Errors while building USB DWC OTG driver
Wed May 25 13:42:57 UTC 2016
On 25/05/16 14:59, Deval Shah wrote:
> On Wed, May 25, 2016 at 3:07 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     If you get
>     On 25/05/16 10:19, Deval Shah wrote:
>         I got the following result.
>         nm: 'a.out': No such file
>     from
>     nm `find build -name '*bcm283x_dwc_fdt*.o`
>     the this is the first issue you have to resolve. Read the man
>     pages of nm and find to figure out what these commands do.
>     You must have object files for all your driver modules.
> I understood the problem. Driver for bcm283x is no getting built. Is
> there any documentation availible for porting a driver to rtems-libbsd
> ? So that I can verify necessary steps for the code I cherry-picked or
> if required do the process from scratch.
See "How to import code from FreeBSD" in libbsd.txt. Please improve the
documentation while you work on this.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
