Qemu System Error
Olufowobi, Habeeb
habeeb.olufowobi at bison.howard.edu
Fri May 20 17:03:56 UTC 2016
Hi Joel,
I was trying to run the ticker.exe on RTEMS 4.12.
Regards,
Habeeb
On Fri, May 20, 2016 at 12:53 PM, Joel Sherrill <joel at rtems.org> wrote:
> What application and what's the RTEMS configuration?
> The error code is internal and there is an enumeration for them. Check
> that list for what happened. Looks like something isn't quite right in
> the application configuration.
> Y
> On Fri, May 20, 2016 at 11:41 AM, Olufowobi, Habeeb <
> habeeb.olufowobi at bison.howard.edu> wrote:
>> I was able to get qemu to work using RSB build. I tried to use the
>> lm4f120 BSP but I got the error message below. Any Idea on how I can fix
>> this? Also, I will like to know if this error is related to the patches in
>> the BSP directory as I am using a newer version of qemu checkout by RSB.
>> (gdb) bt
>> #0 0x000068c8 in _Terminate (the_source=the_source at entry=INTERNAL_ERROR_CORE,
>> is_internal=is_internal at entry=true, the_error=the_error at entry=2)
>> at ../../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:52
>> #1 0x000090ac in _Workspace_Handler_initialization (
>> areas=areas at entry=0x200010e0, area_count=area_count at entry=1,
>> extend=extend at entry=0x0 <bsp_start_vector_table_begin>)
>> at
>> ../../../../../../../rtems/c/src/../../cpukit/score/src/wkspace.c:137
>> #2 0x00000a84 in bsp_work_area_initialize_default (
>> area_begin=<optimized out>, area_size=<optimized out>)
>> at ../../../../../.././lm4f120/lib/include/bsp/bootcard.h:147
>> #3 bsp_work_area_initialize ()
>> at
>> ../../../../../../../../../rtems/c/src/lib/libbsp/arm/lm3s69xx/../../shared/bspgetworkarea.c:61
>> #4 0x00005ddc in rtems_initialize_executive ()
>> at ../../../../../../../rtems/c/src/../../cpukit/sapi/src/exinit.c:138
>> #5 0x00000a60 in boot_card (cmdline=<optimized out>)
>> at
>> ../../../../../../../../../rtems/c/src/lib/libbsp/arm/lm3s69xx/../../shared/bootcard.c:78
>> #6 0x00000116 in bsp_start_hook_0_done ()
>> at
>> ../../../../../../../../../rtems/c/src/lib/libbsp/arm/lm3s69xx/../shared/start/start.S:356
>> Backtrace stopped: previous frame identical to this frame (corrupt stack?)
>> On Sat, May 14, 2016 at 6:39 PM, Olufowobi, Habeeb <
>>> Hello
>>> I am trying to run the xilinx_zynq and lm4f BSP on the qemu but I have
>>> been getting the error message below. The only option I have seen to
>>> resolve this error was to disable libusb during configuration but wasn't
>>> working for me.
>>> Any ideas on how to fix this error?
>>> qemu-system-arm: symbol lookup error: qemu-system-arm: undefined symbol:
>>> libusb_get_port_numbers
>>> Thanks
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160520/dfdd3148/attachment.html>
