[PATCH 2/5] arm/raspberrypi: add VideoCore framebuffer without initialization
ppisa4lists at pikron.com ppisa4lists at pikron.com
Sat May 21 10:54:56 UTC 2016
 c/src/lib/libbsp/arm/raspberrypi/Makefile.am      |   2 +
 c/src/lib/libbsp/arm/raspberrypi/console/fb.c     | 385 ++++++++++++++++++++++
 c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h |  53 +++
 c/src/lib/libbsp/arm/raspberrypi/preinstall.am    |   4 +
 4 files changed, 444 insertions(+)
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fb.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 258f8a0..285da4f 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -50,6 +50,7 @@ include_bsp_HEADERS += include/i2c.h
 include_bsp_HEADERS += include/spi.h
 include_bsp_HEADERS += include/mailbox.h
 include_bsp_HEADERS += include/vc.h
+include_bsp_HEADERS += include/rpi-fb.h
 include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
     ../../../libcpu/arm/shared/include/arm-cp15.h
@@ -114,6 +115,7 @@ libbsp_a_SOURCES += ../../shared/console_select.c
 libbsp_a_SOURCES += ../../shared/console_write.c
 libbsp_a_SOURCES += console/console-config.c
 libbsp_a_SOURCES += console/usart.c
+libbsp_a_SOURCES += console/fb.c
 # Mailbox
 libbsp_a_SOURCES += misc/mailbox.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/fb.c b/c/src/lib/libbsp/arm/raspberrypi/console/fb.c
new file mode 100644
index 0000000..ba285e7
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/fb.c
@@ -0,0 +1,385 @@
+ * @file
+ * @ingroup raspberrypi
+ * @brief framebuffer support.
+ * Copyright (c) 2015 Yang Qiao
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE
+#include <stdlib.h>
+#include <stdio.h>
+#include <errno.h>
+#include <sys/types.h>
+#include <bsp.h>
+#include <bsp/raspberrypi.h>
+#include <bsp/mailbox.h>
+#include <bsp/vc.h>
+#include <bsp/rpi-fb.h>
+#include <libcpu/arm-cp15.h>
+#include <rtems.h>
+#include <rtems/libio.h>
+#include <rtems/fb.h>
+#include <rtems/framebuffer.h>
+#include <rtems/score/atomic.h>
+#define SCREEN_WIDTH 1024
+#define SCREEN_HEIGHT 768
+#define BPP 32
+/* flag to limit driver to protect against multiple opens */
+static Atomic_Flag driver_mutex;
+ * screen information for the driver (fb0).
+static struct fb_var_screeninfo fb_var_info = {
+  .xres                = SCREEN_WIDTH,
+  .yres                = SCREEN_HEIGHT,
+  .bits_per_pixel      = BPP
+static struct fb_fix_screeninfo fb_fix_info = {
+  .smem_start          = (void *) NULL,
+  .smem_len            = 0,
+  .type                = FB_TYPE_PACKED_PIXELS,
+  .visual              = FB_VISUAL_TRUECOLOR,
+  .line_length         = 0
+typedef enum {
+    NO_SUITABLE_MODE    = -1,
+    BAD_FORMAT          = -2,
+    AUTO_SELECT         = -3,
+    DONT_INIT           = -4,
+    NO_MODE_REQ         = -5,
+} mode_err_ret_val;
+int raspberrypi_get_fix_screen_info( struct fb_fix_screeninfo *info )
+  *info = fb_fix_info;
+  return 0;
+int raspberrypi_get_var_screen_info( struct fb_var_screeninfo *info )
+  *info = fb_var_info;
+  return 0;
+ * @brief Find mode given in string format.
+ *  expected format
+ *  <resX>x<resY>[-<bpp>]
+ *  numbers <resX>, <resY> and <bpp> are decadic
+ * @param[out] fb_var_ptr pointer to variable mode part filled by function
+ * @param[in] video_string string to be parsed
+ * @retval video mode number to be set
+ * @retval -1 no suitable mode found
+ * @retval -2 bad format of the video_string
+ * @retval -3 automatic mode selection requested
+ * @retval -4 request to not initialize graphics
+ * @retval -5 no mode requested/empty video string
+static int
+parse_mode_from_string(struct fb_var_screeninfo *fb_var_ptr,
+                      const char *video_string)
+  const char* opt;
+  char* endptr;
+  uint32_t width;
+  uint32_t height;
+  uint32_t bpp = 0;
+  opt = video_string;
+  if (opt == NULL)
+    return NO_MODE_REQ;
+  if (strncmp(opt, "auto", 4) == 0)
+    return AUTO_SELECT;
+  if (strncmp(opt, "none", 4) == 0 ||
+      strncmp(opt, "off", 3) == 0)
+    return DONT_INIT;
+  width = strtol(opt, &endptr, 10);
+  if (*endptr != 'x')
+    return BAD_FORMAT;
+  opt = endptr + 1;
+  height = strtol(opt, &endptr, 10);
+  switch (*endptr)
+    case '-':
+      opt = endptr + 1;
+      endptr = NULL;
+      bpp = strtol(opt, &endptr, 10);
+      if ((endptr == opt) || (endptr == NULL))
+      if (*endptr && (*endptr != ' '))
+      break;
+    case ' ':
+    case 0:
+      break;
+    default:
+  fb_var_ptr->xres    = width;
+  fb_var_ptr->yres    = height;
+  if (bpp != 0)
+    fb_var_ptr->bits_per_pixel = bpp;
+  return 0;
+static int
+find_mode_from_vc(void)
+  bcm2835_get_display_size_entries entries;
+  bcm2835_mailbox_get_display_size(&entries);
+  unsigned int width = entries.width;
+  unsigned int height = entries.height;
+  if (width == 0 || height == 0)
+    fb_var_info.xres    = SCREEN_WIDTH;
+    fb_var_info.yres    = SCREEN_HEIGHT;
+  else
+    fb_var_info.xres     = width;
+    fb_var_info.yres     = height;
+  return 0;
+static bool
+hdmi_is_present(void)
+  if(entries.width == 0x290 && entries.height ==0x1A0 )
+    return false;
+  else
+    return true;
+int
+raspberrypi_fb_init(void)
+  int mode_from_cmdline;
+  if (fb_fix_info.smem_start != NULL)
+    return RASPBERRYPI_FB_INIT_ALREADY_INITIALIZED;
+  if (hdmi_is_present() == false)
+    return RASPBERRYPI_FB_INIT_NO_DISPLAY;
+  mode_from_cmdline = parse_mode_from_string(&fb_var_info,
+                                             rpi_cmdline_get_arg("--video="));
+  switch (mode_from_cmdline)
+    case BAD_FORMAT:
+      return RASPBERRYPI_FB_INIT_CMDLINE_BAD_FORMAT;
+    case AUTO_SELECT:
+      break;
+    case DONT_INIT:
+      return RASPBERRYPI_FB_INIT_CMDLINE_DONT_INIT;
+    case NO_MODE_REQ:
+      return RASPBERRYPI_FB_INIT_CMDLINE_NO_MODE_REQ;
+  if (mode_from_cmdline)
+    if(find_mode_from_vc())
+      return RASPBERRYPI_FB_INIT_MODE_PROBE_ERROR;
+  bcm2835_init_frame_buffer_entries  init_frame_buffer_entries;
+  init_frame_buffer_entries.xres = fb_var_info.xres;
+  init_frame_buffer_entries.yres = fb_var_info.yres;
+  init_frame_buffer_entries.xvirt = fb_var_info.xres;
+  init_frame_buffer_entries.yvirt = fb_var_info.yres;
+  init_frame_buffer_entries.depth = fb_var_info.bits_per_pixel;
+  init_frame_buffer_entries.pixel_order = bcm2835_mailbox_pixel_order_rgb;
+  init_frame_buffer_entries.alpha_mode = bcm2835_mailbox_alpha_mode_0_opaque;
+  init_frame_buffer_entries.voffset_x = 0;
+  init_frame_buffer_entries.voffset_y = 0;
+  init_frame_buffer_entries.overscan_left = 0;
+  init_frame_buffer_entries.overscan_right = 0;
+  init_frame_buffer_entries.overscan_top = 0;
+  init_frame_buffer_entries.overscan_bottom = 0;
+  bcm2835_mailbox_init_frame_buffer(&init_frame_buffer_entries);
+  bcm2835_get_pitch_entries get_pitch_entries;
+  bcm2835_mailbox_get_pitch(&get_pitch_entries);
+  fb_var_info.xres = init_frame_buffer_entries.xres;
+  fb_var_info.yres = init_frame_buffer_entries.yres;
+  fb_var_info.bits_per_pixel = init_frame_buffer_entries.depth;
+  fb_fix_info.smem_start = (void *)init_frame_buffer_entries.base;
+  fb_fix_info.smem_len = init_frame_buffer_entries.size;
+  fb_fix_info.line_length = get_pitch_entries.pitch;
+  if (fb_fix_info.smem_start == NULL)
+    return RASPBERRYPI_FB_INIT_START_ADDR_UNKNOWN;
+  arm_cp15_set_translation_table_entries((void *)fb_fix_info.smem_start,
+                                        (void *)fb_fix_info.smem_start +
+                                        fb_fix_info.smem_len,
+                                        ARMV7_MMU_DATA_READ_WRITE_CACHED);
+  return RASPBERRYPI_FB_INIT_OK;
+ * fbds device driver initialize entry point.
+rtems_device_driver
+frame_buffer_initialize (rtems_device_major_number major,
+                 rtems_device_minor_number minor, void *arg)
+  rtems_status_code status;
+  /* register the devices */
+  status = rtems_io_register_name (FRAMEBUFFER_DEVICE_0_NAME, major, 0);
+  if (status != RTEMS_SUCCESSFUL) {
+    printk ("[!] error registering framebuffer\n");
+    rtems_fatal_error_occurred (status);
+  _Atomic_Flag_clear(&driver_mutex, ATOMIC_ORDER_RELEASE);
+  return RTEMS_SUCCESSFUL;
+ * fbds device driver open operation.
+frame_buffer_open (rtems_device_major_number major,
+  if (_Atomic_Flag_test_and_set(&driver_mutex, ATOMIC_ORDER_ACQUIRE) != 0 ) {
+    printk( "FB_CIRRUS could not lock driver_mutex\n" );
+    return RTEMS_UNSATISFIED;
+  memset ((void *)fb_fix_info.smem_start, 0, fb_fix_info.smem_len);
+ * fbds device driver close operation.
+frame_buffer_close (rtems_device_major_number major,
+  /* restore previous state.  for VGA this means return to text mode.
+   * leave out if graphics hardware has been initialized in
+   * frame_buffer_initialize() */
+ * fbds device driver read operation.
+frame_buffer_read (rtems_device_major_number major,
+  rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *)arg;
+  rw_args->bytes_moved =
+    ((rw_args->offset + rw_args->count) > fb_fix_info.smem_len ) ?
+    (fb_fix_info.smem_len - rw_args->offset) :rw_args->count;
+  memcpy( rw_args->buffer,
+          (const void *) (fb_fix_info.smem_start + rw_args->offset),
+          rw_args->bytes_moved);
+ * fbds device driver write operation.
+frame_buffer_write (rtems_device_major_number major,
+    (fb_fix_info.smem_len - rw_args->offset) : rw_args->count;
+  memcpy( (void *) (fb_fix_info.smem_start + rw_args->offset),
+          rw_args->buffer,
+ * ioctl entry point.
+frame_buffer_control (rtems_device_major_number major,
+  rtems_libio_ioctl_args_t *args = arg;
+  /* XXX check minor */
+  switch (args->command) {
+  case FBIOGET_VSCREENINFO:
+    memcpy (args->buffer, &fb_var_info, sizeof (fb_var_info));
+    args->ioctl_return = 0;
+    break;
+  case FBIOGET_FSCREENINFO:
+    memcpy (args->buffer, &fb_fix_info, sizeof (fb_fix_info));
+    break;
+  case FBIOGETCMAP:
+    break;
+  case FBIOPUTCMAP:
+    break;
+  default:
+    break;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h b/c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h
index 0000000..3d2e5e9
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h
@@ -0,0 +1,53 @@
+ * @file
+ * @ingroup raspberrypi_fb
+ * @brief framebuffer support and setup
+#ifndef LIBBSP_ARM_RASPBERRYPI_FB_H
+#define LIBBSP_ARM_RASPBERRYPI_FB_H
+ * @defgroup raspberrypi_fb
+ * @ingroup arm_raspberrypi
+ * @brief Framebuffer support and setup
+enum raspberrypi_fb_init_result {
+  RASPBERRYPI_FB_INIT_OK = 0,
+  RASPBERRYPI_FB_INIT_ALREADY_INITIALIZED = 1,
+  RASPBERRYPI_FB_INIT_GENERIC_ERROR = -1,
+  RASPBERRYPI_FB_INIT_NO_DISPLAY = -2,
+  RASPBERRYPI_FB_INIT_CMDLINE_BAD_FORMAT = -3,
+  RASPBERRYPI_FB_INIT_CMDLINE_DONT_INIT = -4,
+  RASPBERRYPI_FB_INIT_CMDLINE_NO_MODE_REQ = -5,
+  RASPBERRYPI_FB_INIT_MODE_PROBE_ERROR = -6,
+  RASPBERRYPI_FB_INIT_START_ADDR_UNKNOWN = -7,
+int raspberrypi_fb_init(void);
+int raspberrypi_get_fix_screen_info( struct fb_fix_screeninfo *info );
+int raspberrypi_get_var_screen_info( struct fb_var_screeninfo *info );
+#endif /* LIBBSP_ARM_RASPBERRYPI_FB_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
index 979cba3..cbfa79f 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
@@ -154,6 +154,10 @@ $(PROJECT_INCLUDE)/bsp/vc.h: include/vc.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vc.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vc.h
+$(PROJECT_INCLUDE)/bsp/rpi-fb.h: include/rpi-fb.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/rpi-fb.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/rpi-fb.h
 $(PROJECT_INCLUDE)/libcpu/cache_.h: ../../../libcpu/arm/shared/include/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
1.9.1
