RKI Image for Raspberry PI 2
Alan Cudmore
alan.cudmore at gmail.com
Tue May 24 14:44:50 UTC 2016
The RKI image and other RTEMS examples work on the RPI2. When I build for
the raspberrypi2 BSP, I have to copy the rki.bin ( or other example image )
to kernel7.img on the SD card. No other conversion should be required.
I recently tested the RKI image on the RPI2, so it should work.
Also, make sure the firmware files on the SD card are up to date. My main
RTEMS Raspberry Pi target is a Model A+. When I received a Raspberry Pi
Zero, RTEMS would not boot when I just put my micro-sd card from the A+. I
had to get the latest firmware files then copy rki.bin to kernel.img..
After that the Zero worked fine.
I want to double check that the firmware files from this repo will work on
all models with RTEMS:
https://github.com/raspberrypi/firmware/tree/master/boot
If it works, then it will be easier than using an existing Linux
installation for the SD card.
Alan
On Tue, May 24, 2016 at 10:35 AM, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> Hello Mudit,
> On Tuesday 24 of May 2016 16:17:07 Mudit Jain wrote:
> > Hi Pavel,
> > I have pulled your branch and I am able to build the rki.bin using the
> > following commands.
> > mkdir b-rpi2
> > cd b-rpi2
> > ../rtems/configure --target=arm-rtems4.12 --prefix=$sandbox/rtems-4.12
> > --enable-rtems-inlines --disable-multiprocessing --enable-cxx
> > --enable-rdbg --enable-maintainer-mode --enable-tests=samples
> > --enable-networking --enable-posix --disable-itron --disable-ada
> > --disable-expada --disable-multilib --disable-docs
> > --enable-rtemsbsp="raspberrypi2"
> > make
> > make install
> > cd ../rki
> > waf configure --rtems=$sandbox/rtems-4.12
> > --rtems-tools=/home/mudit/Desktop/sandbox/rtems-4.12 --rtems-version=4.12
> > --rtems-bsps=arm/raspberrypi2
> > waf
> > It succesfully builds rki.bin.
> > This binary is renamed and put in as kernel.img.
> > I previously had an image of raspbian-jessie-lite on the card. I replaced
> > the kernel.img in the boot partition with the kernel.img that was
> prepared
> > by the above process.
> > It had deleted the previous kernel.img and still it was somehow booting
> > into raspbian.
> > Raspbian Jessie Lite was downloaded from -
> > https://www.raspberrypi.org/downloads/raspbian/
> > Is the hash of the kernel saved, and during the boot up process, if the
> > kernel is not authenticated, then a backup kernel takes over ?
> if I remember well then RPi2 boots kernel7.img by default.
> But you can specify image in "config.txt" file. Comment
> old kernel line (if found there) by prepending a hash character '#'.
> Then set
> kernel=ticker.bin
> or ticker.img. On Rpi 1 exact one to one copy of memory from 0x8000 is
> included in ticker.bin. I am not sure about RPi2, because it boots
> linux packed in zImage by default. So I am not sure if plain binary
> file can be booted. If the real zImage is required then there
> is "mkknlimg" utility which could help, is referenced in some
> U-boot for RPi2 discussion, but I am not sure if it is the right tool.
> Other option is to use Linux kernel sources for bzImage decompressor
> shim.
> It is a question for the other developers and contributors
> who worked on RETEM for RPi2 already. I have not been in contact
> with them, my last GSoC student and I have tested RTEMS
> only on RPi version 1.
> Probably Alan Cudmore knows more about BSP state and testing
> on RPi2.
> best wishes,
> Pavel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160524/58fa3dda/attachment.html>
