[PATCH 1/9] cpukit, testsuite: Add rtems_printf and rtems_printer support.
Mon May 23 12:37:52 UTC 2016
How does this affect user applications?
On Mon, May 23, 2016 at 2:55 AM, Chris Johns <chrisj at rtems.org> wrote:
> This change adds rtems_printf and related functions and wraps the
> RTEMS print plugin support into a user API. All references to the
> plugin are removed and replaced with the rtems_printer interface.
> Printk and related functions are made to return a valid number of
> characters formatted and output.
> The function attribute to check printf functions has been added
> to rtems_printf and printk. No changes to remove warrnings are part
> of this patch set.
> The testsuite has been moved over to the rtems_printer. The testsuite
> has a mix of rtems_printer access and direct print control via the
> tmacros.h header file. The support for begink/endk has been removed
> as it served no purpose and only confused the code base. The testsuite
> has not been refactored to use rtems_printf. This is future work.
>  c/src/lib/libbsp/shared/include/irq-info.h    |   5 +-
>  c/src/lib/libbsp/shared/src/irq-info.c        |  29 ++---
>  c/src/lib/libbsp/shared/src/irq-shell.c       |   4 +-
>  cpukit/Makefile.am                            |   1 +
>  cpukit/include/rtems/bspIo.h                  |  33 ++++--
>  cpukit/include/rtems/print.h                  | 134 +++++++++++++++++++++++
>  cpukit/libblock/include/rtems/blkdev.h        |   7 +-
>  cpukit/libblock/src/blkdev-blkstats.c         |  17 ++-
>  cpukit/libblock/src/blkdev-print-stats.c      |   7 +-
>  cpukit/libcsupport/Makefile.am                |   2 +
>  cpukit/libcsupport/src/print_fprintf.c        |  29 +++++
>  cpukit/libcsupport/src/print_printf.c         |  52 +++++++++
>  cpukit/libcsupport/src/printf_plugin.c        |  18 ++--
>  cpukit/libcsupport/src/printk.c               |   9 +-
>  cpukit/libcsupport/src/printk_plugin.c        |  22 ++--
>  cpukit/libcsupport/src/putk.c                 |   8 +-
>  cpukit/libcsupport/src/vprintk.c              |  28 +++--
>  cpukit/libmisc/cpuuse/cpuusagereport.c        |  28 +++--
>  cpukit/libmisc/cpuuse/cpuusagetop.c           | 147 ++++++++++----------------
>  cpukit/libmisc/cpuuse/cpuuse.h                |  14 +--
>  cpukit/libmisc/fb/mw_print.c                  |  23 ++--
>  cpukit/libmisc/fb/mw_uid.h                    |   9 +-
>  cpukit/libmisc/shell/main_blkstats.c          |   7 +-
>  cpukit/libmisc/shell/main_cpuuse.c            |   4 +-
>  cpukit/libmisc/shell/main_perioduse.c         |   5 +-
>  cpukit/libmisc/shell/main_profreport.c        |   5 +-
>  cpukit/libmisc/shell/main_stackuse.c          |   7 +-
>  cpukit/libmisc/shell/main_top.c               |   4 +-
>  cpukit/libmisc/stackchk/check.c               |  36 +++----
>  cpukit/libmisc/stackchk/stackchk.h            |   5 +-
>  cpukit/libmisc/testsupport/test.h             |  60 +++--------
>  cpukit/libmisc/testsupport/testbeginend.c     |  39 ++++---
>  cpukit/libmisc/testsupport/testextension.c    |   6 +-
>  cpukit/preinstall.am                          |   4 +
>  cpukit/rtems/include/rtems/rtems/ratemon.h    |  13 ++-
>  cpukit/rtems/src/ratemonreportstatistics.c    |  27 +++--
>  cpukit/sapi/include/rtems/profiling.h         |  21 +---
>  cpukit/sapi/src/profilingreportxml.c          | 106 +++++++++----------
>  cpukit/score/src/cpusetprintsupport.c         |  30 +++---
>  testsuites/fstests/fsnofs01/init.c            |   4 +-
>  testsuites/libtests/block02/init.c            |   5 +-
>  testsuites/libtests/block03/init.c            |   5 +-
>  testsuites/libtests/block04/init.c            |   5 +-
>  testsuites/libtests/block05/init.c            |   5 +-
>  testsuites/libtests/block06/init.c            |   2 +-
>  testsuites/libtests/block07/init.c            |   6 +-
>  testsuites/libtests/block08/init.c            |   7 +-
>  testsuites/libtests/block09/init.c            |   7 +-
>  testsuites/libtests/block10/init.c            |   7 +-
>  testsuites/libtests/block14/init.c            |   5 +-
>  testsuites/libtests/capture01/init.c          |   3 +
>  testsuites/libtests/complex/init.c            |   4 +-
>  testsuites/libtests/devnullfatal01/testcase.h |   3 +-
>  testsuites/libtests/exit01/init.c             |   8 +-
>  testsuites/libtests/exit02/init.c             |   8 +-
>  testsuites/libtests/math/init.c               |   7 +-
>  testsuites/libtests/mathf/init.c              |   5 +-
>  testsuites/libtests/mathl/init.c              |   4 +-
>  testsuites/libtests/mouse01/init.c            |  13 +--
>  testsuites/libtests/stackchk/init.c           |   2 +-
>  testsuites/libtests/stackchk/system.h         |   1 +
>  testsuites/libtests/uid01/init.c              |   9 +-
>  testsuites/psxtests/psxfatal_support/init.c   |   8 +-
>  testsuites/samples/capture/init.c             |   2 +
>  testsuites/samples/hello/init.c               |   2 +
>  testsuites/samples/paranoia/init.c            |   2 +
>  testsuites/smptests/smp05/init.c              |   4 +-
>  testsuites/smptests/smp07/init.c              |  14 +--
>  testsuites/smptests/smpfatal01/init.c         |  10 +-
>  testsuites/smptests/smpfatal02/init.c         |  10 +-
>  testsuites/smptests/smpfatal04/init.c         |   8 +-
>  testsuites/smptests/smpfatal05/init.c         |   8 +-
>  testsuites/smptests/smpfatal08/init.c         |   8 +-
>  testsuites/sptests/sperror01/init.c           |   4 +-
>  testsuites/sptests/sperror02/init.c           |   6 +-
>  testsuites/sptests/sperror03/init.c           |   5 +-
>  testsuites/sptests/spextensions01/init.c      |   9 +-
>  testsuites/sptests/spfatal07/testcase.h       |   2 +-
>  testsuites/sptests/spfatal16/testcase.h       |   4 +-
>  testsuites/sptests/spfatal26/init.c           |   5 +-
>  testsuites/sptests/spfatal_support/init.c     |   5 +-
>  testsuites/sptests/spfatal_support/system.h   |   6 +-
>  testsuites/sptests/spinternalerror01/init.c   |   9 +-
>  testsuites/sptests/spprintk/init.c            |  17 ++-
>  testsuites/sptests/spprofiling01/init.c       |   4 +-
>  testsuites/sptests/spsysinit01/init.c         |   8 +-
>  testsuites/sptests/sptimecounter01/init.c     |   9 +-
>  testsuites/support/include/buffer_test_io.h   |  16 ++-
>  testsuites/support/include/test_support.h     |   2 -
>  testsuites/support/src/locked_print.c         |  42 +++++---
>  90 files changed, 802 insertions(+), 557 deletions(-)
>  create mode 100644 cpukit/include/rtems/print.h
>  create mode 100644 cpukit/libcsupport/src/print_fprintf.c
>  create mode 100644 cpukit/libcsupport/src/print_printf.c
> diff --git a/c/src/lib/libbsp/shared/include/irq-info.h b/c/src/lib/libbsp/shared/include/irq-info.h
> index df85c8e..ea6d629 100644
> --- a/c/src/lib/libbsp/shared/include/irq-info.h
> +++ b/c/src/lib/libbsp/shared/include/irq-info.h
> @@ -23,7 +23,7 @@
>  #define LIBBSP_SHARED_IRQ_INFO_H
>  #include <rtems/shell.h>
> -#include <rtems/bspIo.h>
> +#include <rtems/print.h>
>  #ifdef __cplusplus
>  extern "C" {
> @@ -34,8 +34,7 @@ extern "C" {
>   * context @a context.
>  void bsp_interrupt_report_with_plugin(
> -  void *context,
> -  rtems_printk_plugin_t print
> +  const rtems_printer *printer
> diff --git a/c/src/lib/libbsp/shared/src/irq-info.c b/c/src/lib/libbsp/shared/src/irq-info.c
> index 7967ee5..f5f2323 100644
> --- a/c/src/lib/libbsp/shared/src/irq-info.c
> +++ b/c/src/lib/libbsp/shared/src/irq-info.c
> @@ -21,12 +21,13 @@
>  #include <inttypes.h>
>  #include <bsp/irq-generic.h>
>  #include <bsp/irq-info.h>
>  typedef struct {
> -  void *context;
> -  rtems_printk_plugin_t print;
> +  const rtems_printer *printer;
>    rtems_vector_number vector;
>  } bsp_interrupt_report_entry;
> @@ -41,9 +42,9 @@ static void bsp_interrupt_report_per_handler_routine(
>    bsp_interrupt_report_entry *e = (bsp_interrupt_report_entry *) arg;
>    const char *opt = options == RTEMS_INTERRUPT_UNIQUE ? "UNIQUE" : "SHARED";
> -  e->print(
> -    e->context,
> -    "%7" PRIu32 " | %-32s | %7s | %010p | %010p\n",
> +  rtems_printf(
> +    e->printer,
> +    "%7" PRIu32 " | %-32s | %7s | %p | %p\n",
>      e->vector,
>      info,
>      opt,
> @@ -53,19 +54,17 @@ static void bsp_interrupt_report_per_handler_routine(
> -  void *context,
>    rtems_vector_number v = 0;
>    bsp_interrupt_report_entry e = {
> -    .context = context,
> -    .print = print,
> +    .printer = printer,
>      .vector = 0
> -  print(
> -    context,
> +  rtems_printf(
> +    printer,
>      "-------------------------------------------------------------------------------\n"
>      "                             INTERRUPT INFORMATION\n"
>      "--------+----------------------------------+---------+------------+------------\n"
> @@ -82,13 +81,15 @@ void bsp_interrupt_report_with_plugin(
> -  print(
> -    context,
> +  rtems_printf(
> +    printer,
>  void bsp_interrupt_report(void)
> -  bsp_interrupt_report_with_plugin(NULL, printk_plugin);
> +  rtems_printer printer;
> +  rtems_print_printer_printk(&printer);
> +  bsp_interrupt_report_with_plugin(&printer);
> diff --git a/c/src/lib/libbsp/shared/src/irq-shell.c b/c/src/lib/libbsp/shared/src/irq-shell.c
> index 0bd63f2..512594c 100644
> --- a/c/src/lib/libbsp/shared/src/irq-shell.c
> +++ b/c/src/lib/libbsp/shared/src/irq-shell.c
> @@ -27,7 +27,9 @@
>  static int bsp_interrupt_shell_main(int argc, char **argv)
> -  bsp_interrupt_report_with_plugin(stdout, (rtems_printk_plugin_t) fprintf);
> +  rtems_print_printer_printf(&printer);
>    return 0;
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index c84ccc3..aa1111e 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -97,6 +97,7 @@ include_rtems_rtl_HEADERS += libdl/rap.h libdl/rap-shell.h
>  endif
>  include_rtems_HEADERS += include/rtems/bspIo.h
> +include_rtems_HEADERS += include/rtems/print.h
>  include_rtems_HEADERS += include/rtems/userenv.h
>  include_rtems_HEADERS += include/rtems/fs.h
>  if !LIBPCI
> diff --git a/cpukit/include/rtems/bspIo.h b/cpukit/include/rtems/bspIo.h
> index dde8d94..403b857 100644
> --- a/cpukit/include/rtems/bspIo.h
> +++ b/cpukit/include/rtems/bspIo.h
> @@ -37,6 +37,15 @@ extern "C" {
> + * Print format function attribute for warning checks. Can be defined if
> + * checking needs to be disabled.
> +#ifndef RTEMS_PRINTF_ATTRIBUTE
> +#define RTEMS_PRINTF_ATTRIBUTE(_format_pos, _ap_pos) \
> +  __attribute__((format(__printf__, _format_pos, _ap_pos)))
> +#endif
>   * This type defines the prototype for the BSP provided method to
>   * print a single character. It is assumed to be polled.
> @@ -84,8 +93,10 @@ extern int getchark(void);
>   * @param[in] fmt is a printf()-style format string
>   * @param[in] ap is a va_list pointer to arguments
> + * @return The number of characters output.
> -extern void vprintk(const char *fmt, va_list ap);
> +extern int vprintk(const char *fmt, va_list ap);
>   * @brief Kernel Print
> @@ -93,8 +104,10 @@ extern void vprintk(const char *fmt, va_list ap);
>   * This method allows the user to perform a debug printk().
> -extern void printk(const char *fmt, ...);
> +extern int printk(const char *fmt, ...) RTEMS_PRINTF_ATTRIBUTE(1, 2);
>   * @brief Kernel Put String
> @@ -102,8 +115,10 @@ extern void printk(const char *fmt, ...);
>   * This method allows the user to perform a debug puts().
>   * @param[in] s is the string to print
> -extern void putk(const char *s);
> +extern int putk(const char *s);
>   * @brief Kernel Put Character
> @@ -118,15 +133,13 @@ extern void rtems_putc(char c);
>   * Type definition for function which can be plugged in to
>   * certain reporting routines to redirect the output.
> - * Methods following this prototype may be passed into RTEMS reporting
> - * functions that allow their output to be redirected.  In particular,
> - * the cpu usage, period usage, and stack usage reporting
> - * functions use this.
> + * Use the RTEMS Print interface to call these functions. Do not
> + * directly use them.
>   * If the user provides their own "printf plugin", then they may
>   * redirect those reports as they see fit.
> -typedef int (*rtems_printk_plugin_t)(void *, const char *format, ...);
> +typedef int (*rtems_print_plugin_t)(void *, const char *format, va_list ap);
>   * @brief Reporting Methods printk() Plugin
> @@ -136,7 +149,7 @@ typedef int (*rtems_printk_plugin_t)(void *, const char *format, ...);
>   * @return The number of characters printed.
> -extern int printk_plugin(void *context, const char *fmt, ...);
> +extern int printk_plugin(void *context, const char *fmt, va_list ap);
>   * @brief Reporting Methods printf() Plugin
> @@ -149,7 +162,7 @@ extern int printk_plugin(void *context, const char *fmt, ...);
> -extern int rtems_printf_plugin(void *context, const char *fmt, ...);
> +extern int rtems_printf_plugin(void *context, const char *fmt, va_list ap);
> diff --git a/cpukit/include/rtems/print.h b/cpukit/include/rtems/print.h
> new file mode 100644
> index 0000000..5268e8c
> --- /dev/null
> +++ b/cpukit/include/rtems/print.h
> @@ -0,0 +1,134 @@
> + * @file rtems/print.h
> + * @brief User print interface to the bspIO print plug in.
> + * This include file defines the user interface to kernel print methods.
> + *  Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
> + *  All rights reserved.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifndef _RTEMS_PRINT_H
> +#define _RTEMS_PRINT_H
> +#include <stdbool.h>
> +#include <stddef.h>
> +#include <stdio.h>
> +#include <rtems/bspIo.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @defgroup RTEMS Print Support
> + * This module contains all methods and support related to providing the user
> + * with an interface to the kernel level print support.
> + * Type definition for the printer structure used to access the kernel print
> + * support.
> +typedef struct {
> +  void                *context;
> +  rtems_print_plugin_t printer;
> +}rtems_printer;
> + * @brief check if the printer is valid.
> + * @param[in] printer Pointer to the printer structure.
> + * @return true The printer is valid else false is returned.
> +static inline bool rtems_print_printer_valid(const rtems_printer *printer)
> +  return printer != NULL && printer->printer != NULL;
> + * @brief Print to the kernel plugin handler. This has to be a macro because
> + * there is no vprint version of the plug in handlers.
> + * @param[in] fmt Print format string.
> + * @param[in] ... Print variable argument list.
> + * @return int Number of characters printed.
> +extern int rtems_printf(const rtems_printer *printer,
> +                        const char          *format,
> +                        ...) RTEMS_PRINTF_ATTRIBUTE(2, 3);
> + * @param[in] ap Print variable argument list pointer.
> +extern int rtems_vprintf(const rtems_printer *printer,
> +                         va_list              ap);
> + * @brief Intiialise the rtems_printer struct to empty.
> + * An empty printer prints nothing. You can use this to implement an enable and
> + * disable type print implementation.
> +static inline void rtems_print_printer_empty(rtems_printer *printer)
> +  printer->context = NULL;
> +  printer->printer = NULL;
> + * @brief Intiialise the rtems_printer struct to printk
> + * The printer will output to the kernel printk support.
> +void rtems_print_printer_printk(rtems_printer *printer);
> + * @brief Intiialise the rtems_printer struct to printf
> + * The printer will output to the libc printf support.
> +extern void rtems_print_printer_printf(rtems_printer *printer);
> + * @brief Intiialise the rtems_printer struct to a fprintf device.
> + * The printer will output to the libc fprintf file provided.
> +extern void rtems_print_printer_fprintf(rtems_printer *printer, FILE *file);
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/cpukit/libblock/include/rtems/blkdev.h b/cpukit/libblock/include/rtems/blkdev.h
> index 81e2dfa..99f8573 100644
> --- a/cpukit/libblock/include/rtems/blkdev.h
> +++ b/cpukit/libblock/include/rtems/blkdev.h
> @@ -16,7 +16,7 @@
>  #include <rtems.h>
>  #include <rtems/diskdevs.h>
>  #include <sys/ioctl.h>
>  #include <stdio.h>
> @@ -348,15 +348,14 @@ void rtems_blkdev_print_stats(
>    uint32_t media_block_size,
>    uint32_t media_block_count,
>    uint32_t block_size,
> -  rtems_printk_plugin_t print,
> -  void *print_arg
> +  const rtems_printer* printer
>   * @brief Block device statistics command.
>  void rtems_blkstats(
> -  FILE *output,
> +  const rtems_printer *printer,
>    const char *device,
>    bool reset
> diff --git a/cpukit/libblock/src/blkdev-blkstats.c b/cpukit/libblock/src/blkdev-blkstats.c
> index 1e773cf..ca1e0e4 100644
> --- a/cpukit/libblock/src/blkdev-blkstats.c
> +++ b/cpukit/libblock/src/blkdev-blkstats.c
> @@ -31,7 +31,7 @@
>  #include <errno.h>
>  #include <string.h>
> -void rtems_blkstats(FILE *output, const char *device, bool reset)
> +void rtems_blkstats(const rtems_printer* printer, const char *device, bool reset)
>    int fd = open(device, O_RDONLY);
> @@ -45,7 +45,7 @@ void rtems_blkstats(FILE *output, const char *device, bool reset)
>          if (reset) {
>            rv = rtems_disk_fd_reset_device_stats(fd);
>            if (rv != 0) {
> -            fprintf(output, "error: reset stats: %s\n", strerror(errno));
> +            rtems_printf(printer, "error: reset stats: %s\n", strerror(errno));
>          } else {
>            uint32_t media_block_size = 0;
> @@ -64,25 +64,24 @@ void rtems_blkstats(FILE *output, const char *device, bool reset)
>                media_block_size,
>                media_block_count,
>                block_size,
> -              (rtems_printk_plugin_t) fprintf,
> -              output
> +              printer
>            } else {
> -            fprintf(output, "error: get stats: %s\n", strerror(errno));
> +            rtems_printf(printer, "error: get stats: %s\n", strerror(errno));
>        } else {
> -        fprintf(output, "error: not a block device\n");
> +        rtems_printf(printer, "error: not a block device\n");
>      } else {
> -      fprintf(output, "error: get file stats: %s\n", strerror(errno));
> +      rtems_printf(printer, "error: get file stats: %s\n", strerror(errno));
>      rv = close(fd);
>      if (rv != 0) {
> -      fprintf(output, "error: close device: %s\n", strerror(errno));
> +      rtems_printf(printer, "error: close device: %s\n", strerror(errno));
>    } else {
> -    fprintf(output, "error: open device: %s\n", strerror(errno));
> +    rtems_printf(printer, "error: open device: %s\n", strerror(errno));
> diff --git a/cpukit/libblock/src/blkdev-print-stats.c b/cpukit/libblock/src/blkdev-print-stats.c
> index edeee90..aba2173 100644
> --- a/cpukit/libblock/src/blkdev-print-stats.c
> +++ b/cpukit/libblock/src/blkdev-print-stats.c
> @@ -32,12 +32,11 @@ void rtems_blkdev_print_stats(
> -  void *print_arg
> -  (*print)(
> -     print_arg,
> +  rtems_printf(
> +     printer,
>       "                               DEVICE STATISTICS\n"
>       "----------------------+--------------------------------------------------------\n"
> diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
> index b3ad3db..f047cfc 100644
> --- a/cpukit/libcsupport/Makefile.am
> +++ b/cpukit/libcsupport/Makefile.am
> @@ -112,6 +112,8 @@ BSD_LIBC_C_FILES = src/strlcpy.c src/strlcat.c src/issetugid.c
>  libcsupport_a_SOURCES = src/gxx_wrappers.c src/getchark.c src/printk.c \
>      src/printk_plugin.c src/putk.c src/vprintk.c \
>      src/rtems_putc.c \
> +    src/print_fprintf.c \
> +    src/print_printf.c \
>      src/printf_plugin.c \
>      src/sup_fs_location.c \
>      src/sup_fs_eval_path.c \
> diff --git a/cpukit/libcsupport/src/print_fprintf.c b/cpukit/libcsupport/src/print_fprintf.c
> index 0000000..5e46d1c
> --- /dev/null
> +++ b/cpukit/libcsupport/src/print_fprintf.c
> @@ -0,0 +1,29 @@
> + *  @file
> + *  @brief RTEMS Print Support
> + *  @ingroup libcsupport
> +#ifdef HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <stdio.h>
> +void rtems_print_printer_fprintf(rtems_printer *printer, FILE *file)
> +  printer->context = file;
> +  printer->printer = (rtems_print_plugin_t) fprintf;
> diff --git a/cpukit/libcsupport/src/print_printf.c b/cpukit/libcsupport/src/print_printf.c
> index 0000000..c869523
> --- /dev/null
> +++ b/cpukit/libcsupport/src/print_printf.c
> @@ -0,0 +1,52 @@
> + *  @file
> +#endif
> +#include <stdio.h>
> +int rtems_vprintf(
> +  va_list              ap
> +  int len = 0;
> +  if ( rtems_print_printer_valid( printer ) ) {
> +    len = printer->printer( printer->context, format, ap );
> +  return len;
> +int rtems_printf(
> +  int len = 0;
> +    va_list ap;
> +    va_start( ap, format );
> +    va_end( ap );
> +  return len;
> diff --git a/cpukit/libcsupport/src/printf_plugin.c b/cpukit/libcsupport/src/printf_plugin.c
> index ab4f4a4..097e412 100644
> --- a/cpukit/libcsupport/src/printf_plugin.c
> +++ b/cpukit/libcsupport/src/printf_plugin.c
> @@ -23,18 +23,18 @@
>    #include "config.h"
>  #endif
>  #include <stdio.h>
> -int rtems_printf_plugin(void *context, const char *format, ...)
> +void rtems_print_printer_printf(rtems_printer *printer)
> -  int rv;
> -  va_list ap;
> -  va_start(ap, format);
> -  rv = vprintf(format, ap);
> -  va_end(ap);
> +  printer->printer = rtems_printf_plugin;
> -  return rv;
> +int rtems_printf_plugin(void *context, const char *format, va_list ap)
> +  (void) context;
> +  return vprintf(format, ap);
> diff --git a/cpukit/libcsupport/src/printk.c b/cpukit/libcsupport/src/printk.c
> index badbd0d..88cd22a 100644
> --- a/cpukit/libcsupport/src/printk.c
> +++ b/cpukit/libcsupport/src/printk.c
> @@ -32,11 +32,12 @@
>   *  Kernel printf function requiring minimal infrastructure.
> -void printk(const char *fmt, ...)
> +int printk(const char *fmt, ...)
> -  va_list  ap;       /* points to each unnamed argument in turn */
> +  va_list ap;       /* points to each unnamed argument in turn */
> +  int     len;
>    va_start(ap, fmt); /* make ap point to 1st unnamed arg */
> -  vprintk(fmt, ap);
> +  len = vprintk(fmt, ap);
>    va_end(ap);        /* clean up when done */
> +  return len;
> diff --git a/cpukit/libcsupport/src/printk_plugin.c b/cpukit/libcsupport/src/printk_plugin.c
> index b600378..3ecacb8 100644
> --- a/cpukit/libcsupport/src/printk_plugin.c
> +++ b/cpukit/libcsupport/src/printk_plugin.c
> @@ -19,23 +19,23 @@
>  #endif
>  #include <stdarg.h>
> +  rtems_printer *printer
> +  printer->printer = printk_plugin;
>  int printk_plugin(
>    void *ignored,
>    const char *format,
> +  va_list ap
> -  va_list arg_pointer;
>    (void) ignored;
> -  va_start (arg_pointer, format);
> -  vprintk( format, arg_pointer );
> -  va_end(arg_pointer); /* clean up when done */
> +  vprintk( format, ap );
>    return 0;
> diff --git a/cpukit/libcsupport/src/putk.c b/cpukit/libcsupport/src/putk.c
> index 2532a64..76fa8b0 100644
> --- a/cpukit/libcsupport/src/putk.c
> +++ b/cpukit/libcsupport/src/putk.c
> @@ -1,7 +1,7 @@
>   *  @file
> - *  @brief Write Character to Stream
> + *  @brief Write Character to Stream
> @@ -23,11 +23,13 @@
>   * Kernel putk (e.g. puts) function requiring minimal infrastrure.
> -void putk(const char *s)
> +int putk(const char *s)
>    const char *p;
> +  int len_out = 0;
> -  for (p=s ; *p ; p++ )
> +  for (p=s ; *p ; p++, len_out++ )
>      BSP_output_char(*p);
>    BSP_output_char('\n');
> +  return len_out + 1;
> diff --git a/cpukit/libcsupport/src/vprintk.c b/cpukit/libcsupport/src/vprintk.c
> index 51e4947..a254934 100644
> --- a/cpukit/libcsupport/src/vprintk.c
> +++ b/cpukit/libcsupport/src/vprintk.c
> @@ -30,7 +30,7 @@
> -static void printNum(
> +static int printNum(
>    long long num,
>    unsigned base,
>    bool sign,
> @@ -45,11 +45,12 @@ static void printNum(
>   * Arguments:
>   *    as in printf: fmt - format string, ... - unnamed arguments.
> -void vprintk(
> +int vprintk(
>    const char *fmt,
>    va_list     ap
> +  int len_out = 0;
>    for (; *fmt != '\0'; fmt++) {
>      unsigned base = 0;
>      unsigned width = 0;
> @@ -66,6 +67,7 @@ void vprintk(
>      if (c != '%') {
>        rtems_putc(c);
> +      ++len_out;
>        continue;
> @@ -101,6 +103,7 @@ void vprintk(
>        /* need a cast here since va_arg() only takes fully promoted types */
>        char chr = (char) va_arg(ap, int);
>        rtems_putc(chr);
> +      ++len_out;
>        continue;
> @@ -120,7 +123,7 @@ void vprintk(
>        /* leading spaces */
>        if ( !minus )
> -        for ( i=len ; i<width ; i++ )
> +        for ( i=len ; i<width ; i++, len_out++ )
>            rtems_putc(' ');
>        /* no width option */
> @@ -129,12 +132,12 @@ void vprintk(
>        /* output the string */
> -      for ( i=0 ; i<width && *str ; str++ )
> +      for ( i=0 ; i<width && *str ; str++, len_out++ )
>          rtems_putc(*str);
>        /* trailing spaces */
>        if ( minus )
>            rtems_putc(' ');
>        continue;
> @@ -154,6 +157,7 @@ void vprintk(
>        base = 16; sign = false; lflag = LFLAG_LONG;
>      } else {
>        rtems_putc(c);
> +      ++len_out;
>        continue;
> @@ -172,8 +176,10 @@ void vprintk(
>          break;
> -    printNum(num, base, sign, width, lead);
> +    len_out += printNum(num, base, sign, width, lead);
> +  return len_out;
> @@ -181,7 +187,7 @@ void vprintk(
>   *  @param[in] num is the number to print
>   *  @param[in] base is the base used to print the number
>    long long num,
>    unsigned base,
>    bool sign,
> @@ -194,9 +200,11 @@ static void printNum(
>    unsigned count;
>    #define UINT64_MAX_IN_OCTAL_FORMAT "1777777777777777777777"
>    char toPrint[sizeof(UINT64_MAX_IN_OCTAL_FORMAT)];
> +  int len_out = 0;
>    if ( sign && (num <  0) ) {
>      rtems_putc('-');
> +    ++len_out;
>      unsigned_num = (unsigned long long) -num;
>      if (maxwidth) maxwidth--;
>    } else {
> @@ -210,10 +218,12 @@ static void printNum(
>    toPrint[count++] = (char) unsigned_num;
> -  for (n=maxwidth ; n > count; n-- )
> +  for (n=maxwidth ; n > count; n--, len_out++ )
>      rtems_putc(lead);
> -  for (n = 0; n < count; n++) {
> +  for (n = 0; n < count; n++, len_out++) {
>      rtems_putc("0123456789ABCDEF"[(int)(toPrint[count-(n+1)])]);
> +  return len_out;
> diff --git a/cpukit/libmisc/cpuuse/cpuusagereport.c b/cpukit/libmisc/cpuuse/cpuusagereport.c
> index 95d0648..5200352 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagereport.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagereport.c
> @@ -34,8 +34,7 @@
>   *  rtems_cpu_usage_report
>  void rtems_cpu_usage_report_with_plugin(
> -  void                  *context,
>    uint32_t             i;
> @@ -44,11 +43,8 @@ void rtems_cpu_usage_report_with_plugin(
>    Objects_Information *information;
>    char                 name[13];
>    uint32_t             ival, fval;
> -  Timestamp_Control  uptime, total, used, uptime_at_last_reset;
> -  uint32_t seconds, nanoseconds;
> -  if ( !print )
> -    return;
> +  Timestamp_Control    uptime, total, used, uptime_at_last_reset;
> +  uint32_t             seconds, nanoseconds;
>     *  When not using nanosecond CPU usage resolution, we have to count
> @@ -58,8 +54,8 @@ void rtems_cpu_usage_report_with_plugin(
>    _Timestamp_Set_to_zero( &total );
>    uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
> -  (*print)(
> -     context,
> +  rtems_printf(
> +     printer,
>       "                              CPU USAGE BY THREAD\n"
>       "------------+----------------------------------------+---------------+---------\n"
> @@ -83,8 +79,8 @@ void rtems_cpu_usage_report_with_plugin(
>          rtems_object_get_name( the_thread->Object.id, sizeof(name), name );
> -        (*print)(
> -          context,
> +        rtems_printf(
> +          printer,
>            " 0x%08" PRIx32 " | %-38s |",
>            name
> @@ -102,7 +98,7 @@ void rtems_cpu_usage_report_with_plugin(
>          seconds = _Timestamp_Get_seconds( &used );
>          nanoseconds = _Timestamp_Get_nanoseconds( &used ) /
>            TOD_NANOSECONDS_PER_MICROSECOND;
> -        (*print)( context,
> +        rtems_printf( printer,
>            "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>            seconds, nanoseconds,
>            ival, fval
> @@ -114,8 +110,8 @@ void rtems_cpu_usage_report_with_plugin(
>    seconds = _Timestamp_Get_seconds( &total );
>    nanoseconds = _Timestamp_Get_nanoseconds( &total ) /
> -  (*print)(
> -     context,
> +  rtems_printf(
> +     printer,
>       " TIME SINCE LAST CPU USAGE RESET IN SECONDS:                    %7" PRIu32 ".%06" PRIu32 "\n"
>       "-------------------------------------------------------------------------------\n",
> @@ -125,5 +121,7 @@ void rtems_cpu_usage_report_with_plugin(
>  void rtems_cpu_usage_report( void )
> -  rtems_cpu_usage_report_with_plugin( NULL, printk_plugin );
> +  rtems_print_printer_printk( &printer );
> +  rtems_cpu_usage_report_with_plugin( &printer );
> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
> index cf896e3..2f48eb8 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagetop.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
> @@ -41,15 +41,6 @@
>  #include <rtems/score/wkspace.h>
> - * Common variable to sync the load monitor task.
> -typedef struct
> -  void*                  context;
> -} rtems_cpu_usage_plugin;
>   * Use a struct for all data to allow more than one top and to support the
>   * thread iterator.
> @@ -61,7 +52,7 @@ typedef struct
>    volatile uint32_t      sort_order;
>    volatile uint32_t      poll_rate_usecs;
>    volatile uint32_t      show;
> -  rtems_cpu_usage_plugin plugin;
> +  const rtems_printer*   printer;
>    Timestamp_Control      zero;
>    Timestamp_Control      uptime;
>    Timestamp_Control      last_uptime;
> @@ -144,27 +135,19 @@ static inline bool less_than_uint32_t( uint32_t * lhs, uint32_t * rhs )
>      return false;
> -#define CPU_usage_Equal_to( _lhs, _rhs ) \
> -       _Timestamp_Equal_to( _lhs, _rhs )
> -#define CPU_usage_Set_to_zero( _time ) \
> -       _Timestamp_Set_to_zero( _time )
> -#define CPU_usage_Less_than( _lhs, _rhs ) \
> -      _Timestamp_Less_than( _lhs, _rhs )
> +#define CPU_usage_Equal_to( _lhs, _rhs )  _Timestamp_Equal_to( _lhs, _rhs )
> +#define CPU_usage_Set_to_zero( _time )    _Timestamp_Set_to_zero( _time )
> +#define CPU_usage_Less_than( _lhs, _rhs ) _Timestamp_Less_than( _lhs, _rhs )
>  static void
>  print_memsize(rtems_cpu_usage_data* data, const uint32_t size, const char* label)
>    if (size > (1024 * 1024))
> -    (*data->plugin.print)(data->plugin.context, "%4" PRIu32 "M %s",
> -                          size / (1024 * 1024), label);
> +    rtems_printf(data->printer, "%4" PRIu32 "M %s", size / (1024 * 1024), label);
>    else if (size > 1024)
> -    (*data->plugin.print)(data->plugin.context, "%4" PRIu32 "K %s",
> -                          size / 1024, label);
> +    rtems_printf(data->printer, "%4" PRIu32 "K %s", size / 1024, label);
>    else
> -    (*data->plugin.print)(data->plugin.context, "%4" PRIu32 " %s",
> -                          size, label);
> +    rtems_printf(data->printer, "%4" PRIu32 " %s", size, label);
>  static int
> @@ -184,19 +167,19 @@ print_time(rtems_cpu_usage_data*    data,
>        uint32_t hours = mins / 60;
>        if (hours > 24)
> -        len += (*data->plugin.print)(data->plugin.context, "%" PRIu32 "d", hours / 24);
> +        len += rtems_printf(data->printer, "%" PRIu32 "d", hours / 24);
>          hours %= 24;
> -      len += (*data->plugin.print)(data->plugin.context, "%" PRIu32 "hr", hours);
> +      len += rtems_printf(data->printer, "%" PRIu32 "hr", hours);
>        mins %= 60;
> -    len += (*data->plugin.print)(data->plugin.context, "%" PRIu32 "m", mins);
> +    len += rtems_printf(data->printer, "%" PRIu32 "m", mins);
>      secs %= 60;
> -  len += (*data->plugin.print)(data->plugin.context, "%" PRIu32 ".%06" PRIu32, secs, usecs);
> +  len += rtems_printf(data->printer, "%" PRIu32 ".%06" PRIu32, secs, usecs);
>    if (len < length)
> -    (*data->plugin.print)(data->plugin.context, "%*c", length - len, ' ');
> +    rtems_printf(data->printer, "%*c", length - len, ' ');
>    return len;
> @@ -344,7 +327,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>        data->current_usage = realloc(data->current_usage, usage_size);
>        if ((data->tasks == NULL) || (data->usage == NULL) || (data->current_usage == NULL))
> -        (*data->plugin.print)(data->plugin.context, "top worker: error: no memory\n");
> +        rtems_printf(data->printer, "top worker: error: no memory\n");
>          data->thread_run = false;
>          break;
> @@ -371,7 +354,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>        data->last_usage = realloc(data->last_usage, usage_size);
>        if ((data->last_tasks == NULL) || (data->last_usage == NULL))
>          break;
> @@ -396,43 +379,43 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>      _Protected_heap_Get_information(&_Workspace_Area, &wksp);
>      if (data->single_page)
> -                            "\x1b[H\x1b[J"
> -                            " ENTER:Exit  SPACE:Refresh"
> -                            "  S:Scroll  A:All  <>:Order  +/-:Lines\n");
> -    (*data->plugin.print)(data->plugin.context,"\n");
> +                   "\x1b[H\x1b[J"
> +                   " ENTER:Exit  SPACE:Refresh"
> +                   "  S:Scroll  A:All  <>:Order  +/-:Lines\n");
> +    rtems_printf(data->printer, "\n");
>       * Uptime and period of this sample.
> -    (*data->plugin.print)(data->plugin.context, "Uptime: ");
> +    rtems_printf(data->printer, "Uptime: ");
>      print_time(data, &data->uptime, 20);
> -    (*data->plugin.print)(data->plugin.context, " Period: ");
> +    rtems_printf(data->printer, " Period: ");
>      print_time(data, &data->period, 20);
>       * Task count, load and idle levels.
> -    (*data->plugin.print)(data->plugin.context, "\nTasks: %4i  ", data->task_count);
> +    rtems_printf(data->printer, "\nTasks: %4i  ", data->task_count);
>      _Timestamp_Subtract(&data->idle, &data->total, &load);
>      _Timestamp_Divide(&load, &data->uptime, &ival, &fval);
> -                          "Load Average: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
> +                 "Load Average: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
>      _Timestamp_Subtract(&data->current_idle, &data->current, &load);
>      _Timestamp_Divide(&load, &data->period, &ival, &fval);
> -                          "  Load: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
> +                 "  Load: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
>      _Timestamp_Divide(&data->current_idle, &data->period, &ival, &fval);
> -                          "  Idle: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
> +                 "  Idle: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
>       * Memory usage.
>      if (rtems_configuration_get_unified_work_area())
> -      (*data->plugin.print)(data->plugin.context, "\nMem: ");
> +      rtems_printf(data->printer, "\nMem: ");
>        print_memsize(data, wksp.Free.total, "free");
>        print_memsize(data, wksp.Used.total, "used");
> @@ -440,7 +423,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>        region_information_block libc_heap;
>        malloc_info(&libc_heap);
> -      (*data->plugin.print)(data->plugin.context, "\nMem: Wksp: ");
> +      rtems_printf(data->printer, "\nMem: Wksp: ");
>        print_memsize(data, wksp.Used.total, "used  Heap: ");
>        print_memsize(data, libc_heap.Free.total, "free");
> @@ -449,7 +432,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>      print_memsize(data, data->stack_size, "stack\n");
>         "\n"
>          " ID         | NAME                | RPRI | CPRI   | TIME                | TOTAL   | CURRENT\n"
>          "-%s---------+---------------------+-%s-----%s-----+---------------------+-%s------+--%s----\n",
> @@ -487,12 +470,12 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>        if (name[0] == '\0')
>          snprintf(name, sizeof(name) - 1, "(%p)", thread->Start.Entry.Kinds.Numeric.entry);
> -                            " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   | ",
> -                            thread->Object.id,
> -                            name,
> -                            thread->real_priority,
> -                            thread->current_priority);
> +                   " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   | ",
> +                   thread->Object.id,
> +                   name,
> +                   thread->real_priority,
> +                   thread->current_priority);
>        usage = data->usage[i];
>        current_usage = data->current_usage[i];
> @@ -502,11 +485,11 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>        print_time(data, &usage, 19);
>        _Timestamp_Divide(&usage, &data->total, &ival, &fval);
> -                            " |%4" PRIu32 ".%03" PRIu32, ival, fval);
> +                   " |%4" PRIu32 ".%03" PRIu32, ival, fval);
>        _Timestamp_Divide(&current_usage, &data->period, &ival, &fval);
> -                            " |%4" PRIu32 ".%03" PRIu32 "\n", ival, fval);
> +                   " |%4" PRIu32 ".%03" PRIu32 "\n", ival, fval);
>      if (data->single_page && (data->show != 0) && (task_count < data->show))
> @@ -514,7 +497,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>        i = data->show - task_count;
>        while (i > 0)
> -        (*data->plugin.print)(data->plugin.context, "\x1b[K\n");
> +        rtems_printf(data->printer, "\x1b[K\n");
>          i--;
> @@ -525,8 +508,8 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>                               &out);
>      if ((sc != RTEMS_SUCCESSFUL) && (sc != RTEMS_TIMEOUT))
> -                            "error: event receive: %s\n", rtems_status_text(sc));
> +                   "error: event receive: %s\n", rtems_status_text(sc));
>        break;
> @@ -542,8 +525,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>  void rtems_cpu_usage_top_with_plugin(
> -  void                  *context,
>    rtems_status_code      sc;
> @@ -553,9 +535,6 @@ void rtems_cpu_usage_top_with_plugin(
>    rtems_cpu_usage_data   data;
>    int                    show_lines = 25;
> -  if ( !print )
> -    return;
>    memset(&data, 0, sizeof(data));
>    data.thread_run = true;
> @@ -563,18 +542,14 @@ void rtems_cpu_usage_top_with_plugin(
>    data.sort_order = RTEMS_TOP_SORT_CURRENT;
>    data.poll_rate_usecs = 3000;
>    data.show = show_lines;
> -  data.plugin.context = context;
> -  data.plugin.print = print;
> +  data.printer = printer;
>    sc = rtems_task_set_priority (RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &priority);
>    if (sc != RTEMS_SUCCESSFUL)
> -    (*print)(
> -       context,
> -       "error: cannot obtain the current priority: %s\n",
> -       rtems_status_text (sc)
> +    rtems_printf (printer,
> +                  "error: cannot obtain the current priority: %s\n", rtems_status_text (sc));
>      return;
> @@ -587,24 +562,16 @@ void rtems_cpu_usage_top_with_plugin(
> -    (*print)(
> -       context,
> -       "error: cannot create helper thread: %s\n",
> +                  "error: cannot create helper thread: %s\n", rtems_status_text (sc));
>      return;
> -  sc = rtems_task_start (
> -    id, rtems_cpuusage_top_thread, (rtems_task_argument) &data
> +  sc = rtems_task_start (id, rtems_cpuusage_top_thread, (rtems_task_argument) &data);
> -    (*print)(
> -       context,
> -       "error: cannot start helper thread: %s\n",
> +                  "error: cannot start helper thread: %s\n", rtems_status_text (sc));
>      rtems_task_delete (id);
>      return;
> @@ -624,7 +591,7 @@ void rtems_cpu_usage_top_with_plugin(
>        while (loops && data.thread_active)
>          rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (100000));
> -      (*print)(context, "load monitoring stopped.\n");
> +      rtems_printf (printer, "load monitoring stopped.\n");
>        return;
>      else if (c == '<')
> @@ -676,7 +643,9 @@ void rtems_cpu_usage_top_with_plugin(
> -void rtems_cpu_usage_top( void )
> +void rtems_cpu_usage_top (void)
> -  rtems_cpu_usage_top_with_plugin( NULL, printk_plugin );
> +  rtems_print_printer_printk (&printer);
> +  rtems_cpu_usage_top_with_plugin (&printer);
> diff --git a/cpukit/libmisc/cpuuse/cpuuse.h b/cpukit/libmisc/cpuuse/cpuuse.h
> index 1e26019..1a3d2a7 100644
> --- a/cpukit/libmisc/cpuuse/cpuuse.h
> +++ b/cpukit/libmisc/cpuuse/cpuuse.h
> @@ -1,6 +1,6 @@
>   * @file rtems/cpuuse.h
>   * @defgroup libmisc_cpuuse CPU Usage
>   * @ingroup libmisc
> @@ -23,7 +23,7 @@
>  #define __RTEMS_CPUUSE_h
>  #include <rtems.h>
>  #include <rtems/score/timestamp.h>
> @@ -43,10 +43,7 @@ extern Timestamp_Control  CPU_usage_Uptime_at_last_reset;
>   * rtems_cpu_usage_report_with_handler
> -void rtems_cpu_usage_report_with_plugin(
> -  void                  *context,
> -  rtems_printk_plugin_t  handler
> +void rtems_cpu_usage_report_with_plugin( const rtems_printer *printer );
>   *  @brief Report CPU usage.
> @@ -62,10 +59,7 @@ void rtems_cpu_usage_report( void );
>   *   Report CPU Usage in top format to
>   *   to a print plugin.
> -void rtems_cpu_usage_top_with_plugin(
> -  void                  *context,
> +void rtems_cpu_usage_top_with_plugin( const rtems_printer *printer );
>   *  @brief CPU usage top.
> diff --git a/cpukit/libmisc/fb/mw_print.c b/cpukit/libmisc/fb/mw_print.c
> index 8f4e465..25a3456 100644
> --- a/cpukit/libmisc/fb/mw_print.c
> +++ b/cpukit/libmisc/fb/mw_print.c
> @@ -43,12 +43,13 @@ void uid_print_message(
>    struct MW_UID_MESSAGE *uid
> -  uid_print_message_with_plugin( NULL, printk_plugin, uid );
> +  uid_print_message_with_plugin( &printer, uid );
>  void uid_print_message_with_plugin(
> -  void                  *context,
> -  rtems_printk_plugin_t  handler,
> @@ -56,11 +57,11 @@ void uid_print_message_with_plugin(
>    switch (uid->type) {
>      case MV_UID_INVALID:
> -      (*handler)( context, "MV_UID_INVALID\n" );
> +      rtems_printf( printer, "MV_UID_INVALID\n" );
>        break;
>      case MV_UID_REL_POS:
> -      (*handler)(
> -        context,
> +      rtems_printf(
> +        printer,
>          "MV_UID_REL_POS - %s x=%d y=%d z=%d\n",
>          uid_buttons( uid->m.pos.btns, buttons, sizeof(buttons)),
>          uid->m.pos.x,    /* x location */
> @@ -69,8 +70,8 @@ void uid_print_message_with_plugin(
>        break;
>      case MV_UID_ABS_POS:
> -      (*handler)(
> -        context,
> +      rtems_printf(
> +        printer,
>          "MV_UID_ABS_POS - %s x=%d y=%d z=%d\n",
> @@ -79,7 +80,7 @@ void uid_print_message_with_plugin(
>        break;
>      case MV_UID_KBD:
>          "MV_UID_KBD - code=0x%04x modifiers=0x%02x mode=0x%02x\n",
>          uid->m.kbd.code,        /* keycode or scancode        */
>          uid->m.kbd.modifiers,   /* key modifiers              */
> @@ -87,10 +88,10 @@ void uid_print_message_with_plugin(
>        break;
>     case MV_UID_TIMER:
> -      (*handler)( context, "MV_UID_TIMER\n" );
> +      rtems_printf( printer, "MV_UID_TIMER\n" );
>        break;
>      default:
> -      (*handler)( context, "Invalid device type\n" );
> +      rtems_printf( printer, "Invalid device type\n" );
>        break;
> diff --git a/cpukit/libmisc/fb/mw_uid.h b/cpukit/libmisc/fb/mw_uid.h
> index 8a10a8f..aa88392 100644
> --- a/cpukit/libmisc/fb/mw_uid.h
> +++ b/cpukit/libmisc/fb/mw_uid.h
> @@ -18,7 +18,7 @@
>  #define _MW_UID_H
>  #include <sys/types.h>
>   *  @defgroup libmisc_fb_mw Input Devices for MicroWindows
> @@ -179,14 +179,11 @@ void uid_print_message(
>   * This methods prints the specified UID message using your fprintf
>   * style method of choice.
> - * @param[in] context is a pointer to a data area which may be
> - *            used by some print handlers
> - * @param[in] handler is the fprintf style method to invoke
> + * @param[in] RTEMS printer
>   * @param[in] uid points to the message to print
> -  void                  *context,
> diff --git a/cpukit/libmisc/shell/main_blkstats.c b/cpukit/libmisc/shell/main_blkstats.c
> index 50d783d..d814df6 100644
> --- a/cpukit/libmisc/shell/main_blkstats.c
> +++ b/cpukit/libmisc/shell/main_blkstats.c
> @@ -31,6 +31,7 @@ static int rtems_shell_main_blkstats(int argc, char **argv)
>    bool ok = false;
>    bool reset = false;
>    const char *device;
>    if (argc == 2) {
>      ok = true;
> @@ -41,10 +42,12 @@ static int rtems_shell_main_blkstats(int argc, char **argv)
>      device = argv [2];
>    if (ok) {
> -    rtems_blkstats(stdout, device, reset);
> +    rtems_blkstats(&printer, device, reset);
>    } else {
> -    fprintf(stdout, "usage: %s\n", rtems_shell_BLKSTATS_Command.usage);
> +    rtems_printf(&printer, "usage: %s\n", rtems_shell_BLKSTATS_Command.usage);
>    return 0;
> diff --git a/cpukit/libmisc/shell/main_cpuuse.c b/cpukit/libmisc/shell/main_cpuuse.c
> index c1f991a..190fd03 100644
> --- a/cpukit/libmisc/shell/main_cpuuse.c
> +++ b/cpukit/libmisc/shell/main_cpuuse.c
> @@ -30,7 +30,9 @@ static int rtems_shell_main_cpuuse(
>     *  When invoked with no arguments, print the report.
>    if ( argc == 1 ) {
> -    rtems_cpu_usage_report_with_plugin(stdout, (rtems_printk_plugin_t)fprintf);
> +    rtems_print_printer_fprintf(&printer, stdout);
> +    rtems_cpu_usage_report_with_plugin(&printer);
>      return 0;
> diff --git a/cpukit/libmisc/shell/main_perioduse.c b/cpukit/libmisc/shell/main_perioduse.c
> index 9b33a75..023e154 100644
> --- a/cpukit/libmisc/shell/main_perioduse.c
> +++ b/cpukit/libmisc/shell/main_perioduse.c
> @@ -29,9 +29,10 @@ static int rtems_shell_main_perioduse(
>    if ( argc == 1 ) {
>      rtems_rate_monotonic_report_statistics_with_plugin(
> -      stdout,
> -      (rtems_printk_plugin_t)fprintf
> +      &printer
>      return 0;
> diff --git a/cpukit/libmisc/shell/main_profreport.c b/cpukit/libmisc/shell/main_profreport.c
> index d6e4c5a..a98b8ba 100644
> --- a/cpukit/libmisc/shell/main_profreport.c
> +++ b/cpukit/libmisc/shell/main_profreport.c
> @@ -24,10 +24,11 @@
>  static int rtems_shell_main_profreport(int argc, char **argv)
>    rtems_profiling_report_xml(
>      "Shell",
> -    (rtems_profiling_printf) fprintf,
> -    stdout,
> +    &printer,
>      0,
> diff --git a/cpukit/libmisc/shell/main_stackuse.c b/cpukit/libmisc/shell/main_stackuse.c
> index 74d47e1..40fc711 100644
> --- a/cpukit/libmisc/shell/main_stackuse.c
> +++ b/cpukit/libmisc/shell/main_stackuse.c
> @@ -25,10 +25,9 @@ static int rtems_shell_main_stackuse(
>    char *argv[] RTEMS_UNUSED
> -  rtems_stack_checker_report_usage_with_plugin(
> -    stdout,
> +  rtems_stack_checker_report_usage_with_plugin( &printer );
>    return 0;
> diff --git a/cpukit/libmisc/shell/main_top.c b/cpukit/libmisc/shell/main_top.c
> index ad6223a..aea50d8 100644
> --- a/cpukit/libmisc/shell/main_top.c
> +++ b/cpukit/libmisc/shell/main_top.c
> @@ -30,7 +30,9 @@ static int rtems_shell_main_top(
>    if ( argc == 1 ) {
> -    rtems_cpu_usage_top_with_plugin(stdout, (rtems_printk_plugin_t)fprintf);
> +    rtems_cpu_usage_top_with_plugin(&printer);
>      return 0;
> diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
> index 9c6932e..93d45de 100644
> --- a/cpukit/libmisc/stackchk/check.c
> +++ b/cpukit/libmisc/stackchk/check.c
> @@ -387,8 +387,7 @@ static inline void *Stack_check_find_high_water_mark(
>   *  Try to print out how much stack was actually used by the task.
> -static void                   *print_context;
> -static rtems_printk_plugin_t   print_handler;
> +static const rtems_printer* printer;
>  static void Stack_check_Dump_threads_usage(
>    Thread_Control *the_thread
> @@ -438,8 +437,8 @@ static void Stack_check_Dump_threads_usage(
>      if ( the_thread )
>    #endif
> -      (*print_handler)(
> -        print_context,
> +      rtems_printf(
> +        printer,
>          "0x%08" PRIx32 "  %4s",
> @@ -447,12 +446,12 @@ static void Stack_check_Dump_threads_usage(
>      #if (CPU_ALLOCATE_INTERRUPT_STACK == TRUE)
>        else {
> -        (*print_handler)( print_context, "0x%08" PRIx32 "  INTR", ~0 );
> +        rtems_printf( printer, "0x%08" PRIx32 "  INTR", ~0 );
>      #endif
> -  (*print_handler)(
> -    print_context,
> +  rtems_printf(
> +    printer,
>      " %010p - %010p %010p  %8" PRId32 "   ",
>      stack->area,
>      stack->area + stack->size - 1,
> @@ -461,9 +460,9 @@ static void Stack_check_Dump_threads_usage(
>    if (Stack_check_Initialized == 0) {
> -    (*print_handler)( print_context, "Unavailable\n" );
> +    rtems_printf( printer, "Unavailable\n" );
>    } else {
> -    (*print_handler)( print_context, "%8" PRId32 "\n", used );
> +    rtems_printf( printer, "%8" PRId32 "\n", used );
> @@ -489,18 +488,16 @@ static void Stack_check_Dump_threads_usage(
>  void rtems_stack_checker_report_usage_with_plugin(
> -  void                  *context,
> +  const rtems_printer* printer_
> -  if ( !print )
> +  if ( printer != NULL || ! rtems_print_printer_valid ( printer_ ) )
>      return;
> -  print_context = context;
> -  print_handler = print;
> +  printer = printer_;
> -  (*print)( context, "Stack usage by thread\n");
> +  rtems_printf( printer, "Stack usage by thread\n");
>  "    ID      NAME    LOW          HIGH     CURRENT     AVAILABLE     USED\n"
> @@ -512,11 +509,12 @@ void rtems_stack_checker_report_usage_with_plugin(
>      Stack_check_Dump_threads_usage((Thread_Control *) -1);
>    #endif
> -  print_context = NULL;
> -  print_handler = NULL;
> +  printer = NULL;
>  void rtems_stack_checker_report_usage( void )
> -  rtems_stack_checker_report_usage_with_plugin( NULL, printk_plugin );
> diff --git a/cpukit/libmisc/stackchk/stackchk.h b/cpukit/libmisc/stackchk/stackchk.h
> index b824057..f7f75b6 100644
> --- a/cpukit/libmisc/stackchk/stackchk.h
> +++ b/cpukit/libmisc/stackchk/stackchk.h
> @@ -25,7 +25,7 @@
>  #include <stdbool.h> /* bool */
>  #include <rtems/score/thread.h> /* Thread_Control */
>   *  @defgroup libmisc_stackchk Stack Checker Mechanism
> @@ -71,8 +71,7 @@ void rtems_stack_checker_report_usage( void );
>   * @note It uses the caller's routine to print the report.
> -  void                  *context,
> diff --git a/cpukit/libmisc/testsupport/test.h b/cpukit/libmisc/testsupport/test.h
> index 497c4b6..980ab66 100644
> --- a/cpukit/libmisc/testsupport/test.h
> +++ b/cpukit/libmisc/testsupport/test.h
> @@ -16,7 +16,7 @@
>  #define _RTEMS_TEST_H
>  #include <rtems.h>
>  #include <rtems/score/atomic.h>
>  #include <rtems/score/smpbarrier.h>
> @@ -38,6 +38,11 @@ extern "C" {
>  extern const char rtems_test_name[];
> + * @brief Each test must define a printer.
> +extern rtems_printer rtems_test_printer;
>   * @brief Fatal extension for tests.
>  void rtems_test_fatal_extension(
> @@ -53,70 +58,35 @@ void rtems_test_fatal_extension(
>    { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension }
> - * @brief Prints a begin of test message.
> - * @param[in] printf_func The formatted output function.
> - * @param[in, out] printf_arg The formatted output function argument.
> - * @returns As specified by printf().
> -int rtems_test_begin_with_plugin(
> -  rtems_printk_plugin_t printf_func,
> -  void *printf_arg
> - * @brief Prints a begin of test message using printf().
> + * @brief Begin of test message format string.
> -static inline int rtems_test_begin(void)
> -  return rtems_test_begin_with_plugin(rtems_printf_plugin, NULL);
> +#define TEST_BEGIN_STRING "\n\n*** BEGIN OF TEST %s ***\n", rtems_test_name
> - * @brief Prints a begin of test message using printk().
> + * @brief End of test message format string.
> -static inline int rtems_test_begink(void)
> -  return rtems_test_begin_with_plugin(printk_plugin, NULL);
> +#define TEST_END_STRING "*** END OF TEST %s ***\n", rtems_test_name
> - * @brief Prints an end of test message.
> + * @brief Prints a begin of test message using printf().
> -int rtems_test_end_with_plugin(
> -  void *printf_arg
> +int rtems_test_begin(void);
>   * @brief Prints an end of test message using printf().
> -static inline int rtems_test_end(void)
> -  return rtems_test_end_with_plugin(rtems_printf_plugin, NULL);
> +int rtems_test_end(void);
> - * @brief Prints an end of test message using printk().
> + * @brief Prints via the RTEMS printer.
> -static inline int rtems_test_endk(void)
> -  return rtems_test_end_with_plugin(printk_plugin, NULL);
> +int rtems_test_print(const char* format, ...) RTEMS_PRINTF_ATTRIBUTE(1, 2);
>   * @brief Internal context for parallel job execution.
> diff --git a/cpukit/libmisc/testsupport/testbeginend.c b/cpukit/libmisc/testsupport/testbeginend.c
> index 6383b33..6bfc400 100644
> --- a/cpukit/libmisc/testsupport/testbeginend.c
> +++ b/cpukit/libmisc/testsupport/testbeginend.c
> @@ -18,26 +18,35 @@
>  #include <rtems/test.h>
> -  void *printf_arg
> +  return rtems_printf(
> +    &rtems_test_printer,
> +    TEST_BEGIN_STRING
> -  return (*printf_func)(
> -    printf_arg,
> -    "\n\n*** BEGIN OF TEST %s ***\n",
> -    rtems_test_name
> +    TEST_END_STRING
> -  void *printf_arg
> +  const char* format,
> -    printf_arg,
> -    "*** END OF TEST %s ***\n",
> -    rtems_test_name
> +  va_list ap;
> +  int len;
> +  va_start(ap, format);
> +  len = rtems_vprintf(
> +    format,
> +    ap
> +  va_end(ap);
> +  return len;
> diff --git a/cpukit/libmisc/testsupport/testextension.c b/cpukit/libmisc/testsupport/testextension.c
> index a689e66..43f79bc 100644
> --- a/cpukit/libmisc/testsupport/testextension.c
> +++ b/cpukit/libmisc/testsupport/testextension.c
> @@ -33,6 +33,9 @@ void rtems_test_fatal_extension(
>  #if defined(RTEMS_PROFILING)
>    rtems_interrupt_lock_context lock_context;
>     * Ensures to report only once on SMP machines and ensures that the report is
> @@ -50,8 +53,7 @@ void rtems_test_fatal_extension(
>        rtems_test_name,
> -      printk_plugin,
> -      NULL,
> +      &printer,
>        1,
> diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
> index c8f2cd3..fdf2016 100644
> --- a/cpukit/preinstall.am
> +++ b/cpukit/preinstall.am
> @@ -224,6 +224,10 @@ $(PROJECT_INCLUDE)/rtems/bspIo.h: include/rtems/bspIo.h $(PROJECT_INCLUDE)/rtems
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/bspIo.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/bspIo.h
> +$(PROJECT_INCLUDE)/rtems/print.h: include/rtems/print.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/print.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/print.h
>  $(PROJECT_INCLUDE)/rtems/userenv.h: include/rtems/userenv.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/userenv.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/userenv.h
> diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h b/cpukit/rtems/include/rtems/rtems/ratemon.h
> index 87bd064..6e8fab6 100644
> --- a/cpukit/rtems/include/rtems/rtems/ratemon.h
> +++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
> @@ -35,7 +35,7 @@
>  #include <rtems/rtems/status.h>
>  #include <rtems/score/watchdog.h>
>  #ifdef __cplusplus
>  extern "C" {
> @@ -356,14 +356,13 @@ void rtems_rate_monotonic_reset_all_statistics( void );
>   *  @brief RTEMS Report Rate Monotonic Statistics
>   *  This routine allows a thread to print the statistics information
> - *  on ALL period instances which have non-zero counts using printk.
> - *  The implementation of this directive straddles the fence between
> - *  inside and outside of RTEMS.  It is presented as part of the Manager
> - *  but actually uses other services of the Manager.
> + *  on ALL period instances which have non-zero counts using the RTEMS
> + *  printer. The implementation of this directive straddles the fence
> + *  between inside and outside of RTEMS.  It is presented as part of
> + *  the Manager but actually uses other services of the Manager.
>  void rtems_rate_monotonic_report_statistics_with_plugin(
> -  void                  *context,
> diff --git a/cpukit/rtems/src/ratemonreportstatistics.c b/cpukit/rtems/src/ratemonreportstatistics.c
> index 856d431..3f264df 100644
> --- a/cpukit/rtems/src/ratemonreportstatistics.c
> +++ b/cpukit/rtems/src/ratemonreportstatistics.c
> @@ -20,6 +20,7 @@
>  #include <rtems/rtems/ratemonimpl.h>
>  #include <rtems/rtems/object.h>
> @@ -29,8 +30,7 @@
>  #define NANOSECONDS_FMT "%06" PRId32
> -  void                  *context,
>    rtems_status_code                      status;
> @@ -39,12 +39,9 @@ void rtems_rate_monotonic_report_statistics_with_plugin(
>    rtems_rate_monotonic_period_status     the_status;
>    char                                   name[5];
> -  if ( !print )
> -    return;
> -  (*print)( context, "Period information by period\n" );
> -  (*print)( context, "--- CPU times are in seconds ---\n" );
> -  (*print)( context, "--- Wall times are in seconds ---\n" );
> +  rtems_printf( printer, "Period information by period\n" );
> +  rtems_printf( printer, "--- CPU times are in seconds ---\n" );
> +  rtems_printf( printer, "--- Wall times are in seconds ---\n" );
>  Layout by columns -- in memory of Hollerith :)
> @@ -58,7 +55,7 @@ ididididid NNNN ccccc mmmmmm X
>  1234567890123456789012345678901234567890123456789012345678901234567890123456789\
>  \n");
>        "   ID     OWNER COUNT MISSED     "
>        "     CPU TIME                  WALL TIME\n"
> @@ -90,7 +87,7 @@ ididididid NNNN ccccc mmmmmm X
>       *  Print part of report line that is not dependent on granularity
>        "0x%08" PRIx32 " %4s %5" PRId32 " %6" PRId32 " ",
>        id, name,
>        the_stats.count, the_stats.missed_count
> @@ -100,7 +97,7 @@ ididididid NNNN ccccc mmmmmm X
>       *  If the count is zero, don't print statistics
>      if (the_stats.count == 0) {
> -      (*print)( context, "\n" );
> +      rtems_printf( printer, "\n" );
>        continue;
> @@ -114,7 +111,7 @@ ididididid NNNN ccccc mmmmmm X
>        struct timespec *total_cpu = &the_stats.total_cpu_time;
>        _Timespec_Divide_by_integer( total_cpu, the_stats.count, &cpu_average );
>          "%" PRId32 "."  NANOSECONDS_FMT "/"        /* min cpu time */
>          "%" PRId32 "."  NANOSECONDS_FMT "/"        /* max cpu time */
>          "%" PRId32 "."  NANOSECONDS_FMT " ",       /* avg cpu time */
> @@ -137,7 +134,7 @@ ididididid NNNN ccccc mmmmmm X
>        struct timespec *total_wall = &the_stats.total_wall_time;
>        _Timespec_Divide_by_integer(total_wall, the_stats.count, &wall_average);
>          "%" PRId32 "." NANOSECONDS_FMT "/"        /* min wall time */
>          "%" PRId32 "." NANOSECONDS_FMT "/"        /* max wall time */
>          "%" PRId32 "." NANOSECONDS_FMT "\n",      /* avg wall time */
> @@ -154,5 +151,7 @@ ididididid NNNN ccccc mmmmmm X
>  void rtems_rate_monotonic_report_statistics( void )
> -  rtems_rate_monotonic_report_statistics_with_plugin( NULL, printk_plugin );
> +  rtems_rate_monotonic_report_statistics_with_plugin( &printer );
> diff --git a/cpukit/sapi/include/rtems/profiling.h b/cpukit/sapi/include/rtems/profiling.h
> index 836e6d8..9e434b2 100644
> --- a/cpukit/sapi/include/rtems/profiling.h
> +++ b/cpukit/sapi/include/rtems/profiling.h
> @@ -25,6 +25,8 @@
>  #include <stdint.h>
>  #ifdef __cplusplus
>  extern "C" {
>  #endif /* __cplusplus */
> @@ -306,24 +308,10 @@ void rtems_profiling_iterate(
> - * @brief Function for formatted output.
> - * @param[in, out] arg Some argument.
> - * @param[in] format The output format as specified by printf().
> - * @param[in] ... More parameters according to format.
> - * @see rtems_profiling_report_xml().
> -typedef int (*rtems_profiling_printf)(void *arg, const char *format, ...);
>   * @brief Reports profiling data as XML.
>   * @param[in] name The name of the profiling report.
> + * @param[in] printer The RTEMS printer to send the output too.
>   * @param[in] indentation_level The current indentation level.
>   * @param[in] indentation The string used for indentation.
> @@ -331,8 +319,7 @@ typedef int (*rtems_profiling_printf)(void *arg, const char *format, ...);
>  int rtems_profiling_report_xml(
>    const char *name,
> -  rtems_profiling_printf printf_func,
> -  void *printf_arg,
>    uint32_t indentation_level,
>    const char *indentation
> diff --git a/cpukit/sapi/src/profilingreportxml.c b/cpukit/sapi/src/profilingreportxml.c
> index 777d1f1..e643146 100644
> --- a/cpukit/sapi/src/profilingreportxml.c
> +++ b/cpukit/sapi/src/profilingreportxml.c
> @@ -23,8 +23,7 @@
>  typedef struct {
> -  rtems_profiling_printf printf_func;
> -  void *printf_arg;
>    uint32_t indentation_level;
>    const char *indentation;
>    int retval;
> @@ -43,7 +42,7 @@ static void indent(context *ctx, uint32_t indentation_level)
>    uint32_t i;
>    for (i = 0; i < n; ++i) {
> -    int rv = (*ctx->printf_func)(ctx->printf_arg, "%s", ctx->indentation);
> +    int rv = rtems_printf(ctx->printer, "%s", ctx->indentation);
>      update_retval(ctx, rv);
> @@ -56,21 +55,19 @@ static uint64_t arithmetic_mean(uint64_t total, uint64_t count)
>  static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
> -  rtems_profiling_printf printf_func = ctx->printf_func;
> -  void *printf_arg = ctx->printf_arg;
>    int rv;
>    indent(ctx, 1);
> -  rv = (*printf_func)(
> -    printf_arg,
> +  rv = rtems_printf(
> +    ctx->printer,
>      "<PerCPUProfilingReport processorIndex=\"%" PRIu32 "\">\n",
>      per_cpu->processor_index
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MaxThreadDispatchDisabledTime unit=\"ns\">%" PRIu32
>        "</MaxThreadDispatchDisabledTime>\n",
>      per_cpu->max_thread_dispatch_disabled_time
> @@ -78,8 +75,8 @@ static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MeanThreadDispatchDisabledTime unit=\"ns\">%" PRIu64
>        "</MeanThreadDispatchDisabledTime>\n",
>      arithmetic_mean(
> @@ -90,8 +87,8 @@ static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<TotalThreadDispatchDisabledTime unit=\"ns\">%" PRIu64
>        "</TotalThreadDispatchDisabledTime>\n",
>      per_cpu->total_thread_dispatch_disabled_time
> @@ -99,24 +96,24 @@ static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<ThreadDispatchDisabledCount>%" PRIu64 "</ThreadDispatchDisabledCount>\n",
>      per_cpu->thread_dispatch_disabled_count
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MaxInterruptDelay unit=\"ns\">%" PRIu32 "</MaxInterruptDelay>\n",
>      per_cpu->max_interrupt_delay
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MaxInterruptTime unit=\"ns\">%" PRIu32
>        "</MaxInterruptTime>\n",
>      per_cpu->max_interrupt_time
> @@ -124,8 +121,8 @@ static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MeanInterruptTime unit=\"ns\">%" PRIu64
>        "</MeanInterruptTime>\n",
>      arithmetic_mean(
> @@ -136,24 +133,24 @@ static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<TotalInterruptTime unit=\"ns\">%" PRIu64 "</TotalInterruptTime>\n",
>      per_cpu->total_interrupt_time
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<InterruptCount>%" PRIu64 "</InterruptCount>\n",
>      per_cpu->interrupt_count
>    indent(ctx, 1);
> -    printf_arg,
> +    ctx->printer,
>      "</PerCPUProfilingReport>\n"
> @@ -161,38 +158,36 @@ static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
>  static void report_smp_lock(context *ctx, const rtems_profiling_smp_lock *smp_lock)
>    int rv;
>    uint32_t i;
>    indent(ctx, 1);
> -    printf_arg,
> +    ctx->printer,
>      "<SMPLockProfilingReport name=\"%s\">\n",
>      smp_lock->name
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MaxAcquireTime unit=\"ns\">%" PRIu32 "</MaxAcquireTime>\n",
>      smp_lock->max_acquire_time
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MaxSectionTime unit=\"ns\">%" PRIu32 "</MaxSectionTime>\n",
>      smp_lock->max_section_time
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MeanAcquireTime unit=\"ns\">%" PRIu64
>        "</MeanAcquireTime>\n",
>      arithmetic_mean(
> @@ -203,8 +198,8 @@ static void report_smp_lock(context *ctx, const rtems_profiling_smp_lock *smp_lo
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<MeanSectionTime unit=\"ns\">%" PRIu64
>        "</MeanSectionTime>\n",
>      arithmetic_mean(
> @@ -215,24 +210,24 @@ static void report_smp_lock(context *ctx, const rtems_profiling_smp_lock *smp_lo
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<TotalAcquireTime unit=\"ns\">%" PRIu64 "</TotalAcquireTime>\n",
>      smp_lock->total_acquire_time
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<TotalSectionTime unit=\"ns\">%" PRIu64 "</TotalSectionTime>\n",
>      smp_lock->total_section_time
>    indent(ctx, 2);
> -    printf_arg,
> +    ctx->printer,
>      "<UsageCount>%" PRIu64 "</UsageCount>\n",
>      smp_lock->usage_count
> @@ -240,8 +235,8 @@ static void report_smp_lock(context *ctx, const rtems_profiling_smp_lock *smp_lo
>    for (i = 0; i < RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS; ++i) {
>      indent(ctx, 2);
> -      printf_arg,
> +      ctx->printer,
>        "<ContentionCount initialQueueLength=\"%" PRIu32 "\">%"
>          PRIu64 "</ContentionCount>\n",
>        i,
> @@ -251,8 +246,8 @@ static void report_smp_lock(context *ctx, const rtems_profiling_smp_lock *smp_lo
>    indent(ctx, 1);
> -    printf_arg,
> +    ctx->printer,
>      "</SMPLockProfilingReport>\n"
> @@ -276,16 +271,14 @@ static void report(void *arg, const rtems_profiling_data *data)
>    const char *name,
> -  void *printf_arg,
>  #ifdef RTEMS_PROFILING
>    context ctx_instance = {
> -    .printf_func = printf_func,
> -    .printf_arg = printf_arg,
>      .indentation_level = indentation_level,
>      .indentation = indentation,
>      .retval = 0
> @@ -294,20 +287,19 @@ int rtems_profiling_report_xml(
>    int rv;
>    indent(ctx, 0);
> -  rv = (*printf_func)(printf_arg, "<ProfilingReport name=\"%s\">\n", name);
> +  rv = rtems_printf(printer, "<ProfilingReport name=\"%s\">\n", name);
>    rtems_profiling_iterate(report, ctx);
>    indent(ctx, 0);
> -  rv = (*printf_func)(printf_arg, "</ProfilingReport>\n");
> +  rv = rtems_printf(printer, "</ProfilingReport>\n");
>    return ctx->retval;
>  #else /* RTEMS_PROFILING */
>    (void) name;
> -  (void) printf_func;
> -  (void) printf_arg;
> +  (void) printer;
>    (void) indentation_level;
>    (void) indentation;
> diff --git a/cpukit/score/src/cpusetprintsupport.c b/cpukit/score/src/cpusetprintsupport.c
> index 76851d3..83345d9 100644
> --- a/cpukit/score/src/cpusetprintsupport.c
> +++ b/cpukit/score/src/cpusetprintsupport.c
> @@ -23,16 +23,15 @@
>  #include <stdio.h>
>  #include <ctype.h>
>  #include <rtems/score/cpusetimpl.h>
>  #ifdef __RTEMS_HAVE_SYS_CPUSET_H__
>    void _CPU_set_Show_with_plugin(
> -    void                  *context,
> -    const char            *description,
> -    const cpu_set_t       *cpuset
> +    const char          *description,
> +    const cpu_set_t     *cpuset
> @@ -42,21 +41,16 @@
>     * print plugin .
> -    void                  *context,
>      int i;
> -    if ( !print )
> -      return;
> -    (*print)(context ,"%s: ", description);
> +    rtems_printf(printer ,"%s: ", description);
>      for(i=0; i<_NCPUWORDS; i++)
> -      (*print)(context ,"%x", cpuset->__bits[i]);
> -    (*print)(context ,"\n");
> +      rtems_printf(printer ,"%x", cpuset->__bits[i]);
> +    rtems_printf(printer ,"\n");
> @@ -67,7 +61,9 @@
>    void _CPU_set_Show( const char *description, const cpu_set_t   *cpuset)
> -    _CPU_set_Show_with_plugin( NULL, printk_plugin, description, cpuset );
> +    _CPU_set_Show_with_plugin( &printer, description, cpuset );
> diff --git a/testsuites/fstests/fsnofs01/init.c b/testsuites/fstests/fsnofs01/init.c
> index 298ba8d..ff2c2a8 100644
> --- a/testsuites/fstests/fsnofs01/init.c
> +++ b/testsuites/fstests/fsnofs01/init.c
> @@ -495,7 +495,7 @@ static void test_check_access(void)
>  static void Init(rtems_task_argument arg)
> -  rtems_test_begink();
> +  TEST_BEGIN();
>    test_initial_values();
>    test_location_obtain();
> @@ -506,7 +506,7 @@ static void Init(rtems_task_argument arg)
>    test_user_env();
>    test_check_access();
> -  rtems_test_endk();
> +  TEST_END();
>    exit(0);
> diff --git a/testsuites/libtests/block02/init.c b/testsuites/libtests/block02/init.c
> index f53dacc..8630641 100644
> --- a/testsuites/libtests/block02/init.c
> +++ b/testsuites/libtests/block02/init.c
> @@ -24,6 +24,7 @@
>  #include "config.h"
>  #endif
> +#define TESTS_USE_PRINTK
>  #include "tmacros.h"
>  #include <rtems.h>
> @@ -82,7 +83,7 @@ static void task_low(rtems_task_argument arg)
>    rtems_test_assert(bd->dd == dd_a);
> +  TEST_END();
>    exit(0);
> @@ -136,7 +137,7 @@ static rtems_task Init(rtems_task_argument argument)
>    dev_t dev_a = 0;
>    dev_t dev_b = 0;
> +  TEST_BEGIN();
>    sc = rtems_disk_io_initialize();
>    ASSERT_SC(sc);
> diff --git a/testsuites/libtests/block03/init.c b/testsuites/libtests/block03/init.c
> index 1da59f0..f2a18b9 100644
> --- a/testsuites/libtests/block03/init.c
> +++ b/testsuites/libtests/block03/init.c
> @@ -24,6 +24,7 @@
>  #include "config.h"
>  #endif
>  #include <rtems.h>
> @@ -76,7 +77,7 @@ static void task_low(rtems_task_argument arg)
>    rtems_test_assert(bd->block == 0);
> +  TEST_END();
>    exit(0);
> @@ -129,7 +130,7 @@ static rtems_task Init(rtems_task_argument argument)
>    rtems_bdbuf_buffer *bd = NULL;
>    dev_t dev = 0;
> +  TEST_BEGIN();
>    ASSERT_SC(sc);
> diff --git a/testsuites/libtests/block04/init.c b/testsuites/libtests/block04/init.c
> index 6731556..3f448c7 100644
> --- a/testsuites/libtests/block04/init.c
> +++ b/testsuites/libtests/block04/init.c
> @@ -24,6 +24,7 @@
>  #include "config.h"
>  #endif
>  #include <rtems.h>
> @@ -101,7 +102,7 @@ static void task_high(rtems_task_argument arg)
>    printk("H: release done: 0\n");
> +  TEST_END();
>    exit(0);
> @@ -111,7 +112,7 @@ static rtems_task Init(rtems_task_argument argument)
>    rtems_status_code sc = RTEMS_SUCCESSFUL;
>    dev_t dev = 0;
> +  TEST_BEGIN();
>    ASSERT_SC(sc);
> diff --git a/testsuites/libtests/block05/init.c b/testsuites/libtests/block05/init.c
> index 59889cc..7cce2ac 100644
> --- a/testsuites/libtests/block05/init.c
> +++ b/testsuites/libtests/block05/init.c
> @@ -24,6 +24,7 @@
>  #include "config.h"
>  #endif
>  #include <stdarg.h>
>  #include <errno.h>
> @@ -426,7 +427,7 @@ static rtems_task Init(rtems_task_argument argument)
>    unsigned i = 0;
> +  TEST_BEGIN();
>    task_id_init = rtems_task_self();
> @@ -505,7 +506,7 @@ static rtems_task Init(rtems_task_argument argument)
> +  TEST_END();
>    exit(0);
> diff --git a/testsuites/libtests/block06/init.c b/testsuites/libtests/block06/init.c
> index 2234034..1b91ad7 100644
> --- a/testsuites/libtests/block06/init.c
> +++ b/testsuites/libtests/block06/init.c
> @@ -32,7 +32,7 @@
>  #include <bsp.h>
> -#include <tmacros.h>
> +#include "tmacros.h"
>  const char rtems_test_name[] = "BLOCK 6";
> diff --git a/testsuites/libtests/block07/init.c b/testsuites/libtests/block07/init.c
> index f34e412..cd1b64a 100644
> --- a/testsuites/libtests/block07/init.c
> +++ b/testsuites/libtests/block07/init.c
> @@ -27,6 +27,8 @@
>  #include <sys/stat.h>
>  #include <fcntl.h>
>  #include <rtems.h>
> @@ -102,7 +104,7 @@ static void task_low(rtems_task_argument arg)
>    printk("L: release done: 0\n");
> +  TEST_END();
>    exit(0);
> @@ -164,7 +166,7 @@ static rtems_task Init(rtems_task_argument argument)
>    dev_t dev = 0;
> +  TEST_BEGIN();
>    ASSERT_SC(sc);
> diff --git a/testsuites/libtests/block08/init.c b/testsuites/libtests/block08/init.c
> index 84e755f..83eaf6d 100644
> --- a/testsuites/libtests/block08/init.c
> +++ b/testsuites/libtests/block08/init.c
> @@ -19,6 +19,8 @@
>  #include "config.h"
>  #endif
>  #define CONFIGURE_INIT
>  #include "system.h"
> @@ -30,10 +32,9 @@ const char rtems_test_name[] = "BLOCK 8";
> -  rtems_test_begin();
> +  TEST_BEGIN();
>    run_bdbuf_tests();
> -  rtems_test_end();
> +  TEST_END();
>    exit(0);
> diff --git a/testsuites/libtests/block09/init.c b/testsuites/libtests/block09/init.c
> index 2d7cc7a..45e3b7a 100644
> --- a/testsuites/libtests/block09/init.c
> +++ b/testsuites/libtests/block09/init.c
> @@ -24,6 +24,9 @@
>  #include "config.h"
>  #endif
>  #include <assert.h>
>  #include <errno.h>
>  #include <stdlib.h>
> @@ -176,7 +179,7 @@ static rtems_task Init(rtems_task_argument argument)
>    dev_t dev = 0;
>    rtems_disk_device *dd = NULL;
> +  TEST_BEGIN();
>    ASSERT_SC(sc);
> @@ -224,7 +227,7 @@ static rtems_task Init(rtems_task_argument argument)
>    sc = rtems_disk_release(dd);
>    ASSERT_SC(sc);
> +  TEST_END();
>    exit(0);
> diff --git a/testsuites/libtests/block10/init.c b/testsuites/libtests/block10/init.c
> index fac6781..1cdc91e 100644
> --- a/testsuites/libtests/block10/init.c
> +++ b/testsuites/libtests/block10/init.c
> @@ -23,6 +23,9 @@
>  #include "config.h"
>  #endif
>  #include <assert.h>
>  #include <errno.h>
>  #include <stdlib.h>
> @@ -402,7 +405,7 @@ static rtems_task Init(rtems_task_argument argument)
>    size_t i_rel = 0;
>    size_t i_p = 0;
> +  TEST_BEGIN();
> @@ -466,7 +469,7 @@ static rtems_task Init(rtems_task_argument argument)
> +  TEST_END();
>    exit(0);
> diff --git a/testsuites/libtests/block14/init.c b/testsuites/libtests/block14/init.c
> index 98282bc..889e853 100644
> --- a/testsuites/libtests/block14/init.c
> +++ b/testsuites/libtests/block14/init.c
> @@ -118,8 +118,11 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
>  static void test_actions(rtems_disk_device *dd)
>    int i;
>    for (i = 0; i < ACTION_COUNT; ++i) {
>      const test_action *action = &actions [i];
> @@ -155,7 +158,7 @@ static void test_actions(rtems_disk_device *dd)
> -  rtems_blkdev_print_stats(&dd->stats, 0, 1, 2, rtems_printf_plugin, NULL);
> +  rtems_blkdev_print_stats(&dd->stats, 0, 1, 2, &printer);
>  static void test(void)
> diff --git a/testsuites/libtests/capture01/init.c b/testsuites/libtests/capture01/init.c
> index 7957742..538583e 100644
> --- a/testsuites/libtests/capture01/init.c
> +++ b/testsuites/libtests/capture01/init.c
> @@ -33,6 +33,7 @@
>  rtems_task Init(rtems_task_argument argument);
>  const char rtems_test_name[] = "CAPTURE 1";
> +rtems_printer rtems_test_printer;
>  rtems_task Init(
>    rtems_task_argument ignored
> @@ -46,6 +47,8 @@ rtems_task Init(
>    rtems_mode          old_mode;
>    rtems_name          to_name = rtems_build_name('I', 'D', 'L', 'E');;
> +  rtems_print_printer_printf(&rtems_test_printer);
>    rtems_test_begin();
>    rtems_task_set_priority(RTEMS_SELF, 20, &old_priority);
> diff --git a/testsuites/libtests/complex/init.c b/testsuites/libtests/complex/init.c
> index 658af91..3d542fb 100644
> --- a/testsuites/libtests/complex/init.c
> +++ b/testsuites/libtests/complex/init.c
> @@ -27,6 +27,7 @@
>  const char rtems_test_name[] = "COMPLEX";
>  #endif
>  #include <stdio.h>
> @@ -60,11 +61,12 @@ int main( void )
>  #endif
>  #if __rtems__
>    rtems_test_begin();
>  #endif
>    docomplex();
> -  docomplexf();
> +  docomplexf();
>    docomplexl();
>  #if __rtems__
>    rtems_test_end();
> diff --git a/testsuites/libtests/devnullfatal01/testcase.h b/testsuites/libtests/devnullfatal01/testcase.h
> index 87a098e..14675da 100644
> --- a/testsuites/libtests/devnullfatal01/testcase.h
> +++ b/testsuites/libtests/devnullfatal01/testcase.h
> @@ -13,6 +13,8 @@
>  #define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
>  #define FATAL_ERROR_EXPECTED_ERROR       RTEMS_TOO_MANY
>  #include <rtems/devnull.h>
> @@ -28,4 +30,3 @@ void force_error()
>    /* A fatal error would be raised in previous call */
>    /* we will not run this far */
> diff --git a/testsuites/libtests/exit01/init.c b/testsuites/libtests/exit01/init.c
> index 6fbad6b..b677c3a 100644
> --- a/testsuites/libtests/exit01/init.c
> +++ b/testsuites/libtests/exit01/init.c
> @@ -16,13 +16,15 @@
>    #include "config.h"
>  #endif
>  #include <stdlib.h>
>  /* Use assert() not rtems_test_assert() since it uses exit() */
>  #include <assert.h>
>  #include <rtems.h>
> -#include <rtems/test.h>
>  const char rtems_test_name[] = "EXIT 1";
> @@ -60,7 +62,7 @@ static void fatal_extension(
>        && error == EXIT_STATUS
>        && counter == 3
> +    TEST_END();
> @@ -85,7 +87,7 @@ static void Init(rtems_task_argument arg)
>    rtems_id id;
> +  TEST_BEGIN();
>    sc = rtems_task_create(
>      rtems_build_name('E', 'X', 'I', 'T'),
> diff --git a/testsuites/libtests/exit02/init.c b/testsuites/libtests/exit02/init.c
> index 88e0874..f185d0f 100644
> --- a/testsuites/libtests/exit02/init.c
> +++ b/testsuites/libtests/exit02/init.c
> @@ -16,13 +16,15 @@
>    #include "config.h"
>  #endif
>  #include <stdlib.h>
>  #include <assert.h>
>  #include <rtems.h>
>  const char rtems_test_name[] = "EXIT 2";
> @@ -44,7 +46,7 @@ static void fatal_extension(
>        && !is_internal
> +    TEST_END();
> @@ -63,7 +65,7 @@ static void Init(rtems_task_argument arg)
>    rtems_id id;
> +  TEST_BEGIN();
> diff --git a/testsuites/libtests/math/init.c b/testsuites/libtests/math/init.c
> index 0d4a97e..c045735 100644
> --- a/testsuites/libtests/math/init.c
> +++ b/testsuites/libtests/math/init.c
> @@ -22,11 +22,16 @@
>  #include "config.h"
>  #endif
> + * @fixme This test should use the test macros but the include paths are
> + *        are wrong in the build system.
>  #if __rtems__
>  #include <bsp.h> /* for device driver prototypes */
>  const char rtems_test_name[] = "MATH";
>  #endif
>  #include <stdio.h>
> @@ -58,6 +63,7 @@ int main( void )
>  #endif
>  #if __rtems__
>    rtems_test_begin();
>  #endif
> @@ -68,4 +74,3 @@ int main( void )
>  #endif
>    exit( 0 );
> diff --git a/testsuites/libtests/mathf/init.c b/testsuites/libtests/mathf/init.c
> index 4cb1994..c91e6fe 100644
> --- a/testsuites/libtests/mathf/init.c
> +++ b/testsuites/libtests/mathf/init.c
> @@ -27,6 +27,7 @@
>  const char rtems_test_name[] = "MATHF";
>  #endif
>  #include <stdio.h>
> @@ -58,14 +59,14 @@ int main( void )
>  #endif
>  #if __rtems__
>    rtems_test_begin();
>  #endif
> -  domathf();
> +  domathf();
>  #if __rtems__
>    rtems_test_end();
>  #endif
>    exit( 0 );
> diff --git a/testsuites/libtests/mathl/init.c b/testsuites/libtests/mathl/init.c
> index 0dab9da..ca26f11 100644
> --- a/testsuites/libtests/mathl/init.c
> +++ b/testsuites/libtests/mathl/init.c
> @@ -27,6 +27,7 @@
>  const char rtems_test_name[] = "MATHL";
>  #endif
>  #include <stdio.h>
> @@ -58,10 +59,11 @@ int main( void )
>  #endif
>  #if __rtems__
>    rtems_test_begin();
>  #endif
> -  domathl();
> +  domathl();
>  #if __rtems__
>    rtems_test_end();
> diff --git a/testsuites/libtests/mouse01/init.c b/testsuites/libtests/mouse01/init.c
> index a002f09..cc33630 100644
> --- a/testsuites/libtests/mouse01/init.c
> +++ b/testsuites/libtests/mouse01/init.c
> @@ -60,7 +60,7 @@ bool enqueue_next_action(
>      return false;
>    termios_test_driver_set_rx_enqueue_now( true );
>    termios_test_driver_set_rx( &actions[Mouse_Index], to_enqueue );
>    Mouse_Index += to_enqueue;
> @@ -95,9 +95,10 @@ void printf_uid_message(
> +  rtems_printer printer;
> +  rtems_print_printer_printf( &printer );
> -    stdout,
> -    (rtems_printk_plugin_t)fprintf,
> +    &printer,
>      uid
> @@ -135,16 +136,16 @@ rtems_task Init(
>    TEST_BEGIN();
>    open_it();
> -  register_it();
> +  register_it();
>    do {
>      more_data = enqueue_next_action(
>        Mouse_Actions,
> -      Mouse_Actions_Size,
> +      Mouse_Actions_Size,
>        Mouse_Actions_Per_Iteration
>      receive_uid_message();
>    } while (more_data);
> -  close_it();
> +  close_it();
>    TEST_END();
>    rtems_test_exit( 0 );
> diff --git a/testsuites/libtests/stackchk/init.c b/testsuites/libtests/stackchk/init.c
> index cc54bf6..4e1e41c 100644
> --- a/testsuites/libtests/stackchk/init.c
> +++ b/testsuites/libtests/stackchk/init.c
> @@ -101,6 +101,6 @@ void Fatal_extension(
>    } else if ( error != rtems_build_name( 'T', 'A', '1', ' ' ) ) {
>      printk( "unexpected fatal error\n" );
>    } else {
> +    TEST_END();
> diff --git a/testsuites/libtests/stackchk/system.h b/testsuites/libtests/stackchk/system.h
> index 6d9ce27..96f56fb 100644
> --- a/testsuites/libtests/stackchk/system.h
> +++ b/testsuites/libtests/stackchk/system.h
> @@ -11,6 +11,7 @@
>  /* macros */
> diff --git a/testsuites/libtests/uid01/init.c b/testsuites/libtests/uid01/init.c
> index 13ec8ba..f8ec4bd 100644
> --- a/testsuites/libtests/uid01/init.c
> +++ b/testsuites/libtests/uid01/init.c
> @@ -69,9 +69,10 @@ void printf_uid_message(
> -    stdout,
> +    &printer,
>      uid
> @@ -111,12 +112,12 @@ rtems_task Init(
>    /* No message should ever be recieved. With a timeout val of 0, this
>     * call will never return. We use this to check if patch was correct
>     * by passing a number of ticks greater than 0 and less than 1. If
> -   * patch was correct, this call will timeout instead of waiting
> +   * patch was correct, this call will timeout instead of waiting
>     * indefinitely.
> -  close_it();
> +  close_it();
>    TEST_END();
> diff --git a/testsuites/psxtests/psxfatal_support/init.c b/testsuites/psxtests/psxfatal_support/init.c
> index 350b3a2..0f995dc 100644
> --- a/testsuites/psxtests/psxfatal_support/init.c
> +++ b/testsuites/psxtests/psxfatal_support/init.c
> @@ -11,6 +11,9 @@
>  #include "config.h"
>  #endif
>  #include "system.h"
> @@ -22,7 +25,7 @@ static void print_test_begin_message(void)
>    if (!done) {
>      done = true;
> +    TEST_BEGIN();
> @@ -95,7 +98,6 @@ void Fatal_extension(
>        && is_internal == FATAL_ERROR_EXPECTED_IS_INTERNAL
>        && error == FATAL_ERROR_EXPECTED_ERROR
> +    TEST_END();
> diff --git a/testsuites/samples/capture/init.c b/testsuites/samples/capture/init.c
> index a10ccc5..557e809 100644
> --- a/testsuites/samples/capture/init.c
> +++ b/testsuites/samples/capture/init.c
> @@ -27,6 +27,7 @@ rtems_task Init(rtems_task_argument argument);
>  static void notification(int fd, int seconds_remaining, void *arg);
>  const char rtems_test_name[] = "CAPTURE ENGINE";
>  volatile int can_proceed = 1;
> @@ -46,6 +47,7 @@ rtems_task Init(
>    rtems_task_priority old_priority;
>    rtems_test_begin();
>    status = rtems_shell_wait_for_input(
> diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
> index d8fe450..ea9af89 100644
> --- a/testsuites/samples/hello/init.c
> +++ b/testsuites/samples/hello/init.c
> @@ -22,11 +22,13 @@
>  const char rtems_test_name[] = "HELLO WORLD";
>  rtems_task Init(
>    rtems_test_begin();
>    printf( "Hello World\n" );
>    rtems_test_end();
> diff --git a/testsuites/samples/paranoia/init.c b/testsuites/samples/paranoia/init.c
> index 3718af4..ac7c214 100644
> --- a/testsuites/samples/paranoia/init.c
> +++ b/testsuites/samples/paranoia/init.c
> @@ -19,6 +19,7 @@
>  extern int paranoia(int, char **);
>  const char rtems_test_name[] = "PARANOIA";
>  char *args[2] = { "paranoia", 0 };
> @@ -35,6 +36,7 @@ rtems_task Init(
>    M68KFPSPInstallExceptionHandlers ();
>  #endif
>    rtems_test_begin();
>    paranoia(1, args);
>    rtems_test_end();
> diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/init.c
> index 424e9df..31f77a3 100644
> --- a/testsuites/smptests/smp05/init.c
> +++ b/testsuites/smptests/smp05/init.c
> @@ -27,7 +27,7 @@ rtems_task Test_task(
>  static void success(void)
> -  rtems_test_end_with_plugin(locked_printf_plugin, NULL);
> +  rtems_test_end();
> @@ -50,7 +50,7 @@ rtems_task Init(
>    locked_print_initialize();
> -  rtems_test_begin_with_plugin(locked_printf_plugin, NULL);
> +  rtems_test_begin();
>    if ( rtems_get_processor_count() == 1 ) {
>      success();
> diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/init.c
> index c26669a..6acfe21 100644
> --- a/testsuites/smptests/smp07/init.c
> +++ b/testsuites/smptests/smp07/init.c
> @@ -18,7 +18,7 @@ const char rtems_test_name[] = "SMP 7";
>  volatile bool TaskRan = false;
>  volatile bool TSRFired = false;
> -rtems_id      Semaphore;
> +rtems_id      Semaphore;
>  rtems_task Init(
> @@ -30,7 +30,7 @@ rtems_task Test_task(
> +  rtems_test_end( );
> @@ -63,8 +63,8 @@ rtems_task Test_task(
>    /* Print that the task is up and running. */
>    locked_printf(
> -    " CPU %" PRIu32 " running Task %s after semaphore release\n",
> -    cpu_num,
> +    " CPU %" PRIu32 " running Task %s after semaphore release\n",
> +    cpu_num,
>      name
> @@ -98,7 +98,7 @@ rtems_task Init(
>    rtems_id           Timer;
>      success();
> @@ -107,7 +107,7 @@ rtems_task Init(
>    /* Create/verify semaphore */
>    status = rtems_semaphore_create(
>      rtems_build_name ('S', 'E', 'M', '1'),
> -    1,
> +    1,
>      RTEMS_LOCAL                   |
>      RTEMS_SIMPLE_BINARY_SEMAPHORE |
>      RTEMS_PRIORITY,
> @@ -157,7 +157,7 @@ rtems_task Init(
>      if ( TSRFired && TaskRan )
>        break;
>    /* Validate the timer fired and that the task ran */
>    if ( !TSRFired )
>      locked_printf( "*** ERROR TSR DID NOT FIRE ***" );
> diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
> index 9346d87..e7f1597 100644
> --- a/testsuites/smptests/smpfatal01/init.c
> +++ b/testsuites/smptests/smpfatal01/init.c
> @@ -16,8 +16,10 @@
>    #include "config.h"
>  #endif
>  #include <rtems.h>
>  #include <rtems/score/percpu.h>
>  #include <rtems/score/smpimpl.h>
> @@ -62,7 +64,7 @@ static void fatal_extension(
>          assert(state == PER_CPU_STATE_SHUTDOWN);
> +      TEST_END();
> @@ -79,7 +81,7 @@ static rtems_status_code test_driver_init(
>    uint32_t cpu_count = rtems_get_processor_count();
>    uint32_t cpu;
> +  TEST_BEGIN();
>    assert(rtems_configuration_get_maximum_processors() == MAX_CPUS);
> @@ -107,7 +109,7 @@ static rtems_status_code test_driver_init(
>      per_cpu->state = PER_CPU_STATE_SHUTDOWN;
>    } else {
> +    TEST_END();
>      exit(0);
> diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
> index c98ff3c..71fff0c 100644
> --- a/testsuites/smptests/smpfatal02/init.c
> +++ b/testsuites/smptests/smpfatal02/init.c
> @@ -16,8 +16,10 @@
>    #include "config.h"
>  #endif
>  #include <rtems.h>
> @@ -67,7 +69,7 @@ static void fatal_extension(
> +      TEST_END();
>      } else {
>        assert(source == RTEMS_FATAL_SOURCE_SMP);
>        assert(code == SMP_FATAL_SHUTDOWN);
> @@ -87,7 +89,7 @@ static rtems_status_code test_driver_init(
>    uint32_t cpu;
> +  TEST_BEGIN();
> @@ -112,7 +114,7 @@ static rtems_status_code test_driver_init(
>    if (cpu_count > 1) {
>      rtems_fatal(RTEMS_FATAL_SOURCE_APPLICATION, 0xdeadbeef);
>    } else {
> +    TEST_END();
>      exit(0);
> diff --git a/testsuites/smptests/smpfatal04/init.c b/testsuites/smptests/smpfatal04/init.c
> index 39ceebf..ebfa849 100644
> --- a/testsuites/smptests/smpfatal04/init.c
> +++ b/testsuites/smptests/smpfatal04/init.c
> @@ -16,8 +16,10 @@
>    #include "config.h"
>  #endif
>  #include <rtems.h>
>  #include <assert.h>
> @@ -36,14 +38,14 @@ static void fatal_extension(
>    rtems_fatal_code code
> +  TEST_BEGIN();
>    if (
>        && !is_internal
>        && code == SMP_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER
> +    TEST_END();
> diff --git a/testsuites/smptests/smpfatal05/init.c b/testsuites/smptests/smpfatal05/init.c
> index 37b3dee..1e1e535 100644
> --- a/testsuites/smptests/smpfatal05/init.c
> +++ b/testsuites/smptests/smpfatal05/init.c
> @@ -16,8 +16,10 @@
>    #include "config.h"
>  #endif
>  #include <rtems.h>
>  #include <assert.h>
> +  TEST_BEGIN();
>    if (
>        && !is_internal
>        && code == SMP_FATAL_MANDATORY_PROCESSOR_NOT_PRESENT
> +    TEST_END();
> diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/smpfatal08/init.c
> index 2de76e4..4b7aaf5 100644
> --- a/testsuites/smptests/smpfatal08/init.c
> +++ b/testsuites/smptests/smpfatal08/init.c
> @@ -16,8 +16,10 @@
>    #include "config.h"
>  #endif
>  #include <rtems.h>
>  #include <bsp.h>
> @@ -93,14 +95,14 @@ static void fatal_extension(
> +  TEST_BEGIN();
>    if (
>        && !is_internal
>        && code == SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED
> +    TEST_END();
> diff --git a/testsuites/sptests/sperror01/init.c b/testsuites/sptests/sperror01/init.c
> index 4c40be5..a84eaf9 100644
> --- a/testsuites/sptests/sperror01/init.c
> +++ b/testsuites/sptests/sperror01/init.c
> @@ -11,7 +11,9 @@
>  #include "config.h"
>  #endif
>  #include "test_support.h"
>  #include "rtems/error.h"
>  #include <errno.h>
> @@ -32,7 +34,7 @@ static void fatal_extension(
>        && !is_internal
>        && error == ENOMEM
> +    TEST_END();
> diff --git a/testsuites/sptests/sperror02/init.c b/testsuites/sptests/sperror02/init.c
> index dca2219..0bb7cea 100644
> --- a/testsuites/sptests/sperror02/init.c
> +++ b/testsuites/sptests/sperror02/init.c
> @@ -11,7 +11,9 @@
>  #include "config.h"
>  #endif
>  #include <errno.h>
>  #include <rtems/error.h>
>        && !is_internal
>        && error == 1
> +    TEST_END();
> @@ -44,7 +46,7 @@ rtems_task Init(
>    errno = ENOMEM;
>    rtems_error(
> -    RTEMS_NO_MEMORY | RTEMS_ERROR_ABORT,
> +    RTEMS_NO_MEMORY | RTEMS_ERROR_ABORT,
>      "Dummy: Resources unavailable\n"
> diff --git a/testsuites/sptests/sperror03/init.c b/testsuites/sptests/sperror03/init.c
> index 818b907..aecdb79 100644
> --- a/testsuites/sptests/sperror03/init.c
> +++ b/testsuites/sptests/sperror03/init.c
> @@ -11,7 +11,8 @@
>  #include "config.h"
>  #endif
>  const char rtems_test_name[] = "SPERROR 3";
> @@ -30,7 +31,7 @@ static void fatal_extension(
>        && !is_internal
>        && error == 0
> +    TEST_END();
> diff --git a/testsuites/sptests/spextensions01/init.c b/testsuites/sptests/spextensions01/init.c
> index d8593b9..091d66f 100644
> --- a/testsuites/sptests/spextensions01/init.c
> +++ b/testsuites/sptests/spextensions01/init.c
> @@ -16,12 +16,13 @@
>    #include "config.h"
>  #endif
>  #include <assert.h>
>  #include <limits.h>
>  #include <stdlib.h>
>  #include <bsp.h>
>  const char rtems_test_name[] = "SPEXTENSIONS 1";
> @@ -199,7 +200,7 @@ static void two_fatal(
>    if (source == RTEMS_FATAL_SOURCE_EXIT) {
>      assert_reverse_order(2);
>      assert(counter == 72);
> +    TEST_END();
> @@ -424,7 +425,7 @@ static void test(void)
> +  TEST_BEGIN();
>    test();
> diff --git a/testsuites/sptests/spfatal07/testcase.h b/testsuites/sptests/spfatal07/testcase.h
> index 5ccaaa4..7cc9a5f 100644
> --- a/testsuites/sptests/spfatal07/testcase.h
> +++ b/testsuites/sptests/spfatal07/testcase.h
> @@ -50,7 +50,7 @@ void force_error()
>        "WARNING - Test not applicable on this target architecture.\n"
>        "WARNING - Only applicable when CPU_ALLOCATE_INTERRUPT_STACK == TRUE.\n"
> +    TEST_END();
>      rtems_test_exit(0);
>    #endif
> diff --git a/testsuites/sptests/spfatal16/testcase.h b/testsuites/sptests/spfatal16/testcase.h
> index 65af957..743b2be 100644
> --- a/testsuites/sptests/spfatal16/testcase.h
> +++ b/testsuites/sptests/spfatal16/testcase.h
> @@ -7,7 +7,7 @@
>   *  http://www.rtems.org/license/LICENSE.
> -/* generate fatal errors in termios.c
> +/* generate fatal errors in termios.c
>   *    rtems_semaphore_create( rtems_build_name ('T', 'R', 'r', c),...);
> @@ -25,6 +25,6 @@
>  void force_error()
>    /* This fatal error depends on the Termios device configuration */
> +  TEST_END();
>    rtems_test_exit(0);
> diff --git a/testsuites/sptests/spfatal26/init.c b/testsuites/sptests/spfatal26/init.c
> index 7235f8d..4013b94 100644
> --- a/testsuites/sptests/spfatal26/init.c
> +++ b/testsuites/sptests/spfatal26/init.c
> @@ -16,6 +16,7 @@
>    #include "config.h"
>  #endif
>  #include <limits.h>
> @@ -51,7 +52,7 @@ static void provoke_aligment_or_data_access_exception( void )
>  static void Init( rtems_task_argument arg )
> +  TEST_BEGIN();
>    provoke_aligment_or_data_access_exception();
> @@ -69,7 +70,7 @@ static void fatal_extension(
>    rtems_exception_frame_print( (const rtems_exception_frame *) code );
> +  TEST_END();
>  #define CONFIGURE_INITIAL_EXTENSIONS \
> diff --git a/testsuites/sptests/spfatal_support/init.c b/testsuites/sptests/spfatal_support/init.c
> index 1052da4..f048d4b 100644
> --- a/testsuites/sptests/spfatal_support/init.c
> +++ b/testsuites/sptests/spfatal_support/init.c
> @@ -22,7 +22,7 @@ static void print_test_begin_message(void)
>    if (!done) {
>      done = true;
> +    TEST_BEGIN();
> @@ -107,7 +107,6 @@ void Fatal_extension(
>        && is_expected_error( error )
> +    TEST_END();
> diff --git a/testsuites/sptests/spfatal_support/system.h b/testsuites/sptests/spfatal_support/system.h
> index 19adb47..0a01e21 100644
> --- a/testsuites/sptests/spfatal_support/system.h
> +++ b/testsuites/sptests/spfatal_support/system.h
> @@ -14,9 +14,11 @@
>   *  Some of the fatal error cases require the ability to peek inside RTEMS
>  #include <rtems.h>
>  /* functions */
> diff --git a/testsuites/sptests/spinternalerror01/init.c b/testsuites/sptests/spinternalerror01/init.c
> index a1ddc14..e864db1 100644
> --- a/testsuites/sptests/spinternalerror01/init.c
> +++ b/testsuites/sptests/spinternalerror01/init.c
> @@ -16,11 +16,12 @@
>    #include "config.h"
>  #endif
>  #include <bsp.h>
>  #include <bsp/bootcard.h>
>  const char rtems_test_name[] = "SPINTERNALERROR 1";
>  #define FATAL_SOURCE 0xdeadbeef
> @@ -40,14 +41,14 @@ static void fatal_extension(
>    Internal_errors_t error
> +  TEST_BEGIN();
>    if (
>      source == FATAL_SOURCE
>        && is_internal == FATAL_IS_INTERNAL
> +    TEST_END();
> diff --git a/testsuites/sptests/spprintk/init.c b/testsuites/sptests/spprintk/init.c
> index eea17ad..8086a1a 100644
> --- a/testsuites/sptests/spprintk/init.c
> +++ b/testsuites/sptests/spprintk/init.c
> @@ -13,11 +13,19 @@
>  #include "config.h"
>  #endif
> -#include <rtems/bspIo.h>
> +#include <rtems/print.h>
>  const char rtems_test_name[] = "SPPRINTK";
> + * Undefined the RTEMS_PRINTF_ATTRIBUTE and make it nothing. The test code
> + * contained in the file is suppose to be wrong.
> +#undef RTEMS_PRINTF_ATTRIBUTE
> +#define RTEMS_PRINTF_ATTRIBUTE(_a, _b)
>  /* forward declarations to avoid warnings */
>  int test_getchar(void);
> @@ -38,7 +46,7 @@ void do_getchark(void)
>    poll_char = BSP_poll_char;
>    BSP_poll_char = NULL;
>    putk( "getchark - NULL getchar method - return -1" );
>    sc = getchark();
>    rtems_test_assert( sc == -1 );
> @@ -124,7 +132,7 @@ rtems_task Init(
> +  TEST_BEGIN();
>    do_putk();
>    putk("");
> @@ -134,7 +142,7 @@ rtems_task Init(
>    do_getchark();
> +  TEST_END();
> @@ -151,4 +159,3 @@ rtems_task Init(
>  #include <rtems/confdefs.h>
> diff --git a/testsuites/sptests/spprofiling01/init.c b/testsuites/sptests/spprofiling01/init.c
> index afbe2c7..60f6bd5 100644
> --- a/testsuites/sptests/spprofiling01/init.c
> +++ b/testsuites/sptests/spprofiling01/init.c
> @@ -115,13 +115,15 @@ static void test_iterate(void)
>  static void test_report_xml(void)
>    int rv;
>    sc = rtems_task_wake_after(3);
>    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> -  rv = rtems_profiling_report_xml("X", rtems_printf_plugin, NULL, 1, "  ");
> +  rtems_print_printer_printf(&printer);
> +  rv = rtems_profiling_report_xml("X", &printer, 1, "  ");
>    printf("characters produced by rtems_profiling_report_xml(): %i\n", rv);
> diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
> index e12f7f3..c598ee5 100644
> --- a/testsuites/sptests/spsysinit01/init.c
> +++ b/testsuites/sptests/spsysinit01/init.c
> @@ -16,6 +16,9 @@
>    #include "config.h"
>  #endif
> @@ -29,7 +32,6 @@
>  #include <rtems/ioimpl.h>
>  #include <rtems/libio_.h>
>  #include <rtems/sysinit.h>
>  #include <rtems/extensionimpl.h>
>  #ifdef RTEMS_POSIX_API
> @@ -173,7 +175,7 @@ static void next_step(init_step expected)
>  FIRST(RTEMS_SYSINIT_BSP_WORK_AREAS)
> +  TEST_BEGIN();
>    assert(_Workspace_Area.area_begin == 0);
>    next_step(BSP_WORK_AREAS_PRE);
> @@ -674,7 +676,7 @@ static void Init(rtems_task_argument arg)
>    pthread_cleanup_pop(0);
>  #endif /* RTEMS_POSIX_API */
>    next_step(INIT_TASK);
> +  TEST_END();
>    exit(0);
> diff --git a/testsuites/sptests/sptimecounter01/init.c b/testsuites/sptests/sptimecounter01/init.c
> index d87ffec..9e396de 100644
> --- a/testsuites/sptests/sptimecounter01/init.c
> +++ b/testsuites/sptests/sptimecounter01/init.c
> @@ -16,12 +16,13 @@
>    #include "config.h"
>  #endif
>  #include <assert.h>
>  #include <rtems/score/timecounterimpl.h>
>  #include <rtems/score/todimpl.h>
>  #include <rtems/timecounter.h>
> @@ -54,7 +55,7 @@ void boot_card(const char *cmdline)
>    struct timeval tv;
>    struct timespec ts;
> +  TEST_BEGIN();
>    assert(time(NULL) == TOD_SECONDS_1970_THROUGH_1988);
> @@ -148,7 +149,7 @@ void boot_card(const char *cmdline)
>    assert(bt.sec == 1);
>    assert(bt.frac == 18446742522092);
> +  TEST_END();
>    _Terminate(RTEMS_FATAL_SOURCE_EXIT, false, 0);
> diff --git a/testsuites/support/include/buffer_test_io.h b/testsuites/support/include/buffer_test_io.h
> index e5fbd2b..0ae3909 100644
> --- a/testsuites/support/include/buffer_test_io.h
> +++ b/testsuites/support/include/buffer_test_io.h
> @@ -24,7 +24,7 @@ extern "C" {
>  #if defined(TESTS_USE_PRINTK)
>    #undef printf
>    #define printf(...) \
> @@ -54,9 +54,9 @@ extern "C" {
>      do { \
>      } while (0)
> -  #define TEST_BEGIN() rtems_test_begink()
> +  #define TEST_BEGIN() printk(TEST_BEGIN_STRING)
> -  #define TEST_END() rtems_test_endk()
> +  #define TEST_END() printk(TEST_END_STRING)
>   *  BUFFER TEST OUTPUT
> @@ -156,9 +156,9 @@ extern "C" {
>        fflush(stdout); \
>      } while (0)
> -  #define TEST_BEGIN() rtems_test_begin()
> +  #define TEST_BEGIN() printf(TEST_BEGIN_STRING)
> -  #define TEST_END() rtems_test_end()
> +  #define TEST_END() printf(TEST_END_STRING)
>   *  USE IPRINT
> @@ -205,11 +205,9 @@ extern "C" {
>        fflush(stdout); \
>      } while (0)
> -  #define TEST_BEGIN() \
> -    rtems_test_begin_with_plugin((rtems_printk_plugin_t) fiprintf, stderr)
> +  #define TEST_BEGIN() fiprintf( stderr, TEST_BEGIN_STRING)
> -  #define TEST_END() \
> -    rtems_test_end_with_plugin((rtems_printk_plugin_t) fiprintf, stderr)
> +  #define TEST_END()  fiprintf( stderr, TEST_END_STRING)
>  #endif
> diff --git a/testsuites/support/include/test_support.h b/testsuites/support/include/test_support.h
> index 7c459ff..d6870b2 100644
> --- a/testsuites/support/include/test_support.h
> +++ b/testsuites/support/include/test_support.h
> @@ -74,8 +74,6 @@ int locked_printf(const char *fmt, ...);
>  int locked_vprintf(const char *fmt, va_list ap);
> -int locked_printf_plugin(void *context, const char *fmt, ...);
>  void locked_printk(const char *fmt, ...);
>  #ifdef __cplusplus
> diff --git a/testsuites/support/src/locked_print.c b/testsuites/support/src/locked_print.c
> index 8414479..7c0df66 100644
> --- a/testsuites/support/src/locked_print.c
> +++ b/testsuites/support/src/locked_print.c
> @@ -1,4 +1,4 @@
>   *  COPYRIGHT (c) 1989-2011.
>   *  On-Line Applications Research Corporation (OAR).
> @@ -14,7 +14,23 @@
> -static rtems_id locked_print_semaphore;      /* synchronisation semaphore */
> +static rtems_id locked_print_semaphore;      /* synchronisation semaphore */
> +static int locked_printf_plugin(void *context, const char *fmt, ...)
> +  int rv;
> +  va_list ap;
> +  (void) context;
> +  va_start(ap, fmt);
> +  rv = locked_vprintf(fmt, ap);
> +  va_end(ap);
> +  return rv;
>  void locked_print_initialize(void)
> @@ -29,7 +45,7 @@ void locked_print_initialize(void)
>    /* Create/verify synchronisation semaphore */
>    sc = rtems_semaphore_create(
> -    1,
> +    1,
>      RTEMS_LOCAL                   |
>      RTEMS_BINARY_SEMAPHORE |
>      RTEMS_PRIORITY_CEILING |
> @@ -38,6 +54,12 @@ void locked_print_initialize(void)
>      &locked_print_semaphore
>    directive_failed( sc, "rtems_semaphore_create" );
> +   * Set up the printer to use the locked printf printer.
> +  rtems_test_printer.context = NULL;
> +  rtems_test_printer.context = locked_printf_plugin;
> @@ -60,20 +82,6 @@ int locked_vprintf(const char *fmt, va_list ap)
>    return rv;
> -  int rv;
> -  va_list ap;
> -  (void) context;
> -  va_start(ap, fmt);
> -  rv = locked_vprintf(fmt, ap);
> -  va_end(ap);
> -  return rv;
>    int               rv;
> 2.4.6
> devel mailing list
> devel at rtems.org
