[PATCH] Delete autotools probe for <sys/cpuset.h> and all references to feature macro
Sun May 22 23:04:49 UTC 2016
This was a transitional feature macro and recent tool verions always
have this header file. Remove as it is now obsolete.
 cpukit/configure.ac                              |    7 --
 cpukit/posix/include/rtems/posix/pthreadimpl.h   |    2 +-
 cpukit/posix/src/pthread.c                       |   34 ++++----
 cpukit/posix/src/pthreadattrcompare.c            |   30 +++----
 cpukit/posix/src/pthreadcreate.c                 |    6 +-
 cpukit/rtems/include/rtems/rtems/tasks.h         |    4 -
 cpukit/rtems/src/schedulergetprocessorset.c      |    4 -
 cpukit/rtems/src/taskgetaffinity.c               |    3 -
 cpukit/rtems/src/tasksetaffinity.c               |    3 -
 cpukit/score/include/rtems/score/cpuset.h        |    4 -
 cpukit/score/include/rtems/score/cpusetimpl.h    |    3 -
 cpukit/score/include/rtems/score/scheduler.h     |    8 +--
 cpukit/score/include/rtems/score/schedulerimpl.h |    4 -
 cpukit/score/src/cpuset.c                        |    4 -
 cpukit/score/src/cpusetprintsupport.c            |   99 +++++++++++-----------
 cpukit/score/src/schedulergetaffinity.c          |    4 -
 cpukit/score/src/schedulersetaffinity.c          |    4 -
 testsuites/psxtests/configure.ac                 |    3 -
 testsuites/smptests/configure.ac                 |    4 -
 testsuites/smptests/smpaffinity01/init.c         |   12 ---
 testsuites/smptests/smpscheduler02/init.c        |   11 ---
 testsuites/sptests/Makefile.am                   |    3 -
 testsuites/sptests/configure.ac                  |    4 -
 testsuites/sptests/spcpuset01/init.c             |   13 ---
 testsuites/sptests/spcpuset01/system.h           |    2 -
 testsuites/sptests/spcpuset01/test.c             |    2 -
 testsuites/sptests/spscheduler01/init.c          |    4 -
 27 files changed, 82 insertions(+), 199 deletions(-)
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 054e60e..8bda761 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -116,7 +116,6 @@ RTEMS_CHECK_FUNC([pthread_getaffinity_np],[
 RTEMS_CHECK_FUNC([pthread_getattr_np],[
   #define _GNU_SOURCE
   #include <pthread.h>])
-AC_CHECK_HEADERS([sys/cpuset.h])
 # This was added to newlib in August 2014 to improve conformance.
 # Disable use of internal definition if it is present.
@@ -249,12 +248,6 @@ RTEMS_CPUOPT([RTEMS_VERSION],
   [RTEMS version string])
 ## Header file differences that need to be known in .h after install
-RTEMS_CPUOPT([__RTEMS_HAVE_SYS_CPUSET_H__],
-  [test x"${ac_cv_header_sys_cpuset_h}" = x"yes"],
-  [1],
-  [indicate if <sys/cpuset.h> is present in toolset])
-## Header file differences that need to be known in .h after install
 RTEMS_CPUOPT([__RTEMS_HAVE_DECL_SIGALTSTACK__],
   [test x"${ac_cv_have_decl_sigaltstack}" = x"yes"],
   [1],
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index 16b0163..3627643 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -165,7 +165,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Threads_Copy_attributes(
   *dst_attr = *src_attr;
-#if defined(RTEMS_SMP) && defined(__RTEMS_HAVE_SYS_CPUSET_H__)
+#if defined(RTEMS_SMP)
   _Assert(
     dst_attr->affinitysetsize == sizeof(dst_attr->affinitysetpreallocated)
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 766ac01..a3cac22 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -76,11 +76,9 @@ pthread_attr_t _POSIX_Threads_Default_attributes = {
     .cputime_clock_allowed = 1,                        /* cputime_clock_allowed */
   #endif
   .detachstate             = PTHREAD_CREATE_JOINABLE,    /* detachstate */
-  #if defined(__RTEMS_HAVE_SYS_CPUSET_H__)
-    .affinitysetsize         = 0,
-    .affinityset             = NULL,
-    .affinitysetpreallocated = {{0x0}}
-  #endif
+  .affinitysetsize         = 0,
+  .affinityset             = NULL,
+  .affinitysetpreallocated = {{0x0}}
 static bool _POSIX_Threads_Sporadic_budget_TSR_filter(
@@ -280,20 +278,18 @@ User_extensions_Control _POSIX_Threads_User_extensions = {
 static void _POSIX_Threads_Manager_initialization(void)
-  #if defined(RTEMS_SMP) && defined(__RTEMS_HAVE_SYS_CPUSET_H__)
-    const CPU_set_Control *affinity;
-    pthread_attr_t *attr;
-    /* Initialize default attribute. */
-    attr = &_POSIX_Threads_Default_attributes;
-    /*  Initialize the affinity to be the default cpu set for the system */
-    affinity = _CPU_set_Default();
-    _Assert( affinity->setsize == sizeof( attr->affinitysetpreallocated ) );
-    attr->affinityset             = &attr->affinitysetpreallocated;
-    attr->affinitysetsize         = affinity->setsize;
-    CPU_COPY( attr->affinityset, affinity->set );
-  #endif
+  const CPU_set_Control *affinity;
+  pthread_attr_t *attr;
+  /* Initialize default attribute. */
+  attr = &_POSIX_Threads_Default_attributes;
+  /*  Initialize the affinity to be the default cpu set for the system */
+  affinity = _CPU_set_Default();
+  _Assert( affinity->setsize == sizeof( attr->affinitysetpreallocated ) );
+  attr->affinityset             = &attr->affinitysetpreallocated;
+  attr->affinitysetsize         = affinity->setsize;
+  CPU_COPY( attr->affinityset, affinity->set );
   _Thread_Initialize_information(
     &_POSIX_Threads_Information, /* object information table */
diff --git a/cpukit/posix/src/pthreadattrcompare.c b/cpukit/posix/src/pthreadattrcompare.c
index 4cc4098..6a3b625 100644
--- a/cpukit/posix/src/pthreadattrcompare.c
+++ b/cpukit/posix/src/pthreadattrcompare.c
@@ -67,24 +67,22 @@ int rtems_pthread_attribute_compare(
   if ( attr1->detachstate != attr2->detachstate )
     return 1;
-    if ( attr1->affinitysetsize != attr2->affinitysetsize )
-      return 1;
+  if ( attr1->affinitysetsize != attr2->affinitysetsize )
+    return 1;
-    if (!CPU_EQUAL_S(
-      attr1->affinitysetsize,
-      attr1->affinityset,
-      attr2->affinityset
-      return 1;
+  if (!CPU_EQUAL_S(
+    attr1->affinitysetsize,
+    attr1->affinityset,
+    attr2->affinityset
+    return 1;
-    if (!CPU_EQUAL_S(
-      &attr1->affinitysetpreallocated,
-      &attr2->affinitysetpreallocated
-      return 1;
-  #endif
+  if (!CPU_EQUAL_S(
+    &attr1->affinitysetpreallocated,
+    &attr2->affinitysetpreallocated
+    return 1;
   return 0;
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 7f95898..1fda1e4 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -153,12 +153,10 @@ int pthread_create(
     return rc;
-#if __RTEMS_HAVE_SYS_CPUSET_H__
-  status = _CPU_set_Is_valid( the_attr->affinityset, the_attr->affinitysetsize );
+  status = _CPU_set_Is_valid(the_attr->affinityset, the_attr->affinitysetsize);
   if ( !status )
     return EINVAL;
 #endif
-#endif
    *  Currently all POSIX threads are floating point if the hardware
@@ -207,7 +205,7 @@ int pthread_create(
   the_thread->Life.state |= THREAD_LIFE_CHANGE_DEFERRED;
-#if defined(RTEMS_SMP) && __RTEMS_HAVE_SYS_CPUSET_H__
   _ISR_lock_ISR_disable( &lock_context );
    status = _Scheduler_Set_affinity(
      the_thread,
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 84ea806..d4b0f00 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -373,7 +373,6 @@ rtems_status_code rtems_task_is_suspended(
   rtems_id   id
-#if defined(__RTEMS_HAVE_SYS_CPUSET_H__)
  * @brief Gets the processor affinity set of a task.
@@ -429,7 +428,6 @@ rtems_status_code rtems_task_set_affinity(
   size_t           cpusetsize,
   const cpu_set_t *cpuset
-#endif
  * @brief Gets the scheduler of a task.
@@ -493,7 +491,6 @@ rtems_status_code rtems_scheduler_ident(
   rtems_id   *id
  * @brief Gets the set of processors owned by the scheduler.
@@ -515,7 +512,6 @@ rtems_status_code rtems_scheduler_get_processor_set(
   size_t     cpusetsize,
   cpu_set_t *cpuset
-#endif
diff --git a/cpukit/rtems/src/schedulergetprocessorset.c b/cpukit/rtems/src/schedulergetprocessorset.c
index 016c368..267dcae 100644
--- a/cpukit/rtems/src/schedulergetprocessorset.c
+++ b/cpukit/rtems/src/schedulergetprocessorset.c
@@ -16,8 +16,6 @@
   #include "config.h"
 #endif
 #include <rtems/score/cpusetimpl.h>
@@ -46,5 +44,3 @@ rtems_status_code rtems_scheduler_get_processor_set(
   return RTEMS_SUCCESSFUL;
-#endif /* defined(__RTEMS_HAVE_SYS_CPUSET_H__) */
diff --git a/cpukit/rtems/src/taskgetaffinity.c b/cpukit/rtems/src/taskgetaffinity.c
index b24966d..4519534 100644
--- a/cpukit/rtems/src/taskgetaffinity.c
+++ b/cpukit/rtems/src/taskgetaffinity.c
@@ -18,8 +18,6 @@
 #include "config.h"
 #endif
@@ -65,4 +63,3 @@ rtems_status_code rtems_task_get_affinity(
   _Thread_Dispatch_enable( cpu_self );
   return ok ? RTEMS_SUCCESSFUL : RTEMS_INVALID_NUMBER;
-#endif
diff --git a/cpukit/rtems/src/tasksetaffinity.c b/cpukit/rtems/src/tasksetaffinity.c
index 6caf862..290a13b 100644
--- a/cpukit/rtems/src/tasksetaffinity.c
+++ b/cpukit/rtems/src/tasksetaffinity.c
@@ -18,8 +18,6 @@
 #include "config.h"
 #endif
@@ -65,4 +63,3 @@ rtems_status_code rtems_task_set_affinity(
-#endif
diff --git a/cpukit/score/include/rtems/score/cpuset.h b/cpukit/score/include/rtems/score/cpuset.h
index ebdb35d..564f4a5 100644
--- a/cpukit/score/include/rtems/score/cpuset.h
+++ b/cpukit/score/include/rtems/score/cpuset.h
@@ -21,8 +21,6 @@
-#ifdef __RTEMS_HAVE_SYS_CPUSET_H__
 #include <sys/cpuset.h>
 #ifdef __cplusplus
@@ -61,7 +59,5 @@ typedef struct {
 #endif
-#endif /* __RTEMS_HAVE_SYS_CPUSET_H__ */
 #endif /* _RTEMS_SCORE_CPUSET_H */
 /* end of include file */
diff --git a/cpukit/score/include/rtems/score/cpusetimpl.h b/cpukit/score/include/rtems/score/cpusetimpl.h
index f9a0f0f..6a6bf97 100644
--- a/cpukit/score/include/rtems/score/cpusetimpl.h
+++ b/cpukit/score/include/rtems/score/cpusetimpl.h
@@ -28,8 +28,6 @@
 extern "C" {
 #endif
  * @brief Determine If the CPU Set if Valid
@@ -121,7 +119,6 @@ static inline void _CPU_set_Set(
   set->setsize = setsize;
   CPU_COPY( set->set, cpuset );
-#endif
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index 1e6236f..a5a4d32 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -21,9 +21,7 @@
 #include <rtems/score/priority.h>
-#if defined(__RTEMS_HAVE_SYS_CPUSET_H__) && defined(RTEMS_SMP)
-  #include <sys/cpuset.h>
-#endif
+#include <sys/cpuset.h>
 #ifdef __cplusplus
 extern "C" {
@@ -152,7 +150,6 @@ typedef struct {
     struct Per_CPU_Control *
   /** @see _Scheduler_Get_affinity() */
   bool ( *get_affinity )(
     const Scheduler_Control *,
@@ -168,7 +165,6 @@ typedef struct {
     size_t,
     const cpu_set_t *
-#endif
 } Scheduler_Operations;
@@ -517,7 +513,7 @@ void _Scheduler_default_Start_idle(
   struct Per_CPU_Control  *cpu
    * @brief Get affinity for the default scheduler.
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index bfc6df3..f3b3d1b 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -641,8 +641,6 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_Set(
 #endif
 RTEMS_INLINE_ROUTINE void _Scheduler_Get_processor_set(
   const Scheduler_Control *scheduler,
   size_t                   cpusetsize,
@@ -723,8 +721,6 @@ bool _Scheduler_Set_affinity(
 RTEMS_INLINE_ROUTINE void _Scheduler_Generic_block(
   Thread_Control          *the_thread,
diff --git a/cpukit/score/src/cpuset.c b/cpukit/score/src/cpuset.c
index deb9e43..718e887 100644
--- a/cpukit/score/src/cpuset.c
+++ b/cpukit/score/src/cpuset.c
@@ -19,7 +19,6 @@
 #include "config.h"
 #endif
 #include <rtems/sysinit.h>
@@ -96,6 +95,3 @@ const CPU_set_Control *_CPU_set_Default()
   return &cpuset_default;
-#endif
diff --git a/cpukit/score/src/cpusetprintsupport.c b/cpukit/score/src/cpusetprintsupport.c
index 76851d3..82a462c 100644
--- a/cpukit/score/src/cpusetprintsupport.c
+++ b/cpukit/score/src/cpusetprintsupport.c
@@ -26,59 +26,56 @@
 #include <rtems/bspIo.h>
+void _CPU_set_Show_with_plugin(
+  void                  *context,
+  rtems_printk_plugin_t  print,
+  const char            *description,
+  const cpu_set_t       *cpuset
-  void _CPU_set_Show_with_plugin(
-    void                  *context,
-    rtems_printk_plugin_t  print,
-    const char            *description,
-    const cpu_set_t       *cpuset
-   * _CPU_set_Show_with_plugin
-   * This routine shows cpuset cpuset using a
-   * print plugin .
-    void                  *context,
-    int i;
+ * _CPU_set_Show_with_plugin
+ * This routine shows cpuset cpuset using a
+ * print plugin .
+  void                  *context,
+  int i;
-    if ( !print )
-      return;
+  if ( !print )
+    return;
-    (*print)(context ,"%s: ", description);
-    for(i=0; i<_NCPUWORDS; i++)
-      (*print)(context ,"%x", cpuset->__bits[i]);
-    (*print)(context ,"\n");
+  (*print)(context ,"%s: ", description);
+  for(i=0; i<_NCPUWORDS; i++)
+    (*print)(context ,"%x", cpuset->__bits[i]);
+  (*print)(context ,"\n");
-   * _CPU_set_Show
-   * This routine shows a cpuset using the
-   * printk plugin.
-  void _CPU_set_Show( const char *description, const cpu_set_t   *cpuset)
-    _CPU_set_Show_with_plugin( NULL, printk_plugin, description, cpuset );
+ * _CPU_set_Show
+ * This routine shows a cpuset using the
+ * printk plugin.
+void _CPU_set_Show( const char *description, const cpu_set_t   *cpuset)
+  _CPU_set_Show_with_plugin( NULL, printk_plugin, description, cpuset );
-   * _CPU_set_Show_default
-   * This routine shows the default cpuset.
- void _CPU_set_Show_default( const char *description )
-    const CPU_set_Control *ctl;
-    ctl = _CPU_set_Default();
-    _CPU_set_Show( description, ctl->set );
-#endif
+ * _CPU_set_Show_default
+ * This routine shows the default cpuset.
+void _CPU_set_Show_default( const char *description )
+  const CPU_set_Control *ctl;
+  ctl = _CPU_set_Default();
+  _CPU_set_Show( description, ctl->set );
diff --git a/cpukit/score/src/schedulergetaffinity.c b/cpukit/score/src/schedulergetaffinity.c
index c910a75..db092aa 100644
--- a/cpukit/score/src/schedulergetaffinity.c
+++ b/cpukit/score/src/schedulergetaffinity.c
@@ -18,8 +18,6 @@
 bool _Scheduler_Get_affinity(
   size_t          cpusetsize,
@@ -56,5 +54,3 @@ bool _Scheduler_Get_affinity(
   _Scheduler_Release_critical( scheduler, &lock_context );
   return ok;
diff --git a/cpukit/score/src/schedulersetaffinity.c b/cpukit/score/src/schedulersetaffinity.c
index b59d8eb..cdf3679 100644
--- a/cpukit/score/src/schedulersetaffinity.c
+++ b/cpukit/score/src/schedulersetaffinity.c
@@ -18,8 +18,6 @@
   size_t           cpusetsize,
@@ -56,5 +54,3 @@ bool _Scheduler_Set_affinity(
   return ok;
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 779e0b5..665dc84 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -81,9 +81,6 @@ AC_CHECK_DECLS([pthread_getattr_np],[],[],[[
   #define _GNU_SOURCE
   #include <pthread.h>]])
-# Added to newlib pthreads for RTEMS SMP (np), may not be present
-AC_CHECK_HEADERS([cpuset.h])
 # Mandated by POSIX, not declared in some versions of newlib.
 AC_CHECK_DECLS([getrusage],,,[#include sys/resource.h])
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 2ea9eec..3b5973b 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -51,10 +51,6 @@ AC_CHECK_DECLS([pthread_getattr_np],[],[],[[
   #define _GNU_SOURCE
-AM_CONDITIONAL(HAS_CPUSET,test x"${ac_cv_header_sys_cpuset_h}" = x"yes")
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
 smpstrongapa01/Makefile
diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/smpaffinity01/init.c
index 969a332..1b8fc72 100644
--- a/testsuites/smptests/smpaffinity01/init.c
+++ b/testsuites/smptests/smpaffinity01/init.c
@@ -17,8 +17,6 @@
 const char rtems_test_name[] = "SMPAFFINITY 1";
 rtems_id           Init_id;
 rtems_id           Med_id[NUM_CPUS-1];
 rtems_id           Low_id[NUM_CPUS];
@@ -226,16 +224,6 @@ static void Init(rtems_task_argument arg)
   rtems_test_exit(0);
-#else
-static void Init(rtems_task_argument arg)
-  TEST_BEGIN();
-  puts( " Affinity NOT Supported");
-  TEST_END();
-  rtems_test_exit(0);
-#endif
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
index 40a481c..c78cbbf 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -23,8 +23,6 @@
 const char rtems_test_name[] = "SMPSCHEDULER 2";
 #define SCHED_A rtems_build_name(' ', ' ', ' ', 'A')
 #define SCHED_B rtems_build_name(' ', ' ', ' ', 'B')
@@ -177,15 +175,6 @@ static void test(void)
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-#else /* defined(__RTEMS_HAVE_SYS_CPUSET_H__) */
-static void test(void)
-  /* Nothing to do */
   rtems_resource_snapshot snapshot;
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 20ea9d5..103e4f2 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -81,10 +81,7 @@ _SUBDIRS += spinternalerror02
 _SUBDIRS += sptimer_err01 sptimer_err02
 _SUBDIRS += sptimerserver01
 _SUBDIRS += spclock_err02
-if HAS_CPUSET
 _SUBDIRS += spcpuset01
-endif
 include $(top_srcdir)/../automake/test-subdirs.am
 include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index c96edd3..a2375fb 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -36,10 +36,6 @@ AM_CONDITIONAL(HAS__THREAD_QUEUE_QUEUE,test x"${ac_cv_type_struct__Thread_queue_
 AC_CHECK_HEADERS([threads.h])
 AM_CONDITIONAL([HAS_THREADS_H],[test x"$ac_cv_header_threads_h" = x"yes"])
 # Some tests should not be built/run in SMP configurations
 RTEMS_CHECK_CPUOPTS([RTEMS_SMP])
 AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
diff --git a/testsuites/sptests/spcpuset01/init.c b/testsuites/sptests/spcpuset01/init.c
index d77a240..5883707 100644
--- a/testsuites/sptests/spcpuset01/init.c
+++ b/testsuites/sptests/spcpuset01/init.c
@@ -15,7 +15,6 @@
 const char rtems_test_name[] = "SPCPUSET 1";
 static void test_cpu_zero_case_1(void)
   size_t i;
@@ -154,15 +153,3 @@ rtems_task Init(
   TEST_END();
   exit( 0 );
-#else
-#error "Init - No cpuset"
-rtems_task Init(
-  rtems_task_argument ignored
-  TEST_BEGIN();
-  puts( "  cpuset not supported\n" );
-  TEST_END();
-  exit( 0 );
-#endif
diff --git a/testsuites/sptests/spcpuset01/system.h b/testsuites/sptests/spcpuset01/system.h
index bc9138d..85571c8 100644
--- a/testsuites/sptests/spcpuset01/system.h
+++ b/testsuites/sptests/spcpuset01/system.h
@@ -10,14 +10,12 @@
 #include "tmacros.h"
 #include "test_support.h"
 /* global variables */
 extern cpu_set_t set1;
 extern cpu_set_t set2;
 extern cpu_set_t set3;
-#endif
 /* enable/disable verbose output */
 #ifndef DPRINT
diff --git a/testsuites/sptests/spcpuset01/test.c b/testsuites/sptests/spcpuset01/test.c
index 494880d..8b4673f 100644
--- a/testsuites/sptests/spcpuset01/test.c
+++ b/testsuites/sptests/spcpuset01/test.c
@@ -11,7 +11,6 @@
 #include <assert.h>
 #include "system.h"
 void test_cpu_and_case_1(size_t cpu1, size_t cpu2);
 void test_cpu_nand_case_1(size_t cpu1, size_t cpu2);
 void test_cpu_or_case_1(size_t cpu1, size_t cpu2);
@@ -124,4 +123,3 @@ void cpuset_logic_test()
-#endif
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index 31a0ec8..f2796d5 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -33,7 +33,6 @@ static const rtems_id invalid_id = 1;
 static void test_task_get_set_affinity(void)
   rtems_id self_id = rtems_task_self();
   rtems_id task_id;
   rtems_status_code sc;
@@ -116,7 +115,6 @@ static void test_task_get_set_affinity(void)
   CPU_FREE(cpusetbig);
   CPU_FREE(cpusetbigone);
 static void task(rtems_task_argument arg)
@@ -217,7 +215,6 @@ static void test_scheduler_ident(void)
 static void test_scheduler_get_processors(void)
   rtems_name name = BLUE;
   rtems_id scheduler_id;
@@ -264,7 +261,6 @@ static void test_scheduler_get_processors(void)
1.7.1
