[PATCH v2 7/7] arm/raspberrypi: add fbcons support for rpi bsp
ppisa4lists at pikron.com ppisa4lists at pikron.com
Sun May 22 00:13:10 UTC 2016
 c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |   4 +-
 .../arm/raspberrypi/console/console-config.c       |  12 +-
 .../arm/raspberrypi/console/console_select.c       | 113 +++++++++++++
 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c  | 177 +++++++++++++++++++++
 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h  |  47 ++++++
 c/src/lib/libbsp/arm/raspberrypi/include/bsp.h     |   3 +
 c/src/lib/libbsp/arm/raspberrypi/preinstall.am     |   4 +
 .../libbsp/arm/raspberrypi/startup/bspstarthooks.c |   4 +
 8 files changed, 362 insertions(+), 2 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/console_select.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index f5b87ab..e115745 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -53,6 +53,7 @@ include_bsp_HEADERS += include/spi.h
 include_bsp_HEADERS += include/mailbox.h
 include_bsp_HEADERS += include/vc.h
 include_bsp_HEADERS += include/rpi-fb.h
+include_bsp_HEADERS += console/fbcons.h
 include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
     ../../../libcpu/arm/shared/include/arm-cp15.h
@@ -113,11 +114,12 @@ libbsp_a_SOURCES += irq/irq.c
 libbsp_a_SOURCES += ../../shared/console.c
 libbsp_a_SOURCES += ../../shared/console_control.c
 libbsp_a_SOURCES += ../../shared/console_read.c
-libbsp_a_SOURCES += ../../shared/console_select.c
 libbsp_a_SOURCES += ../../shared/console_write.c
 libbsp_a_SOURCES += console/console-config.c
+libbsp_a_SOURCES += console/console_select.c
 libbsp_a_SOURCES += console/usart.c
 libbsp_a_SOURCES += console/fb.c
+libbsp_a_SOURCES += console/fbcons.c
 libbsp_a_SOURCES += console/outch.c
 # Mailbox
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c b/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
index b948b77..dfb9826 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
@@ -7,6 +7,8 @@
+ * Copyright (c) 2015 Yang Qiao
+ * based on work by:
  * Copyright (c) 2013 Alan Cudmore
  *  The license and distribution terms for this file may be
@@ -24,6 +26,7 @@
 #include <bsp/irq.h>
 #include <bsp/usart.h>
 #include <bsp/raspberrypi.h>
+#include <bsp/fbcons.h>
 console_tbl Console_Configuration_Ports [] = {
@@ -36,7 +39,14 @@ console_tbl Console_Configuration_Ports [] = {
       .ulCtrlPort2 = 0,
       .ulClock = USART0_DEFAULT_BAUD,
       .ulIntVector = BCM2835_IRQ_ID_UART
+      .sDeviceName ="/dev/fbcons",
+      .deviceType = SERIAL_CUSTOM,
+      .pDeviceFns = &fbcons_fns,
+      .deviceProbe = fbcons_probe,
+      .pDeviceFlow = NULL,
 #define PORT_COUNT \
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/console_select.c b/c/src/lib/libbsp/arm/raspberrypi/console/console_select.c
new file mode 100644
index 0000000..c038cd9
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/console_select.c
@@ -0,0 +1,113 @@
+ * @file
+ * @ingroup raspberrypi_console
+ * @brief console select
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE
+#include <bsp.h>
+#include <bsp/fatal.h>
+#include <rtems/libio.h>
+#include <stdlib.h>
+#include <assert.h>
+#include <termios.h>
+#include <rtems/termiostypes.h>
+#include <libchip/serial.h>
+#include "../../../shared/console_private.h"
+#include <bsp/rpi-fb.h>
+rtems_device_minor_number BSPPrintkPort = 0;
+ * Method to return true if the device associated with the
+ * minor number probs available.
+static bool bsp_Is_Available( rtems_device_minor_number minor )
+  console_tbl *cptr = Console_Port_Tbl[ minor ];
+   * First perform the configuration dependent probe, then the
+   * device dependent probe
+  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
+       cptr->pDeviceFns->deviceProbe( minor ) ) {
+    return true;
+  return false;
+ * Method to return the first available device.
+static rtems_device_minor_number bsp_First_Available_Device( void )
+  rtems_device_minor_number minor;
+  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
+      return minor;
+   *  Error No devices were found.  We will want to bail here.
+  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
+void bsp_console_select( void )
+   *  Reset Console_Port_Minor and
+   *  BSPPrintkPort here if desired.
+   *  This default version allows the bsp to set these
+   *  values at creation and will not touch them again
+   *  unless the selected port number is not available.
+  const char *opt;
+  Console_Port_Minor = BSP_CONSOLE_UART0;
+  BSPPrintkPort = BSP_CONSOLE_UART0;
+  opt = rpi_cmdline_get_arg( "--console=" );
+  if ( opt ) {
+    if ( strncmp( opt, "fbcons", sizeof( "fbcons" - 1 ) ) == 0 ) {
+      if ( rpi_video_is_initialized() > 0 ) {
+        Console_Port_Minor = BSP_CONSOLE_FB;
+        BSPPrintkPort = BSP_CONSOLE_FB;
+   * If the device that was selected isn't available then
+   * let the user know and select the first available device.
+  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
+    Console_Port_Minor = bsp_First_Available_Device();
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c b/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c
index 0000000..3669ba4
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c
@@ -0,0 +1,177 @@
+ * @file
+ * @brief framebuffer graphic console support.
+#include <rtems.h>
+#include <libchip/sersupp.h>
+#include <bsp.h>
+#include <bsp/vc.h>
+ *  fbcons_init
+ *  This function initializes the fb console to a quiecsent state.
+static void fbcons_init( int minor )
+ *  fbcons_open
+ *  This function opens a port for communication.
+ *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
+static int fbcons_open(
+  int   major,
+  int   minor,
+  void *arg
+  return RTEMS_SUCCESSFUL;
+ *  fbcons_close
+ *  This function shuts down the requested port.
+static int fbcons_close(
+  int   major,
+  int   minor,
+  void *arg
+  return ( RTEMS_SUCCESSFUL );
+ *  fbcons_write_polled
+ *  This routine polls out the requested character.
+static void fbcons_write_polled(
+  int  minor,
+  char c
+  rpi_fb_outch( c );
+  if ( c == '\n' )
+    rpi_fb_outch( '\r' );            /* LF = LF + CR */
+ *  fbcons_write_support_polled
+ *  Console Termios output entry point when using polled output.
+static ssize_t fbcons_write_support_polled(
+  int         minor,
+  const char *buf,
+  size_t      len
+  int nwrite = 0;
+   * poll each byte in the string out of the port.
+  while ( nwrite < len ) {
+    fbcons_write_polled( minor, *buf++ );
+    nwrite++;
+   * return the number of bytes written.
+  return nwrite;
+ *  fbcons_inbyte_nonblocking_polled
+ *  Console Termios polling input entry point.
+static int fbcons_inbyte_nonblocking_polled( int minor )
+  // if( rtems_kbpoll() ) {
+  //   int c = getch();
+  //   return c;
+  return -1;
+ *  fbcons_set_attributes
+ *  This function sets the UART channel to reflect the requested termios
+ *  port settings.
+static int fbcons_set_attributes(
+  int                   minor,
+  const struct termios *t
+  return 0;
+bool fbcons_probe( int minor )
+  // rtems_status_code status;
+  static bool firstTime = true;
+  static bool ret = false;
+   *  keyboard interrupt should be registered when the keyboard is available
+  if ( firstTime ) {
+    if ( !rpi_fb_hdmi_is_present() ) {
+      ret = false;
+    } else {
+      ret = true;
+  firstTime = false;
+  return ret;
+const console_fns fbcons_fns =
+  .deviceProbe = libchip_serial_default_probe,     /* deviceProbe */
+  .deviceFirstOpen = fbcons_open,                 /* deviceFirstOpen */
+  .deviceLastClose = fbcons_close,                /* deviceLastClose */
+  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
+  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite */
+  .deviceInitialize = fbcons_init,                /* deviceInitialize */
+  .deviceWritePolled = fbcons_write_polled,       /* deviceWritePolled */
+  .deviceSetAttributes = fbcons_set_attributes,   /* deviceSetAttributes */
+  .deviceOutputUsesInterrupts = FALSE,           /* deviceOutputUsesInterrupts*/
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h b/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h
index 0000000..d0e1266
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h
@@ -0,0 +1,47 @@
+ * @file
+#ifndef _FBCONS_H_
+#define _FBCONS_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *  This is the ASCII for "PI" in the upper word and 2835
+ *  in the lower which should be unique enough to
+ *  distinguish this type of serial device from others.
+#define FB_CONSOLE 0x50492835
+bool fbcons_probe( int minor );
+ * Driver function table
+extern const console_fns fbcons_fns;
+#ifdef __cplusplus
+#endif
+#endif /* _FBCONS_H_ */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
index 67df810..5241979 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
@@ -38,6 +38,9 @@ extern "C" {
 #define BSP_GPIO_PINS_PER_BANK 32
 #define BSP_GPIO_PINS_PER_SELECT_BANK 10
+#define BSP_CONSOLE_UART0   0
+#define BSP_CONSOLE_FB      1
 void rpi_init_cmdline(void);
 const char *rpi_cmdline_get_cached(void);
 const char *rpi_cmdline_get_raw(void);
diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
index cbfa79f..e6f0ca0 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
@@ -158,6 +158,10 @@ $(PROJECT_INCLUDE)/bsp/rpi-fb.h: include/rpi-fb.h $(PROJECT_INCLUDE)/bsp/$(dirst
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/rpi-fb.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/rpi-fb.h
+$(PROJECT_INCLUDE)/bsp/fbcons.h: console/fbcons.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/fbcons.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/fbcons.h
 $(PROJECT_INCLUDE)/libcpu/cache_.h: ../../../libcpu/arm/shared/include/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
index d44be03..0a90e7a 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
@@ -27,6 +27,8 @@
 #include <bsp/mm.h>
 #include <libcpu/arm-cp15.h>
+#include <bsp.h>
 void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
@@ -71,4 +73,6 @@ void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
   bsp_start_copy_sections();
   bsp_memory_management_initialize();
   bsp_start_clear_bss();
+  rpi_video_init();
1.9.1
