[PATCH 9/9] testsuite: Fix printk format warnings.
Mon May 23 06:55:48 UTC 2016
 testsuites/libtests/block08/bdbuf_test1_1.c | 13 ++++----
 testsuites/libtests/block08/bdbuf_test1_2.c |  9 +++---
 testsuites/libtests/block08/bdbuf_test1_3.c |  9 +++---
 testsuites/libtests/block08/bdbuf_test1_4.c | 20 ++++++-------
 testsuites/libtests/block08/bdbuf_test1_5.c | 11 ++++---
 testsuites/libtests/block08/bdbuf_test2_1.c | 13 ++++----
 testsuites/libtests/block08/bdbuf_test2_2.c | 16 +++++-----
 testsuites/libtests/block08/bdbuf_test3_1.c | 20 ++++++-------
 testsuites/libtests/block08/bdbuf_test3_2.c |  5 ++--
 testsuites/libtests/block08/bdbuf_test3_3.c |  9 +++---
 testsuites/libtests/block08/bdbuf_test4_1.c | 10 +++----
 testsuites/libtests/block08/bdbuf_test4_2.c |  4 +--
 testsuites/libtests/block08/bdbuf_test4_3.c |  4 +--
 testsuites/libtests/block08/bdbuf_tests.h   | 46 ++++++++++++++---------------
 testsuites/libtests/block08/test_disk.c     |  5 ++--
 testsuites/sptests/spfatal_support/init.c   |  2 +-
 testsuites/sptests/spprintk/init.c          | 12 ++++----
 17 files changed, 94 insertions(+), 114 deletions(-)
diff --git a/testsuites/libtests/block08/bdbuf_test1_1.c b/testsuites/libtests/block08/bdbuf_test1_1.c
index 5514948..c4f242c 100644
--- a/testsuites/libtests/block08/bdbuf_test1_1.c
+++ b/testsuites/libtests/block08/bdbuf_test1_1.c
@@ -1,19 +1,19 @@
 /*! @file
- * @brief Check the behaviour of rtems_bdbuf_read() function
+ * @brief Check the behaviour of rtems_bdbuf_read() function
  * with different reports from disk device driver.
  * Test sequence:
- * -# Call rtems_bdbuf_read() function and return 0 from disk device
+ * -# Call rtems_bdbuf_read() function and return 0 from disk device
  *    driver ioctl() function, and the result of asynchronous read
  *    complete notification is successful.
  * -# Check that rtems_bdbuf_read() returns RTEMS_SUCCESSFUL and
  *    provides buffer descriptor.
  * -# Call rtems_bdbuf_read() function and return -1 from disk device
- *    driver ioctl() function (there will be no asynchronous read
+ *    driver ioctl() function (there will be no asynchronous read
  *    complete notification).
  * -# Check that rtems_bdbuf_read() returns RTEMS_IO_ERROR.
- *    driver ioctl() function, but the result of asynchronous read
+ *    driver ioctl() function, but the result of asynchronous read
  *    complete notification is faulty (with some erroneous status).
  * -# Check that rtems_bdbuf_read() returns that status and does not
  *    return buffer descriptor.
@@ -47,7 +47,7 @@ bdbuf_test1_1_main()
      * Create working thread that will call rtems_bdbuf_read() function.
     START_THREAD(1, bdbuf_test1_1_thread1);
      * Step 1:
      * Check that rtems_bdbuf_read() returns RTEMS_SUCCESSFUL
@@ -91,7 +91,7 @@ bdbuf_test1_1_main()
     CONTINUE_THREAD(1);
-    TEST_END();
+    TEST_STOP();
@@ -147,4 +147,3 @@ bdbuf_test1_1_thread1(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test1_2.c b/testsuites/libtests/block08/bdbuf_test1_2.c
index 5a6feb1..94ed4dd 100644
--- a/testsuites/libtests/block08/bdbuf_test1_2.c
+++ b/testsuites/libtests/block08/bdbuf_test1_2.c
@@ -4,7 +4,7 @@
  * driver reports failure in read complete notification.
  * Test sequence:
- * -# Call rtems_bdbuf_read() function in thread #1 and block on
+ * -# Call rtems_bdbuf_read() function in thread #1 and block on
  *    waiting for read complete notification.
  * -# Call rtems_bdbuf_read() function in thread #2 for the same
  *    block number. As the result it blocks on this read as well
@@ -58,7 +58,7 @@ bdbuf_test1_2_main()
      * Step 2:
-     * Thread #2 calls rtems_bdbuf_read() for the same
+     * Thread #2 calls rtems_bdbuf_read() for the same
      * block number, as the result it shall block waiting
      * on buffer state change.
@@ -86,7 +86,7 @@ bdbuf_test1_2_main()
      * As the result we will get read call to device driver.
     WAIT_DRV_MSG(&msg);
     /* Check that thread #2 is still blocked */
     CHECK_THREAD_BLOCKED(2);
@@ -102,7 +102,7 @@ bdbuf_test1_2_main()
     CONTINUE_THREAD(2);
     TEST_CHECK_RESULT("5");
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -160,4 +160,3 @@ bdbuf_test1_2_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test1_3.c b/testsuites/libtests/block08/bdbuf_test1_3.c
index 6e57565..4b002b3 100644
--- a/testsuites/libtests/block08/bdbuf_test1_3.c
+++ b/testsuites/libtests/block08/bdbuf_test1_3.c
@@ -1,6 +1,6 @@
 /*! @file
  * @brief Check how rtems_bdbuf_read() handles two readers waiting
- * for a buffer with the same block number in cases when disk device
+ * for a buffer with the same block number in cases when disk device
  * Test sequence:
@@ -16,7 +16,7 @@
  *    again so disk device ioctl() function is called again for this
  *    block number.
  * -# This time disk device reports success in read complete notification.
- *    As the result rtems_bdbuf_read() in thread #2 shall return
+ *    As the result rtems_bdbuf_read() in thread #2 shall return
  *    RTEMS_SUCCESSFUL and provide buffer descriptor.
  * -# Call rtems_bdbuf_release() function in thread #2.
@@ -59,7 +59,7 @@ bdbuf_test1_3_main()
      * Step 2:
@@ -111,7 +111,7 @@ bdbuf_test1_3_main()
     CONTINUE_THREAD(2);
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -176,4 +176,3 @@ bdbuf_test1_3_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test1_4.c b/testsuites/libtests/block08/bdbuf_test1_4.c
index 3e54a1c..a140ebb 100644
--- a/testsuites/libtests/block08/bdbuf_test1_4.c
+++ b/testsuites/libtests/block08/bdbuf_test1_4.c
@@ -1,6 +1,6 @@
 /*! @file
  * driver reports success in read complete notification.
  * Test sequence:
@@ -13,7 +13,7 @@
  *    As the result rtems_bdbuf_read() function returns RTEMS_SUCCESSFUL
  *    in thread #1.
  * -# Thread #1 releases buffer with rtems_bdbuf_release() function.
- * -# rtems_bdbuf_read() function in thread #2 unlocks and
+ * -# rtems_bdbuf_read() function in thread #2 unlocks and
  *    returns RTEMS_SUCCESSFUL.
@@ -57,7 +57,7 @@ bdbuf_test1_4_main()
      * Step 2:
      * on buffer state change (waiting on TRANSFER state).
@@ -79,7 +79,7 @@ bdbuf_test1_4_main()
     WAIT_THREAD_SYNC(1);
     TEST_CHECK_RESULT("3");
      * Check that thread #2 is still blocked.
@@ -104,7 +104,7 @@ bdbuf_test1_4_main()
     CONTINUE_THREAD(2);
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -119,8 +119,8 @@ bdbuf_test1_4_thread1(rtems_task_argument arg)
      * We will block on this read and meanwhile
      * thread #2 will try to read the same block.
      * After blocking on read in thread #2, device
-     * driver will notify successful completion of
-     * date transfer, and as the result this call
+     * driver will notify successful completion of
+     * date transfer, and as the result this call
      * will return valid buffer.
     rc = rtems_bdbuf_read(test_dd, TEST_BLK_NUM, &bd);
@@ -156,8 +156,8 @@ bdbuf_test1_4_thread2(rtems_task_argument arg)
      * on data transfer operation, so we will block here as well.
      * Step 5:
-     * On step 4 thread #1 releases buffer and as the result
-     * our read operation should finish with success.
+     * On step 4 thread #1 releases buffer and as the result
+     * our read operation should finish with success.
     if (rc != RTEMS_SUCCESSFUL)
@@ -177,5 +177,3 @@ bdbuf_test1_4_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test1_5.c b/testsuites/libtests/block08/bdbuf_test1_5.c
index 1a33cca..7dfab8e 100644
--- a/testsuites/libtests/block08/bdbuf_test1_5.c
+++ b/testsuites/libtests/block08/bdbuf_test1_5.c
@@ -3,7 +3,7 @@
  * for a buffer that is owned by an application.
  * Test sequence:
  *    provide successful read complete notification for this operation.
  *    As the result rtems_bdbuf_read() returns RTEMS_SUCCESSFUL
  *    in thread #1.
@@ -13,7 +13,7 @@
  * -# Call rtems_bdbuf_release() function in thread #1 in order to give
  *    it back under control of bdbuf library.
  * -# Buffer now is ready to be returned for another application and
- *    as the result rtems_bdbuf_read() unblocks and returns
+ *    as the result rtems_bdbuf_read() unblocks and returns
  *    RTEMS_SUCCESSFUL in thread #2.
@@ -56,7 +56,7 @@ bdbuf_test1_5_main()
     TEST_CHECK_RESULT("1");
      * Step 2:
      * Thread #2 calls rtems_bdbuf_read() and blocks
@@ -85,8 +85,8 @@ bdbuf_test1_5_main()
      * Thread #2 release buffer.
     CONTINUE_THREAD(2);
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -145,4 +145,3 @@ bdbuf_test1_5_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test2_1.c b/testsuites/libtests/block08/bdbuf_test2_1.c
index c24cf07..4e8b1a6 100644
--- a/testsuites/libtests/block08/bdbuf_test2_1.c
+++ b/testsuites/libtests/block08/bdbuf_test2_1.c
@@ -62,7 +62,7 @@ bdbuf_test2_1_main()
      * Step 2:
@@ -121,7 +121,7 @@ bdbuf_test2_1_main()
     WAIT_DRV_MSG_WR(&msg);
     SEND_DRV_MSG(0, 0, RTEMS_SUCCESSFUL, 0);
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -136,8 +136,8 @@ bdbuf_test2_1_thread1(rtems_task_argument arg)
@@ -173,8 +173,8 @@ bdbuf_test2_1_thread2(rtems_task_argument arg)
      * Step 5:
@@ -194,4 +194,3 @@ bdbuf_test2_1_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test2_2.c b/testsuites/libtests/block08/bdbuf_test2_2.c
index d9f3489..7f65e69 100644
--- a/testsuites/libtests/block08/bdbuf_test2_2.c
+++ b/testsuites/libtests/block08/bdbuf_test2_2.c
@@ -9,7 +9,7 @@
  * Test sequence:
- * -# Call rtems_bdbuf_read() function in thread #2 for
+ * -# Call rtems_bdbuf_read() function in thread #2 for
  *    the same block number. As the result it blocks on this read
  *    as well (but it will block on transfer semaphore).
  * -# Disk device reports success in read complete notification.
@@ -62,7 +62,7 @@ bdbuf_test2_2_main()
      * Step 2:
@@ -121,7 +121,7 @@ bdbuf_test2_2_main()
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -136,8 +136,8 @@ bdbuf_test2_2_thread1(rtems_task_argument arg)
@@ -173,8 +173,8 @@ bdbuf_test2_2_thread2(rtems_task_argument arg)
      * Step 5:
@@ -194,5 +194,3 @@ bdbuf_test2_2_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test3_1.c b/testsuites/libtests/block08/bdbuf_test3_1.c
index 11ed0cb..a952f48 100644
--- a/testsuites/libtests/block08/bdbuf_test3_1.c
+++ b/testsuites/libtests/block08/bdbuf_test3_1.c
@@ -3,7 +3,7 @@
  * Test sequence:
  * -# In thread #1 call rtems_bdbuf_get(#N) to get an empty block #N.
- * -# In thread #1 call rtems_bdbuf_release_modified() for previously
+ * -# In thread #1 call rtems_bdbuf_release_modified() for previously
  *    got buffer.
  * -# In thread #1 call rtems_bdbuf_read(#N) to get the same buffer
  *    (after this call a buffer is in AVL tree with ACCESS_MODIFIED state).
@@ -79,7 +79,7 @@ bdbuf_test3_1_main()
     WAIT_THREAD_SYNC(2);
      * Release buffer in thread #2
     CONTINUE_THREAD(2);
@@ -91,7 +91,7 @@ bdbuf_test3_1_main()
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -107,11 +107,11 @@ bdbuf_test3_1_thread1(rtems_task_argument arg)
      * it in AVL tree with ACCESS state.
      * Step 2:
      * Call release_modified(bd);
-     * [Now we have one entry in modified list and it is still
+     * [Now we have one entry in modified list and it is still
      * in AVL tree with MODIFIED state]
-     * Step 3:
+     * Step 3:
      * Call read(#N) to get the same buffer.
-     * [An entry is found in AVL tree, removed from modified list and
+     * [An entry is found in AVL tree, removed from modified list and
      * returned with state ACCESS_MODIFIED]
     rc = rtems_bdbuf_get(test_dd, TEST_BLK_NUM_N, &bd);
@@ -119,7 +119,7 @@ bdbuf_test3_1_thread1(rtems_task_argument arg)
         TEST_FAILED();
     rc = rtems_bdbuf_release_modified(bd);
@@ -136,7 +136,7 @@ bdbuf_test3_1_thread1(rtems_task_argument arg)
     /* Step 5:
      * Call rtems_bdbuf_release(#N).
-     * As the result buffer will be used by bdbuf to get
+     * As the result buffer will be used by bdbuf to get
      * buffer #M for thread #2.
     rc = rtems_bdbuf_release(bd);
@@ -161,7 +161,7 @@ bdbuf_test3_1_thread2(rtems_task_argument arg)
      * In thread #2 call read/get(#M)
      * [We ask for block number #M - there is no such entry in AVL,
      * and all the lists are empty (ready, lru, modified), as a result
-     * this thread blocks on
+     * this thread blocks on
      * rtems_bdbuf_wait(pool, &pool->waiting, &pool->wait_waiters)]
     rc = rtems_bdbuf_get(test_dd, TEST_BLK_NUM_M, &bd);
@@ -182,5 +182,3 @@ bdbuf_test3_1_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test3_2.c b/testsuites/libtests/block08/bdbuf_test3_2.c
index 312a75b..e9cfc9e 100644
--- a/testsuites/libtests/block08/bdbuf_test3_2.c
+++ b/testsuites/libtests/block08/bdbuf_test3_2.c
@@ -102,7 +102,7 @@ bdbuf_test3_2_main()
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -187,7 +187,7 @@ bdbuf_test3_2_thread3(rtems_task_argument arg)
     printk("Thread #3 DEBLOCK\n");
     CONTINUE_MAIN(3);
@@ -196,4 +196,3 @@ bdbuf_test3_2_thread3(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test3_3.c b/testsuites/libtests/block08/bdbuf_test3_3.c
index 749f8e5..9b3080b 100644
--- a/testsuites/libtests/block08/bdbuf_test3_3.c
+++ b/testsuites/libtests/block08/bdbuf_test3_3.c
@@ -1,7 +1,7 @@
 /*! @file
  * @brief Check how read/release work in case of only one buffer in ready list.
- * The same as Test 3.2, but instead of calling rtems_bdbuf_get() in
+ * The same as Test 3.2, but instead of calling rtems_bdbuf_get() in
  * threads #1 and #2, it calls rtems_bdbuf_read().
  * Test sequence:
@@ -13,7 +13,7 @@
  * -# Call rtems_bdbuf_release(#N1) in thread #1.
  * -# Check that only one thread (thread #2 or thread #3) got a buffer.
  *    Another thread shall still be blocked.
- * -# Call rtems_bdbuf_release(#N2) in thread #2 and check that
+ * -# Call rtems_bdbuf_release(#N2) in thread #2 and check that
  *    thread #3 got a buffer as the result.
@@ -113,7 +113,7 @@ bdbuf_test3_3_main()
     CHECK_NO_DRV_MSG();
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -198,7 +198,7 @@ bdbuf_test3_3_thread3(rtems_task_argument arg)
     CONTINUE_MAIN(3);
@@ -207,4 +207,3 @@ bdbuf_test3_3_thread3(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test4_1.c b/testsuites/libtests/block08/bdbuf_test4_1.c
index 4c2eb0a..c39469e 100644
--- a/testsuites/libtests/block08/bdbuf_test4_1.c
+++ b/testsuites/libtests/block08/bdbuf_test4_1.c
@@ -59,7 +59,7 @@ bdbuf_test4_1_main()
      * Call rtems_bdbuf_read(#N) in thread #2.
     CONTINUE_THREAD(2);
     /* Make sure that thread #2 blocks */
     TEST_CHECK_RESULT("2");
@@ -70,7 +70,7 @@ bdbuf_test4_1_main()
     CONTINUE_THREAD(1);
      * Setp 4:
      * Wait for Write request to device driver.
@@ -107,7 +107,7 @@ bdbuf_test4_1_main()
     CONTINUE_THREAD(1);
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -127,7 +127,7 @@ bdbuf_test4_1_thread1(rtems_task_argument arg)
     CONTINUE_MAIN(1);
      * Step 3:
      * Call rtems_bdbuf_sync(#N)
@@ -174,5 +174,3 @@ bdbuf_test4_1_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test4_2.c b/testsuites/libtests/block08/bdbuf_test4_2.c
index 455b1b5..67b4706 100644
--- a/testsuites/libtests/block08/bdbuf_test4_2.c
+++ b/testsuites/libtests/block08/bdbuf_test4_2.c
@@ -94,7 +94,7 @@ bdbuf_test4_2_main()
     /* Exit from thread #1 */
     CONTINUE_THREAD(1);
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -159,5 +159,3 @@ bdbuf_test4_2_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_test4_3.c b/testsuites/libtests/block08/bdbuf_test4_3.c
index b1b44f9..f8cae2f 100644
--- a/testsuites/libtests/block08/bdbuf_test4_3.c
+++ b/testsuites/libtests/block08/bdbuf_test4_3.c
@@ -88,7 +88,7 @@ bdbuf_test4_3_main()
     CONTINUE_THREAD(1);
-    TEST_END();
+    TEST_STOP();
 static rtems_task
@@ -153,5 +153,3 @@ bdbuf_test4_3_thread2(rtems_task_argument arg)
     THREAD_END();
diff --git a/testsuites/libtests/block08/bdbuf_tests.h b/testsuites/libtests/block08/bdbuf_tests.h
index 3f92c5d..1a0703f 100644
--- a/testsuites/libtests/block08/bdbuf_tests.h
+++ b/testsuites/libtests/block08/bdbuf_tests.h
@@ -12,6 +12,7 @@
 #ifndef BDBUF_TESTS_H
 #define BDBUF_TESTS_H
+#include <inttypes.h>
@@ -74,8 +75,8 @@ enum bdbuf_test_msg_type {
  * Message used in communication between test disk driver
  * and main test task.
  * All R/W requests obtained by driver (from bdbuf library)
- * are directed to main test task. Then main test task
- * sends a reply after which test disk driver notifies
+ * are directed to main test task. Then main test task
+ * sends a reply after which test disk driver notifies
  * bdbuf library about operation complete event.
 typedef struct bdbuf_test_msg {
@@ -111,7 +112,7 @@ typedef struct test_ctx {
      * disk device driver.
     Objects_Id test_qid;
      * Object ID for disk driver queue.
      * Test task will send messages to this queue in reply
@@ -122,7 +123,7 @@ typedef struct test_ctx {
     /** Test name */
     const char *test_name;
      * Semaphore used for synchronization between test thread
      * Main test task blocks on one of these semaphores and an auxiliary thread
@@ -210,7 +211,7 @@ extern bool       good_test_result;
     } while (0)
- * Start thread number @p t_num_ with @p func_ function
+ * Start thread number @p t_num_ with @p func_ function
  * as an entry point of the thread.
  * @param t_num_  thread number.
@@ -255,20 +256,20 @@ extern bool       good_test_result;
     } while (0)
 #define WAIT_DRV_MSG_WR(msg_) \
-    do {        \
-        WAIT_DRV_MSG(msg_);                                             \
-        if ((msg_)->val.driver_req.req != RTEMS_BLKIO_REQUEST ||        \
-            (msg_)->val.driver_req.dd != test_dd ||                   \
-            ((rtems_blkdev_request *)                                   \
-                 ((msg_)->val.driver_req.argp))->req !=                 \
-                 RTEMS_BLKDEV_REQ_WRITE)                                \
-            printk("Unexpected message received by disk driver: "       \
-                   "req - 0x%x (0x%x), dev - %d (%d)\n",                \
-                   (msg_)->val.driver_req.req, RTEMS_BLKIO_REQUEST,     \
-                   (msg_)->val.driver_req.dd, test_dd);               \
-            return;                                                     \
+  do {        \
+        WAIT_DRV_MSG(msg_);                                                \
+        if ((msg_)->val.driver_req.req != RTEMS_BLKIO_REQUEST ||           \
+            (msg_)->val.driver_req.dd != test_dd ||                        \
+            ((rtems_blkdev_request *)                                      \
+                 ((msg_)->val.driver_req.argp))->req !=                    \
+                 RTEMS_BLKDEV_REQ_WRITE)                                   \
+            printk("Unexpected message received by disk driver: "          \
+                   "req - 0x%" PRIx32 " (0x%" PRIx32 "), dev - %p (%p)\n", \
+                   (msg_)->val.driver_req.req, RTEMS_BLKIO_REQUEST,        \
+                   (msg_)->val.driver_req.dd, test_dd);                    \
+            return;                                                        \
     } while (0)
 #define CHECK_NO_DRV_MSG() \
@@ -298,7 +299,7 @@ extern bdbuf_test_msg test_drv_msg;
  *                     ioctl() function.
  * @param ret_errno_   errno value to set to errno variable.
  * @param res_status_  In case return value from the ioctl()
- *                     function is equal to 0, this value
+ *                     function is equal to 0, this value
  *                     is used as status code in asynchronous
  *                     notification.
  * @param res_errno_   In case return value from the ioctl()
@@ -333,7 +334,7 @@ extern bdbuf_test_msg test_drv_msg;
  * Block main test task until a thread passes back control
  * with CONTINUE_MAIN().
- * @param t_num_  thread number from which the main thread
+ * @param t_num_  thread number from which the main thread
  *                is waiting for a sync.
 #define WAIT_THREAD_SYNC(t_num_) \
@@ -457,7 +458,7 @@ extern bdbuf_test_msg test_drv_msg;
     } while (0)
-#define TEST_END() \
+#define TEST_STOP() \
     do {                                 \
         bdbuf_test_end();                \
@@ -500,4 +501,3 @@ bdbuf_test_start_aux_task(rtems_name name,
 #endif
 #endif /* BDBUF_TESTS_H */
diff --git a/testsuites/libtests/block08/test_disk.c b/testsuites/libtests/block08/test_disk.c
index c107687..9a4c5bf 100644
--- a/testsuites/libtests/block08/test_disk.c
+++ b/testsuites/libtests/block08/test_disk.c
@@ -51,14 +51,14 @@ test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
                    r->req == RTEMS_BLKDEV_REQ_WRITE ? "W" : "?");
             for (i = 0, sg = r->bufs; i < r->bufnum; i++, sg++)
-                printk("[%d] ", sg->block);
+                printk("[%" PRIu32 "] ", sg->block);
             printk("\n");
             break;
         default:
-            printk("%s() Unexpected request comes %u\n",
+            printk("%s() Unexpected request comes %" PRIu32 "\n",
                    __FUNCTION__, req);
             return -1;
@@ -151,4 +151,3 @@ test_disk_initialize(
     printk("TEST DISK - OK\n");
     return RTEMS_SUCCESSFUL;
diff --git a/testsuites/sptests/spfatal_support/init.c b/testsuites/sptests/spfatal_support/init.c
index f048d4b..319dbd2 100644
--- a/testsuites/sptests/spfatal_support/init.c
+++ b/testsuites/sptests/spfatal_support/init.c
@@ -43,7 +43,7 @@ void Put_Error( uint32_t source, uint32_t error )
   else if (source == INTERNAL_ERROR_RTEMS_API ){
     if (error >  RTEMS_NOT_IMPLEMENTED )
-      printk("Unknown Internal Rtems Error (0x%08x)", error);
+      printk("Unknown Internal Rtems Error (0x%08" PRIx32 ")", error);
     else
       printk( "%s", rtems_status_text( error ) );
diff --git a/testsuites/sptests/spprintk/init.c b/testsuites/sptests/spprintk/init.c
index 8086a1a..4b45450 100644
--- a/testsuites/sptests/spprintk/init.c
+++ b/testsuites/sptests/spprintk/init.c
@@ -13,12 +13,6 @@
 #include "config.h"
 #endif
-#define TESTS_USE_PRINTK
-#include <tmacros.h>
-#include <rtems/print.h>
-const char rtems_test_name[] = "SPPRINTK";
  * Undefined the RTEMS_PRINTF_ATTRIBUTE and make it nothing. The test code
  * contained in the file is suppose to be wrong.
@@ -26,6 +20,12 @@ const char rtems_test_name[] = "SPPRINTK";
 #undef RTEMS_PRINTF_ATTRIBUTE
 #define RTEMS_PRINTF_ATTRIBUTE(_a, _b)
+#define TESTS_USE_PRINTK
+#include <tmacros.h>
+#include <rtems/print.h>
+const char rtems_test_name[] = "SPPRINTK";
 /* forward declarations to avoid warnings */
 rtems_task Init(rtems_task_argument argument);
 int test_getchar(void);
2.4.6
