LM3S69xx BSP Qemu Error
Olufowobi, Habeeb
habeeb.olufowobi at bison.howard.edu
Sat May 28 15:45:09 UTC 2016
Thanks so much for your help Martin.
I will look to work on the reset routine as said.
Regards,
Habeeb
On Fri, May 27, 2016 at 8:23 AM, Martin Galvan <
martin.galvan at tallertechnologies.com> wrote:
> On Fri, May 27, 2016 at 12:01 PM, Olufowobi, Habeeb
> <habeeb.olufowobi at bison.howard.edu> wrote:
> > Hi Martin,
> > I am able to run HelloWorld with what you provided. I also noticed that
> the
> > process does not terminate by itself and I have to manually kill it. I
> > noticed that for the HelloWorld and ticker. Does it behave like that when
> > you run it?
> That's great! Yeah, I believe the "freezing" you're seeing is normal.
> IIRC exit() ends up calling _Terminate, which in turn calls bsp_reset.
> Since the LM3S69xx BSP doesn't have its own bsp_reset, it defaults to
> the shared one which does nothing. Therefore we go back to _Terminate,
> which ends with an endless loop.
> For the record, it would be great to add a proper reset routine to the
> LM3S69xx (if possible). I may take a shot at doing it myself if I can
> find the time.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160528/7c76649a/attachment.html>
