Skip Building a few packages by RSB
Sambeet Panigrahi
sambeet161616 at gmail.com
Fri May 27 10:42:57 UTC 2016
Hi,
I am working on porting Rock to RTEMS as a Summer of code project.I have to
modify the code and build RTEMS using RSB a lot many times. RSB is designed
to clean install every time but building newlib and gcc each time is a very
time consuming task. Is there a way I can select what packages to build and
what not to using RSB so that I can apply changes and build whatever is
required and build whatever is required?
Regards
Sambeet
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160527/59ca6dc8/attachment.html>
