[PATCH 32/32] score: Remove the Giant lock
Gedare Bloom
gedare at rtems.org
Thu May 19 23:04:38 UTC 2016
Nice work. Just a few small nits mostly related to doc.
On Wed, May 18, 2016 at 5:20 AM, Sebastian Huber
> Update #2555.
> cpukit/score/Makefile.am | 5 -
> cpukit/score/include/rtems/score/percpu.h | 6 -
> cpukit/score/include/rtems/score/threaddispatch.h | 175 ----------------------
> cpukit/score/src/smp.c | 9 --
> cpukit/score/src/threaddisabledispatch.c | 60 --------
> cpukit/score/src/threaddispatchdisablelevel.c | 140 -----------------
> cpukit/score/src/threadenabledispatch.c | 32 ----
> testsuites/smptests/Makefile.am | 1 -
> testsuites/smptests/configure.ac | 1 -
> testsuites/smptests/smpfatal03/Makefile.am | 19 ---
> testsuites/smptests/smpfatal03/init.c | 151 -------------------
> testsuites/smptests/smpfatal03/smpfatal03.doc | 12 --
> testsuites/smptests/smpfatal03/smpfatal03.scn | 2 -
> 13 files changed, 613 deletions(-)
> delete mode 100644 cpukit/score/src/threaddisabledispatch.c
> delete mode 100644 cpukit/score/src/threaddispatchdisablelevel.c
> delete mode 100644 cpukit/score/src/threadenabledispatch.c
> delete mode 100644 testsuites/smptests/smpfatal03/Makefile.am
> delete mode 100644 testsuites/smptests/smpfatal03/init.c
> delete mode 100644 testsuites/smptests/smpfatal03/smpfatal03.doc
> delete mode 100644 testsuites/smptests/smpfatal03/smpfatal03.scn
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index f5bf11c..0d2b395 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -296,7 +296,6 @@ libscore_a_SOURCES += src/rbtreereplace.c
> libscore_a_SOURCES += src/thread.c src/threadchangepriority.c \
> src/threadclearstate.c src/threadcreateidle.c \
> src/threaddispatch.c \
> - src/threadenabledispatch.c src/threaddisabledispatch.c \
> src/threadget.c src/threadhandler.c src/threadinitialize.c \
> src/threadloadenv.c \
> src/threadrestart.c src/threadsetpriority.c \
> @@ -312,10 +311,6 @@ libscore_a_SOURCES += src/threadtimeout.c
> libscore_a_SOURCES += src/threadwaitgetid.c
> libscore_a_SOURCES += src/threadyield.c
> -if HAS_SMP
> -libscore_a_SOURCES += src/threaddispatchdisablelevel.c
> -endif
> ## THREADQ_C_FILES
> libscore_a_SOURCES += src/threadq.c \
> src/threadqenqueue.c \
> diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
> index ea69cd6..55f799e 100644
> --- a/cpukit/score/include/rtems/score/percpu.h
> +++ b/cpukit/score/include/rtems/score/percpu.h
> @@ -393,12 +393,6 @@ typedef struct Per_CPU_Control {
> #endif
> - * @brief Context for the Giant lock acquire and release pair of this
> - * processor.
> - SMP_lock_Context Giant_lock_context;
> * @brief Bit field for SMP messages.
> * This bit field is not protected locks. Atomic operations are used to
> diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
> index be3883f..573d1be 100644
> --- a/cpukit/score/include/rtems/score/threaddispatch.h
> +++ b/cpukit/score/include/rtems/score/threaddispatch.h
> @@ -86,122 +86,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization( void )
> _Thread_Dispatch_disable_level = 1;
> -#if defined(RTEMS_SMP)
> - * @brief Acquires the giant lock.
> - * The giant lock is a recursive SMP lock protecting nearly all operating
> - * system services.
> - * This lock is implicitly acquired in
> - * _Thread_Dispatch_increment_disable_level().
> - * Thread dispatching must be disabled before the Giant lock can be acquired
> - * and must no be enabled while owning the Giant lock. The thread dispatch
> - * disable level is not altered by this function.
> - * @param[in] cpu_self The current processor.
> - void _Giant_Acquire( Per_CPU_Control *cpu_self );
> - * @brief Releases the giant lock.
> - * This lock is implicitly released in
> - * _Thread_Dispatch_decrement_disable_level().
> - * The thread dispatch disable level is not altered by this function.
> - void _Giant_Release( Per_CPU_Control *cpu_self );
> - * @brief Releases the giant lock completely if held by the executing processor.
> - * The only use case for this operation is in _SMP_Request_shutdown().
> - void _Giant_Drop( Per_CPU_Control *cpu_self );
> - * @brief Increments the thread dispatch level.
> - * This rountine increments the thread dispatch level
> - uint32_t _Thread_Dispatch_increment_disable_level(void);
> - * @brief Decrements the thread dispatch level.
> - * This routine decrements the thread dispatch level.
> - uint32_t _Thread_Dispatch_decrement_disable_level(void);
> -#else /* RTEMS_SMP */
> - * @brief Increase thread dispatch disable level.
> - RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_increment_disable_level(void)
> - uint32_t disable_level = _Thread_Dispatch_disable_level;
> -#if defined( RTEMS_PROFILING )
> - ISR_Level level;
> - _ISR_Local_disable( level );
> - _Profiling_Thread_dispatch_disable( _Per_CPU_Get(), disable_level );
> -#endif
> - ++disable_level;
> - _Thread_Dispatch_disable_level = disable_level;
> - _ISR_Local_enable( level );
> -#endif
> - return disable_level;
> - * @brief Decrease thread dispatch disable level.
> - RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_decrement_disable_level(void)
> - ISR_Level level;
> -#endif
> - --disable_level;
> - _Profiling_Thread_dispatch_enable( _Per_CPU_Get(), disable_level );
> -#endif
> - RTEMS_INLINE_ROUTINE void _Giant_Acquire( Per_CPU_Control *cpu_self )
> - (void) cpu_self;
> - RTEMS_INLINE_ROUTINE void _Giant_Release( Per_CPU_Control *cpu_self )
> - (void) cpu_self;
> -#endif /* RTEMS_SMP */
> * @brief Performs a thread dispatch if necessary.
> @@ -240,8 +124,6 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level );
> * @brief Disables thread dispatching inside a critical section (interrupts
> * disabled) with the current processor.
> - * This function does not acquire the Giant lock.
> * @param[in] lock_context The lock context of the corresponding
> * _ISR_lock_ISR_disable() that started the critical section.
> @@ -270,8 +152,6 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable_with_CPU(
> * disabled).
> @@ -287,8 +167,6 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable_critical(
> * @brief Disables thread dispatching.
> * @return The current processor.
> RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable( void )
> @@ -314,8 +192,6 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable( void )
> * May perfrom a thread dispatch if necessary as a side-effect.
> - * This function does not release the Giant lock.
> RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
> @@ -343,8 +219,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
> * @brief Unnests thread dispatching.
> RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest( Per_CPU_Control *cpu_self )
> @@ -352,55 +226,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest( Per_CPU_Control *cpu_self )
> --cpu_self->thread_dispatch_disable_level;
> - * @brief Disables thread dispatching and acquires the Giant lock.
> -#if defined ( __THREAD_DO_NOT_INLINE_DISABLE_DISPATCH__ )
> -void _Thread_Disable_dispatch( void );
> -#else
> -RTEMS_INLINE_ROUTINE void _Thread_Disable_dispatch( void )
> - _Thread_Dispatch_increment_disable_level();
> - RTEMS_COMPILER_MEMORY_BARRIER();
> -#endif
> -RTEMS_INLINE_ROUTINE void _Thread_Enable_dispatch_body( void )
> - Per_CPU_Control *cpu_self = _Per_CPU_Get();
> - _Giant_Release( cpu_self );
> - _Thread_Dispatch_enable( cpu_self );
> - * @brief Enables thread dispatching and releases the Giant lock.
> - * May perfrom a thread dispatch if necessary as a side-effect.
> -#if defined ( __THREAD_DO_NOT_INLINE_ENABLE_DISPATCH__ )
> - void _Thread_Enable_dispatch( void );
> -#else
> - /* inlining of enable dispatching must be true */
> - RTEMS_INLINE_ROUTINE void _Thread_Enable_dispatch( void )
> - _Thread_Enable_dispatch_body();
> -#endif
> - * @warning A thread dispatch is not performed as a side-effect. Use this
> - * function with
> -RTEMS_INLINE_ROUTINE void _Thread_Unnest_dispatch( void )
> - _Thread_Dispatch_decrement_disable_level();
> #ifdef __cplusplus
> diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
> index 85256b0..e26de42 100644
> --- a/cpukit/score/src/smp.c
> +++ b/cpukit/score/src/smp.c
> @@ -21,7 +21,6 @@
> #include <rtems/score/smpimpl.h>
> #include <rtems/score/assert.h>
> #include <rtems/score/schedulerimpl.h>
> -#include <rtems/score/threaddispatch.h>
> #include <rtems/score/threadimpl.h>
> #include <rtems/config.h>
> @@ -162,14 +161,6 @@ void _SMP_Request_shutdown( void )
> Per_CPU_Control *self_cpu = _Per_CPU_Get();
> _Per_CPU_State_change( self_cpu, PER_CPU_STATE_SHUTDOWN );
> - * We have to drop the Giant lock here in order to give other processors the
> - * opportunity to receive the inter-processor interrupts issued previously.
> - * In case the executing thread still holds SMP locks, then other processors
> - * already waiting for this SMP lock will spin forever.
> - _Giant_Drop( self_cpu );
> void _SMP_Send_message( uint32_t cpu_index, unsigned long message )
> diff --git a/cpukit/score/src/threaddisabledispatch.c b/cpukit/score/src/threaddisabledispatch.c
> deleted file mode 100644
> index 8746cd0..0000000
> --- a/cpukit/score/src/threaddisabledispatch.c
> +++ /dev/null
> @@ -1,60 +0,0 @@
> - * @file
> - * @brief Disaable Thread Dispatching
> - * @ingroup ScoreThread
> - * COPYRIGHT (c) 1989-2011.
> - * On-Line Applications Research Corporation (OAR).
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> -#if HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <rtems/system.h>
> -#include <rtems/score/sysstate.h>
> -#include <rtems/score/thread.h>
> - * This check is very brutal to system performance but is very helpful
> - * at finding blown stack problems. If you have a stack problem and
> - * need help finding it, then uncomment this code. Every system
> - * call will check the stack and since mutexes are used frequently
> - * in most systems, you might get lucky.
> - #if defined(RTEMS_HEAVY_STACK_DEBUG)
> - if (_System_state_Is_up(_System_state_Get()) && (_ISR_Nest_level == 0)) {
> - if ( rtems_stack_checker_is_blown() ) {
> - printk( "Stack blown!!\n" );
> - rtems_fatal_error_occurred( 99 );
> - #endif
> - * This check is even more brutal than the other one. This enables
> - * malloc heap integrity checking upon entry to every system call.
> - #if defined(RTEMS_HEAVY_MALLOC_DEBUG)
> - if ( _Thread_Dispatch_get_disable_level() == 1 ) {
> - _Heap_Walk( RTEMS_Malloc_Heap,99, false );
> - #endif
> -#endif
> diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
> index 75b12bd..0000000
> --- a/cpukit/score/src/threaddispatchdisablelevel.c
> +++ /dev/null
> @@ -1,140 +0,0 @@
> - * @file
> - * @brief Thread Dispatch Disable Functions
> -#include <rtems/score/assert.h>
> -#include <rtems/score/profiling.h>
> -#define NO_OWNER_CPU NULL
> -typedef struct {
> - SMP_lock_Control lock;
> - Per_CPU_Control *owner_cpu;
> - uint32_t nest_level;
> -} Giant_Control;
> -static Giant_Control _Giant = {
> - .lock = SMP_LOCK_INITIALIZER("Giant"),
> - .owner_cpu = NO_OWNER_CPU,
> - .nest_level = 0
> -static void _Giant_Do_acquire( Per_CPU_Control *cpu_self )
> - Giant_Control *giant = &_Giant;
> - if ( giant->owner_cpu != cpu_self ) {
> - _SMP_lock_Acquire( &giant->lock, &cpu_self->Giant_lock_context );
> - giant->owner_cpu = cpu_self;
> - giant->nest_level = 1;
> - } else {
> - ++giant->nest_level;
> -static void _Giant_Do_release( Per_CPU_Control *cpu_self )
> - --giant->nest_level;
> - if ( giant->nest_level == 0 ) {
> - giant->owner_cpu = NO_OWNER_CPU;
> - _SMP_lock_Release( &giant->lock, &cpu_self->Giant_lock_context );
> -void _Giant_Drop( Per_CPU_Control *cpu_self )
> - _Assert( _ISR_Get_level() != 0 );
> - if ( giant->owner_cpu == cpu_self ) {
> - giant->nest_level = 0;
> -uint32_t _Thread_Dispatch_increment_disable_level( void )
> - ISR_Level isr_level;
> - uint32_t disable_level;
> - Per_CPU_Control *cpu_self;
> - _ISR_Local_disable( isr_level );
> - * We must obtain the processor after interrupts are disabled to prevent
> - * thread migration.
> - cpu_self = _Per_CPU_Get();
> - _Giant_Do_acquire( cpu_self );
> - disable_level = cpu_self->thread_dispatch_disable_level;
> - _Profiling_Thread_dispatch_disable( cpu_self, disable_level );
> - ++disable_level;
> - cpu_self->thread_dispatch_disable_level = disable_level;
> - _ISR_Local_enable( isr_level );
> -uint32_t _Thread_Dispatch_decrement_disable_level( void )
> - _Assert( disable_level > 0);
> - --disable_level;
> - _Giant_Do_release( cpu_self );
> - _Profiling_Thread_dispatch_enable( cpu_self, disable_level );
> -void _Giant_Acquire( Per_CPU_Control *cpu_self )
> - _Assert( _Thread_Dispatch_disable_level != 0 );
> -void _Giant_Release( Per_CPU_Control *cpu_self )
> diff --git a/cpukit/score/src/threadenabledispatch.c b/cpukit/score/src/threadenabledispatch.c
> index baf58a0..0000000
> --- a/cpukit/score/src/threadenabledispatch.c
> +++ /dev/null
> @@ -1,32 +0,0 @@
> - * @file
> - * @brief Enable Dispatching of Threads
> - * _Thread_Enable_dispatch
> -#if HAVE_CONFIG_H
> -#endif
> -#if defined (__THREAD_DO_NOT_INLINE_ENABLE_DISPATCH__ )
> -void _Thread_Enable_dispatch( void )
> -#endif
> diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
> index 8ab12dc..9cefd26 100644
> --- a/testsuites/smptests/Makefile.am
> +++ b/testsuites/smptests/Makefile.am
> @@ -17,7 +17,6 @@ SUBDIRS += smpcapture02
> SUBDIRS += smpclock01
> SUBDIRS += smpfatal01
> SUBDIRS += smpfatal02
> -SUBDIRS += smpfatal03
> SUBDIRS += smpfatal04
> SUBDIRS += smpfatal05
> SUBDIRS += smpfatal08
> diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
> index 3611e32..2ea9eec 100644
> --- a/testsuites/smptests/configure.ac
> +++ b/testsuites/smptests/configure.ac
> @@ -73,7 +73,6 @@ smpcapture02/Makefile
> smpclock01/Makefile
> smpfatal01/Makefile
> smpfatal02/Makefile
> -smpfatal03/Makefile
> smpfatal04/Makefile
> smpfatal05/Makefile
> smpfatal08/Makefile
> diff --git a/testsuites/smptests/smpfatal03/Makefile.am b/testsuites/smptests/smpfatal03/Makefile.am
> index 4ec2862..0000000
> --- a/testsuites/smptests/smpfatal03/Makefile.am
> +++ /dev/null
> @@ -1,19 +0,0 @@
> -rtems_tests_PROGRAMS = smpfatal03
> -smpfatal03_SOURCES = init.c
> -dist_rtems_tests_DATA = smpfatal03.scn smpfatal03.doc
> -include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> -include $(top_srcdir)/../automake/compile.am
> -include $(top_srcdir)/../automake/leaf.am
> -AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> -LINK_OBJS = $(smpfatal03_OBJECTS)
> -LINK_LIBS = $(smpfatal03_LDLIBS)
> -smpfatal03$(EXEEXT): $(smpfatal03_OBJECTS) $(smpfatal03_DEPENDENCIES)
> - @rm -f smpfatal03$(EXEEXT)
> - $(make-exe)
> -include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/smptests/smpfatal03/init.c b/testsuites/smptests/smpfatal03/init.c
> index 2f3980b..0000000
> --- a/testsuites/smptests/smpfatal03/init.c
> +++ /dev/null
> @@ -1,151 +0,0 @@
> - * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
> - * embedded brains GmbH
> - * Dornierstr. 4
> - * 82178 Puchheim
> - * Germany
> - * <rtems at embedded-brains.de>
> -#ifdef HAVE_CONFIG_H
> - #include "config.h"
> -#endif
> -#include <rtems.h>
> -#include <rtems/counter.h>
> -#include <rtems/test.h>
> -#include <rtems/score/smpbarrier.h>
> -#include <rtems/score/smpimpl.h>
> -#include <assert.h>
> -#include <stdlib.h>
> -const char rtems_test_name[] = "SMPFATAL 3";
> -#define CPU_COUNT 2
> -static uint32_t main_cpu;
> -static SMP_barrier_Control giant_barrier = SMP_BARRIER_CONTROL_INITIALIZER;
> -static SMP_barrier_Control fatal_barrier = SMP_BARRIER_CONTROL_INITIALIZER;
> -static void acquire_giant_and_fatal_task(rtems_task_argument arg)
> - SMP_barrier_State state = SMP_BARRIER_STATE_INITIALIZER;
> - int i;
> - for (i = 0; i < 13; ++i) {
> - _Giant_Acquire();
> - _SMP_barrier_Wait(&giant_barrier, &state, CPU_COUNT);
> - * Now we have to wait some time so that the other thread can actually start
> - * with the _Giant_Acquire() procedure.
> - rtems_counter_delay_nanoseconds(1000000);
> - rtems_fatal(RTEMS_FATAL_SOURCE_APPLICATION, 0xdeadbeef);
> -static void wait_for_giant(void)
> - _Giant_Release();
> -static void Init(rtems_task_argument arg)
> - uint32_t self = rtems_get_current_processor();
> - uint32_t cpu_count = rtems_get_processor_count();
> - rtems_test_begink();
> - main_cpu = self;
> - if (cpu_count >= CPU_COUNT) {
> - rtems_status_code sc;
> - rtems_id id;
> - sc = rtems_task_create(
> - rtems_build_name( 'W', 'A', 'I', 'T' ),
> - 1,
> - RTEMS_MINIMUM_STACK_SIZE,
> - RTEMS_DEFAULT_MODES,
> - RTEMS_DEFAULT_ATTRIBUTES,
> - &id
> - assert(sc == RTEMS_SUCCESSFUL);
> - sc = rtems_task_start(id, acquire_giant_and_fatal_task, 0);
> - wait_for_giant();
> - } else {
> - rtems_test_endk();
> - exit(0);
> -static void fatal_extension(
> - rtems_fatal_source source,
> - bool is_internal,
> - rtems_fatal_code code
> - if (
> - source == RTEMS_FATAL_SOURCE_APPLICATION
> - || source == RTEMS_FATAL_SOURCE_SMP
> - assert(!is_internal);
> - if (self == main_cpu) {
> - assert(source == RTEMS_FATAL_SOURCE_SMP);
> - assert(code == SMP_FATAL_SHUTDOWN_RESPONSE);
> - } else {
> - assert(source == RTEMS_FATAL_SOURCE_APPLICATION);
> - assert(code == 0xdeadbeef);
> - _SMP_barrier_Wait(&fatal_barrier, &state, CPU_COUNT);
> - if (self == 0) {
> -#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> -#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> -#define CONFIGURE_INITIAL_EXTENSIONS \
> - { .fatal = fatal_extension }, \
> - RTEMS_TEST_INITIAL_EXTENSION
> -#define CONFIGURE_SMP_APPLICATION
> -#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
> -#define CONFIGURE_MAXIMUM_TASKS 2
> -#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> -#include <rtems/confdefs.h>
> diff --git a/testsuites/smptests/smpfatal03/smpfatal03.doc b/testsuites/smptests/smpfatal03/smpfatal03.doc
> index 5c5a8ba..0000000
> --- a/testsuites/smptests/smpfatal03/smpfatal03.doc
> +++ /dev/null
> @@ -1,12 +0,0 @@
> -This file describes the directives and concepts tested by this test set.
> -test set name: smpfatal03
> -directives:
> - - _Terminate()
> -concepts:
> - - Ensure that _Terminate() drops the Giant lock so that other processors
> - waiting on the Giant lock can receive shutdown requests.
> diff --git a/testsuites/smptests/smpfatal03/smpfatal03.scn b/testsuites/smptests/smpfatal03/smpfatal03.scn
> index f502b4e..0000000
> --- a/testsuites/smptests/smpfatal03/smpfatal03.scn
> +++ /dev/null
> @@ -1,2 +0,0 @@
> -*** TEST SMPFATAL 3 ***
> -*** END OF TEST SMPFATAL 3 ***
> 1.8.4.5
> devel mailing list
> devel at rtems.org
