[GSOC2016_RTEMS-Jailhouse] can I get some instructions to build Jailhouse on RTEMS?
Wed May 25 01:27:50 UTC 2016
On Tue, May 24, 2016 at 5:01 AM, Jan Kiszka <jan.kiszka at siemens.com> wrote:
> Hi Wonjun Hwang,
> On 2016-05-24 10:53, 황원준 wrote:
>> I found Jailhouse Github repository and there are instructions for building and installation for Linux.
>> I want to start coding quickly. however it is hard to build for understanding whole structure easily.
>> Can I get some instructions to build Jailhouse on RTEMS?
> You surely don't want to build it "on" RTEMS :). Jailhouse and RTEMS is
> built under Linux, and then you install the RTEMS image in a Jailhouse
> non-root cell, aside Linux.
> If you didn't have a running Jailhouse setup yet, follow the
> instructions for a QEMU/KVM-based deployment. That's most easy to
> handle, and to debug.
Yes, start with the demonstration of Jailhouse and run a Linux guest
first, before you try to get the RTEMS guest to work.
>> And I don't know other mentors email. Would you tell me other mentors email address?
> Pavel's email you have already, Gedare should be able to give you the
> others. Not sure about who is involved to which degree, though.
I plan to handle the RTEMS side as much as I can for this project. I
will have a lot more time for this in June. I CC'd the other
co-mentors for completeness, though.
> Regards,
> Jan
