[PATCH 1/5] confdefs.h: Fix heap alloc size estimate
Tue May 24 12:07:11 UTC 2016
Account for the heap minimum block size.
 cpukit/sapi/include/confdefs.h | 12 ++++++++----
 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 95f29fd..d35aaa4 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1369,10 +1369,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
 #define _Configure_Zero_or_One(_number) ((_number) ? 1 : 0)
- * General helper to aligned a value up to a power of two boundary.
+ * General helper to align up a value.
 #define _Configure_Align_up(_val, _align) \
-  (((_val) + (_align) - 1) & ~((_align) - 1))
+  (((_val) + (_align) - 1) - ((_val) + (_align) - 1) % (_align))
+#define CONFIGURE_HEAP_MIN_BLOCK_SIZE \
+  _Configure_Align_up(sizeof(Heap_Block), CPU_HEAP_ALIGNMENT)
  * This is a helper macro used in calculations in this file.  It is used
@@ -1381,8 +1384,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * may be applied.
 #define _Configure_From_workspace(_size) \
-   (ssize_t) (_Configure_Zero_or_One(_size) * \
-     _Configure_Align_up((_size) + HEAP_BLOCK_HEADER_SIZE, CPU_HEAP_ALIGNMENT))
+  (ssize_t) (_Configure_Zero_or_One(_size) * \
+    _Configure_Align_up(_size + HEAP_BLOCK_HEADER_SIZE, \
+      CONFIGURE_HEAP_MIN_BLOCK_SIZE))
  * This is a helper macro used in stack space calculations in this file.  It
1.8.4.5
