[PATCH 1/3] Fix semaphore post overflow status
Sebastian Huber
Wed May 25 13:48:56 UTC 2016
Close #2720.
cpukit/posix/src/semaphoretranslatereturncode.c | 5 +---
cpukit/posix/src/sempost.c | 14 ++++++++--
cpukit/rtems/src/semrelease.c | 1 +
cpukit/rtems/src/semtranslatereturncode.c | 2 +-
cpukit/score/include/rtems/score/coresemimpl.h | 3 ++-
cpukit/score/src/mpci.c | 2 +-
testsuites/psxtests/psxsem01/init.c | 34 +++++++++++++++++++++++++
testsuites/sptests/spsem_err01/init.c | 29 +++++++++++++++++++++
testsuites/sptests/spsem_err01/spsem_err01.scn | 7 +++--
9 files changed, 86 insertions(+), 11 deletions(-)
diff --git a/cpukit/posix/src/semaphoretranslatereturncode.c b/cpukit/posix/src/semaphoretranslatereturncode.c
index d7b99ea..04b293d 100644
--- a/cpukit/posix/src/semaphoretranslatereturncode.c
+++ b/cpukit/posix/src/semaphoretranslatereturncode.c
@@ -27,8 +27,5 @@ const int _POSIX_Semaphore_Return_codes[CORE_SEMAPHORE_STATUS_LAST + 1] = {
EAGAIN, /* CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT */
EINVAL, /* CORE_SEMAPHORE_WAS_DELETED */
ETIMEDOUT, /* CORE_SEMAPHORE_TIMEOUT */
- /* The next error can not occur since we set the maximum
- * count to the largest value the count can hold.
- ENOSYS, /* CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED */
+ EOVERFLOW /* CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED */
diff --git a/cpukit/posix/src/sempost.c b/cpukit/posix/src/sempost.c
index 86d2f5a..f4633dc 100644
--- a/cpukit/posix/src/sempost.c
+++ b/cpukit/posix/src/sempost.c
@@ -19,6 +19,7 @@
#endif
#include <semaphore.h>
+#include <limits.h>
#include <rtems/posix/semaphoreimpl.h>
@@ -28,6 +29,7 @@ int sem_post(
POSIX_Semaphore_Control *the_semaphore;
Thread_queue_Context queue_context;
+ CORE_semaphore_Status status;
the_semaphore = _POSIX_Semaphore_Get( sem, &queue_context );
@@ -35,9 +37,17 @@ int sem_post(
rtems_set_errno_and_return_minus_one( EINVAL );
- _CORE_semaphore_Surrender(
+ status = _CORE_semaphore_Surrender(
&the_semaphore->Semaphore,
+ SEM_VALUE_MAX,
&queue_context
- return 0;
+ if ( status == CORE_SEMAPHORE_STATUS_SUCCESSFUL ) {
+ return 0;
+ rtems_set_errno_and_return_minus_one(
+ _POSIX_Semaphore_Translate_core_semaphore_return_code( status )
diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
index 197e4d8..aa80e83 100644
--- a/cpukit/rtems/src/semrelease.c
+++ b/cpukit/rtems/src/semrelease.c
@@ -68,6 +68,7 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
} else {
semaphore_status = _CORE_semaphore_Surrender(
&the_semaphore->Core_control.semaphore,
+ UINT32_MAX,
&queue_context
return _Semaphore_Translate_core_semaphore_return_code( semaphore_status );
diff --git a/cpukit/rtems/src/semtranslatereturncode.c b/cpukit/rtems/src/semtranslatereturncode.c
index 9aa9420..ea7e8bc 100644
--- a/cpukit/rtems/src/semtranslatereturncode.c
+++ b/cpukit/rtems/src/semtranslatereturncode.c
@@ -37,5 +37,5 @@ const rtems_status_code _Semaphore_Translate_core_semaphore_return_code_[] = {
RTEMS_UNSATISFIED, /* CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT */
RTEMS_OBJECT_WAS_DELETED, /* CORE_SEMAPHORE_WAS_DELETED */
RTEMS_TIMEOUT, /* CORE_SEMAPHORE_TIMEOUT */
- RTEMS_INTERNAL_ERROR, /* CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED */
+ RTEMS_UNSATISFIED /* CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED */
diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
index 1660c1d..5dad11b 100644
--- a/cpukit/score/include/rtems/score/coresemimpl.h
+++ b/cpukit/score/include/rtems/score/coresemimpl.h
@@ -149,6 +149,7 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Destroy(
RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Surrender(
CORE_semaphore_Control *the_semaphore,
+ uint32_t maximum_count,
Thread_queue_Context *queue_context
@@ -171,7 +172,7 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Surrender(
queue_context
} else {
- if ( the_semaphore->count < UINT32_MAX )
+ if ( the_semaphore->count < maximum_count )
the_semaphore->count += 1;
else
status = CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED;
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 4022a80..3442bbd 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -374,7 +374,7 @@ void _MPCI_Announce ( void )
_ISR_lock_ISR_disable( &queue_context.Lock_context );
- (void) _CORE_semaphore_Surrender( &_MPCI_Semaphore, &queue_context );
+ (void) _CORE_semaphore_Surrender( &_MPCI_Semaphore, UINT32_MAX, &queue_context );
void _MPCI_Internal_packets_Send_process_packet (
diff --git a/testsuites/psxtests/psxsem01/init.c b/testsuites/psxtests/psxsem01/init.c
index 24f6d96..1bec5c6 100644
--- a/testsuites/psxtests/psxsem01/init.c
+++ b/testsuites/psxtests/psxsem01/init.c
@@ -15,6 +15,7 @@
#include <fcntl.h>
#include <time.h>
#include <tmacros.h>
#include <pmacros.h>
@@ -76,6 +77,38 @@ static void test_sem_wait_during_delete(void)
rtems_test_assert( eno == 0 );
+static void test_sem_post_overflow(void)
+ sem_t sem;
+ int rv;
+ int val;
+ rv = sem_init( &sem, 0, SEM_VALUE_MAX );
+ rtems_test_assert( rv == 0 );
+ rv = sem_getvalue( &sem, &val );
+ rtems_test_assert( val == (int) SEM_VALUE_MAX );
+ errno = 0;
+ rv = sem_post( &sem );
+ rtems_test_assert( rv == -1 );
+ rtems_test_assert( errno == EOVERFLOW );
+ rv = sem_wait( &sem );
+ rv = sem_destroy( &sem );
void *POSIX_Init(
void *argument
@@ -345,6 +378,7 @@ void *POSIX_Init(
rtems_test_assert( (status == -1) && (errno == ENOENT) );
test_sem_wait_during_delete();
+ test_sem_post_overflow();
/* Try adding in unlinking before closing... (can we still open?) */
diff --git a/testsuites/sptests/spsem_err01/init.c b/testsuites/sptests/spsem_err01/init.c
index 897581a..39a366b 100644
--- a/testsuites/sptests/spsem_err01/init.c
+++ b/testsuites/sptests/spsem_err01/init.c
@@ -30,6 +30,35 @@ rtems_task Init(
Semaphore_name[ 2 ] = rtems_build_name( 'S', 'M', '2', ' ' );
Semaphore_name[ 3 ] = rtems_build_name( 'S', 'M', '3', ' ' );
+ /* release overflow */
+ status = rtems_semaphore_create(
+ Semaphore_name[ 1 ],
+ UINT32_MAX,
+ RTEMS_COUNTING_SEMAPHORE,
+ 0,
+ &Semaphore_id[ 1 ]
+ fatal_directive_status(
+ status,
+ RTEMS_SUCCESSFUL,
+ "rtems_semaphore_create"
+ puts( "TA1 - rtems_semaphore_create - RTEMS_SUCCESSFUL" );
+ status = rtems_semaphore_release( Semaphore_id[ 1 ] );
+ status,
+ RTEMS_UNSATISFIED,
+ "rtems_semaphore_release"
+ puts( "TA1 - rtems_semaphore_release - RTEMS_UNSATISFIED" );
+ status = rtems_semaphore_delete( Semaphore_id[ 1 ] );
+ status,
+ RTEMS_SUCCESSFUL,
+ "rtems_semaphore_delete"
+ puts( "TA1 - rtems_semaphore_delete - RTEMS_SUCCESSFUL" );
/* invalid name */
0,
diff --git a/testsuites/sptests/spsem_err01/spsem_err01.scn b/testsuites/sptests/spsem_err01/spsem_err01.scn
index 00d363d..b617219 100644
--- a/testsuites/sptests/spsem_err01/spsem_err01.scn
+++ b/testsuites/sptests/spsem_err01/spsem_err01.scn
@@ -1,4 +1,7 @@
-*** TEST SEMAPHORE ERROR 01 ***
+*** BEGIN OF TEST SP SEMAPHORE ERROR 01 ***
+TA1 - rtems_semaphore_create - RTEMS_SUCCESSFUL
+TA1 - rtems_semaphore_release - RTEMS_UNSATISFIED
+TA1 - rtems_semaphore_delete - RTEMS_SUCCESSFUL
TA1 - rtems_semaphore_create - RTEMS_INVALID_NAME
TA1 - rtems_semaphore_create - RTEMS_INVALID_ADDRESS
TA1 - rtems_semaphore_create - 1 - RTEMS_SUCCESSFUL
@@ -16,4 +19,4 @@ TA1 - rtems_semaphore_ident - global RTEMS_INVALID_NAME
TA1 - rtems_semaphore_ident - local RTEMS_INVALID_NAME
TA1 - rtems_semaphore_release - RTEMS_INVALID_ID
TA1 - rtems_semaphore_flush - RTEMS_INVALID_ID
-*** END TEST SEMAPHORE ERROR 01 ***
+*** END OF TEST SP SEMAPHORE ERROR 01 ***
1.8.4.5
