[civetweb] Interface for setting stack size and scheduler options
Christian Mauderer
christian.mauderer at embedded-brains.de
Sun May 22 09:04:44 UTC 2016
To the question from Joe Mucchiello:
I think the thread startup is more a toppic of the init_thread callback
that has been added here: https://github.com/civetweb/civetweb/pull/304
This function gets called after the thread is started. Is this what you had
in mind?
To bel:
I created a draft for a callback. It's not worked out and only thought as a
basis for further discussions:
https://github.com/c-mauderer/civetweb/commit/380db13ad3c6c504002ba508605ced6d8ab7d550
I had the following problems:
- The thread has a different return type for windows and for POSIX. It
seems that no thread is really using the possibility to return anything.
Currently I removed the return and just set it to void. I would expect that
this leads to warnings when compiling the code. How could we handle this?
- The *struct mg_context* is declared in the civetweb.h but defined in
civetweb.c file. So It could be tricky to access any context fields from
inside a callback (e.g. for getting parameters). How is this handled in
other callbacks? Did I overlook something?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160522/7c4683b3/attachment.html>
