/src/mutexget.c
> @@ -19,50 +19,19 @@
>  #endif
>  #include <rtems/posix/muteximpl.h>
> -#include <rtems/score/apimutex.h>
> -static bool _POSIX_Mutex_Check_id_and_auto_init( pthread_mutex_t *mutex )
> -  if ( mutex == NULL ) {
> -    return false;
> -  if ( *mutex == PTHREAD_MUTEX_INITIALIZER ) {
> -    int eno;
> -    _Once_Lock();
> -      eno = pthread_mutex_init( mutex, NULL );
> -    } else {
> -      eno = 0;
> -    _Once_Unlock();
> -    if ( eno != 0 ) {
> -      return false;
> -  return true;
>  POSIX_Mutex_Control *_POSIX_Mutex_Get_interrupt_disable(
>    pthread_mutex_t  *mutex,
> -  Objects_Locations location;
> -  if ( !_POSIX_Mutex_Check_id_and_auto_init( mutex ) ) {
> -    return NULL;
> -  return (POSIX_Mutex_Control *) _Objects_Get_isr_disable(
> +    POSIX_Mutex_Control,
> +    mutex,
> +    lock_context,
>      &_POSIX_Mutex_Information,
> -    (Objects_Id) *mutex,
> -    &location,
> -    lock_context
> +    PTHREAD_MUTEX_INITIALIZER,
> +    pthread_mutex_init
> diff --git a/cpukit/posix/src/prwlockinit.c b/cpukit/posix/src/prwlockinit.c
> index 8847c17..fcf4e29 100644
> --- a/cpukit/posix/src/prwlockinit.c
> +++ b/cpukit/posix/src/prwlockinit.c
> @@ -21,50 +21,20 @@
>  #endif
>  #include <rtems/posix/rwlockimpl.h>
> -static bool _POSIX_RWLock_Check_id_and_auto_init(
> -  pthread_mutex_t *rwlock
> -  if ( rwlock == NULL ) {
> -    return false;
> -  if ( *rwlock == PTHREAD_RWLOCK_INITIALIZER ) {
> -    int eno;
> -    _Once_Lock();
> -      eno = pthread_rwlock_init( rwlock, NULL );
> -    } else {
> -      eno = 0;
> -    _Once_Unlock();
> -    if ( eno != 0 ) {
> -      return false;
> -  return true;
>  POSIX_RWLock_Control *_POSIX_RWLock_Get(
>    pthread_rwlock_t *rwlock,
> -  if ( !_POSIX_RWLock_Check_id_and_auto_init( rwlock ) ) {
> -    return NULL;
> -  return (POSIX_RWLock_Control *) _Objects_Get_local(
> -    *rwlock,
> +    POSIX_RWLock_Control,
> +    rwlock,
>      lock_context,
> -    &_POSIX_RWLock_Information
> +    &_POSIX_RWLock_Information,
> +    PTHREAD_RWLOCK_INITIALIZER,
> +    pthread_rwlock_init
> 1.8.4.5
> devel mailing list
> devel at rtems.org
