[PATCH 02/12] score: _CORE_mutex_Check_dispatch_for_seize()
Fri May 27 13:50:31 UTC 2016
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it.  Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
 cpukit/posix/include/rtems/posix/psignalimpl.h   |  24 ++++-
 cpukit/posix/src/condwaitsupp.c                  |   3 +-
 cpukit/posix/src/killinfo.c                      |   9 +-
 cpukit/posix/src/psignalclearsignals.c           |   7 +-
 cpukit/posix/src/psignalsetprocesssignals.c      |   7 +-
 cpukit/posix/src/psignalunblockthread.c          |  15 +--
 cpukit/posix/src/pthreadjoin.c                   |  26 ++---
 cpukit/posix/src/sigaction.c                     |   7 +-
 cpukit/posix/src/sigtimedwait.c                  |  26 ++---
 cpukit/sapi/src/interrtext.c                     |   2 +-
 cpukit/score/include/rtems/score/coremuteximpl.h |  33 +-----
 cpukit/score/include/rtems/score/coresemimpl.h   |   3 +-
 cpukit/score/include/rtems/score/interr.h        |   2 +-
 cpukit/score/include/rtems/score/threadimpl.h    |   8 +-
 cpukit/score/include/rtems/score/threadq.h       |   9 ++
 cpukit/score/include/rtems/score/threadqimpl.h   |  46 +++++++--
 cpukit/score/src/condition.c                     |  88 ++++++++--------
 cpukit/score/src/corebarrierwait.c               |   3 +-
 cpukit/score/src/coremsgseize.c                  |   3 +-
 cpukit/score/src/coremsgsubmit.c                 |   3 +-
 cpukit/score/src/coremutexseize.c                |  22 ++--
 cpukit/score/src/corerwlockobtainread.c          |   3 +-
 cpukit/score/src/corerwlockobtainwrite.c         |   3 +-
 cpukit/score/src/futex.c                         |  36 ++++---
 cpukit/score/src/mutex.c                         | 125 ++++++++++++-----------
 cpukit/score/src/semaphore.c                     |  37 ++++---
 cpukit/score/src/threadqenqueue.c                |  17 ++-
 cpukit/score/src/threadrestart.c                 |  18 ++--
 testsuites/sptests/spfatal03/testcase.h          |   6 +-
 29 files changed, 339 insertions(+), 252 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/psignalimpl.h b/cpukit/posix/include/rtems/posix/psignalimpl.h
index 3b76fc3..62c1a85 100644
--- a/cpukit/posix/include/rtems/posix/psignalimpl.h
+++ b/cpukit/posix/include/rtems/posix/psignalimpl.h
@@ -73,11 +73,25 @@ extern Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
  *  Internal routines
-#define _POSIX_signals_Acquire( lock_context ) \
-  _Thread_queue_Acquire( &_POSIX_signals_Wait_queue, lock_context )
-#define _POSIX_signals_Release( lock_context ) \
-  _Thread_queue_Release( &_POSIX_signals_Wait_queue, lock_context )
+RTEMS_INLINE_ROUTINE void _POSIX_signals_Acquire(
+  Thread_queue_Context *queue_context
+  _Thread_queue_Acquire(
+    &_POSIX_signals_Wait_queue,
+    &queue_context->Lock_context
+RTEMS_INLINE_ROUTINE void _POSIX_signals_Release(
+  _Thread_queue_Release(
  * @brief Unlock POSIX signals thread.
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index 9270c36..7dff27f 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -86,13 +86,14 @@ int _POSIX_Condition_variables_Wait_support(
   if ( !already_timedout ) {
+    _Thread_queue_Context_set_expected_level( &queue_context, 2 );
       &the_cond->Wait_queue.Queue,
       POSIX_CONDITION_VARIABLES_TQ_OPERATIONS,
       executing,
       STATES_WAITING_FOR_CONDITION_VARIABLE,
       timeout,
-      &queue_context.Lock_context
+      &queue_context
   } else {
     _POSIX_Condition_variables_Release( the_cond, &queue_context );
diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
index b16b408..33754af 100644
--- a/cpukit/posix/src/killinfo.c
+++ b/cpukit/posix/src/killinfo.c
@@ -75,7 +75,7 @@ int _POSIX_signals_Send(
   siginfo_t                   *siginfo;
   POSIX_signals_Siginfo_node  *psiginfo;
   Thread_queue_Heads          *heads;
-  ISR_lock_Context             lock_context;
+  Thread_queue_Context         queue_context;
   Per_CPU_Control             *cpu_self;
@@ -334,14 +334,15 @@ post_process_signal:
   _POSIX_signals_Set_process_signals( mask );
-  _POSIX_signals_Acquire( &lock_context );
+  _Thread_queue_Context_initialize( &queue_context );
+  _POSIX_signals_Acquire( &queue_context );
   if ( _POSIX_signals_Vectors[ sig ].sa_flags == SA_SIGINFO ) {
     psiginfo = (POSIX_signals_Siginfo_node *)
       _Chain_Get_unprotected( &_POSIX_signals_Inactive_siginfo );
     if ( !psiginfo ) {
-      _POSIX_signals_Release( &lock_context );
+      _POSIX_signals_Release( &queue_context );
       _Thread_Dispatch_enable( cpu_self );
       rtems_set_errno_and_return_minus_one( EAGAIN );
@@ -354,7 +355,7 @@ post_process_signal:
   DEBUG_STEP("\n");
   return 0;
diff --git a/cpukit/posix/src/psignalclearsignals.c b/cpukit/posix/src/psignalclearsignals.c
index c785255..39ea41c 100644
--- a/cpukit/posix/src/psignalclearsignals.c
+++ b/cpukit/posix/src/psignalclearsignals.c
@@ -47,7 +47,7 @@ bool _POSIX_signals_Clear_signals(
   sigset_t                    mask;
   sigset_t                    signals_unblocked;
   bool                        do_callout;
@@ -68,7 +68,8 @@ bool _POSIX_signals_Clear_signals(
   /* XXX are we sure they can be cleared the same way? */
   if ( do_signals_acquire_release ) {
     if ( is_global ) {
@@ -102,7 +103,7 @@ bool _POSIX_signals_Clear_signals(
   return do_callout;
diff --git a/cpukit/posix/src/psignalsetprocesssignals.c b/cpukit/posix/src/psignalsetprocesssignals.c
index 8a25864..b755c2d 100644
--- a/cpukit/posix/src/psignalsetprocesssignals.c
+++ b/cpukit/posix/src/psignalsetprocesssignals.c
@@ -36,9 +36,10 @@ void _POSIX_signals_Set_process_signals(
   sigset_t   mask
     _POSIX_signals_Pending |= mask;
diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
index b4475b2..d75e454 100644
--- a/cpukit/posix/src/psignalunblockthread.c
+++ b/cpukit/posix/src/psignalunblockthread.c
@@ -96,9 +96,9 @@ static void _POSIX_signals_Action_handler(
   ISR_lock_Context *lock_context
-  POSIX_API_Control  *api;
-  int                 signo;
-  uint32_t            hold_errno;
+  POSIX_API_Control *api;
+  int                signo;
+  uint32_t           hold_errno;
   (void) action;
   _Thread_State_release( executing, lock_context );
@@ -135,13 +135,16 @@ static void _POSIX_signals_Action_handler(
    *  processed at all.  No point in doing this loop otherwise.
   while (1) {
-    _POSIX_signals_Acquire( lock_context );
       if ( !(api->signals_unblocked &
             (api->signals_pending | _POSIX_signals_Pending)) ) {
-       _POSIX_signals_Release( lock_context );
        break;
     for ( signo = SIGRTMIN ; signo <= SIGRTMAX ; signo++ ) {
       _POSIX_signals_Check_signal( api, signo, false );
diff --git a/cpukit/posix/src/pthreadjoin.c b/cpukit/posix/src/pthreadjoin.c
index f4a0676..86b8051 100644
--- a/cpukit/posix/src/pthreadjoin.c
+++ b/cpukit/posix/src/pthreadjoin.c
@@ -32,13 +32,15 @@
 static int _POSIX_Threads_Join( pthread_t thread, void **value_ptr )
-  Thread_Control    *the_thread;
-  Per_CPU_Control   *cpu_self;
-  Thread_Control    *executing;
-  void              *value;
+  Thread_Control       *the_thread;
+  Per_CPU_Control      *cpu_self;
+  Thread_Control       *executing;
+  void                 *value;
-  the_thread = _Thread_Get( thread, &lock_context );
+  _Thread_queue_Context_set_expected_level( &queue_context, 1 );
+  the_thread = _Thread_Get( thread, &queue_context.Lock_context );
   if ( the_thread == NULL ) {
     return ESRCH;
@@ -48,29 +50,29 @@ static int _POSIX_Threads_Join( pthread_t thread, void **value_ptr )
   executing = _Per_CPU_Get_executing( cpu_self );
   if ( executing == the_thread ) {
-    _ISR_lock_ISR_enable( &lock_context );
+    _ISR_lock_ISR_enable( &queue_context.Lock_context );
     return EDEADLK;
-  _Thread_State_acquire_critical( the_thread, &lock_context );
+  _Thread_State_acquire_critical( the_thread, &queue_context.Lock_context );
   if ( !_Thread_Is_joinable( the_thread ) ) {
-    _Thread_State_release( the_thread, &lock_context );
+    _Thread_State_release( the_thread, &queue_context.Lock_context );
     return EINVAL;
   if ( _States_Is_waiting_for_join_at_exit( the_thread->current_state ) ) {
     value = the_thread->Life.exit_value;
     _Thread_Clear_state_locked( the_thread, STATES_WAITING_FOR_JOIN_AT_EXIT );
-    _Thread_Dispatch_disable_with_CPU( cpu_self, &lock_context );
+    _Thread_Dispatch_disable_with_CPU( cpu_self, &queue_context.Lock_context );
   } else {
     _Thread_Join(
       the_thread,
       STATES_INTERRUPTIBLE_BY_SIGNAL | STATES_WAITING_FOR_JOIN,
       executing,
-      &lock_context
+      &queue_context
     if ( _POSIX_Get_error_after_wait( executing ) != 0 ) {
diff --git a/cpukit/posix/src/sigaction.c b/cpukit/posix/src/sigaction.c
index 177dcd1..26df98d 100644
--- a/cpukit/posix/src/sigaction.c
+++ b/cpukit/posix/src/sigaction.c
@@ -33,7 +33,7 @@ int sigaction(
   struct sigaction       *__restrict oact
   if ( !sig )
     rtems_set_errno_and_return_minus_one( EINVAL );
@@ -51,7 +51,8 @@ int sigaction(
   if ( sig == SIGKILL )
   if ( oact )
     *oact = _POSIX_signals_Vectors[ sig ];
@@ -76,7 +77,7 @@ int sigaction(
   return 0;
diff --git a/cpukit/posix/src/sigtimedwait.c b/cpukit/posix/src/sigtimedwait.c
index ddc2884..7855bb0 100644
--- a/cpukit/posix/src/sigtimedwait.c
+++ b/cpukit/posix/src/sigtimedwait.c
@@ -69,14 +69,14 @@ int sigtimedwait(
   const struct timespec  *__restrict timeout
-  Watchdog_Interval  interval;
-  siginfo_t          signal_information;
-  siginfo_t         *the_info;
-  int                signo;
-  int                error;
+  Watchdog_Interval     interval;
+  siginfo_t             signal_information;
+  siginfo_t            *the_info;
+  int                   signo;
+  int                   error;
    *  Error check parameters before disabling interrupts.
@@ -115,7 +115,8 @@ int sigtimedwait(
   /* API signals pending? */
   if ( *set & api->signals_pending ) {
     /* XXX real info later */
     the_info->si_signo = _POSIX_signals_Get_lowest( api->signals_pending );
@@ -127,7 +128,7 @@ int sigtimedwait(
       false,
       false
     the_info->si_code = SI_USER;
     the_info->si_value.sival_int = 0;
@@ -139,7 +140,7 @@ int sigtimedwait(
   if ( *set & _POSIX_signals_Pending ) {
     signo = _POSIX_signals_Get_lowest( _POSIX_signals_Pending );
     _POSIX_signals_Clear_signals( api, signo, the_info, true, false, false );
     the_info->si_signo = signo;
@@ -151,13 +152,14 @@ int sigtimedwait(
   executing->Wait.option          = *set;
   executing->Wait.return_argument = the_info;
     &_POSIX_signals_Wait_queue.Queue,
     POSIX_SIGNALS_TQ_OPERATIONS,
     executing,
     STATES_WAITING_FOR_SIGNAL | STATES_INTERRUPTIBLE_BY_SIGNAL,
     interval,
-    &lock_context
+    &queue_context
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 3a0681d..3ae7315 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -45,7 +45,7 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_BAD_ATTRIBUTES",
   "INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY",
   "OBSOLETE_INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL",
-  "INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE",
+  "INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_FROM_BAD_STATE",
   "INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0",
   "OBSOLETE_INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP",
   "INTERNAL_ERROR_GXX_KEY_ADD_FAILED",
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index f5faf95..e29d4b7 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -21,7 +21,6 @@
 #include <rtems/score/coremutex.h>
 #include <rtems/score/status.h>
-#include <rtems/score/sysstate.h>
@@ -95,27 +94,13 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Release(
  *  @param[in] lock_context is the interrupt level
 Status_Control _CORE_mutex_Seize_interrupt_blocking(
-  CORE_mutex_Control  *the_mutex,
-  Thread_Control      *executing,
-  Watchdog_Interval    timeout,
-  ISR_lock_Context    *lock_context
+  CORE_mutex_Control   *the_mutex,
+  Thread_Control       *executing,
+  Watchdog_Interval     timeout,
- *  @brief Verifies that a mutex blocking seize is performed safely.
- *  This macro is to verify that a mutex blocking seize is
- *  performed from a safe system state.  For example, one
- *  cannot block inside an isr.
- *  @retval this method returns true if dispatch is in an unsafe state.
-#define _CORE_mutex_Check_dispatch_for_seize(_wait) \
-  (!_Thread_Dispatch_is_enabled() \
-    && (_wait) \
-    && (_System_state_Get() >= SYSTEM_STATE_UP))
  * @brief Is mutex locked.
  * This routine returns true if the mutex specified is locked and false
@@ -301,14 +286,6 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_mutex_Seize(
   Status_Control status;
-  if ( _CORE_mutex_Check_dispatch_for_seize( wait ) ) {
-    _Terminate(
-      INTERNAL_ERROR_CORE,
-      false,
-      INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE
   _CORE_mutex_Acquire_critical( the_mutex, queue_context );
   status = _CORE_mutex_Seize_interrupt_trylock(
@@ -330,7 +307,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_mutex_Seize(
     the_mutex,
     executing,
     timeout,
-    &queue_context->Lock_context
+    queue_context
diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
index ac90f20..a55089e 100644
--- a/cpukit/score/include/rtems/score/coresemimpl.h
+++ b/cpukit/score/include/rtems/score/coresemimpl.h
@@ -204,13 +204,14 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Seize(
     return STATUS_UNSATISFIED;
+  _Thread_queue_Context_set_expected_level( queue_context, 1 );
     &the_semaphore->Wait_queue.Queue,
     the_semaphore->operations,
     executing,
     STATES_WAITING_FOR_SEMAPHORE,
     timeout,
+    queue_context
   return _Thread_Wait_get_status( executing );
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index ea468e0..ca48db2 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -154,7 +154,7 @@ typedef enum {
   INTERNAL_ERROR_BAD_ATTRIBUTES,
   INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY,
   OBSOLETE_INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL,
-  INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE,
+  INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_FROM_BAD_STATE,
   INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0,
   OBSOLETE_INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP,
   INTERNAL_ERROR_GXX_KEY_ADD_FAILED,
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 1081108..d102212 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -232,10 +232,10 @@ void _Thread_Exit(
 void _Thread_Join(
-  Thread_Control    *the_thread,
-  States_Control     waiting_for_join,
+  Thread_Control       *the_thread,
+  States_Control        waiting_for_join,
 void _Thread_Cancel(
diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
index 2859c79..4c2f8e2 100644
--- a/cpukit/score/include/rtems/score/threadq.h
+++ b/cpukit/score/include/rtems/score/threadq.h
@@ -70,6 +70,15 @@ typedef struct {
   ISR_lock_Context Lock_context;
+   * @brief The expected thread dispatch disable level for
+   * _Thread_queue_Enqueue_critical().
+   * In case the actual thread dispatch disable level is not equal to the
+   * expected level, then a fatal error occurs.
+  uint32_t expected_thread_dispatch_disable_level;
    * @brief Callout to unblock the thread in case it is actually a thread
    * proxy.
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 7772959..b528c30 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -62,14 +62,35 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Context_initialize(
-#if defined(RTEMS_MULTIPROCESSING) && defined(RTEMS_DEBUG)
+#if defined(RTEMS_DEBUG)
+  queue_context->expected_thread_dispatch_disable_level = 0xdeadbeef;
+#if defined(RTEMS_MULTIPROCESSING)
   queue_context->mp_callout = NULL;
+#endif
 #else
   (void) queue_context;
 #endif
+ * @brief Sets the expected thread dispatch disable level in the thread queue
+ * context.
+ * @param queue_context The thread queue context.
+ * @param expected_level The expected thread dispatch disable level.
+ * @see _Thread_queue_Enqueue_critical().
+_Thread_queue_Context_set_expected_level(
+  Thread_queue_Context *queue_context,
+  uint32_t              expected_level
+  queue_context->expected_thread_dispatch_disable_level = expected_level;
  * @brief Sets the MP callout in the thread queue context.
@@ -308,17 +329,19 @@ Thread_Control *_Thread_queue_Do_dequeue(
  * void _Mutex_Obtain( Mutex *mutex )
- *   ISR_lock_Context  lock_context;
- *   Thread_Control   *executing;
+ *   Thread_queue_Context  queue_context;
+ *   Thread_Control       *executing;
- *   _Thread_queue_Acquire( &mutex->Queue, &lock_context );
+ *   _Thread_queue_Context_initialize( &queue_context );
+ *   _Thread_queue_Acquire( &mutex->Queue, &queue_context.Lock_context );
  *   executing = _Thread_Executing;
  *   if ( mutex->owner == NULL ) {
  *     mutex->owner = executing;
- *     _Thread_queue_Release( &mutex->Queue, &lock_context );
+ *     _Thread_queue_Release( &mutex->Queue, &queue_context.Lock_context );
  *   } else {
+ *     _Thread_queue_Context_set_expected_level( &queue_context, 1 );
  *       &mutex->Queue.Queue,
  *       MUTEX_TQ_OPERATIONS,
@@ -326,7 +349,7 @@ Thread_Control *_Thread_queue_Do_dequeue(
  *       STATES_WAITING_FOR_MUTEX,
  *       WATCHDOG_NO_TIMEOUT,
  *       0,
- *       &lock_context
+ *       &queue_context
@@ -338,7 +361,7 @@ Thread_Control *_Thread_queue_Do_dequeue(
  * @param[in] state The new state of the thread.
  * @param[in] timeout Interval to wait.  Use WATCHDOG_NO_TIMEOUT to block
  * potentially forever.
- * @param[in] lock_context The lock context of the lock acquire.
+ * @param[in] queue_context The thread queue context of the lock acquire.
 void _Thread_queue_Enqueue_critical(
   Thread_queue_Queue            *queue,
@@ -346,7 +369,7 @@ void _Thread_queue_Enqueue_critical(
   States_Control                 state,
@@ -361,16 +384,17 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Enqueue(
-  _Thread_queue_Acquire( the_thread_queue, &lock_context );
+  _Thread_queue_Acquire( the_thread_queue, &queue_context.Lock_context );
     &the_thread_queue->Queue,
     operations,
     the_thread,
     state,
     timeout,
-    &lock_context
+    &queue_context
diff --git a/cpukit/score/src/condition.c b/cpukit/score/src/condition.c
index fae150a..e7d9805 100644
--- a/cpukit/score/src/condition.c
+++ b/cpukit/score/src/condition.c
@@ -53,8 +53,8 @@ static Condition_Control *_Condition_Get(
 static Thread_Control *_Condition_Queue_acquire_critical(
-  Condition_Control *condition,
+  Condition_Control    *condition,
@@ -63,24 +63,27 @@ static Thread_Control *_Condition_Queue_acquire_critical(
   _Thread_queue_Queue_acquire_critical(
     &condition->Queue.Queue,
     &executing->Potpourri_stats,
-    lock_context
   return executing;
 static void _Condition_Queue_release(
-  _Thread_queue_Queue_release( &condition->Queue.Queue, lock_context );
+  _Thread_queue_Queue_release(
+    &condition->Queue.Queue,
 static Per_CPU_Control *_Condition_Do_wait(
   struct _Condition_Control *_condition,
   Condition_Control *condition;
@@ -88,16 +91,17 @@ static Per_CPU_Control *_Condition_Do_wait(
   condition = _Condition_Get( _condition );
-  executing = _Condition_Queue_acquire_critical( condition, lock_context );
-  cpu_self = _Thread_Dispatch_disable_critical( lock_context );
+  executing = _Condition_Queue_acquire_critical( condition, queue_context );
+  cpu_self = _Thread_Dispatch_disable_critical( &queue_context->Lock_context );
+  _Thread_queue_Context_set_expected_level( queue_context, 2 );
     CONDITION_TQ_OPERATIONS,
     executing,
     STATES_WAITING_FOR_SYS_LOCK_CONDITION,
     timeout,
-    lock_context
+    queue_context
   return cpu_self;
@@ -108,11 +112,12 @@ void _Condition_Wait(
   struct _Mutex_Control     *_mutex
-  _ISR_lock_ISR_disable( &lock_context );
-  cpu_self = _Condition_Do_wait( _condition, 0, &lock_context );
+  _ISR_lock_ISR_disable( &queue_context.Lock_context );
+  cpu_self = _Condition_Do_wait( _condition, 0, &queue_context );
   _Mutex_Release( _mutex );
@@ -125,27 +130,28 @@ int _Condition_Wait_timed(
   const struct timespec     *abstime
-  int                eno;
-  Watchdog_Interval  ticks;
+  int                   eno;
+  Watchdog_Interval     ticks;
   switch ( _TOD_Absolute_timeout_to_ticks( abstime, &ticks ) ) {
     case TOD_ABSOLUTE_TIMEOUT_INVALID:
       return EINVAL;
     case TOD_ABSOLUTE_TIMEOUT_IS_IN_PAST:
     case TOD_ABSOLUTE_TIMEOUT_IS_NOW:
       return ETIMEDOUT;
     default:
       break;
-  cpu_self = _Condition_Do_wait( _condition, ticks, &lock_context );
+  cpu_self = _Condition_Do_wait( _condition, ticks, &queue_context );
   executing = cpu_self->executing;
@@ -161,12 +167,13 @@ void _Condition_Wait_recursive(
   struct _Mutex_recursive_Control *_mutex
-  unsigned int      nest_level;
+  unsigned int          nest_level;
   nest_level = _mutex->_nest_level;
   _mutex->_nest_level = 0;
@@ -182,28 +189,29 @@ int _Condition_Wait_recursive_timed(
-  int                eno;
+  int                    eno;
       return EINVAL;
       return ETIMEDOUT;
     default:
       break;
@@ -249,14 +257,14 @@ static void _Condition_Wake( struct _Condition_Control *_condition, int count )
   _Thread_queue_Context_initialize( &context.Base );
   _ISR_lock_ISR_disable( &context.Base.Lock_context );
-  _Condition_Queue_acquire_critical( condition, &context.Base.Lock_context );
+  _Condition_Queue_acquire_critical( condition, &context.Base );
    * In common uses cases of condition variables there are normally no threads
    * on the queue, so check this condition early.
   if ( __predict_true( _Thread_queue_Is_empty( &condition->Queue.Queue ) ) ) {
-    _Condition_Queue_release( condition, &context.Base.Lock_context );
+    _Condition_Queue_release( condition, &context.Base );
     return;
diff --git a/cpukit/score/src/corebarrierwait.c b/cpukit/score/src/corebarrierwait.c
index a1c862d..d939acf 100644
--- a/cpukit/score/src/corebarrierwait.c
+++ b/cpukit/score/src/corebarrierwait.c
@@ -45,13 +45,14 @@ Status_Control _CORE_barrier_Seize(
     return STATUS_BARRIER_AUTOMATICALLY_RELEASED;
   } else {
     the_barrier->number_of_waiting_threads = number_of_waiting_threads;
       &the_barrier->Wait_queue.Queue,
       CORE_BARRIER_TQ_OPERATIONS,
       executing,
       STATES_WAITING_FOR_BARRIER,
       timeout,
+      queue_context
diff --git a/cpukit/score/src/coremsgseize.c b/cpukit/score/src/coremsgseize.c
index 00ff437..6906328 100644
--- a/cpukit/score/src/coremsgseize.c
+++ b/cpukit/score/src/coremsgseize.c
@@ -114,13 +114,14 @@ Status_Control _CORE_message_queue_Seize(
   executing->Wait.return_argument = size_p;
   /* Wait.count will be filled in with the message priority */
     &the_message_queue->Wait_queue.Queue,
     the_message_queue->operations,
     executing,
     STATES_WAITING_FOR_MESSAGE,
     timeout,
+    queue_context
diff --git a/cpukit/score/src/coremsgsubmit.c b/cpukit/score/src/coremsgsubmit.c
index a623291..fb56ffe 100644
--- a/cpukit/score/src/coremsgsubmit.c
+++ b/cpukit/score/src/coremsgsubmit.c
@@ -132,13 +132,14 @@ Status_Control _CORE_message_queue_Submit(
     executing->Wait.option = (uint32_t) size;
     executing->Wait.count = submit_type;
       executing,
       timeout,
+      queue_context
   #endif
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index 0fc63f4..37de3a1 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -22,13 +22,14 @@
 #include <rtems/score/isr.h>
+#include <rtems/score/sysstate.h>
 #if !defined(RTEMS_SMP)
@@ -51,23 +52,30 @@ Status_Control _CORE_mutex_Seize_interrupt_blocking(
      * otherwise the current holder may be no longer the holder of the mutex
      * once we released the lock.
-    _Thread_queue_Release( &the_mutex->Wait_queue, lock_context );
+    _CORE_mutex_Release( the_mutex, queue_context );
 #endif
     _Thread_Inherit_priority( holder, executing );
-    _Thread_queue_Acquire( &the_mutex->Wait_queue, lock_context );
+    _ISR_lock_ISR_disable( &queue_context->Lock_context );
+    _CORE_mutex_Acquire_critical( the_mutex, queue_context );
 #endif
+#if defined(RTEMS_SMP)
+#else
+#endif
     &the_mutex->Wait_queue.Queue,
     the_mutex->operations,
     executing,
     timeout,
-    lock_context
+    queue_context
diff --git a/cpukit/score/src/corerwlockobtainread.c b/cpukit/score/src/corerwlockobtainread.c
index 5192eb1..bce992c 100644
--- a/cpukit/score/src/corerwlockobtainread.c
+++ b/cpukit/score/src/corerwlockobtainread.c
@@ -79,13 +79,14 @@ Status_Control _CORE_RWLock_Seize_for_reading(
   executing->Wait.option = CORE_RWLOCK_THREAD_WAITING_FOR_READ;
      &the_rwlock->Wait_queue.Queue,
      CORE_RWLOCK_TQ_OPERATIONS,
      executing,
      STATES_WAITING_FOR_RWLOCK,
      timeout,
+     queue_context
diff --git a/cpukit/score/src/corerwlockobtainwrite.c b/cpukit/score/src/corerwlockobtainwrite.c
index 0536b82..c261d32 100644
--- a/cpukit/score/src/corerwlockobtainwrite.c
+++ b/cpukit/score/src/corerwlockobtainwrite.c
@@ -67,13 +67,14 @@ Status_Control _CORE_RWLock_Seize_for_writing(
   executing->Wait.option = CORE_RWLOCK_THREAD_WAITING_FOR_WRITE;
      executing,
      timeout,
+     queue_context
diff --git a/cpukit/score/src/futex.c b/cpukit/score/src/futex.c
index 980c7fb..a192509 100644
--- a/cpukit/score/src/futex.c
+++ b/cpukit/score/src/futex.c
@@ -50,52 +50,56 @@ static Futex_Control *_Futex_Get( struct _Futex_Control *_futex )
 static Thread_Control *_Futex_Queue_acquire(
   Futex_Control    *futex,
-  _ISR_lock_ISR_disable( lock_context );
     &futex->Queue.Queue,
-    lock_context
   return executing;
 static void _Futex_Queue_release(
-  Futex_Control    *futex,
+  Futex_Control        *futex,
-  _Thread_queue_Queue_release( &futex->Queue.Queue, lock_context );
+    &futex->Queue.Queue,
 int _Futex_Wait( struct _Futex_Control *_futex, int *uaddr, int val )
-  Futex_Control    *futex;
-  int               eno;
+  Futex_Control        *futex;
+  int                   eno;
   futex = _Futex_Get( _futex );
-  executing = _Futex_Queue_acquire( futex, &lock_context );
+  executing = _Futex_Queue_acquire( futex, &queue_context );
   if ( *uaddr == val ) {
       FUTEX_TQ_OPERATIONS,
       executing,
       STATES_WAITING_FOR_SYS_LOCK_FUTEX,
-      &lock_context
+      &queue_context
     eno = 0;
   } else {
-    _Futex_Queue_release( futex, &lock_context );
+    _Futex_Queue_release( futex, &queue_context );
     eno = EWOULDBLOCK;
@@ -128,11 +132,11 @@ static Thread_Control *_Futex_Flush_filter(
 int _Futex_Wake( struct _Futex_Control *_futex, int count )
   Futex_Context  context;
-  _Futex_Queue_acquire( futex, &context.Base.Lock_context );
+  _Futex_Queue_acquire( futex, &context.Base );
    * For some synchronization objects like barriers the _Futex_Wake() must be
@@ -140,7 +144,7 @@ int _Futex_Wake( struct _Futex_Control *_futex, int count )
    * check this condition early.
   if ( __predict_true( _Thread_queue_Is_empty( &futex->Queue.Queue ) ) ) {
-    _Futex_Queue_release( futex, &context.Base.Lock_context );
+    _Futex_Queue_release( futex, &context.Base );
     return 0;
diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
index e93a8e4..dbc1d8c 100644
--- a/cpukit/score/src/mutex.c
+++ b/cpukit/score/src/mutex.c
@@ -79,47 +79,51 @@ static Mutex_Control *_Mutex_Get( struct _Mutex_Control *_mutex )
 static Thread_Control *_Mutex_Queue_acquire(
-  Mutex_Control    *mutex,
+  Mutex_Control        *mutex,
-    lock_context
   return executing;
 static void _Mutex_Queue_release(
-  _Thread_queue_Queue_release( &mutex->Queue.Queue, lock_context );
+    &mutex->Queue.Queue,
 static void _Mutex_Acquire_slow(
-  Thread_Control    *owner,
+  Thread_Control       *owner,
   _Thread_Inherit_priority( owner, executing );
     executing,
     STATES_WAITING_FOR_SYS_LOCK_MUTEX,
     timeout,
-    lock_context
+    queue_context
@@ -155,7 +159,7 @@ static void _Mutex_Release_slow(
   } else {
-    _Mutex_Queue_release( mutex, &queue_context->Lock_context );
+    _Mutex_Queue_release( mutex, queue_context );
   if ( !keep_priority ) {
@@ -192,7 +196,7 @@ static void _Mutex_Release_critical(
     || !executing->priority_restore_hint;
   if ( __predict_true( heads == NULL && keep_priority ) ) {
   } else {
       mutex,
@@ -206,22 +210,23 @@ static void _Mutex_Release_critical(
 void _Mutex_Acquire( struct _Mutex_Control *_mutex )
-  Mutex_Control    *mutex;
-  Thread_Control   *owner;
+  Mutex_Control        *mutex;
+  Thread_Control       *owner;
   mutex = _Mutex_Get( _mutex );
-  executing = _Mutex_Queue_acquire( mutex, &lock_context );
+  executing = _Mutex_Queue_acquire( mutex, &queue_context );
   owner = mutex->owner;
   if ( __predict_true( owner == NULL ) ) {
     ++executing->resource_count;
-    _Mutex_Queue_release( mutex, &lock_context );
+    _Mutex_Queue_release( mutex, &queue_context );
   } else {
-    _Mutex_Acquire_slow( mutex, owner, executing, 0, &lock_context );
+    _Mutex_Acquire_slow( mutex, owner, executing, 0, &queue_context );
@@ -230,20 +235,21 @@ int _Mutex_Acquire_timed(
     return 0;
   } else {
@@ -251,17 +257,17 @@ int _Mutex_Acquire_timed(
         return EINVAL;
         return ETIMEDOUT;
       default:
         break;
-    _Mutex_Acquire_slow( mutex, owner, executing, ticks, &lock_context );
+    _Mutex_Acquire_slow( mutex, owner, executing, ticks, &queue_context );
     return STATUS_GET_POSIX( _Thread_Wait_get_status( executing ) );
@@ -269,14 +275,15 @@ int _Mutex_Acquire_timed(
 int _Mutex_Try_acquire( struct _Mutex_Control *_mutex )
-  int               eno;
+  int                   eno;
@@ -288,7 +295,7 @@ int _Mutex_Try_acquire( struct _Mutex_Control *_mutex )
     eno = EBUSY;
   return eno;
@@ -301,7 +308,7 @@ void _Mutex_Release( struct _Mutex_Control *_mutex )
-  executing = _Mutex_Queue_acquire( mutex, &queue_context.Lock_context );
   _Assert( mutex->owner == executing );
@@ -318,24 +325,25 @@ static Mutex_recursive_Control *_Mutex_recursive_Get(
 void _Mutex_recursive_Acquire( struct _Mutex_recursive_Control *_mutex )
   Mutex_recursive_Control *mutex;
   mutex = _Mutex_recursive_Get( _mutex );
-  executing = _Mutex_Queue_acquire( &mutex->Mutex, &lock_context );
+  executing = _Mutex_Queue_acquire( &mutex->Mutex, &queue_context );
   owner = mutex->Mutex.owner;
     mutex->Mutex.owner = executing;
-    _Mutex_Queue_release( &mutex->Mutex, &lock_context );
+    _Mutex_Queue_release( &mutex->Mutex, &queue_context );
   } else if ( owner == executing ) {
     ++mutex->nest_level;
   } else {
-    _Mutex_Acquire_slow( &mutex->Mutex, owner, executing, 0, &lock_context );
+    _Mutex_Acquire_slow( &mutex->Mutex, owner, executing, 0, &queue_context );
@@ -345,24 +353,25 @@ int _Mutex_recursive_Acquire_timed(
     return 0;
     return 0;
   } else {
@@ -370,11 +379,11 @@ int _Mutex_recursive_Acquire_timed(
         return EINVAL;
         return ETIMEDOUT;
       default:
         break;
@@ -385,7 +394,7 @@ int _Mutex_recursive_Acquire_timed(
       owner,
       executing,
       ticks,
-      &lock_context
+      &queue_context
@@ -395,13 +404,14 @@ int _Mutex_recursive_Acquire_timed(
 int _Mutex_recursive_Try_acquire( struct _Mutex_recursive_Control *_mutex )
   int                      eno;
@@ -416,7 +426,7 @@ int _Mutex_recursive_Try_acquire( struct _Mutex_recursive_Control *_mutex )
     eno = EBUSY;
   return eno;
@@ -430,10 +440,7 @@ void _Mutex_recursive_Release( struct _Mutex_recursive_Control *_mutex )
-    &mutex->Mutex,
   _Assert( mutex->Mutex.owner == executing );
@@ -444,7 +451,7 @@ void _Mutex_recursive_Release( struct _Mutex_recursive_Control *_mutex )
   } else {
     mutex->nest_level = nest_level - 1;
-    _Mutex_Queue_release( &mutex->Mutex, &queue_context.Lock_context );
diff --git a/cpukit/score/src/semaphore.c b/cpukit/score/src/semaphore.c
index 72abd9e..03af9cf 100644
--- a/cpukit/score/src/semaphore.c
+++ b/cpukit/score/src/semaphore.c
@@ -56,53 +56,58 @@ static Semaphore_Control *_Semaphore_Get(
 static Thread_Control *_Semaphore_Queue_acquire(
-  Semaphore_Control *sem,
+  Semaphore_Control    *sem,
     &sem->Queue.Queue,
-    lock_context
   return executing;
 static void _Semaphore_Queue_release(
-  _Thread_queue_Queue_release( &sem->Queue.Queue, lock_context );
+    &sem->Queue.Queue,
 void _Semaphore_Wait( struct _Semaphore_Control *_sem )
-  Semaphore_Control *sem ;
-  unsigned int       count;
+  Semaphore_Control    *sem ;
+  unsigned int          count;
   sem = _Semaphore_Get( _sem );
-  executing = _Semaphore_Queue_acquire( sem, &lock_context );
+  executing = _Semaphore_Queue_acquire( sem, &queue_context );
   count = sem->count;
   if ( count > 0 ) {
     sem->count = count - 1;
-    _Semaphore_Queue_release( sem, &lock_context );
+    _Semaphore_Queue_release( sem, &queue_context );
   } else {
       &sem->Queue.Queue,
       SEMAPHORE_TQ_OPERATIONS,
       executing,
       STATES_WAITING_FOR_SYS_LOCK_SEMAPHORE,
-      &lock_context
+      &queue_context
@@ -115,13 +120,13 @@ void _Semaphore_Post( struct _Semaphore_Control *_sem )
-  _Semaphore_Queue_acquire( sem, &queue_context.Lock_context );
+  _Semaphore_Queue_acquire( sem, &queue_context );
   heads = sem->Queue.Queue.heads;
   if ( heads == NULL ) {
     _Assert( sem->count < UINT_MAX );
     ++sem->count;
-    _Semaphore_Queue_release( sem, &queue_context.Lock_context );
   } else {
     const Thread_queue_Operations *operations;
     Thread_Control *first;
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 4eaafa9..1e95003 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -40,7 +40,7 @@ void _Thread_queue_Enqueue_critical(
@@ -61,8 +61,19 @@ void _Thread_queue_Enqueue_critical(
   ( *operations->enqueue )( queue, the_thread );
   _Thread_Wait_flags_set( the_thread, THREAD_QUEUE_INTEND_TO_BLOCK );
-  _Thread_queue_Queue_release( queue, lock_context );
+  _Thread_queue_Queue_release( queue, &queue_context->Lock_context );
+  if (
+    cpu_self->thread_dispatch_disable_level
+      != queue_context->expected_thread_dispatch_disable_level
+    _Terminate(
+      INTERNAL_ERROR_CORE,
+      false,
    *  Set the blocking state for this thread queue in the thread.
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 3bddac4..f155980 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -443,10 +443,10 @@ static void _Thread_Finalize_life_change(
 void _Thread_Join(
   _Assert( the_thread != executing );
@@ -462,7 +462,7 @@ void _Thread_Join(
     executing,
     waiting_for_join,
-    lock_context
+    queue_context
@@ -524,14 +524,16 @@ void _Thread_Cancel(
 void _Thread_Close( Thread_Control *the_thread, Thread_Control *executing )
-  _Thread_State_acquire( the_thread, &lock_context );
+  _Thread_State_acquire( the_thread, &queue_context.Lock_context );
   _Thread_Join(
     the_thread,
     executing,
-    &lock_context
+    &queue_context
   _Thread_Cancel( the_thread, executing, NULL );
diff --git a/testsuites/sptests/spfatal03/testcase.h b/testsuites/sptests/spfatal03/testcase.h
index 86b3003..34a20f6 100644
--- a/testsuites/sptests/spfatal03/testcase.h
+++ b/testsuites/sptests/spfatal03/testcase.h
@@ -16,7 +16,7 @@
 #define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_CORE
 #define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
 #define FATAL_ERROR_EXPECTED_ERROR       \
 void force_error(void)
@@ -26,7 +26,7 @@ void force_error(void)
   status = rtems_semaphore_create(
     rtems_build_name( 'S','0',' ',' '),
-    1,
+    0,
     RTEMS_LOCAL|
     RTEMS_SIMPLE_BINARY_SEMAPHORE,
     0,
@@ -37,7 +37,7 @@ void force_error(void)
   printk("Obtain semaphore in dispatching critical section\n");
   _Thread_Dispatch_disable();
-  status = rtems_semaphore_obtain( mutex, RTEMS_DEFAULT_OPTIONS, 0 );
+  status = rtems_semaphore_obtain( mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
   /* !!! SHOULD NOT RETURN FROM THE ABOVE CALL */
   rtems_test_assert( 0 );
1.8.4.5
