GSOC2016: Improvements in RTEMS Tracing Framework
Fri May 27 22:41:17 UTC 2016
On 27/05/2016 4:22 PM, vivek kukreja wrote:
> Now the ctrace command returns the following error:
> trace read failed: RTEMS_UNSATISFIED.
Is there enough resources defined in your init.c where confdefs.h is
included?
> I think the problem lies in rtems_capture_read function call in capture_support.c file. Im trying to debug the capture engine code. Does anyone how to resolve this?
Do you know what the call is?
