[PATCH 2/9] i386/pc386: Fix printk formatting warnings.
Mon May 23 06:55:41 UTC 2016
 c/src/lib/libbsp/i386/pc386/console/console_control.c |  2 +-
 c/src/lib/libbsp/i386/pc386/console/exar17d15x.c      |  2 +-
 c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c      | 12 +++++++-----
 c/src/lib/libbsp/i386/pc386/console/inch.c            |  2 ++
 c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c    |  6 +++---
 c/src/lib/libbsp/i386/pc386/ide/ide.c                 | 16 ++++++++++------
 c/src/lib/libbsp/i386/shared/comm/i386-stub.c         |  1 -
 c/src/lib/libbsp/i386/shared/comm/tty_drv.c           |  4 +++-
 8 files changed, 27 insertions(+), 18 deletions(-)
diff --git a/c/src/lib/libbsp/i386/pc386/console/console_control.c b/c/src/lib/libbsp/i386/pc386/console/console_control.c
index 3a454d9..e5e4bc1 100644
--- a/c/src/lib/libbsp/i386/pc386/console/console_control.c
+++ b/c/src/lib/libbsp/i386/pc386/console/console_control.c
@@ -54,7 +54,7 @@ rtems_device_driver console_control(
         break;
       case MW_UID_REGISTER_DEVICE:
-        printk( "SerialMouse: reg=%s\n", args->buffer );
+        printk( "SerialMouse: reg=%s\n", (const char*) args->buffer );
         register_kbd_msg_queue( args->buffer, 0 );
         break;
diff --git a/c/src/lib/libbsp/i386/pc386/console/exar17d15x.c b/c/src/lib/libbsp/i386/pc386/console/exar17d15x.c
index d17c948..83cb029 100644
--- a/c/src/lib/libbsp/i386/pc386/console/exar17d15x.c
+++ b/c/src/lib/libbsp/i386/pc386/console/exar17d15x.c
@@ -166,7 +166,7 @@ rtems_device_driver exar17d15x_initialize(
       &conf[instance].base
     printk(
-      "Found Exar 17D15x %d at 0x%08x IRQ %d with %d ports\n",
+      "Found Exar 17D15x %d at 0x%08lx IRQ %d with %d ports\n",
       instance,
       conf[instance].base,
       conf[instance].irq,
diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
index fa41d01..fa3f00c 100644
--- a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
+++ b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
@@ -42,6 +42,8 @@
  *   - RTEMS fb_cirrus.c - Alexandru-Sever Horin (alex.sever.h at gmail.com)
+#include <inttypes.h>
 #include <bsp.h>
 #include <bsp/fb_default_mode.h>
@@ -785,7 +787,7 @@ void vesa_realmode_bootup_init(void)
     if ((vbe_ret_val&0xff)!=VBE_functionSupported ||
         (vbe_ret_val>>8)!=VBE_callSuccessful)
-        printk(FB_VESA_NAME " Cannot get mode info anymore. ax=0x%x\n",
+        printk(FB_VESA_NAME " Cannot get mode info anymore. ax=0x%lx\n",
             vbe_ret_val);
@@ -822,7 +824,7 @@ void vesa_realmode_bootup_init(void)
     if ((vbe_ret_val&0xff)!= (VBE_functionSupported | VBE_callSuccessful<<8))
         printk(FB_VESA_NAME " Call to function 2h (set VBE mode) failed. "
-            "ax=0x%x\n", vbe_ret_val);
+            "ax=0x%" PRIx32 "\n", vbe_ret_val);
     vib = (void *) 0;
     mib = (void *) 0;
@@ -968,9 +970,9 @@ frame_buffer_control(
   rtems_libio_ioctl_args_t *args = arg;
-  printk( FB_VESA_NAME " ioctl called, cmd=%x\n", args->command  );
-    printk("fbxres %d, fbyres %d\n", fb_var.xres, fb_var.yres);
-    printk("fbbpp %d\n", fb_var.bits_per_pixel);
+  printk( FB_VESA_NAME " ioctl called, cmd=%" PRIx32 "\n", args->command  );
+    printk("fbxres %lu, fbyres %lu\n", fb_var.xres, fb_var.yres);
+    printk("fbbpp %lu\n", fb_var.bits_per_pixel);
   switch (args->command)
diff --git a/c/src/lib/libbsp/i386/pc386/console/inch.c b/c/src/lib/libbsp/i386/pc386/console/inch.c
index e503de5..047269e 100644
--- a/c/src/lib/libbsp/i386/pc386/console/inch.c
+++ b/c/src/lib/libbsp/i386/pc386/console/inch.c
@@ -206,9 +206,11 @@ _IBMPC_scankey(char *outChar)
 static bool
 _IBMPC_chrdy(char *c)
+#if CCJ_REMOVED_NO_IDEA_ABOUT_THIS_CODE_OR_COMMENT
   /* FIX ME!!! It doesn't work without something like the following line.
      Find out why! */
   printk("");
+#endif
   /* Check buffer our ISR builds */
   if (kbd_first != kbd_last)
diff --git a/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c b/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
index 7b48248..e90eb57 100644
--- a/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
+++ b/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
@@ -285,14 +285,14 @@ static uint8_t pci_ns16550_io_get_register(uint32_t addr, uint8_t i)
   uint8_t val = rtems_inb(addr + i);
   if (UART_PCI_IO)
-    printk( "RD(%p -> 0x%02x) ", addr + i, val );
+    printk( "RD(%p -> 0x%02x) ", (void*) addr + i, val );
   return val;
 static void pci_ns16550_io_set_register(uint32_t addr, uint8_t i, uint8_t val)
   if (UART_PCI_IO)
-    printk( "WR(%p <- 0x%02x) ", addr + i, val );
+    printk( "WR(%p <- 0x%02x) ", (void*) addr + i, val );
   rtems_outb(addr + i, val);
@@ -453,7 +453,7 @@ void pci_uart_probe(void)
         printk(
-          "%s:%d:%s,%s:0x%x%s%s,irq:%d,clk:%d\n", /*  */
+          "%s:%d:%s,%s:0x%lx%s%s,irq:%d,clk:%lu\n", /*  */
 	  name, b, conf[b].desc,
 	  io ? "io" : "mem", base, locatable, prefectable,
 	  conf[b].irq, conf[b].clock
diff --git a/c/src/lib/libbsp/i386/pc386/ide/ide.c b/c/src/lib/libbsp/i386/pc386/ide/ide.c
index 73b6df2..52877cf 100644
--- a/c/src/lib/libbsp/i386/pc386/ide/ide.c
+++ b/c/src/lib/libbsp/i386/pc386/ide/ide.c
@@ -23,7 +23,10 @@
 | 01.14.03  creation                                         doe  |
 #include <bsp.h>
 #include <libchip/ide_ctrl.h>
 #include <libchip/ide_ctrl_cfg.h>
@@ -199,7 +202,7 @@ static void pc386_ide_initialize
   uint8_t  dev = 0;
   if (pc386_ide_show)
-    printk("IDE%d: port base: %04x\n", minor, port);
+    printk("IDE%d: port base: %04" PRIu32 "\n", minor, port);
   outport_byte(port+IDE_REGISTER_DEVICE_HEAD,
                (dev << IDE_REGISTER_DEVICE_HEAD_DEV_POS) | 0xE0);
@@ -303,7 +306,7 @@ static void pc386_ide_initialize
       uint16_t word;
       if (pc386_ide_show && ((byte % 16) == 0))
-        printk("\n %04x : ", byte);
+        printk("\n %04" PRIx32 " : ", byte);
       inport_word(port+IDE_REGISTER_DATA, word);
@@ -346,7 +349,7 @@ static void pc386_ide_initialize
     if (pc386_ide_show)
-      printk("\nbytes read = %d\n", byte);
+      printk("\nbytes read = %" PRIu32 "\n", byte);
     if (p != &model_number[0])
@@ -388,7 +391,7 @@ static void pc386_ide_initialize
         p--;
-      printk("IDE%d:%s:%s, %u.%u%c (%u/%u/%u), max blk size:%d\n",
+      printk("IDE%d:%s:%s, %" PRIu32 ".%" PRIu32 "%c (%" PRIu32 "/%" PRIu32 "/%" PRIu32 "), max blk size:%d\n",
              minor, label, model_number, left, right, units,
              heads, cylinders, sectors, max_multiple_sectors * 512);
@@ -541,7 +544,8 @@ static void pc386_ide_read_block
     if (!pc386_ide_status_data_ready (port, pc386_ide_timeout,
                                       &status_val, pc386_ide_tasking_sleep))
-      printk ("pc386_ide_read_block: block=%u cbuf=%u status=%02x, cnt=%d bs=%d\n",
+      printk ("pc386_ide_read_block: block=%" PRIu32 \
+              " cbuf=%" PRIu32 " status=%02x, cnt=%" PRIu32 " bs=%" PRIu32 "\n",
               bufs[*cbuf].block, *cbuf, status_val, cnt, block_size);
       /* FIXME: add an error here. */
       return;
@@ -620,7 +624,7 @@ static void pc386_ide_write_block
-      printk ("pc386_ide_write_block: block=%u status=%02x, cnt=%d bs=%d\n",
+      printk ("pc386_ide_write_block: block=%" PRIu32 " status=%02x, cnt=%" PRIu32 " bs=%" PRIu32 "\n",
               bufs[*cbuf].block, status_val, cnt, block_size);
       return;
diff --git a/c/src/lib/libbsp/i386/shared/comm/i386-stub.c b/c/src/lib/libbsp/i386/shared/comm/i386-stub.c
index d28a431..1eff100 100644
--- a/c/src/lib/libbsp/i386/shared/comm/i386-stub.c
+++ b/c/src/lib/libbsp/i386/shared/comm/i386-stub.c
@@ -1032,7 +1032,6 @@ handle_exception (int exceptionVector)
 	  if (*(ptr++) == ',')
 	      bool insert = remcomInBuffer[0] == 'Z';
-	      printk("hbreak type\n", insert);
 	      if (hexToInt (&ptr, &addr))
diff --git a/c/src/lib/libbsp/i386/shared/comm/tty_drv.c b/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
index 16a40df..bbc22af 100644
--- a/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
+++ b/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
@@ -16,6 +16,7 @@
 #include <assert.h>
@@ -262,7 +263,8 @@ conSetAttr(int port, int minor, const struct termios *t)
     stopbits = 0;
-  printk("Setting attributes, port=%X, baud=%d, linemode = 0x%02x\n", port, baud, databits | parity | stopbits );
+  printk("Setting attributes, port=%X, baud=%" PRId32 ", linemode = 0x%02" PRIx32 "\n",
+         port, baud, databits | parity | stopbits );
   BSP_uart_set_attributes(port, baud, databits, parity, stopbits);
   return 0;
2.4.6
