[PATCH 0/5] Raspberry Pi VideoCore support for console on HDMI output
ppisa4lists at pikron.com ppisa4lists at pikron.com
Sat May 21 10:54:54 UTC 2016
The series updates and cleans YANG Qiao GSoC 2015 work for actual
RTEMS 4.12 development version.
The changes require that VideoCore firmware is running even
if video output is not used because mailbox based communication
with VideoCore is used to obtain SD command line parameters
passed to the RTEMS application image and to limit RTEMS RAM
workarea to not go beyond VideoCore assigned memory start.
The two options configurable by "cmdline.txt" file read
and made accessible by VideoCore firmware are present
  --video=
     possible values
         auto  - select mode automatically according to the connected monitor
         off  (or none) - disable video support
         width x height with optional bpp - for example 800x600 or 800x600-32
  --console=
     fbcons - redirect RTEMS console output to the connected monitor
         if --video= is not specified/enabled or monitor is not detected
         then output stays to be connected to the UART
Typical "cmdline.txt" content for testing
  --video=auto --console=fbcons
WARNING: the used VideoCore service for command line arguments retrieval
         returns only these arguments setup in "cmdline.txt".
         Arguments provided to U-boot or other loader are ignored.
Code has been tested or Raspberry Pi 1 with U-boot + TFTP and with direct
boot from SD card with and without monitor connected.
Pavel Pisa (2):
  arm/raspberrypi: cmdline enhancement and early access workaround.
  arm/raspberrypi: move MMU in front of application image to respect
    variable memory size.
YANG Qiao (3):
  arm/raspberrypi: add VideoCore framebuffer without initialization
  arm/raspberrypi: add video outchar support for rpi bsp
  arm/raspberrypi: add fbcons support for rpi bsp
 c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |   13 +-
 .../arm/raspberrypi/console/console-config.c       |   12 +-
 .../arm/raspberrypi/console/console_select.c       |  114 +
 c/src/lib/libbsp/arm/raspberrypi/console/fb.c      |  385 ++
 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c  |  184 +
 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h  |   47 +
 .../lib/libbsp/arm/raspberrypi/console/font_data.h | 4639 ++++++++++++++++++++
 c/src/lib/libbsp/arm/raspberrypi/console/outch.c   |  411 ++
 c/src/lib/libbsp/arm/raspberrypi/include/bsp.h     |    9 +
 c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h  |   53 +
 c/src/lib/libbsp/arm/raspberrypi/preinstall.am     |    8 +
 .../arm/raspberrypi/startup/bspgetworkarea.c       |   74 +
 .../libbsp/arm/raspberrypi/startup/bspstarthooks.c |    4 +
 c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c |   12 +-
 c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds  |    6 +-
 c/src/lib/libbsp/arm/raspberrypi/startup/mminit.c  |   31 +
 16 files changed, 5991 insertions(+), 11 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/console_select.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fb.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/font_data.h
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/outch.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/bspgetworkarea.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/mminit.c
1.9.1
