[PATCH 05/12] score: Add semaphore variants
Sat May 28 12:15:49 UTC 2016
On Fri, May 27, 2016 at 9:50 AM, Sebastian Huber
>  cpukit/posix/include/rtems/posix/semaphoreimpl.h |  2 +
>  cpukit/posix/src/semaphorecreatesupp.c           |  6 +--
>  cpukit/posix/src/semaphoredeletesupp.c           |  6 ++-
>  cpukit/posix/src/semaphorewaitsupp.c             |  1 +
>  cpukit/posix/src/sempost.c                       |  1 +
>  cpukit/rtems/include/rtems/rtems/sem.h           | 18 +++++++
>  cpukit/rtems/include/rtems/rtems/semimpl.h       | 25 +++++++++
>  cpukit/rtems/src/semcreate.c                     | 31 ++++++-----
>  cpukit/rtems/src/semdelete.c                     | 68 ++++++++++++++----------
>  cpukit/rtems/src/semflush.c                      | 54 +++++++++----------
>  cpukit/rtems/src/semobtain.c                     | 59 ++++++++++----------
>  cpukit/rtems/src/semrelease.c                    | 44 +++++++--------
>  cpukit/score/include/rtems/score/coresem.h       | 17 ------
>  cpukit/score/include/rtems/score/coresemimpl.h   | 54 ++++++++++---------
>  cpukit/score/src/coresem.c                       | 11 +---
>  cpukit/score/src/mpci.c                          | 11 +++-
>  16 files changed, 227 insertions(+), 181 deletions(-)
> diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> index 1521ead..17d3f64 100644
> --- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> +++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> @@ -34,6 +34,8 @@ extern "C" {
>  extern Objects_Information _POSIX_Semaphore_Information;
> +#define POSIX_SEMAPHORE_TQ_OPERATIONS &_Thread_queue_Operations_FIFO
>  RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *
>    _POSIX_Semaphore_Allocate_unprotected( void )
> diff --git a/cpukit/posix/src/semaphorecreatesupp.c b/cpukit/posix/src/semaphorecreatesupp.c
> index 79db888..d66e194 100644
> --- a/cpukit/posix/src/semaphorecreatesupp.c
> +++ b/cpukit/posix/src/semaphorecreatesupp.c
> @@ -92,11 +92,7 @@ int _POSIX_Semaphore_Create_support(
>     *  thing is certain, no matter what we decide, it won't be
>     *  the same as  all other POSIX implementations. :)
> -  _CORE_semaphore_Initialize(
> -    &the_semaphore->Semaphore,
> -    CORE_SEMAPHORE_DISCIPLINES_FIFO,
> -    value
> +  _CORE_semaphore_Initialize( &the_semaphore->Semaphore, value );
>     *  Make the semaphore available for use.
> diff --git a/cpukit/posix/src/semaphoredeletesupp.c b/cpukit/posix/src/semaphoredeletesupp.c
> index 2d39b2a..325e4a6 100644
> --- a/cpukit/posix/src/semaphoredeletesupp.c
> +++ b/cpukit/posix/src/semaphoredeletesupp.c
> @@ -27,7 +27,11 @@ void _POSIX_Semaphore_Delete(
>    if ( !the_semaphore->linked && !the_semaphore->open_count ) {
>      _Objects_Close( &_POSIX_Semaphore_Information, &the_semaphore->Object );
> -    _CORE_semaphore_Destroy( &the_semaphore->Semaphore, queue_context );
> +    _CORE_semaphore_Destroy(
> +      &the_semaphore->Semaphore,
> +      POSIX_SEMAPHORE_TQ_OPERATIONS,
> +      queue_context
>      _POSIX_Semaphore_Free( the_semaphore );
>    } else {
>      _CORE_semaphore_Release( &the_semaphore->Semaphore, queue_context );
> diff --git a/cpukit/posix/src/semaphorewaitsupp.c b/cpukit/posix/src/semaphorewaitsupp.c
> index d8e0d69..9ba8d55 100644
> --- a/cpukit/posix/src/semaphorewaitsupp.c
> +++ b/cpukit/posix/src/semaphorewaitsupp.c
> @@ -43,6 +43,7 @@ int _POSIX_Semaphore_Wait_support(
>    status = _CORE_semaphore_Seize(
>      _Thread_Executing,
>      blocking,
>      timeout,
> diff --git a/cpukit/posix/src/sempost.c b/cpukit/posix/src/sempost.c
> index 322663b..da2b1a5 100644
> --- a/cpukit/posix/src/sempost.c
> +++ b/cpukit/posix/src/sempost.c
> @@ -40,6 +40,7 @@ int sem_post(
>    status = _CORE_semaphore_Surrender(
>      SEM_VALUE_MAX,
>      &queue_context
> diff --git a/cpukit/rtems/include/rtems/rtems/sem.h b/cpukit/rtems/include/rtems/rtems/sem.h
> index 2c99f57..fe74f44 100644
> --- a/cpukit/rtems/include/rtems/rtems/sem.h
> +++ b/cpukit/rtems/include/rtems/rtems/sem.h
> @@ -97,6 +97,24 @@ typedef struct {
>    } Core_control;
> +   * @brief The semaphore variant.
> +   * @see Semaphore_Variant.
> +  unsigned int variant : 3;
Shouldn't this only need 1 bit in uniproc, and 2 bits in smp?
The width requirement for bit fields should be more explicitly stated,
and also mentioned in the cross-referenced enum so that if someone
increases the enum cases they would check the bit width here too.
I noticed the same bit width approach is used in patch 12/12, please
add similar doco there to cross-reference the enum and the bit field.
> +   * @brief The semaphore thread queue discipline.
> +   * @see Semaphore_Discipline.
> +  unsigned int discipline : 1;
> +#if defined(RTEMS_MULTIPROCESSING)
> +  unsigned int is_global : 1;
> +#endif
>     *  This is the Classic API attribute provided to the create directive.
>     *  It is translated into behavioral attributes on the SuperCore Semaphore
>     *  or Mutex instance.
> diff --git a/cpukit/rtems/include/rtems/rtems/semimpl.h b/cpukit/rtems/include/rtems/rtems/semimpl.h
> index a498927..813f885 100644
> --- a/cpukit/rtems/include/rtems/rtems/semimpl.h
> +++ b/cpukit/rtems/include/rtems/rtems/semimpl.h
> @@ -26,12 +26,37 @@
>  extern "C" {
>  #endif
> +typedef enum {
> +  SEMAPHORE_VARIANT_MUTEX,
> +  SEMAPHORE_VARIANT_COUNTING
> +#if defined(RTEMS_SMP)
> +  SEMAPHORE_VARIANT_MRSP
> +#endif
> +} Semaphore_Variant;
> +typedef enum {
> +  SEMAPHORE_DISCIPLINE_PRIORITY,
> +  SEMAPHORE_DISCIPLINE_FIFO
> +} Semaphore_Discipline;
>   *  The following defines the information control block used to manage
>   *  this class of objects.
>  extern Objects_Information _Semaphore_Information;
> +RTEMS_INLINE_ROUTINE const Thread_queue_Operations *_Semaphore_Get_operations(
> +  const Semaphore_Control *the_semaphore
> +  if ( the_semaphore->discipline == SEMAPHORE_DISCIPLINE_PRIORITY ) {
> +    return &_Thread_queue_Operations_priority;
> +  } else {
> +    return &_Thread_queue_Operations_FIFO;
>   *  @brief Allocates a semaphore control block from
>   *  the inactive chain of free semaphore control blocks.
> diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
> index 83d46b6..be8f9f5 100644
> --- a/cpukit/rtems/src/semcreate.c
> +++ b/cpukit/rtems/src/semcreate.c
> @@ -61,10 +61,9 @@ rtems_status_code rtems_semaphore_create(
>    rtems_id            *id
> -  Semaphore_Control          *the_semaphore;
> -  CORE_mutex_Attributes       the_mutex_attr;
> -  CORE_semaphore_Disciplines  semaphore_discipline;
> -  Status_Control              status;
> +  Semaphore_Control     *the_semaphore;
> +  CORE_mutex_Attributes  the_mutex_attr;
> +  Status_Control         status;
>    if ( !rtems_is_name_valid( name ) )
>      return RTEMS_INVALID_NAME;
> @@ -125,6 +124,8 @@ rtems_status_code rtems_semaphore_create(
> +  the_semaphore->is_global = _Attributes_Is_global( attribute_set );
>    if ( _Attributes_Is_global( attribute_set ) &&
>         ! ( _Objects_MP_Allocate_and_open( &_Semaphore_Information, name,
>                              the_semaphore->Object.id, false ) ) ) {
> @@ -136,29 +137,25 @@ rtems_status_code rtems_semaphore_create(
>    the_semaphore->attribute_set = attribute_set;
> +  if ( _Attributes_Is_priority( attribute_set ) ) {
> +    the_semaphore->discipline = SEMAPHORE_DISCIPLINE_PRIORITY;
> +  } else {
> +    the_semaphore->discipline = SEMAPHORE_DISCIPLINE_FIFO;
>     *  Initialize it as a counting semaphore.
>    if ( _Attributes_Is_counting_semaphore( attribute_set ) ) {
> -    if ( _Attributes_Is_priority( attribute_set ) )
> -      semaphore_discipline = CORE_SEMAPHORE_DISCIPLINES_PRIORITY;
> -    else
> -      semaphore_discipline = CORE_SEMAPHORE_DISCIPLINES_FIFO;
> -     *  The following are just to make Purify happy.
> -    the_mutex_attr.lock_nesting_behavior = CORE_MUTEX_NESTING_ACQUIRES;
> -    the_mutex_attr.priority_ceiling = PRIORITY_MINIMUM;
> +    the_semaphore->variant = SEMAPHORE_VARIANT_COUNTING;
>        &the_semaphore->Core_control.semaphore,
> -      semaphore_discipline,
>        count
>      status = STATUS_SUCCESSFUL;
>    } else if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
> +    the_semaphore->variant = SEMAPHORE_VARIANT_MRSP;
>      status = _MRSP_Initialize(
>        &the_semaphore->Core_control.mrsp,
>        priority_ceiling,
> @@ -167,6 +164,8 @@ rtems_status_code rtems_semaphore_create(
>  #endif
>    } else {
> +    the_semaphore->variant = SEMAPHORE_VARIANT_MUTEX;
>       *  It is either simple binary semaphore or a more powerful mutex
>       *  style binary semaphore.  This is the mutex style.
> diff --git a/cpukit/rtems/src/semdelete.c b/cpukit/rtems/src/semdelete.c
> index 16889cd..45c356f 100644
> --- a/cpukit/rtems/src/semdelete.c
> +++ b/cpukit/rtems/src/semdelete.c
> @@ -53,22 +53,27 @@ rtems_status_code rtems_semaphore_delete(
>      &queue_context.Lock_context
> +  switch ( the_semaphore->variant ) {
> +    case SEMAPHORE_VARIANT_MUTEX:
> +      if (
> +        _CORE_mutex_Is_locked( &the_semaphore->Core_control.mutex )
> +          && !_Attributes_Is_simple_binary_semaphore( attribute_set )
> +        status = STATUS_RESOURCE_IN_USE;
> +      } else {
> +        status = STATUS_SUCCESSFUL;
> +      break;
> -  if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
> -    status = _MRSP_Can_destroy( &the_semaphore->Core_control.mrsp );
> -  } else
> +    case SEMAPHORE_VARIANT_MRSP:
> +      status = _MRSP_Can_destroy( &the_semaphore->Core_control.mrsp );
> +      break;
>  #endif
> -  if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
> -    if (
> -      _CORE_mutex_Is_locked( &the_semaphore->Core_control.mutex )
> -        && !_Attributes_Is_simple_binary_semaphore( attribute_set )
> -      status = STATUS_RESOURCE_IN_USE;
> -    } else {
> +    default:
> +      _Assert( the_semaphore->variant == SEMAPHORE_VARIANT_COUNTING );
> -  } else {
> -    status = STATUS_SUCCESSFUL;
> +      break;
>    if ( status != STATUS_SUCCESSFUL ) {
> @@ -82,27 +87,32 @@ rtems_status_code rtems_semaphore_delete(
>    _Objects_Close( &_Semaphore_Information, &the_semaphore->Object );
> +      _CORE_mutex_Flush(
> +        &the_semaphore->Core_control.mutex,
> +        _Thread_queue_Flush_status_object_was_deleted,
> +        &queue_context
> +      _CORE_mutex_Destroy( &the_semaphore->Core_control.mutex );
> +      break;
> -    _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &queue_context );
> -  } else
> +      _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &queue_context );
> +      break;
>  #endif
> -    _CORE_mutex_Flush(
> -      &the_semaphore->Core_control.mutex,
> -      _Thread_queue_Flush_status_object_was_deleted,
> -      &queue_context
> -    _CORE_mutex_Destroy( &the_semaphore->Core_control.mutex );
> -  } else {
> -      &the_semaphore->Core_control.semaphore,
> -      &queue_context
> +    default:
> +        &the_semaphore->Core_control.semaphore,
> +        _Semaphore_Get_operations( the_semaphore ),
> +        &queue_context
> +      break;
> -  if ( _Attributes_Is_global( attribute_set ) ) {
> +  if ( the_semaphore->is_global ) {
>      _Objects_MP_Close( &_Semaphore_Information, id );
> diff --git a/cpukit/rtems/src/semflush.c b/cpukit/rtems/src/semflush.c
> index 07d4aa9..f768bbd 100644
> --- a/cpukit/rtems/src/semflush.c
> +++ b/cpukit/rtems/src/semflush.c
> @@ -19,13 +19,11 @@
>  #endif
>  #include <rtems/rtems/semimpl.h>
> -#include <rtems/rtems/attrimpl.h>
>  rtems_status_code rtems_semaphore_flush( rtems_id id )
>    Thread_queue_Context  queue_context;
> -  rtems_attribute       attribute_set;
>    the_semaphore = _Semaphore_Get( id, &queue_context );
> @@ -39,38 +37,40 @@ rtems_status_code rtems_semaphore_flush( rtems_id id )
>      return RTEMS_INVALID_ID;
> -  attribute_set = the_semaphore->attribute_set;
> +  _Thread_queue_Acquire_critical(
> +    &the_semaphore->Core_control.Wait_queue,
> +    &queue_context.Lock_context
>    _Thread_queue_Context_set_MP_callout(
>      &queue_context,
>      _Semaphore_MP_Send_object_was_deleted
> -    _ISR_lock_ISR_enable( &queue_context.Lock_context );
> -    return RTEMS_NOT_DEFINED;
> -  } else
> +      _Thread_queue_Release(
> +      return RTEMS_NOT_DEFINED;
>  #endif
> -    _CORE_mutex_Acquire_critical(
> -      &queue_context
> -      _Thread_queue_Flush_status_unavailable,
> -      &queue_context
> -  } else {
> -    _CORE_semaphore_Acquire_critical(
> -      &queue_context
> -    _CORE_semaphore_Flush(
> -      &queue_context
> +        _Thread_queue_Flush_status_unavailable,
> +        &queue_context
> +      break;
> +    default:
> +      _CORE_semaphore_Flush(
> +        &queue_context
> +      break;
>    return RTEMS_SUCCESSFUL;
> diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
> index 8cb195c..00474da 100644
> --- a/cpukit/rtems/src/semobtain.c
> +++ b/cpukit/rtems/src/semobtain.c
> @@ -54,7 +54,6 @@ rtems_status_code rtems_semaphore_obtain(
>    Thread_Control       *executing;
>    bool                  wait;
> @@ -69,36 +68,40 @@ rtems_status_code rtems_semaphore_obtain(
>    executing = _Thread_Executing;
>    wait = !_Options_Is_no_wait( option_set );
> -    status = _MRSP_Seize(
> -      &the_semaphore->Core_control.mrsp,
> -      executing,
> -      wait,
> -      timeout,
> -      &queue_context
> -  } else
> +      status = _MRSP_Seize(
> +        &the_semaphore->Core_control.mrsp,
> +        executing,
> +        wait,
> +        timeout,
> +        &queue_context
> +      break;
>  #endif
> -    status = _CORE_mutex_Seize(
> -      executing,
> -      wait,
> -      timeout,
> -      &queue_context
> -  } else {
> -    /* must be a counting semaphore */
> -    status = _CORE_semaphore_Seize(
> -      executing,
> -      wait,
> -      timeout,
> -      &queue_context
> +      status = _CORE_mutex_Seize(
> +        executing,
> +        wait,
> +        timeout,
> +        &queue_context
> +      break;
> +    default:
> +      status = _CORE_semaphore_Seize(
> +        executing,
> +        wait,
> +        timeout,
> +        &queue_context
> +      break;
>    return _Status_Get( status );
> diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
> index 10fe743..d18901a 100644
> --- a/cpukit/rtems/src/semrelease.c
> +++ b/cpukit/rtems/src/semrelease.c
> @@ -22,14 +22,12 @@
>  #endif
>  #include <rtems/rtems/statusimpl.h>
>  rtems_status_code rtems_semaphore_release( rtems_id id )
> @@ -47,27 +45,31 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
>      _Semaphore_Core_mutex_mp_support
> -    status = _MRSP_Surrender(
> -      _Thread_Executing,
> -      &queue_context
> -  } else
> +      status = _MRSP_Surrender(
> +        _Thread_Executing,
> +        &queue_context
> +      break;
>  #endif
> -    status = _CORE_mutex_Surrender(
> -      &queue_context
> -  } else {
> -    status = _CORE_semaphore_Surrender(
> -      UINT32_MAX,
> -      &queue_context
> +      status = _CORE_mutex_Surrender(
> +        &queue_context
> +      break;
> +    default:
> +      status = _CORE_semaphore_Surrender(
> +        UINT32_MAX,
> +        &queue_context
> +      break;
> diff --git a/cpukit/score/include/rtems/score/coresem.h b/cpukit/score/include/rtems/score/coresem.h
> index 84fde0b..f9d3ac8 100644
> --- a/cpukit/score/include/rtems/score/coresem.h
> +++ b/cpukit/score/include/rtems/score/coresem.h
> @@ -38,18 +38,6 @@ extern "C" {
> - *  Blocking disciplines for a semaphore.
> -typedef enum {
> -  /** This specifies that threads will wait for the semaphore in FIFO order. */
> -   *  priority order.
> -  CORE_SEMAPHORE_DISCIPLINES_PRIORITY
> -}   CORE_semaphore_Disciplines;
>   *  The following defines the control block used to manage each
>   *  counting semaphore.
> @@ -59,11 +47,6 @@ typedef struct {
>    Thread_queue_Control        Wait_queue;
> -   * @brief The thread queue operations according to the blocking discipline.
> -  const Thread_queue_Operations *operations;
>    /** This element contains the current count of this semaphore. */
>    uint32_t                    count;
>  }   CORE_semaphore_Control;
> diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
> index a55089e..24d8c51 100644
> --- a/cpukit/score/include/rtems/score/coresemimpl.h
> +++ b/cpukit/score/include/rtems/score/coresemimpl.h
> @@ -46,13 +46,11 @@ extern "C" {
>   *  This routine initializes the semaphore based on the parameters passed.
>   *  @param[in] the_semaphore is the semaphore to initialize
> - *  @param[in] discipline the blocking discipline
>   *  @param[in] initial_value is the initial count of the semaphore
>  void _CORE_semaphore_Initialize(
> -  CORE_semaphore_Control     *the_semaphore,
> -  CORE_semaphore_Disciplines  discipline,
> -  uint32_t                    initial_value
> +  CORE_semaphore_Control *the_semaphore,
> +  uint32_t                initial_value
>  RTEMS_INLINE_ROUTINE void _CORE_semaphore_Acquire_critical(
> @@ -78,13 +76,14 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Release(
>  RTEMS_INLINE_ROUTINE void _CORE_semaphore_Destroy(
> -  Thread_queue_Context   *queue_context
> +  const Thread_queue_Operations *operations,
> +  Thread_queue_Context          *queue_context
>    _Thread_queue_Flush_critical(
>      &the_semaphore->Wait_queue.Queue,
> -    the_semaphore->operations,
> +    operations,
>      queue_context
> @@ -99,15 +98,17 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Destroy(
>   *  given to that task.  Otherwise, the unit will be returned to the semaphore.
>   *  @param[in] the_semaphore is the semaphore to surrender
> + *  @param[in] operations The thread queue operations.
>   *  @param[in] queue_context is a temporary variable used to contain the ISR
>   *        disable level cookie
>   *  @retval an indication of whether the routine succeeded or failed
>  RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Surrender(
> -  uint32_t                 maximum_count,
> +  uint32_t                       maximum_count,
>    Thread_Control *the_thread;
> @@ -119,12 +120,12 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Surrender(
>    the_thread = _Thread_queue_First_locked(
>      &the_semaphore->Wait_queue,
> +    operations
>    if ( the_thread != NULL ) {
>      _Thread_queue_Extract_critical(
> +      operations,
>        the_thread,
>        queue_context
> @@ -141,13 +142,14 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Surrender(
>  RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush(
> +    operations,
>      queue_context
> @@ -161,7 +163,7 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush(
>   * @return the current count of this semaphore
>  RTEMS_INLINE_ROUTINE uint32_t  _CORE_semaphore_Get_count(
> +  const CORE_semaphore_Control *the_semaphore
>    return the_semaphore->count;
> @@ -174,23 +176,23 @@ RTEMS_INLINE_ROUTINE uint32_t  _CORE_semaphore_Get_count(
>   * available.
>   * @param[in] the_semaphore is the semaphore to obtain
> - * @param[in,out] executing The currently executing thread.
> + * @param[in] executing The currently executing thread.
>   * @param[in] wait is true if the thread is willing to wait
>   * @param[in] timeout is the maximum number of ticks to block
> - * @note There is currently no MACRO version of this routine.
>  RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Seize(
> -  Thread_Control         *executing,
> -  bool                    wait,
> -  Watchdog_Interval       timeout,
> +  Thread_Control                *executing,
> +  bool                           wait,
> +  Watchdog_Interval              timeout,
> -  /* disabled when you get here */
> +  _Assert( _ISR_Get_level() != 0 );
>    _CORE_semaphore_Acquire_critical( the_semaphore, queue_context );
>    if ( the_semaphore->count != 0 ) {
> @@ -207,7 +209,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Seize(
>    _Thread_queue_Context_set_expected_level( queue_context, 1 );
>    _Thread_queue_Enqueue_critical(
> +    operations,
>      executing,
>      STATES_WAITING_FOR_SEMAPHORE,
>      timeout,
> diff --git a/cpukit/score/src/coresem.c b/cpukit/score/src/coresem.c
> index 2bdd81c..e928f3d 100644
> --- a/cpukit/score/src/coresem.c
> +++ b/cpukit/score/src/coresem.c
> @@ -21,18 +21,11 @@
>  #include <rtems/score/coresemimpl.h>
>    the_semaphore->count = initial_value;
>    _Thread_queue_Initialize( &the_semaphore->Wait_queue );
> -  if ( discipline == CORE_SEMAPHORE_DISCIPLINES_PRIORITY ) {
> -    the_semaphore->operations = &_Thread_queue_Operations_priority;
> -  } else {
> -    the_semaphore->operations = &_Thread_queue_Operations_FIFO;
> diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
> index 1e26b1f..721868e 100644
> --- a/cpukit/score/src/mpci.c
> +++ b/cpukit/score/src/mpci.c
> @@ -35,6 +35,8 @@ RTEMS_STATIC_ASSERT(
>    MPCI_Internal_packet
> +#define MPCI_SEMAPHORE_TQ_OPERATIONS &_Thread_queue_Operations_FIFO
>  bool _System_state_Is_multiprocessing;
>  rtems_multiprocessing_table *_Configuration_MP_table;
> @@ -119,7 +121,6 @@ static void _MPCI_Handler_initialization( void )
>      &_MPCI_Semaphore,
>      0                         /* initial_value */
> @@ -334,6 +335,7 @@ void _MPCI_Receive_server(
>      _ISR_lock_ISR_disable( &queue_context.Lock_context );
>        &_MPCI_Semaphore,
> +      MPCI_SEMAPHORE_TQ_OPERATIONS,
>        executing,
>        true,
>        WATCHDOG_NO_TIMEOUT,
> @@ -372,7 +374,12 @@ void _MPCI_Announce ( void )
> -  (void) _CORE_semaphore_Surrender( &_MPCI_Semaphore, UINT32_MAX, &queue_context );
> +  (void) _CORE_semaphore_Surrender(
> +    &_MPCI_Semaphore,
> +    UINT32_MAX,
> +    &queue_context
>  void _MPCI_Internal_packets_Send_process_packet (
> 1.8.4.5
> devel mailing list
> devel at rtems.org
