[PATCH] pc386: Add virtio network driver
Jinhyun jinhyun at konkuk.ac.kr
Mon May 30 07:35:13 UTC 2016
>From 1eebb8a11846e1b760f0362c77aac19d5a294bb8 Mon Sep 17 00:00:00 2001
Date: Mon, 30 May 2016 15:40:43 +0900
Subject: [PATCH] virtio
 c/src/lib/libbsp/i386/pc386/Makefile.am          |   18 +
 c/src/lib/libbsp/i386/pc386/virtio/HOWTOUSE      |   62 +
 c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.c    | 4151
 c/src/lib/libbsp/i386/pc386/virtio/if_vtnetvar.h |  391 ++
 c/src/lib/libbsp/i386/pc386/virtio/virtio.c      |  291 ++
 c/src/lib/libbsp/i386/pc386/virtio/virtio.h      |  255 ++
 c/src/lib/libbsp/i386/pc386/virtio/virtio_net.h  |  218 ++
 c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.c  | 1526 ++++++++
 c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.h  |  166 +
 c/src/lib/libbsp/i386/pc386/virtio/virtio_ring.h |  180 +
 c/src/lib/libbsp/i386/pc386/virtio/virtqueue.c   |  963 +++++
 c/src/lib/libbsp/i386/pc386/virtio/virtqueue.h   |  127 +
 12 files changed, 8348 insertions(+)
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/HOWTOUSE
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.c
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/if_vtnetvar.h
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/virtio.c
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/virtio.h
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/virtio_net.h
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.c
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.h
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/virtio_ring.h
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/virtqueue.c
 create mode 100644 c/src/lib/libbsp/i386/pc386/virtio/virtqueue.h
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am
b/c/src/lib/libbsp/i386/pc386/Makefile.am
index a8c9ec1..d4ef7a2 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -226,6 +226,23 @@ noinst_PROGRAMS += 3c509.rel
 3c509_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 endif
+if HAS_NETWORKING
+vtnet_CPPFLAGS = -D__INSIDE_RTEMS_BSD_TCPIP_STACK__
+noinst_PROGRAMS += vtnet.rel
+vtnet_rel_SOURCES = virtio/if_vtnet.c
+vtnet_rel_SOURCES += virtio/if_vtnetvar.h
+vtnet_rel_SOURCES += virtio/virtio_net.h
+vtnet_rel_SOURCES += virtio/virtio_pci.c
+vtnet_rel_SOURCES += virtio/virtio_pci.h
+vtnet_rel_SOURCES += virtio/virtqueue.c
+vtnet_rel_SOURCES += virtio/virtqueue.h
+vtnet_rel_SOURCES += virtio/virtio.c
+vtnet_rel_SOURCES += virtio/virtio.h
+vtnet_rel_SOURCES += virtio/virtio_ring.h
+vtnet_rel_CPPFLAGS = $(AM_CPPFLAGS) $(vtnet_CPPFLAGS)
+vtnet_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
+endif
 libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/cache.rel
 libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/page.rel
 libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/score.rel
@@ -240,6 +257,7 @@ if HAS_NETWORKING
 libbsp_a_LIBADD += ne2000.rel
 libbsp_a_LIBADD += wd8003.rel
 libbsp_a_LIBADD += 3c509.rel
+libbsp_a_LIBADD += vtnet.rel
 endif
 EXTRA_DIST += HOWTO
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/HOWTOUSE
b/c/src/lib/libbsp/i386/pc386/virtio/HOWTOUSE
new file mode 100644
index 0000000..eb91f80
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/HOWTOUSE
@@ -0,0 +1,62 @@
+1. Introduction
+	This document explains how to setup RTEMS so that RTEMS applications
can be
+built for and run with the virtio network driver. The virtio network driver
is
+ported from FreeBSD release 10.0.0, and RTEMS specific changes of the
driver are
+ ifdef'ed by RTEMS_VIRTIO_NET.
+2. Building RTEMS kernel with the virtio network driver
+	When running configure, you need to use following values for the
listed
+options with an i386-rtems toolset. The original virtio network driver of
+FreeBSD works with various CPUs, but the virtio network driver for RTEMS is
only
+tested on i386-pc386, yet.
+		--target=i386-rtems
+		--enable-rtemsbsp=pc386
+3. Building RTEMS applications with virtio network driver
+	You can use virtio network driver in the same way with other network
drivers
+of RTEMS, but you have to set the mbuf cluster space so that it can be
larger
+than 512KB because the virtio network driver uses 256 mbuf clusters for Rx.
An
+example of network configuration is as follows.
+	extern int rtems_vtnet_driver_attach(struct rtems_bsdnet_ifconfig *,
int)
+	static struct rtems_bsdnet_ifconfig virtio_config[]={
+	  "vio1", rtems_vtnet_driver_attach, NULL,
+	struct rtems_bsdnet_config rtems_bsdnet_config = {
+		virtio_config,		/* link to next interface */
+		0,				/* Use BOOTP to get network
configuration */
+		150,				/* Network task priority */
+		128*1024,			/* MBUF space */
+		512*1024,			/* MBUF cluster space */
+4. Running virtual machine with virtio network device
+	To use the virtio network driver, the hypervisor has to support
virtio
+network device. The current implementation can successfully run with KVM
and
+VirtualBox. Example commands for these hypervisors are as follows.
+	For KVM:
+	$ qemu-system-i386 -enable-kvm -no-shutdown -m 128 \
+		-boot a -fda rtems-boot.img \
+		-hda hdd.img -net nic,model=virtio -net
tap,ifname=tap0,script=no \
+		-monitor stdio
+	For VirtualBox:
+ 	$ VBoxManage modifyvm RTEMS-4.11 --nictype1 virtio
+ 	$ VBoxManage startvm RTEMS-4.11
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.c
b/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.c
index 0000000..1ee9199
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/if_vtnet.c
@@ -0,0 +1,4151 @@
+ * @file if_vtnet.c
+ * @brief Driver for virtio network devices
+ * Authors: Jin-Hyun Kim <jinhyun at konkuk.ac.kr>,
+ *   and Hyun-Wook Jin <jinh at konkuk.ac.kr>, http://sslab.konkuk.ac.kr
+ * Ported from FreeBSD to RTEMS March 16
+ * http://www.rtems.org/license/LICENSE.NET
+ * Copyright (c) 2011, Bryan Venteicher <bryanv at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ *    notice unmodified, this list of conditions, and the following
+ *    disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/network/if_vtnet.c 256066
2013-10-05 18:07:24Z bryanv $
+#define VTNET_LEGACY_TX
+#define RTEMS_VIRTIO_NET
+#include <rtems.h>
+#include <rtems/rtems_bsdnet.h>
+#include <bsp.h>
+#include <sys/mbuf.h>
+#include <sys/param.h>
+#include <sys/socket.h>
+#include <sys/sockio.h>
+#include <sys/systm.h>
+#include <net/if.h>
+#include <netinet/in.h>
+#include <netinet/if_ether.h>
+#include "virtio.h"
+#include "virtqueue.h"
+#include "virtio_pci.h"
+#include "virtio_net.h"
+#include "if_vtnetvar.h"
+#ifdef RTEMS_VIRTIO_NET
+static struct vtnet_softc vtnet_softc;
+static rtems_interval     vtnet_ticksPerSecond;
+static const char vtnet_nameunit[] = "vtnet";
+#define IFF_DRV_RUNNING IFF_RUNNING
+#define if_drv_flags if_flags
+#define device_get_softc(dev) &vtnet_softc
+#define device_get_nameunit(dev) vtnet_nameunit
+#define IF_LLADDR(ifp) (sc->arpcom.ac_enaddr)
+#define IFQ_SET_MAXLEN(ifq, len) ((ifq)->ifq_maxlen=(len))
+#define IFQ_DRV_IS_EMPTY(ifq) (0==(ifq)->ifq_head)
+#define IFQ_DRV_DEQUEUE(ifq,m) IF_DEQUEUE((ifq),(m))
+#define IFQ_DRV_PREPEND(ifq,m) IF_PREPEND((ifq),(m))
+int rtems_vtnet_driver_attach(struct rtems_bsdnet_ifconfig *config, int
attaching);
+static void vtnet_daemon( void *xsc );
+#endif
+#ifdef NOTUSED
+static int	vtnet_modevent(module_t, int, void *);
+static int	vtnet_probe(device_t);
+static int	vtnet_detach(device_t);
+static int	vtnet_suspend(device_t);
+static int	vtnet_resume(device_t);
+static int	vtnet_shutdown(device_t);
+static int	vtnet_attach_completed(device_t);
+static int	vtnet_config_change(device_t);
+static int	vtnet_alloc_rx_filters(struct vtnet_softc *);
+static void	vtnet_free_rx_filters(struct vtnet_softc *);
+static int	vtnet_change_mtu(struct vtnet_softc *, int);
+static int	vtnet_rxq_csum(struct vtnet_rxq *, struct mbuf *,
+		     struct virtio_net_hdr *);
+static void	vtnet_rxq_tq_intr(void *, int);
+static int	vtnet_txq_offload_ctx(struct vtnet_txq *, struct mbuf *,
+		    int *, int *, int *);
+static int	vtnet_txq_offload_tso(struct vtnet_txq *, struct mbuf *,
int,
+		    int, struct virtio_net_hdr *);
+static struct mbuf *
+		vtnet_txq_offload(struct vtnet_txq *, struct mbuf *,
+#ifdef VTNET_LEGACY_TX
+static void	vtnet_start_locked(struct vtnet_txq *, struct ifnet *);
+#else
+static int	vtnet_txq_mq_start_locked(struct vtnet_txq *, struct mbuf
+static int	vtnet_txq_mq_start(struct ifnet *, struct mbuf *);
+static void	vtnet_txq_tq_deferred(void *, int);
+#endif
+static void	vtnet_txq_tq_intr(void *, int);
+#ifndef VTNET_LEGACY_TX
+static void	vtnet_qflush(struct ifnet *);
+#endif
+static void	vtnet_rxq_accum_stats(struct vtnet_rxq *,
+		    struct vtnet_rxq_stats *);
+static void	vtnet_txq_accum_stats(struct vtnet_txq *,
+		    struct vtnet_txq_stats *);
+static void	vtnet_accumulate_stats(struct vtnet_softc *);
+static void	vtnet_start_taskqueues(struct vtnet_softc *);
+static void	vtnet_free_taskqueues(struct vtnet_softc *);
+static void	vtnet_drain_taskqueues(struct vtnet_softc *);
+static void	vtnet_init_rx_filters(struct vtnet_softc *);
+static void	vtnet_free_ctrl_vq(struct vtnet_softc *);
+static void	vtnet_exec_ctrl_cmd(struct vtnet_softc *, void *,
+		    struct sglist *, int, int);
+static int	vtnet_ctrl_mac_cmd(struct vtnet_softc *, uint8_t *);
+static int	vtnet_ctrl_mq_cmd(struct vtnet_softc *, uint16_t);
+static int	vtnet_ctrl_rx_cmd(struct vtnet_softc *, int, int);
+static int	vtnet_set_promisc(struct vtnet_softc *, int);
+static int	vtnet_set_allmulti(struct vtnet_softc *, int);
+static void	vtnet_attach_disable_promisc(struct vtnet_softc *);
+static void	vtnet_rx_filter(struct vtnet_softc *);
+static void	vtnet_rx_filter_mac(struct vtnet_softc *);
+static int	vtnet_exec_vlan_filter(struct vtnet_softc *, int, uint16_t);
+static void	vtnet_rx_filter_vlan(struct vtnet_softc *);
+static void	vtnet_update_vlan_filter(struct vtnet_softc *, int,
uint16_t);
+static void	vtnet_register_vlan(void *, struct ifnet *, uint16_t);
+static void	vtnet_unregister_vlan(void *, struct ifnet *, uint16_t);
+static int	vtnet_ifmedia_upd(struct ifnet *);
+static void	vtnet_ifmedia_sts(struct ifnet *, struct ifmediareq *);
+static void	vtnet_vlan_tag_remove(struct mbuf *);
+static void	vtnet_setup_rxq_sysctl(struct sysctl_ctx_list *,
+		    struct sysctl_oid_list *, struct vtnet_rxq *);
+static void	vtnet_setup_txq_sysctl(struct sysctl_ctx_list *,
+		    struct sysctl_oid_list *, struct vtnet_txq *);
+static void	vtnet_setup_queue_sysctl(struct vtnet_softc *);
+static void	vtnet_setup_sysctl(struct vtnet_softc *);
+static int	vtnet_tunable_int(struct vtnet_softc *, const char *, int);
+#endif
+static int	vtnet_attach(device_t);
+static void	vtnet_negotiate_features(struct vtnet_softc *);
+static void	vtnet_setup_features(struct vtnet_softc *);
+static int	vtnet_init_rxq(struct vtnet_softc *, int);
+static int	vtnet_init_txq(struct vtnet_softc *, int);
+static int	vtnet_alloc_rxtx_queues(struct vtnet_softc *);
+static void	vtnet_free_rxtx_queues(struct vtnet_softc *);
+static int	vtnet_alloc_virtqueues(struct vtnet_softc *);
+static int	vtnet_setup_interface(struct vtnet_softc *);
+static int	vtnet_ioctl(struct ifnet *, u_long, caddr_t);
+static int	vtnet_rxq_populate(struct vtnet_rxq *);
+static void	vtnet_rxq_free_mbufs(struct vtnet_rxq *);
+		vtnet_rx_alloc_buf(struct vtnet_softc *, int , struct mbuf
+static int	vtnet_rxq_replace_lro_nomgr_buf(struct vtnet_rxq *,
+		    struct mbuf *, int);
+static int	vtnet_rxq_replace_buf(struct vtnet_rxq *, struct mbuf *,
int);
+static int	vtnet_rxq_enqueue_buf(struct vtnet_rxq *, struct mbuf *);
+static int	vtnet_rxq_new_buf(struct vtnet_rxq *);
+static void	vtnet_rxq_discard_merged_bufs(struct vtnet_rxq *, int);
+static void	vtnet_rxq_discard_buf(struct vtnet_rxq *, struct mbuf *);
+static int	vtnet_rxq_merged_eof(struct vtnet_rxq *, struct mbuf *,
int);
+static void	vtnet_rxq_input(struct vtnet_rxq *, struct mbuf *,
+static int	vtnet_rxq_eof(struct vtnet_rxq *);
+static void	vtnet_rx_vq_intr(void *);
+static void	vtnet_tx_start_all(struct vtnet_softc *);
+static void	vtnet_txq_free_mbufs(struct vtnet_txq *);
+static int	vtnet_txq_enqueue_buf(struct vtnet_txq *, struct mbuf **,
+		    struct vtnet_tx_header *);
+static int	vtnet_txq_encap(struct vtnet_txq *, struct mbuf **);
+static void	vtnet_start(struct ifnet *);
+static void	vtnet_txq_eof(struct vtnet_txq *);
+static void	vtnet_tx_vq_intr(void *);
+static int	vtnet_watchdog(struct vtnet_txq *);
+static void	vtnet_tick(void *);
+static void	vtnet_drain_rxtx_queues(struct vtnet_softc *);
+static void	vtnet_stop_rendezvous(struct vtnet_softc *);
+static void	vtnet_stop(struct vtnet_softc *);
+static int	vtnet_virtio_reinit(struct vtnet_softc *);
+static int	vtnet_init_rx_queues(struct vtnet_softc *);
+static int	vtnet_init_tx_queues(struct vtnet_softc *);
+static int	vtnet_init_rxtx_queues(struct vtnet_softc *);
+static void	vtnet_set_active_vq_pairs(struct vtnet_softc *);
+static int	vtnet_reinit(struct vtnet_softc *);
+static void	vtnet_init_locked(struct vtnet_softc *);
+static void	vtnet_init(void *);
+static int	vtnet_is_link_up(struct vtnet_softc *);
+static void	vtnet_update_link_status(struct vtnet_softc *);
+static void	vtnet_get_hwaddr(struct vtnet_softc *);
+static void	vtnet_set_hwaddr(struct vtnet_softc *);
+static int	vtnet_rxq_enable_intr(struct vtnet_rxq *);
+static void	vtnet_rxq_disable_intr(struct vtnet_rxq *);
+static int	vtnet_txq_enable_intr(struct vtnet_txq *);
+static void	vtnet_txq_disable_intr(struct vtnet_txq *);
+static void	vtnet_enable_rx_interrupts(struct vtnet_softc *);
+static void	vtnet_enable_tx_interrupts(struct vtnet_softc *);
+static void	vtnet_enable_interrupts(struct vtnet_softc *);
+static void	vtnet_disable_rx_interrupts(struct vtnet_softc *);
+static void	vtnet_disable_tx_interrupts(struct vtnet_softc *);
+static void	vtnet_disable_interrupts(struct vtnet_softc *);
+#ifdef NOTUSED
+/* Tunables. */
+static int vtnet_csum_disable = 0;
+TUNABLE_INT("hw.vtnet.csum_disable", &vtnet_csum_disable);
+static int vtnet_tso_disable = 0;
+TUNABLE_INT("hw.vtnet.tso_disable", &vtnet_tso_disable);
+static int vtnet_lro_disable = 0;
+TUNABLE_INT("hw.vtnet.lro_disable", &vtnet_lro_disable);
+static int vtnet_mq_disable = 0;
+TUNABLE_INT("hw.vtnet.mq_disable", &vtnet_mq_disable);
+static int vtnet_mq_max_pairs = 0;
+TUNABLE_INT("hw.vtnet.mq_max_pairs", &vtnet_mq_max_pairs);
+static int vtnet_rx_process_limit = 512;
+TUNABLE_INT("hw.vtnet.rx_process_limit", &vtnet_rx_process_limit);
+ * Reducing the number of transmit completed interrupts can improve
+ * performance. To do so, the define below keeps the Tx vq interrupt
+ * disabled and adds calls to vtnet_txeof() in the start and watchdog
+ * paths. The price to pay for this is the m_free'ing of transmitted
+ * mbufs may be delayed until the watchdog fires.
+ * BMV: Reintroduce this later as a run-time option, if it makes
+ * sense after the EVENT_IDX feature is supported.
+ * #define VTNET_TX_INTR_MODERATION
+static uma_zone_t vtnet_tx_header_zone;
+static struct virtio_feature_desc vtnet_feature_desc[] = {
+	{ VIRTIO_NET_F_CSUM,		"TxChecksum"	},
+	{ VIRTIO_NET_F_GUEST_CSUM,	"RxChecksum"	},
+	{ VIRTIO_NET_F_MAC,		"MacAddress"	},
+	{ VIRTIO_NET_F_GSO,		"TxAllGSO"	},
+	{ VIRTIO_NET_F_GUEST_TSO4,	"RxTSOv4"	},
+	{ VIRTIO_NET_F_GUEST_TSO6,	"RxTSOv6"	},
+	{ VIRTIO_NET_F_GUEST_ECN,	"RxECN"		},
+	{ VIRTIO_NET_F_GUEST_UFO,	"RxUFO"		},
+	{ VIRTIO_NET_F_HOST_TSO4,	"TxTSOv4"	},
+	{ VIRTIO_NET_F_HOST_TSO6,	"TxTSOv6"	},
+	{ VIRTIO_NET_F_HOST_ECN,	"TxTSOECN"	},
+	{ VIRTIO_NET_F_HOST_UFO,	"TxUFO"		},
+	{ VIRTIO_NET_F_MRG_RXBUF,	"MrgRxBuf"	},
+	{ VIRTIO_NET_F_STATUS,		"Status"	},
+	{ VIRTIO_NET_F_CTRL_VQ,		"ControlVq"	},
+	{ VIRTIO_NET_F_CTRL_RX,		"RxMode"	},
+	{ VIRTIO_NET_F_CTRL_VLAN,	"VLanFilter"	},
+	{ VIRTIO_NET_F_CTRL_RX_EXTRA,	"RxModeExtra"	},
+	{ VIRTIO_NET_F_GUEST_ANNOUNCE,	"GuestAnnounce"	},
+	{ VIRTIO_NET_F_MQ,		"Multiqueue"	},
+	{ VIRTIO_NET_F_CTRL_MAC_ADDR,	"SetMacAddress"	},
+	{ 0, NULL }
+static device_method_t vtnet_methods[] = {
+	/* Device methods. */
+	DEVMETHOD(device_probe,			vtnet_probe),
+	DEVMETHOD(device_attach,		vtnet_attach),
+	DEVMETHOD(device_detach,		vtnet_detach),
+	DEVMETHOD(device_suspend,		vtnet_suspend),
+	DEVMETHOD(device_resume,		vtnet_resume),
+	DEVMETHOD(device_shutdown,		vtnet_shutdown),
+	/* VirtIO methods. */
+	DEVMETHOD(virtio_attach_completed,	vtnet_attach_completed),
+	DEVMETHOD(virtio_config_change,		vtnet_config_change),
+	DEVMETHOD_END
+static driver_t vtnet_driver = {
+	"vtnet",
+	vtnet_methods,
+	sizeof(struct vtnet_softc)
+static devclass_t vtnet_devclass;
+DRIVER_MODULE(vtnet, virtio_pci, vtnet_driver, vtnet_devclass,
+    vtnet_modevent, 0);
+MODULE_VERSION(vtnet, 1);
+MODULE_DEPEND(vtnet, virtio, 1, 1, 1);
+static int
+vtnet_modevent(module_t mod, int type, void *unused)
+	int error;
+	error = 0;
+	switch (type) {
+	case MOD_LOAD:
+		vtnet_tx_header_zone = uma_zcreate("vtnet_tx_hdr",
+		    sizeof(struct vtnet_tx_header),
+		    NULL, NULL, NULL, NULL, 0, 0);
+		break;
+	case MOD_QUIESCE:
+	case MOD_UNLOAD:
+		if (uma_zone_get_cur(vtnet_tx_header_zone) > 0)
+			error = EBUSY;
+		else if (type == MOD_UNLOAD) {
+			uma_zdestroy(vtnet_tx_header_zone);
+			vtnet_tx_header_zone = NULL;
+		break;
+	case MOD_SHUTDOWN:
+		break;
+	default:
+		error = EOPNOTSUPP;
+		break;
+	return (error);
+static int
+vtnet_probe(device_t dev)
+	if (virtio_get_device_type(dev) != VIRTIO_ID_NETWORK)
+		return (ENXIO);
+	device_set_desc(dev, "VirtIO Networking Adapter");
+	return (BUS_PROBE_DEFAULT);
+#endif
+int
+rtems_vtnet_driver_attach(
+  struct rtems_bsdnet_ifconfig *config,
+  int                           attaching
+	struct vtnet_softc *sc;
+	int error;
+	sc = &vtnet_softc;
+	sc->config = config;
+	memset(sc, 0, sizeof(struct vtnet_softc));
+	vtnet_ticksPerSecond = rtems_clock_get_ticks_per_second();
+	error = rtems_vtpci_attach( config, &sc->vtpci_softc );
+	if ( error ) {
+		device_printf(dev, "cannot attach pci device\n");
+		return error;
+	sc->vtnet_flags = 0;
+	sc->vtnet_hdr_size = 0;
+	sc->vtnet_max_vq_pairs = 1;
+	sc->vtnet_rx_process_limit = 512;
+	error = vtnet_attach(attaching);
+	return (error);
+static void
+vtnet_daemon( void *xsc )
+	struct vtpci_softc *sc;
+	struct vtpci_virtqueue *vqx;
+	rtems_event_set     events;
+	int                 i;
+	sc = ((struct vtnet_softc *)xsc)->vtpci_softc;
+	while ( 1 ) {
+	rtems_bsdnet_event_receive( RTEMS_EVENT_1,
+		RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &events );
+		vqx = &sc->vtpci_vqs[0];
+		for (i = 0; i < sc->vtpci_nvqs; i++, vqx++) {
+			if (vqx->vtv_no_intr == 0)
+				virtqueue_intr(vqx->vtv_vq);
+#endif
+static int
+vtnet_attach(device_t dev)
+	int error;
+	sc = device_get_softc(dev);
+	sc->vtnet_dev = dev;
+#ifdef NOTUSED
+	/* Register our feature descriptions. */
+	virtio_set_feature_desc(dev, vtnet_feature_desc);
+	VTNET_CORE_LOCK_INIT(sc);
+	callout_init_mtx(&sc->vtnet_tick_ch, VTNET_CORE_MTX(sc), 0);
+	vtnet_setup_sysctl(sc);
+#endif
+	vtnet_setup_features(sc);
+#ifdef NOTUSED
+	error = vtnet_alloc_rx_filters(sc);
+	if (error) {
+		device_printf(dev, "cannot allocate Rx filters\n");
+		goto fail;
+#endif
+	error = vtnet_alloc_rxtx_queues(sc);
+	if (error) {
+		device_printf(dev, "cannot allocate queues\n");
+		goto fail;
+	error = vtnet_alloc_virtqueues(sc);
+	if (error) {
+		device_printf(dev, "cannot allocate virtqueues\n");
+		goto fail;
+	error = vtnet_setup_interface(sc);
+	if (error) {
+		device_printf(dev, "cannot setup interface\n");
+		goto fail;
+	error = virtio_setup_intr(dev, INTR_TYPE_NET);
+	if (error) {
+		device_printf(dev, "cannot setup virtqueue interrupts\n");
+		/* BMV: This will crash if during boot! */
+#ifdef NOTUSED
+		ether_ifdetach(sc->vtnet_ifp);
+#endif
+		goto fail;
+#ifdef NOTUSED
+	vtnet_start_taskqueues(sc);
+#endif
+fail:
+#ifdef NOTUSED
+	if (error)
+		vtnet_detach(dev);
+#endif
+	return (error);
+#ifdef NOTUSED
+static int
+vtnet_detach(device_t dev)
+	struct ifnet *ifp;
+	ifp = sc->vtnet_ifp;
+	if (device_is_attached(dev)) {
+		VTNET_CORE_LOCK(sc);
+		vtnet_stop(sc);
+		VTNET_CORE_UNLOCK(sc);
+		callout_drain(&sc->vtnet_tick_ch);
+		vtnet_drain_taskqueues(sc);
+		ether_ifdetach(ifp);
+	vtnet_free_taskqueues(sc);
+	if (sc->vtnet_vlan_attach != NULL) {
+		EVENTHANDLER_DEREGISTER(vlan_config, sc->vtnet_vlan_attach);
+		sc->vtnet_vlan_attach = NULL;
+	if (sc->vtnet_vlan_detach != NULL) {
+		EVENTHANDLER_DEREGISTER(vlan_unconfg,
sc->vtnet_vlan_detach);
+		sc->vtnet_vlan_detach = NULL;
+	ifmedia_removeall(&sc->vtnet_media);
+	if (ifp != NULL) {
+		if_free(ifp);
+		sc->vtnet_ifp = NULL;
+	vtnet_free_rxtx_queues(sc);
+	vtnet_free_rx_filters(sc);
+	if (sc->vtnet_ctrl_vq != NULL)
+		vtnet_free_ctrl_vq(sc);
+	VTNET_CORE_LOCK_DESTROY(sc);
+	return (0);
+static int
+vtnet_suspend(device_t dev)
+	vtnet_stop(sc);
+	sc->vtnet_flags |= VTNET_FLAG_SUSPENDED;
+	return (0);
+static int
+vtnet_resume(device_t dev)
+	if (ifp->if_flags & IFF_UP)
+		vtnet_init_locked(sc);
+	sc->vtnet_flags &= ~VTNET_FLAG_SUSPENDED;
+	return (0);
+static int
+vtnet_shutdown(device_t dev)
+	 * Suspend already does all of what we need to
+	 * do here; we just never expect to be resumed.
+	return (vtnet_suspend(dev));
+static int
+vtnet_attach_completed(device_t dev)
+	vtnet_attach_disable_promisc(device_get_softc(dev));
+	return (0);
+#endif
+static int
+vtnet_config_change(device_t dev)
+	vtnet_update_link_status(sc);
+	if (sc->vtnet_link_active != 0)
+		vtnet_tx_start_all(sc);
+	return (0);
+static void
+vtnet_negotiate_features(struct vtnet_softc *sc)
+	device_t dev;
+	uint64_t mask, features;
+	dev = sc->vtnet_dev;
+	mask = 0;
+#ifdef NOTUSED
+	 * TSO and LRO are only available when their corresponding checksum
+	 * offload feature is also negotiated.
+	if (vtnet_tunable_int(sc, "csum_disable", vtnet_csum_disable)) {
+		mask |= VIRTIO_NET_F_CSUM | VIRTIO_NET_F_GUEST_CSUM;
+		mask |= VTNET_TSO_FEATURES | VTNET_LRO_FEATURES;
+	if (vtnet_tunable_int(sc, "tso_disable", vtnet_tso_disable))
+		mask |= VTNET_TSO_FEATURES;
+	if (vtnet_tunable_int(sc, "lro_disable", vtnet_lro_disable))
+		mask |= VTNET_LRO_FEATURES;
+	if (vtnet_tunable_int(sc, "mq_disable", vtnet_mq_disable))
+		mask |= VIRTIO_NET_F_MQ;
+#endif
+#endif
+	features = VTNET_FEATURES & ~mask;
+	sc->vtnet_features = virtio_negotiate_features(dev, features);
+	if (virtio_with_feature(dev, VTNET_LRO_FEATURES) == 0)
+		return;
+	if (virtio_with_feature(dev, VIRTIO_NET_F_MRG_RXBUF))
+		return;
+#ifdef NOTUSED
+	 * LRO without mergeable buffers requires special care. This is not
+	 * ideal because every receive buffer must be large enough to hold
+	 * the maximum TCP packet, the Ethernet header, and the header. This
+	 * requires up to 34 descriptors with MCLBYTES clusters. If we do
+	 * not have indirect descriptors, LRO is disabled since the
virtqueue
+	 * will not contain very many receive buffers.
+	if (virtio_with_feature(dev, VIRTIO_RING_F_INDIRECT_DESC) == 0) {
+		    "LRO disabled due to both mergeable buffers and indirect
+		    "descriptors not negotiated\n");
+		features &= ~VTNET_LRO_FEATURES;
features);
+	} else
+		sc->vtnet_flags |= VTNET_FLAG_LRO_NOMRG;
+#endif
+static void
+vtnet_setup_features(struct vtnet_softc *sc)
+	device_t dev;
+	int max_pairs, max;
+	vtnet_negotiate_features(sc);
+	if (virtio_with_feature(dev, VIRTIO_RING_F_EVENT_IDX))
+		sc->vtnet_flags |= VTNET_FLAG_EVENT_IDX;
+	if (virtio_with_feature(dev, VIRTIO_NET_F_MAC)) {
+		/* This feature should always be negotiated. */
+		sc->vtnet_flags |= VTNET_FLAG_MAC;
+	if (virtio_with_feature(dev, VIRTIO_NET_F_MRG_RXBUF)) {
+		sc->vtnet_flags |= VTNET_FLAG_MRG_RXBUFS;
+		sc->vtnet_hdr_size = sizeof(struct
virtio_net_hdr_mrg_rxbuf);
+	} else
+		sc->vtnet_hdr_size = sizeof(struct virtio_net_hdr);
+	if (virtio_with_feature(dev, VIRTIO_NET_F_CTRL_VQ)) {
+		sc->vtnet_flags |= VTNET_FLAG_CTRL_VQ;
+		if (virtio_with_feature(dev, VIRTIO_NET_F_CTRL_RX))
+			sc->vtnet_flags |= VTNET_FLAG_CTRL_RX;
+		if (virtio_with_feature(dev, VIRTIO_NET_F_CTRL_VLAN))
+			sc->vtnet_flags |= VTNET_FLAG_VLAN_FILTER;
+		if (virtio_with_feature(dev, VIRTIO_NET_F_CTRL_MAC_ADDR))
+			sc->vtnet_flags |= VTNET_FLAG_CTRL_MAC;
+	if (virtio_with_feature(dev, VIRTIO_NET_F_MQ) &&
+	    sc->vtnet_flags & VTNET_FLAG_CTRL_VQ) {
+		max_pairs = virtio_read_dev_config_2(dev,
+		    offsetof(struct virtio_net_config,
max_virtqueue_pairs));
+		if (max_pairs < VIRTIO_NET_CTRL_MQ_VQ_PAIRS_MIN ||
+		    max_pairs > VIRTIO_NET_CTRL_MQ_VQ_PAIRS_MAX)
+			max_pairs = 1;
+	} else
+		max_pairs = 1;
+#ifdef NOTUSED
+	if (max_pairs > 1) {
+		 * Limit the maximum number of queue pairs to the number of
+		 * CPUs or the configured maximum. The actual number of
+		 * queues that get used may be less.
+		max = vtnet_tunable_int(sc, "mq_max_pairs",
+		if (max > 0 && max_pairs > max)
+			max_pairs = max;
+		if (max_pairs > mp_ncpus)
+			max_pairs = mp_ncpus;
+		if (max_pairs > VTNET_MAX_QUEUE_PAIRS)
+			max_pairs = VTNET_MAX_QUEUE_PAIRS;
+			sc->vtnet_flags |= VTNET_FLAG_MULTIQ;
+#endif
+	sc->vtnet_max_vq_pairs = max_pairs;
+static int
+vtnet_init_rxq(struct vtnet_softc *sc, int id)
+	struct vtnet_rxq *rxq;
+	rxq = &sc->vtnet_rxqs[id];
+	snprintf(rxq->vtnrx_name, sizeof(rxq->vtnrx_name), "%s-rx%d",
+	    device_get_nameunit(sc->vtnet_dev), id);
+	mtx_init(&rxq->vtnrx_mtx, rxq->vtnrx_name, NULL, MTX_DEF);
+	rxq->vtnrx_sc = sc;
+	rxq->vtnrx_id = id;
+#ifdef NOTUSED
+	TASK_INIT(&rxq->vtnrx_intrtask, 0, vtnet_rxq_tq_intr, rxq);
+	rxq->vtnrx_tq = taskqueue_create(rxq->vtnrx_name, M_NOWAIT,
+	    taskqueue_thread_enqueue, &rxq->vtnrx_tq);
+	return (rxq->vtnrx_tq == NULL ? ENOMEM : 0);
+#endif
+	return (0);
+static int
+vtnet_init_txq(struct vtnet_softc *sc, int id)
+	struct vtnet_txq *txq;
+	txq = &sc->vtnet_txqs[id];
+	snprintf(txq->vtntx_name, sizeof(txq->vtntx_name), "%s-tx%d",
+	mtx_init(&txq->vtntx_mtx, txq->vtntx_name, NULL, MTX_DEF);
+	txq->vtntx_sc = sc;
+	txq->vtntx_id = id;
+	txq->vtntx_br = buf_ring_alloc(VTNET_DEFAULT_BUFRING_SIZE, M_DEVBUF,
+	    M_NOWAIT, &txq->vtntx_mtx);
+	if (txq->vtntx_br == NULL)
+		return (ENOMEM);
+	TASK_INIT(&txq->vtntx_defrtask, 0, vtnet_txq_tq_deferred, txq);
+#endif
+#ifdef NOTUSED
+	TASK_INIT(&txq->vtntx_intrtask, 0, vtnet_txq_tq_intr, txq);
+	txq->vtntx_tq = taskqueue_create(txq->vtntx_name, M_NOWAIT,
+	    taskqueue_thread_enqueue, &txq->vtntx_tq);
+	if (txq->vtntx_tq == NULL)
+		return (ENOMEM);
+#endif
+	return (0);
+static int
+vtnet_alloc_rxtx_queues(struct vtnet_softc *sc)
+	int i, npairs, error;
+	npairs = sc->vtnet_max_vq_pairs;
+	sc->vtnet_rxqs = malloc(sizeof(struct vtnet_rxq) * npairs, M_DEVBUF,
+	    M_NOWAIT | M_ZERO);
+	sc->vtnet_txqs = malloc(sizeof(struct vtnet_txq) * npairs, M_DEVBUF,
+	if (sc->vtnet_rxqs == NULL || sc->vtnet_txqs == NULL)
+		return (ENOMEM);
+	for (i = 0; i < npairs; i++) {
+		error = vtnet_init_rxq(sc, i);
+		if (error)
+			return (error);
+		error = vtnet_init_txq(sc, i);
+		if (error)
+			return (error);
+#ifdef NOTUSED
+	vtnet_setup_queue_sysctl(sc);
+#endif
+	return (0);
+static void
+vtnet_destroy_rxq(struct vtnet_rxq *rxq)
+	rxq->vtnrx_sc = NULL;
+	rxq->vtnrx_id = -1;
+	if (mtx_initialized(&rxq->vtnrx_mtx) != 0)
+		mtx_destroy(&rxq->vtnrx_mtx);
+static void
+vtnet_destroy_txq(struct vtnet_txq *txq)
+	txq->vtntx_sc = NULL;
+	txq->vtntx_id = -1;
+	if (txq->vtntx_br != NULL) {
+		buf_ring_free(txq->vtntx_br, M_DEVBUF);
+		txq->vtntx_br = NULL;
+#endif
+	if (mtx_initialized(&txq->vtntx_mtx) != 0)
+		mtx_destroy(&txq->vtntx_mtx);
+static void
+vtnet_free_rxtx_queues(struct vtnet_softc *sc)
+	int i;
+	if (sc->vtnet_rxqs != NULL) {
+		for (i = 0; i < sc->vtnet_max_vq_pairs; i++)
+			vtnet_destroy_rxq(&sc->vtnet_rxqs[i]);
+		free(sc->vtnet_rxqs, M_DEVBUF);
+		sc->vtnet_rxqs = NULL;
+	if (sc->vtnet_txqs != NULL) {
+			vtnet_destroy_txq(&sc->vtnet_txqs[i]);
+		free(sc->vtnet_txqs, M_DEVBUF);
+		sc->vtnet_txqs = NULL;
+#ifdef NOTUSED
+static int
+vtnet_alloc_rx_filters(struct vtnet_softc *sc)
+	if (sc->vtnet_flags & VTNET_FLAG_CTRL_RX) {
+		sc->vtnet_mac_filter = malloc(sizeof(struct
vtnet_mac_filter),
+		    M_DEVBUF, M_NOWAIT | M_ZERO);
+		if (sc->vtnet_mac_filter == NULL)
+			return (ENOMEM);
+	if (sc->vtnet_flags & VTNET_FLAG_VLAN_FILTER) {
+		sc->vtnet_vlan_filter = malloc(sizeof(uint32_t) *
+		    VTNET_VLAN_FILTER_NWORDS, M_DEVBUF, M_NOWAIT | M_ZERO);
+		if (sc->vtnet_vlan_filter == NULL)
+			return (ENOMEM);
+	return (0);
+static void
+vtnet_free_rx_filters(struct vtnet_softc *sc)
+	if (sc->vtnet_mac_filter != NULL) {
+		free(sc->vtnet_mac_filter, M_DEVBUF);
+		sc->vtnet_mac_filter = NULL;
+	if (sc->vtnet_vlan_filter != NULL) {
+		free(sc->vtnet_vlan_filter, M_DEVBUF);
+		sc->vtnet_vlan_filter = NULL;
+#endif
+static int
+vtnet_alloc_virtqueues(struct vtnet_softc *sc)
+	device_t dev;
+	struct vq_alloc_info *info;
+	int i, idx, flags, nvqs, rxsegs, error;
+	flags = 0;
+	 * Indirect descriptors are not needed for the Rx virtqueue when
+	 * mergeable buffers are negotiated. The header is placed inline
+	 * with the data, not in a separate descriptor, and mbuf clusters
+	 * are always physically contiguous.
+	if (sc->vtnet_flags & VTNET_FLAG_MRG_RXBUFS)
+		rxsegs = 0;
+	else if (sc->vtnet_flags & VTNET_FLAG_LRO_NOMRG)
+		rxsegs = VTNET_MAX_RX_SEGS;
+	else
+		rxsegs = VTNET_MIN_RX_SEGS;
+	nvqs = sc->vtnet_max_vq_pairs * 2;
+	if (sc->vtnet_flags & VTNET_FLAG_CTRL_VQ)
+		nvqs++;
+	info = malloc(sizeof(struct vq_alloc_info) * nvqs , M_TEMP,
M_NOWAIT);
+	if (info == NULL)
+		return (ENOMEM);
+	for (i = 0, idx = 0; i < sc->vtnet_max_vq_pairs; i++, idx+=2) {
+		rxq = &sc->vtnet_rxqs[i];
+		VQ_ALLOC_INFO_INIT(&info[idx], rxsegs,
+		    vtnet_rx_vq_intr, rxq, &rxq->vtnrx_vq,
+		    "%s-%d rx", device_get_nameunit(dev), rxq->vtnrx_id);
+		txq = &sc->vtnet_txqs[i];
+		VQ_ALLOC_INFO_INIT(&info[idx+1], VTNET_MAX_TX_SEGS,
+		    vtnet_tx_vq_intr, txq, &txq->vtntx_vq,
+		    "%s-%d tx", device_get_nameunit(dev), txq->vtntx_id);
+	if (sc->vtnet_flags & VTNET_FLAG_CTRL_VQ) {
+		VQ_ALLOC_INFO_INIT(&info[idx], 0, NULL, NULL,
+		    &sc->vtnet_ctrl_vq, "%s ctrl",
device_get_nameunit(dev));
+	 * Enable interrupt binding if this is multiqueue. This only matters
+	 * when per-vq MSIX is available.
+	if (sc->vtnet_flags & VTNET_FLAG_MULTIQ)
+		flags |= 0;
+	error = virtio_alloc_virtqueues(dev, flags, nvqs, info);
+	free(info, M_TEMP);
+	return (error);
+static int
+vtnet_setup_interface(struct vtnet_softc *sc)
+	device_t dev;
+	int limit;
+#ifdef NOTUSED
+	ifp = sc->vtnet_ifp = if_alloc(IFT_ETHER);
+	if (ifp == NULL) {
+		device_printf(dev, "cannot allocate ifnet structure\n");
+		return (ENOSPC);
+	if_initname(ifp, device_get_name(dev), device_get_unit(dev));
+	if_initbaudrate(ifp, IF_Gbps(10));	/* Approx. */
+#endif
+	ifp = &sc->arpcom.ac_if;
+	sc->vtnet_ifp = ifp;
+#endif
+	ifp->if_softc = sc;
+	ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX | IFF_MULTICAST;
+	ifp->if_init = vtnet_init;
+	ifp->if_ioctl = vtnet_ioctl;
+#ifdef NOTUSED
+	ifp->if_transmit = vtnet_txq_mq_start;
+	ifp->if_qflush = vtnet_qflush;
+#else
+	struct virtqueue *vq = sc->vtnet_txqs[0].vtntx_vq;
+	ifp->if_start = vtnet_start;
+	IFQ_SET_MAXLEN(&ifp->if_snd, virtqueue_size(vq) - 1);
+	ifp->if_snd.ifq_drv_maxlen = virtqueue_size(vq) - 1;
+	IFQ_SET_READY(&ifp->if_snd);
+#endif
+	ifmedia_init(&sc->vtnet_media, IFM_IMASK, vtnet_ifmedia_upd,
+	    vtnet_ifmedia_sts);
+	ifmedia_add(&sc->vtnet_media, VTNET_MEDIATYPE, 0, NULL);
+	ifmedia_set(&sc->vtnet_media, VTNET_MEDIATYPE);
+#endif
+	/* Read (or generate) the MAC address for the adapter. */
+	vtnet_get_hwaddr(sc);
+	ifp->if_unit = sc->vtpci_softc->unit_number;
+	ifp->if_name = sc->vtpci_softc->unit_name;
+	ifp->if_mtu = sc->config->mtu ? sc->config->mtu : ETHERMTU;
+	ifp->if_output = ether_output;
+	if_attach(ifp);
+#endif
+	ether_ifattach(ifp);
+#ifdef NOTUSED
+	if (virtio_with_feature(dev, VIRTIO_NET_F_STATUS))
+		ifp->if_capabilities |= IFCAP_LINKSTATE;
+	/* Tell the upper layer(s) we support long frames. */
+	ifp->if_data.ifi_hdrlen = sizeof(struct ether_vlan_header);
+	ifp->if_capabilities |= IFCAP_JUMBO_MTU | IFCAP_VLAN_MTU;
+	if (virtio_with_feature(dev, VIRTIO_NET_F_CSUM)) {
+		ifp->if_capabilities |= IFCAP_TXCSUM | IFCAP_TXCSUM_IPV6;
+		if (virtio_with_feature(dev, VIRTIO_NET_F_GSO)) {
+			ifp->if_capabilities |= IFCAP_TSO4 | IFCAP_TSO6;
+			sc->vtnet_flags |= VTNET_FLAG_TSO_ECN;
+		} else {
VIRTIO_NET_F_HOST_TSO4))
+				ifp->if_capabilities |= IFCAP_TSO4;
VIRTIO_NET_F_HOST_TSO6))
+				ifp->if_capabilities |= IFCAP_TSO6;
+			if (virtio_with_feature(dev, VIRTIO_NET_F_HOST_ECN))
+		if (ifp->if_capabilities & IFCAP_TSO)
+			ifp->if_capabilities |= IFCAP_VLAN_HWTSO;
+	if (virtio_with_feature(dev, VIRTIO_NET_F_GUEST_CSUM))
+		ifp->if_capabilities |= IFCAP_RXCSUM | IFCAP_RXCSUM_IPV6;
+	if (ifp->if_capabilities & IFCAP_HWCSUM) {
+		 * VirtIO does not support VLAN tagging, but we can fake
+		 * it by inserting and removing the 802.1Q header during
+		 * transmit and receive. We are then able to do checksum
+		 * offloading of VLAN frames.
+		    IFCAP_VLAN_HWTAGGING | IFCAP_VLAN_HWCSUM;
+	ifp->if_capenable = ifp->if_capabilities;
+	 * Capabilities after here are not enabled by default.
+	if (ifp->if_capabilities & IFCAP_RXCSUM) {
+		if (virtio_with_feature(dev, VIRTIO_NET_F_GUEST_TSO4) ||
+		    virtio_with_feature(dev, VIRTIO_NET_F_GUEST_TSO6))
+			ifp->if_capabilities |= IFCAP_LRO;
+		ifp->if_capabilities |= IFCAP_VLAN_HWFILTER;
+		sc->vtnet_vlan_attach = EVENTHANDLER_REGISTER(vlan_config,
+		    vtnet_register_vlan, sc, EVENTHANDLER_PRI_FIRST);
+		sc->vtnet_vlan_detach = EVENTHANDLER_REGISTER(vlan_unconfig,
+		    vtnet_unregister_vlan, sc, EVENTHANDLER_PRI_FIRST);
+	limit = vtnet_tunable_int(sc, "rx_process_limit",
+	    vtnet_rx_process_limit);
+	if (limit < 0)
+		limit = INT_MAX;
+	sc->vtnet_rx_process_limit = limit;
+#endif
+	return (0);
+#ifdef NOTUSED
+static int
+vtnet_change_mtu(struct vtnet_softc *sc, int new_mtu)
+	int frame_size, clsize;
+	if (new_mtu < ETHERMIN || new_mtu > VTNET_MAX_MTU)
+		return (EINVAL);
+	frame_size = sc->vtnet_hdr_size + sizeof(struct ether_vlan_header) +
+	    new_mtu;
+	 * Based on the new MTU (and hence frame size) determine which
+	 * cluster size is most appropriate for the receive queues.
+	if (frame_size <= MCLBYTES) {
+		clsize = MCLBYTES;
+	} else if ((sc->vtnet_flags & VTNET_FLAG_MRG_RXBUFS) == 0) {
+		/* Avoid going past 9K jumbos. */
+		if (frame_size > MJUM9BYTES)
+			return (EINVAL);
+		clsize = MJUM9BYTES;
+	} else
+		clsize = MJUMPAGESIZE;
+	ifp->if_mtu = new_mtu;
+	sc->vtnet_rx_new_clsize = clsize;
+	if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+		ifp->if_drv_flags &= ~IFF_DRV_RUNNING;
+	return (0);
+#endif
+static int
+vtnet_ioctl(struct ifnet *ifp, u_long cmd, caddr_t data)
+	struct ifreq *ifr;
+	int reinit, mask, error;
+	sc = ifp->if_softc;
+	ifr = (struct ifreq *) data;
+	error = 0;
+	switch (cmd) {
+#ifdef NOTUSED
+	case SIOCSIFMTU:
+		if (ifp->if_mtu != ifr->ifr_mtu) {
+			error = vtnet_change_mtu(sc, ifr->ifr_mtu);
+		break;
+#endif
+	case SIOCSIFFLAGS:
+		if ((ifp->if_flags & IFF_UP) == 0) {
+			if (ifp->if_drv_flags & IFF_DRV_RUNNING){
+				vtnet_stop(sc);
+#ifdef NOTUSED
+		} else if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+			if ((ifp->if_flags ^ sc->vtnet_if_flags) &
+			    (IFF_PROMISC | IFF_ALLMULTI)) {
+					vtnet_rx_filter(sc);
+				else
+					error = ENOTSUP;
+#endif
+		} else{
+		if (error == 0)
+			sc->vtnet_if_flags = ifp->if_flags;
+		break;
+#ifdef NOTUSED
+	case SIOCADDMULTI:
+	case SIOCDELMULTI:
+		if ((sc->vtnet_flags & VTNET_FLAG_CTRL_RX) == 0)
+			break;
+			vtnet_rx_filter_mac(sc);
+		break;
+	case SIOCSIFMEDIA:
+	case SIOCGIFMEDIA:
+		error = ifmedia_ioctl(ifp, ifr, &sc->vtnet_media, cmd);
+		break;
+	case SIOCSIFCAP:
+		mask = ifr->ifr_reqcap ^ ifp->if_capenable;
+		if (mask & IFCAP_TXCSUM)
+			ifp->if_capenable ^= IFCAP_TXCSUM;
+		if (mask & IFCAP_TXCSUM_IPV6)
+			ifp->if_capenable ^= IFCAP_TXCSUM_IPV6;
+		if (mask & IFCAP_TSO4)
+			ifp->if_capenable ^= IFCAP_TSO4;
+		if (mask & IFCAP_TSO6)
+			ifp->if_capenable ^= IFCAP_TSO6;
+		if (mask & (IFCAP_RXCSUM | IFCAP_RXCSUM_IPV6 | IFCAP_LRO |
+		    IFCAP_VLAN_HWFILTER)) {
+			/* These Rx features require us to renegotiate. */
+			reinit = 1;
+			if (mask & IFCAP_RXCSUM)
+				ifp->if_capenable ^= IFCAP_RXCSUM;
+			if (mask & IFCAP_RXCSUM_IPV6)
+				ifp->if_capenable ^= IFCAP_RXCSUM_IPV6;
+			if (mask & IFCAP_LRO)
+				ifp->if_capenable ^= IFCAP_LRO;
+			if (mask & IFCAP_VLAN_HWFILTER)
+				ifp->if_capenable ^= IFCAP_VLAN_HWFILTER;
+		} else
+			reinit = 0;
+		if (mask & IFCAP_VLAN_HWTSO)
+			ifp->if_capenable ^= IFCAP_VLAN_HWTSO;
+		if (mask & IFCAP_VLAN_HWTAGGING)
+			ifp->if_capenable ^= IFCAP_VLAN_HWTAGGING;
+		if (reinit && (ifp->if_drv_flags & IFF_DRV_RUNNING)) {
+		VLAN_CAPABILITIES(ifp);
+		break;
+#endif
+	default:
+		error = ether_ioctl(ifp, cmd, data);
+		break;
+	VTNET_CORE_LOCK_ASSERT_NOTOWNED(sc);
+	return (error);
+static int
+vtnet_rxq_populate(struct vtnet_rxq *rxq)
+	struct virtqueue *vq;
+	int nbufs, error;
+	vq = rxq->vtnrx_vq;
+	error = ENOSPC;
+	for (nbufs = 0; !virtqueue_full(vq); nbufs++) {
+		error = vtnet_rxq_new_buf(rxq);
+		if (error)
+			break;
+	if (nbufs > 0) {
+		virtqueue_notify(vq);
+		 * EMSGSIZE signifies the virtqueue did not have enough
+		 * entries available to hold the last mbuf. This is not
+		 * an error.
+		if (error == EMSGSIZE)
+			error = 0;
+	return (error);
+static void
+vtnet_rxq_free_mbufs(struct vtnet_rxq *rxq)
+	struct mbuf *m;
+	int last;
+	last = 0;
+	while ((m = virtqueue_drain(vq, &last)) != NULL)
+		m_freem(m);
+	KASSERT(virtqueue_empty(vq),
+	    ("%s: mbufs remaining in rx queue %p", __func__, rxq));
+vtnet_rx_alloc_buf(struct vtnet_softc *sc, int nbufs, struct mbuf
**m_tailp)
+	struct mbuf *m_head, *m_tail, *m;
+	int i, clsize;
+	clsize = sc->vtnet_rx_clsize;
+	KASSERT(nbufs == 1 || sc->vtnet_flags & VTNET_FLAG_LRO_NOMRG,
+	    ("%s: chained mbuf %d request without LRO_NOMRG", __func__,
nbufs));
+#ifdef NOTUSED
+	m_head = m_getjcl(M_NOWAIT, MT_DATA, M_PKTHDR, clsize);
+#endif
+	m_head = m_gethdr(M_NOWAIT, MT_DATA);
+	if (m_head == NULL)
+		goto fail;
+	MCLGET(m_head, M_NOWAIT);
+#endif
+	m_head->m_len = clsize;
+	m_tail = m_head;
+	/* Allocate the rest of the chain. */
+	for (i = 1; i < nbufs; i++) {
+#ifdef NOTUSED
+		m = m_getjcl(M_NOWAIT, MT_DATA, 0, clsize);
+#endif
+		m = m_gethdr(M_NOWAIT, MT_DATA);
+		if (m == NULL)
+			goto fail;
+#endif
+		m->m_len = clsize;
+		m_tail->m_next = m;
+		m_tail = m;
+	if (m_tailp != NULL)
+		*m_tailp = m_tail;
+	return (m_head);
+fail:
+	sc->vtnet_stats.mbuf_alloc_failed++;
+	m_freem(m_head);
+	return (NULL);
+ * Slow path for when LRO without mergeable buffers is negotiated.
+static int
+vtnet_rxq_replace_lro_nomgr_buf(struct vtnet_rxq *rxq, struct mbuf *m0,
+    int len0)
+	struct mbuf *m, *m_prev;
+	struct mbuf *m_new, *m_tail;
+	int len, clsize, nreplace, error;
+	sc = rxq->vtnrx_sc;
+	m_prev = NULL;
+	m_tail = NULL;
+	nreplace = 0;
+	m = m0;
+	len = len0;
+	 * Since these mbuf chains are so large, we avoid allocating an
+	 * entire replacement chain if possible. When the received frame
+	 * did not consume the entire chain, the unused mbufs are moved
+	 * to the replacement chain.
+	while (len > 0) {
+		 * Something is seriously wrong if we received a frame
+		 * larger than the chain. Drop it.
+		if (m == NULL) {
+			sc->vtnet_stats.rx_frame_too_large++;
+			return (EMSGSIZE);
+		/* We always allocate the same cluster size. */
+		KASSERT(m->m_len == clsize,
+		    ("%s: mbuf size %d is not the cluster size %d",
+		    __func__, m->m_len, clsize));
+		m->m_len = MIN(m->m_len, len);
+		len -= m->m_len;
+		m_prev = m;
+		m = m->m_next;
+		nreplace++;
+	KASSERT(nreplace <= sc->vtnet_rx_nmbufs,
+	    ("%s: too many replacement mbufs %d max %d", __func__, nreplace,
+	    sc->vtnet_rx_nmbufs));
+	m_new = vtnet_rx_alloc_buf(sc, nreplace, &m_tail);
+	if (m_new == NULL) {
+		m_prev->m_len = clsize;
+		return (ENOBUFS);
+	 * Move any unused mbufs from the received chain onto the end
+	 * of the new chain.
+	if (m_prev->m_next != NULL) {
+		m_tail->m_next = m_prev->m_next;
+		m_prev->m_next = NULL;
+	error = vtnet_rxq_enqueue_buf(rxq, m_new);
+	if (error) {
+		 * BAD! We could not enqueue the replacement mbuf chain. We
+		 * must restore the m0 chain to the original state if it was
+		 * modified so we can subsequently discard it.
+		 * NOTE: The replacement is suppose to be an identical copy
+		 * to the one just dequeued so this is an unexpected error.
+		sc->vtnet_stats.rx_enq_replacement_failed++;
+		if (m_tail->m_next != NULL) {
+			m_prev->m_next = m_tail->m_next;
+			m_tail->m_next = NULL;
+		m_freem(m_new);
+	return (error);
+static int
+vtnet_rxq_replace_buf(struct vtnet_rxq *rxq, struct mbuf *m, int len)
+	struct mbuf *m_new;
+	int error;
+	KASSERT(sc->vtnet_flags & VTNET_FLAG_LRO_NOMRG || m->m_next == NULL,
+	    ("%s: chained mbuf without LRO_NOMRG", __func__));
+	if (m->m_next == NULL) {
+		/* Fast-path for the common case of just one mbuf. */
+		if (m->m_len < len)
+			return (EINVAL);
+		m_new = vtnet_rx_alloc_buf(sc, 1, NULL);
+			return (ENOBUFS);
+		if (error) {
+			 * The new mbuf is suppose to be an identical
+			 * copy of the one just dequeued so this is an
+			 * unexpected error.
+			m_freem(m_new);
+		} else
+			m->m_len = len;
+	} else
+		error = vtnet_rxq_replace_lro_nomgr_buf(rxq, m, len);
+	return (error);
+static int
+vtnet_rxq_enqueue_buf(struct vtnet_rxq *rxq, struct mbuf *m)
+#ifdef NOTUSED
+	struct sglist sg;
+	struct sglist_seg segs[VTNET_MAX_RX_SEGS];
+	struct vtnet_rx_header *rxhdr;
+	uint8_t *mdata;
+	int offset, error, nsegs;
+	mdata = mtod(m, uint8_t *);
+	VTNET_RXQ_LOCK_ASSERT(rxq);
+	KASSERT(m->m_len == sc->vtnet_rx_clsize,
+	    ("%s: unexpected cluster size %d/%d", __func__, m->m_len,
+	     sc->vtnet_rx_clsize));
+	sglist_init(&sg, VTNET_MAX_RX_SEGS, segs);
+	if ((sc->vtnet_flags & VTNET_FLAG_MRG_RXBUFS) == 0) {
+		MPASS(sc->vtnet_hdr_size == sizeof(struct virtio_net_hdr));
+		rxhdr = (struct vtnet_rx_header *) mdata;
+		sglist_append(&sg, &rxhdr->vrh_hdr, sc->vtnet_hdr_size);
+		offset = sizeof(struct vtnet_rx_header);
+	} else
+		offset = 0;
+	sglist_append(&sg, mdata + offset, m->m_len - offset);
+	if (m->m_next != NULL) {
+		error = sglist_append_mbuf(&sg, m->m_next);
+		MPASS(error == 0);
+	error = virtqueue_enqueue(rxq->vtnrx_vq, m, &sg, 0, sg.sg_nsegs);
+#endif
+	struct mbuf *m_rxhdr;
+	int error, nsegs;
+	nsegs = 0;
+		MGET(m_rxhdr, M_DONTWAIT, MT_DATA);
+		if( m_rxhdr == NULL ){
+			m_freem(m);
+			m_freem(m_rxhdr);
+			return ENOBUFS;
+		memcpy(m_rxhdr->m_data, mtod(m, uint8_t *),
+		m_adj(m, sc->vtnet_hdr_size);
+		m_rxhdr->m_len = sc->vtnet_hdr_size;
+		m_rxhdr->m_next = m;
+	else{
+		m_rxhdr = m;
+	for( m=m_rxhdr ; m!=NULL ; m=m->m_next )
+		nsegs++;
+	error = rtems_virtqueue_enqueue(rxq->vtnrx_vq, m_rxhdr, 0, nsegs);
+#endif
+	return (error);
+static int
+vtnet_rxq_new_buf(struct vtnet_rxq *rxq)
+	struct mbuf *m;
+	int error;
+	m = vtnet_rx_alloc_buf(sc, sc->vtnet_rx_nmbufs, NULL);
+	if (m == NULL)
+		return (ENOBUFS);
+	error = vtnet_rxq_enqueue_buf(rxq, m);
+	if (error)
+		m_freem(m);
+	return (error);
+#ifdef NOTUSED
+ * Use the checksum offset in the VirtIO header to set the
+ * correct CSUM_* flags.
+static int
+vtnet_rxq_csum_by_offset(struct vtnet_rxq *rxq, struct mbuf *m,
+    uint16_t eth_type, int ip_start, struct virtio_net_hdr *hdr)
+#if defined(INET) || defined(INET6)
+	int offset = hdr->csum_start + hdr->csum_offset;
+#endif
+	/* Only do a basic sanity check on the offset. */
+	switch (eth_type) {
+#if defined(INET)
+	case ETHERTYPE_IP:
+		if (__predict_false(offset < ip_start + sizeof(struct ip)))
+			return (1);
+		break;
+#endif
+#if defined(INET6)
+	case ETHERTYPE_IPV6:
ip6_hdr)))
+			return (1);
+		break;
+#endif
+	default:
+		sc->vtnet_stats.rx_csum_bad_ethtype++;
+		return (1);
+	 * Use the offset to determine the appropriate CSUM_* flags. This is
+	 * a bit dirty, but we can get by with it since the checksum offsets
+	 * happen to be different. We assume the host host does not do IPv4
+	 * header checksum offloading.
+	switch (hdr->csum_offset) {
+	case offsetof(struct udphdr, uh_sum):
+	case offsetof(struct tcphdr, th_sum):
+		m->m_pkthdr.csum_flags |= CSUM_DATA_VALID | CSUM_PSEUDO_HDR;
+		m->m_pkthdr.csum_data = 0xFFFF;
+		break;
+	case offsetof(struct sctphdr, checksum):
+		m->m_pkthdr.csum_flags |= CSUM_SCTP_VALID;
+		break;
+	default:
+		sc->vtnet_stats.rx_csum_bad_offset++;
+		return (1);
+	return (0);
+static int
+vtnet_rxq_csum_by_parse(struct vtnet_rxq *rxq, struct mbuf *m,
+	int offset, proto;
+#if defined(INET)
+	case ETHERTYPE_IP: {
+		struct ip *ip;
+		if (__predict_false(m->m_len < ip_start + sizeof(struct
ip)))
+			return (1);
+		ip = (struct ip *)(m->m_data + ip_start);
+		proto = ip->ip_p;
+		offset = ip_start + (ip->ip_hl << 2);
+		break;
+#endif
+#if defined(INET6)
+		    sizeof(struct ip6_hdr)))
+			return (1);
+		offset = ip6_lasthdr(m, ip_start, IPPROTO_IPV6, &proto);
+		if (__predict_false(offset < 0))
+			return (1);
+		break;
+#endif
+	default:
+		return (1);
+	switch (proto) {
+	case IPPROTO_TCP:
+		if (__predict_false(m->m_len < offset + sizeof(struct
tcphdr)))
+			return (1);
+		break;
+	case IPPROTO_UDP:
udphdr)))
+			return (1);
+		break;
+	case IPPROTO_SCTP:
sctphdr)))
+			return (1);
+		break;
+	default:
+		 * For the remaining protocols, FreeBSD does not support
+		 * checksum offloading, so the checksum will be recomputed.
+#if 0
+		if_printf(sc->vtnet_ifp, "cksum offload of unsupported "
+		    "protocol eth_type=%#x proto=%d csum_start=%d "
+		    "csum_offset=%d\n", __func__, eth_type, proto,
+		    hdr->csum_start, hdr->csum_offset);
+#endif
+		break;
+	return (0);
+ * Set the appropriate CSUM_* flags. Unfortunately, the information
+ * provided is not directly useful to us. The VirtIO header gives the
+ * offset of the checksum, which is all Linux needs, but this is not
+ * how FreeBSD does things. We are forced to peek inside the packet
+ * a bit.
+ * It would be nice if VirtIO gave us the L4 protocol or if FreeBSD
+ * could accept the offsets and let the stack figure it out.
+static int
+vtnet_rxq_csum(struct vtnet_rxq *rxq, struct mbuf *m,
+    struct virtio_net_hdr *hdr)
+	struct ether_header *eh;
+	struct ether_vlan_header *evh;
+	uint16_t eth_type;
+	int offset, error;
+	eh = mtod(m, struct ether_header *);
+	eth_type = ntohs(eh->ether_type);
+	if (eth_type == ETHERTYPE_VLAN) {
+		/* BMV: We should handle nested VLAN tags too. */
+		evh = mtod(m, struct ether_vlan_header *);
+		eth_type = ntohs(evh->evl_proto);
+		offset = sizeof(struct ether_vlan_header);
+	} else
+		offset = sizeof(struct ether_header);
+	if (hdr->flags & VIRTIO_NET_HDR_F_NEEDS_CSUM)
+		error = vtnet_rxq_csum_by_offset(rxq, m, eth_type, offset,
hdr);
+	else
+		error = vtnet_rxq_csum_by_parse(rxq, m, eth_type, offset,
hdr);
+	return (error);
+#endif
+static void
+vtnet_rxq_discard_merged_bufs(struct vtnet_rxq *rxq, int nbufs)
+	struct mbuf *m;
+	while (--nbufs > 0) {
+		m = virtqueue_dequeue(rxq->vtnrx_vq, NULL);
+		if (m == NULL)
+			break;
+		vtnet_rxq_discard_buf(rxq, m);
+static void
+vtnet_rxq_discard_buf(struct vtnet_rxq *rxq, struct mbuf *m)
+	int error;
+	 * Requeue the discarded mbuf. This should always be successful
+	 * since it was just dequeued.
+	KASSERT(error == 0,
+	    ("%s: cannot requeue discarded mbuf %d", __func__, error));
+static int
+vtnet_rxq_merged_eof(struct vtnet_rxq *rxq, struct mbuf *m_head, int nbufs)
+	struct mbuf *m, *m_tail;
+#ifdef NOTUSED
+	int len;
+#endif
+	uint32_t len;
+#endif
+	m_tail = m_head;
+		m = virtqueue_dequeue(vq, &len);
+		if (m == NULL) {
+			rxq->vtnrx_stats.vrxs_ierrors++;
+			goto fail;
+		if (vtnet_rxq_new_buf(rxq) != 0) {
+			rxq->vtnrx_stats.vrxs_iqdrops++;
+			if (nbufs > 1)
+				vtnet_rxq_discard_merged_bufs(rxq, nbufs);
+			goto fail;
+			len = m->m_len;
+		m->m_len = len;
+		m->m_flags &= ~M_PKTHDR;
+		m_head->m_pkthdr.len += len;
+		m_tail = m;
+	return (0);
+fail:
+	sc->vtnet_stats.rx_mergeable_failed++;
+	m_freem(m_head);
+	return (1);
+static void
+vtnet_rxq_input(struct vtnet_rxq *rxq, struct mbuf *m,
+#ifdef NOTUSED
+	if (ifp->if_capenable & IFCAP_VLAN_HWTAGGING) {
+		if (eh->ether_type == htons(ETHERTYPE_VLAN)) {
+			vtnet_vlan_tag_remove(m);
+			 * With the 802.1Q header removed, update the
+			 * checksum starting location accordingly.
+				hdr->csum_start -= ETHER_VLAN_ENCAP_LEN;
+	m->m_pkthdr.flowid = rxq->vtnrx_id;
+	m->m_flags |= M_FLOWID;
+	 * BMV: FreeBSD does not have the UNNECESSARY and PARTIAL checksum
+	 * distinction that Linux does. Need to reevaluate if performing
+	 * offloading for the NEEDS_CSUM case is really appropriate.
+	if (hdr->flags & (VIRTIO_NET_HDR_F_NEEDS_CSUM |
+	    VIRTIO_NET_HDR_F_DATA_VALID)) {
+		if (vtnet_rxq_csum(rxq, m, hdr) == 0)
+			rxq->vtnrx_stats.vrxs_csum++;
+		else
+			rxq->vtnrx_stats.vrxs_csum_failed++;
+#endif
+	rxq->vtnrx_stats.vrxs_ipackets++;
+	rxq->vtnrx_stats.vrxs_ibytes += m->m_pkthdr.len;
+#ifdef NOTUSED
+	VTNET_RXQ_UNLOCK(rxq);
+	(*ifp->if_input)(ifp, m);
+	VTNET_RXQ_LOCK(rxq);
+#endif
+    m_adj( m, sizeof( struct ether_header ) );
+	ether_input(ifp, eh, m);
+#endif
+static int
+vtnet_rxq_eof(struct vtnet_rxq *rxq)
+	struct virtio_net_hdr lhdr, *hdr;
+	struct mbuf *m;
+	struct virtio_net_hdr_mrg_rxbuf *mhdr;
+#ifdef NOTUSED
+	int len, deq, nbufs, adjsz, count;
+#endif
+	uint32_t len;
+	int deq, nbufs, adjsz, count;
+#endif
+	hdr = &lhdr;
+	deq = 0;
+	count = sc->vtnet_rx_process_limit;
+	while (count-- > 0) {
+		if (m == NULL)
+			break;
+		deq++;
+		if (len < sc->vtnet_hdr_size + ETHER_HDR_LEN) {
+			continue;
+			nbufs = 1;
+			adjsz = sizeof(struct vtnet_rx_header);
+			 * Account for our pad inserted between the header
+			 * and the actual start of the frame.
+			len += VTNET_RX_HEADER_PAD;
+		} else {
+			mhdr = mtod(m, struct virtio_net_hdr_mrg_rxbuf *);
+			nbufs = mhdr->num_buffers;
+			adjsz = sizeof(struct virtio_net_hdr_mrg_rxbuf);
+		if (vtnet_rxq_replace_buf(rxq, m, len) != 0) {
+			if (nbufs > 1)
+			continue;
+		m->m_pkthdr.len = len;
+		m->m_pkthdr.rcvif = ifp;
+#ifdef NOTUSED
+		m->m_pkthdr.csum_flags = 0;
+#endif
+		if (nbufs > 1) {
+			/* Dequeue the rest of chain. */
+			if (vtnet_rxq_merged_eof(rxq, m, nbufs) != 0)
+				continue;
+		 * Save copy of header before we strip it. For both
mergeable
+		 * and non-mergeable, the header is at the beginning of the
+		 * mbuf data. We no longer need num_buffers, so always use a
+		 * regular header.
+		 * BMV: Is this memcpy() expensive? We know the mbuf data is
+		 * still valid even after the m_adj().
+		memcpy(hdr, mtod(m, void *), sizeof(struct virtio_net_hdr));
+		m_adj(m, adjsz);
+		vtnet_rxq_input(rxq, m, hdr);
+		/* Must recheck after dropping the Rx lock. */
+		if ((ifp->if_drv_flags & IFF_DRV_RUNNING) == 0)
+			break;
+	if (deq > 0)
+	return (count > 0 ? 0 : EAGAIN);
+static void
+vtnet_rx_vq_intr(void *xrxq)
+	int tries, more;
+	rxq = xrxq;
+	tries = 0;
+	if (__predict_false(rxq->vtnrx_id >= sc->vtnet_act_vq_pairs)) {
+		 * Ignore this interrupt. Either this is a spurious
interrupt
+		 * or multiqueue without per-VQ MSIX so every queue needs to
+		 * be polled (a brain dead configuration we could try harder
+		 * to avoid).
+		vtnet_rxq_disable_intr(rxq);
+		return;
+again:
+	if ((ifp->if_drv_flags & IFF_DRV_RUNNING) == 0) {
+		return;
+	more = vtnet_rxq_eof(rxq);
+	if (more || vtnet_rxq_enable_intr(rxq) != 0) {
+		if (!more)
+		 * This is an occasional condition or race (when !more),
+		 * so retry a few times before scheduling the taskqueue.
+		rxq->vtnrx_stats.vrxs_rescheduled++;
+		if (tries++ < VTNET_INTR_DISABLE_RETRIES)
+			goto again;
+#ifdef NOTUSED
+		taskqueue_enqueue(rxq->vtnrx_tq, &rxq->vtnrx_intrtask);
+#endif
+	} else
+#ifdef NOTUSED
+static void
+vtnet_rxq_tq_intr(void *xrxq, int pending)
+	int more;
+	rxq = xrxq;
+		return;
+		if (!more)
+#endif
+static void
+vtnet_txq_free_mbufs(struct vtnet_txq *txq)
+	struct mbuf *m_txhdr;
+	int last;
+	vq = txq->vtntx_vq;
+	last = 0;
+#ifdef NOTUSED
+	while ((txhdr = virtqueue_drain(vq, &last)) != NULL) {
+		m_freem(txhdr->vth_mbuf);
+		uma_zfree(vtnet_tx_header_zone, txhdr);
+#endif
+	while ((m_txhdr = virtqueue_drain(vq, &last)) != NULL) {
+		m_freem(m_txhdr);
+#endif
+	    ("%s: mbufs remaining in tx queue %p", __func__, txq));
+#ifdef NOTUSED
+ * BMV: Much of this can go away once we finally have offsets in
+ * the mbuf packet header. Bug andre at .
+static int
+vtnet_txq_offload_ctx(struct vtnet_txq *txq, struct mbuf *m,
+    int *etype, int *proto, int *start)
+	int offset;
+	sc = txq->vtntx_sc;
+	if (evh->evl_encap_proto == htons(ETHERTYPE_VLAN)) {
+		*etype = ntohs(evh->evl_proto);
+	} else {
+		*etype = ntohs(evh->evl_encap_proto);
+	switch (*etype) {
+#if defined(INET)
+		struct ip *ip, iphdr;
+		if (__predict_false(m->m_len < offset + sizeof(struct ip)))
+			m_copydata(m, offset, sizeof(struct ip),
+			    (caddr_t) &iphdr);
+			ip = &iphdr;
+		} else
+			ip = (struct ip *)(m->m_data + offset);
+		*proto = ip->ip_p;
+		*start = offset + (ip->ip_hl << 2);
+		break;
+#endif
+#if defined(INET6)
+		*proto = -1;
+		*start = ip6_lasthdr(m, offset, IPPROTO_IPV6, proto);
+		/* Assert the network stack sent us a valid packet. */
+		KASSERT(*start > offset,
+		    ("%s: mbuf %p start %d offset %d proto %d", __func__, m,
+		    *start, offset, *proto));
+		break;
+#endif
+	default:
+		sc->vtnet_stats.tx_csum_bad_ethtype++;
+		return (EINVAL);
+	return (0);
+static int
+vtnet_txq_offload_tso(struct vtnet_txq *txq, struct mbuf *m, int eth_type,
+    int offset, struct virtio_net_hdr *hdr)
+	static struct timeval lastecn;
+	static int curecn;
+	struct tcphdr *tcp, tcphdr;
+	if (__predict_false(m->m_len < offset + sizeof(struct tcphdr))) {
+		m_copydata(m, offset, sizeof(struct tcphdr), (caddr_t)
&tcphdr);
+		tcp = &tcphdr;
+	} else
+		tcp = (struct tcphdr *)(m->m_data + offset);
+	hdr->hdr_len = offset + (tcp->th_off << 2);
+	hdr->gso_size = m->m_pkthdr.tso_segsz;
+	hdr->gso_type = eth_type == ETHERTYPE_IP ? VIRTIO_NET_HDR_GSO_TCPV4
+	    VIRTIO_NET_HDR_GSO_TCPV6;
+	if (tcp->th_flags & TH_CWR) {
+		 * Drop if VIRTIO_NET_F_HOST_ECN was not negotiated. In
FreeBSD,
+		 * ECN support is not on a per-interface basis, but globally
via
+		 * the net.inet.tcp.ecn.enable sysctl knob. The default is
off.
+		if ((sc->vtnet_flags & VTNET_FLAG_TSO_ECN) == 0) {
+			if (ppsratecheck(&lastecn, &curecn, 1))
+				    "TSO with ECN not negotiated with
host\n");
+			return (ENOTSUP);
+		hdr->gso_type |= VIRTIO_NET_HDR_GSO_ECN;
+	txq->vtntx_stats.vtxs_tso++;
+	return (0);
+vtnet_txq_offload(struct vtnet_txq *txq, struct mbuf *m,
+	int flags, etype, csum_start, proto, error;
+	flags = m->m_pkthdr.csum_flags;
+	error = vtnet_txq_offload_ctx(txq, m, &etype, &proto, &csum_start);
+	if (error)
+		goto drop;
+	if ((etype == ETHERTYPE_IP && flags & VTNET_CSUM_OFFLOAD) ||
+	    (etype == ETHERTYPE_IPV6 && flags & VTNET_CSUM_OFFLOAD_IPV6)) {
+		 * We could compare the IP protocol vs the CSUM_ flag too,
+		 * but that really should not be necessary.
+		hdr->flags |= VIRTIO_NET_HDR_F_NEEDS_CSUM;
+		hdr->csum_start = csum_start;
+		hdr->csum_offset = m->m_pkthdr.csum_data;
+		txq->vtntx_stats.vtxs_csum++;
+	if (flags & CSUM_TSO) {
+		if (__predict_false(proto != IPPROTO_TCP)) {
+			/* Likely failed to correctly parse the mbuf. */
+			sc->vtnet_stats.tx_tso_not_tcp++;
+			goto drop;
+		KASSERT(hdr->flags & VIRTIO_NET_HDR_F_NEEDS_CSUM,
+		    ("%s: mbuf %p TSO without checksum offload", __func__,
m));
+		error = vtnet_txq_offload_tso(txq, m, etype, csum_start,
hdr);
+		if (error)
+			goto drop;
+	return (m);
+drop:
+	m_freem(m);
+	return (NULL);
+#endif
+static int
+vtnet_txq_enqueue_buf(struct vtnet_txq *txq, struct mbuf **m_head,
+    struct vtnet_tx_header *txhdr)
+#ifdef NOTUSED
+	struct sglist sg;
+	struct sglist_seg segs[VTNET_MAX_TX_SEGS];
+	struct mbuf *m;
+	int collapsed, error;
+	m = *m_head;
+	collapsed = 0;
+	sglist_init(&sg, VTNET_MAX_TX_SEGS, segs);
+	error = sglist_append(&sg, &txhdr->vth_uhdr, sc->vtnet_hdr_size);
+	KASSERT(error == 0 && sg.sg_nseg == 1,
+	    ("%s: error %d adding header to sglist", __func__, error));
+again:
+	error = sglist_append_mbuf(&sg, m);
+	if (error) {
+		if (collapsed)
+			goto fail;
+		m = m_collapse(m, M_NOWAIT, VTNET_MAX_TX_SEGS - 1);
+		if (m == NULL)
+			goto fail;
+		*m_head = m;
+		collapsed = 1;
+		txq->vtntx_stats.vtxs_collapsed++;
+		goto again;
+	txhdr->vth_mbuf = m;
+	error = virtqueue_enqueue(vq, txhdr, &sg, sg.sg_nseg, 0);
+#endif
+	struct mbuf *m;
+	int nsegs, error;
+	nsegs = 0;
+	txhdr->vth_mbuf = (*m_head)->m_next;
+	for( m=*m_head ; m!=NULL ; m=m->m_next )
+		nsegs++;
+	error = rtems_virtqueue_enqueue(vq, *m_head, nsegs, 0);
+#endif
+	return (error);
+#ifdef NOTUSED
+fail:
+	m_freem(*m_head);
+	*m_head = NULL;
+	return (ENOBUFS);
+#endif
+static int
+vtnet_txq_encap(struct vtnet_txq *txq, struct mbuf **m_head)
+	struct vtnet_tx_header *txhdr;
+	struct virtio_net_hdr *hdr;
+	struct mbuf *m;
+	int error;
+	m = *m_head;
+#ifdef NOTUSED
+	M_ASSERTPKTHDR(m);
+	txhdr = uma_zalloc(vtnet_tx_header_zone, M_NOWAIT | M_ZERO);
+	if( txhdr == NULL ){
+		m_freem(m);
+		*m_head = NULL;
+		return (ENOMEM);
+	 * Always use the non-mergeable header, regardless if the feature
+	 * was negotiated. For transmit, num_buffers is always zero. The
+	 * vtnet_hdr_size is used to enqueue the correct header size.
+	hdr = &txhdr->vth_uhdr.hdr;
+	if (m->m_flags & M_VLANTAG) {
+		m = ether_vlanencap(m, m->m_pkthdr.ether_vtag);
+		if ((*m_head = m) == NULL) {
+			error = ENOBUFS;
+			goto fail;
+		m->m_flags &= ~M_VLANTAG;
+	if (m->m_pkthdr.csum_flags & VTNET_CSUM_ALL_OFFLOAD) {
+		m = vtnet_txq_offload(txq, m, hdr);
+			error = ENOBUFS;
+			goto fail;
+	error = vtnet_txq_enqueue_buf(txq, m_head, txhdr);
+#endif
+	MGET(m_txhdr, M_DONTWAIT, MT_DATA);
+	if( m_txhdr == NULL ){
+		m_freem(m);
+		*m_head = NULL;
+		return (ENOMEM);
+	memset(m_txhdr->m_data, 0, sc->vtnet_hdr_size);
+	m_txhdr->m_len = sc->vtnet_hdr_size;
+	m_txhdr->m_next = *m_head;
+	txhdr = mtod(m_txhdr, struct vtnet_tx_header *);
+	error = vtnet_txq_enqueue_buf(txq, &m_txhdr, txhdr);
+#endif
+	if (error == 0)
+		return (0);
+#ifdef NOTUSED
+fail:
+#endif
+	m_free(m_txhdr);
+#endif
+	return (error);
+static void
+vtnet_start_locked(struct vtnet_txq *txq, struct ifnet *ifp)
+	struct mbuf *m0;
+	int enq;
+	enq = 0;
+	VTNET_TXQ_LOCK_ASSERT(txq);
+	if ((ifp->if_drv_flags & IFF_DRV_RUNNING) == 0 ||
+	    sc->vtnet_link_active == 0)
+		return;
+	vtnet_txq_eof(txq);
+	while (!IFQ_DRV_IS_EMPTY(&ifp->if_snd)) {
+		if (virtqueue_full(vq))
+			break;
+		IFQ_DRV_DEQUEUE(&ifp->if_snd, m0);
+		if (m0 == NULL)
+			break;
+		if (vtnet_txq_encap(txq, &m0) != 0) {
+			if (m0 != NULL)
+				IFQ_DRV_PREPEND(&ifp->if_snd, m0);
+			break;
+		enq++;
+#ifdef NOTUSED
+		ETHER_BPF_MTAP(ifp, m0);
+#endif
+	if (enq > 0) {
+		txq->vtntx_watchdog = VTNET_TX_TIMEOUT;
+static void
+vtnet_start(struct ifnet *ifp)
+	txq = &sc->vtnet_txqs[0];
+	VTNET_TXQ_LOCK(txq);
+	vtnet_start_locked(txq, ifp);
+	VTNET_TXQ_UNLOCK(txq);
+#else /* !VTNET_LEGACY_TX */
+static int
+vtnet_txq_mq_start_locked(struct vtnet_txq *txq, struct mbuf *m)
+	struct buf_ring *br;
+	int enq, error;
+	br = txq->vtntx_br;
+	enq = 0;
+	error = 0;
+	    sc->vtnet_link_active == 0) {
+		if (m != NULL)
+			error = drbr_enqueue(ifp, br, m);
+		return (error);
+	if (m != NULL) {
+		if (error)
+			return (error);
+	while ((m = drbr_peek(ifp, br)) != NULL) {
+		error = vtnet_txq_encap(txq, &m);
+		if (error) {
+			if (m != NULL)
+				drbr_putback(ifp, br, m);
+			else
+				drbr_advance(ifp, br);
+			break;
+		enq++;
+		ETHER_BPF_MTAP(ifp, m);
+	if (enq > 0) {
+	return (error);
+static int
+vtnet_txq_mq_start(struct ifnet *ifp, struct mbuf *m)
+	npairs = sc->vtnet_act_vq_pairs;
+	if (m->m_flags & M_FLOWID)
+		i = m->m_pkthdr.flowid % npairs;
+	else
+		i = curcpu % npairs;
+	if (VTNET_TXQ_TRYLOCK(txq) != 0) {
+		error = vtnet_txq_mq_start_locked(txq, m);
+	} else {
+		error = drbr_enqueue(ifp, txq->vtntx_br, m);
+		taskqueue_enqueue(txq->vtntx_tq, &txq->vtntx_defrtask);
+	return (error);
+static void
+vtnet_txq_tq_deferred(void *xtxq, int pending)
+	txq = xtxq;
+	if (!drbr_empty(sc->vtnet_ifp, txq->vtntx_br))
+		vtnet_txq_mq_start_locked(txq, NULL);
+#endif /* VTNET_LEGACY_TX */
+#ifdef NOTUSED
+static void
+vtnet_txq_tq_intr(void *xtxq, int pending)
+	txq = xtxq;
+		return;
+	if (!IFQ_DRV_IS_EMPTY(&ifp->if_snd))
+#else
+	if (!drbr_empty(ifp, txq->vtntx_br))
+#endif
+	if (vtnet_txq_enable_intr(txq) != 0) {
+		vtnet_txq_disable_intr(txq);
+		txq->vtntx_stats.vtxs_rescheduled++;
+		taskqueue_enqueue(txq->vtntx_tq, &txq->vtntx_intrtask);
+}al
+#endif
+static void
+vtnet_txq_eof(struct vtnet_txq *txq)
+	struct mbuf *m;
+#ifdef NOTUSED
+	while ((txhdr = virtqueue_dequeue(vq, NULL)) != NULL) {
+		m = txhdr->vth_mbuf;
+		txq->vtntx_stats.vtxs_opackets++;
+		txq->vtntx_stats.vtxs_obytes += m->m_pkthdr.len;
+		if (m->m_flags & M_MCAST)
+			txq->vtntx_stats.vtxs_omcasts++;
+		m_freem(m);
+#endif
+	while((m_txhdr = virtqueue_dequeue(vq, NULL)) != NULL) {
txhdr->vth_mbuf->m_pkthdr.len;
+		m_freem(m_txhdr);
+#endif
+	if (virtqueue_empty(vq))
+		txq->vtntx_watchdog = 0;
+static void
+vtnet_tx_vq_intr(void *xtxq)
+	int tries;
+	txq = xtxq;
+	tries = 0;
+	if (__predict_false(txq->vtntx_id >= sc->vtnet_act_vq_pairs)) {
interrupt
+		 * to avoid).
+		return;
+again:
+		return;
+#else
+#endif
+		 * This is an occasional race, so retry a few times
+		 * before scheduling the taskqueue.
+			goto again;
+#ifdef NOTUSED
+#endif
+	} else
+static void
+vtnet_tx_start_all(struct vtnet_softc *sc)
+	int i;
+	VTNET_CORE_LOCK_ASSERT(sc);
+	for (i = 0; i < sc->vtnet_act_vq_pairs; i++) {
+#else
+#endif
+static void
+vtnet_qflush(struct ifnet *ifp)
+	struct mbuf *m;
+	int i;
+		while ((m = buf_ring_dequeue_sc(txq->vtntx_br)) != NULL)
+			m_freem(m);
+	if_qflush(ifp);
+#endif
+static int
+vtnet_watchdog(struct vtnet_txq *txq)
+	if (sc->vtnet_flags & VTNET_FLAG_EVENT_IDX)
+	if (txq->vtntx_watchdog == 0 || --txq->vtntx_watchdog) {
+		return (0);
+#ifdef NOTUSED
+	if_printf(sc->vtnet_ifp, "watchdog timeout on queue %d\n",
+	    txq->vtntx_id);
+#endif
+	return (1);
+#ifdef NOTUSED
+static void
+vtnet_rxq_accum_stats(struct vtnet_rxq *rxq, struct vtnet_rxq_stats *accum)
+	struct vtnet_rxq_stats *st;
+	st = &rxq->vtnrx_stats;
+	accum->vrxs_ipackets += st->vrxs_ipackets;
+	accum->vrxs_ibytes += st->vrxs_ibytes;
+	accum->vrxs_iqdrops += st->vrxs_iqdrops;
+	accum->vrxs_csum += st->vrxs_csum;
+	accum->vrxs_csum_failed += st->vrxs_csum_failed;
+	accum->vrxs_rescheduled += st->vrxs_rescheduled;
+static void
+vtnet_txq_accum_stats(struct vtnet_txq *txq, struct vtnet_txq_stats *accum)
+	struct vtnet_txq_stats *st;
+	st = &txq->vtntx_stats;
+	accum->vtxs_opackets += st->vtxs_opackets;
+	accum->vtxs_obytes += st->vtxs_obytes;
+	accum->vtxs_csum += st->vtxs_csum;
+	accum->vtxs_tso += st->vtxs_tso;
+	accum->vtxs_collapsed += st->vtxs_collapsed;
+	accum->vtxs_rescheduled += st->vtxs_rescheduled;
+static void
+vtnet_accumulate_stats(struct vtnet_softc *sc)
+	struct vtnet_statistics *st;
+	struct vtnet_rxq_stats rxaccum;
+	struct vtnet_txq_stats txaccum;
+	int i;
+	st = &sc->vtnet_stats;
+	bzero(&rxaccum, sizeof(struct vtnet_rxq_stats));
+	bzero(&txaccum, sizeof(struct vtnet_txq_stats));
+	for (i = 0; i < sc->vtnet_max_vq_pairs; i++) {
+		vtnet_rxq_accum_stats(&sc->vtnet_rxqs[i], &rxaccum);
+		vtnet_txq_accum_stats(&sc->vtnet_txqs[i], &txaccum);
+	st->rx_csum_offloaded = rxaccum.vrxs_csum;
+	st->rx_csum_failed = rxaccum.vrxs_csum_failed;
+	st->rx_task_rescheduled = rxaccum.vrxs_rescheduled;
+	st->tx_csum_offloaded = txaccum.vtxs_csum;
+	st->tx_tso_offloaded = txaccum.vtxs_tso;
+	st->tx_task_rescheduled = txaccum.vtxs_rescheduled;
+	 * With the exception of if_ierrors, these ifnet statistics are
+	 * only updated in the driver, so just set them to our accumulated
+	 * values. if_ierrors is updated in ether_input() for malformed
+	 * frames that we should have already discarded.
+	ifp->if_ipackets = rxaccum.vrxs_ipackets;
+	ifp->if_iqdrops = rxaccum.vrxs_iqdrops;
+	ifp->if_ierrors = rxaccum.vrxs_ierrors;
+	ifp->if_opackets = txaccum.vtxs_opackets;
+	ifp->if_obytes = txaccum.vtxs_obytes;
+	ifp->if_omcasts = txaccum.vtxs_omcasts;
+#endif
+#endif
+static void
+vtnet_tick(void *xsc)
+	int i, timedout;
+	sc = xsc;
+	timedout = 0;
+#ifdef NOTUSED
+	vtnet_accumulate_stats(sc);
+#endif
+		timedout |= vtnet_watchdog(&sc->vtnet_txqs[i]);
+	if (timedout != 0) {
+	} else
+#ifdef NOTUSED
+		callout_schedule(&sc->vtnet_tick_ch, hz);
+#endif
+		if( sc->stat_ch == vtnet_timeout_running ) {
+			timeout(vtnet_tick, sc, hz);
+		} else if ( sc->stat_ch == vtnet_timeout_stop_rq ) {
+			sc->stat_ch = vtnet_timeout_stopped;
+#endif
+#ifdef NOTUSED
+static void
+vtnet_start_taskqueues(struct vtnet_softc *sc)
+	device_t dev;
+	int i, error;
+	 * Errors here are very difficult to recover from - we cannot
+	 * easily fail because, if this is during boot, we will hang
+	 * when freeing any successfully started taskqueues because
+	 * the scheduler isn't up yet.
+	 * Most drivers just ignore the return value - it only
+	 * with ENOMEM so an error is not likely.
+		error = taskqueue_start_threads(&rxq->vtnrx_tq, 1, PI_NET,
+		    "%s rxq %d", device_get_nameunit(dev), rxq->vtnrx_id);
+		if (error) {
+			device_printf(dev, "failed to start rx taskq %d\n",
+			    rxq->vtnrx_id);
+		error = taskqueue_start_threads(&txq->vtntx_tq, 1, PI_NET,
+		    "%s txq %d", device_get_nameunit(dev), txq->vtntx_id);
+		if (error) {
+			device_printf(dev, "failed to start tx taskq %d\n",
+			    txq->vtntx_id);
+static void
+vtnet_free_taskqueues(struct vtnet_softc *sc)
+	int i;
+		if (rxq->vtnrx_tq != NULL) {
+			taskqueue_free(rxq->vtnrx_tq);
+			rxq->vtnrx_vq = NULL;
+		if (txq->vtntx_tq != NULL) {
+			taskqueue_free(txq->vtntx_tq);
+			txq->vtntx_tq = NULL;
+static void
+vtnet_drain_taskqueues(struct vtnet_softc *sc)
+	int i;
+			taskqueue_drain(rxq->vtnrx_tq,
+			taskqueue_drain(txq->vtntx_tq,
+#endif
+#endif
+static void
+vtnet_drain_rxtx_queues(struct vtnet_softc *sc)
+	int i;
+		vtnet_rxq_free_mbufs(rxq);
+		vtnet_txq_free_mbufs(txq);
+static void
+vtnet_stop_rendezvous(struct vtnet_softc *sc)
+	int i;
+	 * Lock and unlock the per-queue mutex so we known the stop
+	 * state is visible. Doing only the active queues should be
+	 * sufficient, but it does not cost much extra to do all the
+	 * queues. Note we hold the core mutex here too.
+static void
+vtnet_stop(struct vtnet_softc *sc)
+	device_t dev;
+	sc->vtnet_link_active = 0;
+#ifdef NOTUSED
+	callout_stop(&sc->vtnet_tick_ch);
+#endif
+	if( sc->stat_ch == vtnet_timeout_running ){
+		sc->stat_ch = vtnet_timeout_stop_rq;
+		while( sc->stat_ch != vtnet_timeout_stopped ){
+			rtems_bsdnet_semaphore_release();
+			rtems_task_wake_after( vtnet_ticksPerSecond );
+			rtems_bsdnet_semaphore_obtain();
+#endif
+	/* Only advisory. */
+	vtnet_disable_interrupts(sc);
+	 * Stop the host adapter. This resets it to the pre-initialized
+	 * state. It will not generate any interrupts until after it is
+	 * reinitialized.
+	virtio_stop(dev);
+	vtnet_stop_rendezvous(sc);
+	/* Free any mbufs left in the virtqueues. */
+	vtnet_drain_rxtx_queues(sc);
+static int
+vtnet_virtio_reinit(struct vtnet_softc *sc)
+	device_t dev;
+	uint64_t features;
+	int mask, error;
+	features = sc->vtnet_features;
+	mask = 0;
+#ifdef NOTUSED
+#if defined(INET)
+	mask |= IFCAP_RXCSUM;
+#endif
+#if defined (INET6)
+	mask |= IFCAP_RXCSUM_IPV6;
+#endif
+	 * Re-negotiate with the host, removing any disabled receive
+	 * features. Transmit features are disabled only on our side
+	 * via if_capenable and if_hwassist.
+	if (ifp->if_capabilities & mask) {
+		 * We require both IPv4 and IPv6 offloading to be enabled
+		 * in order to negotiated it: VirtIO does not distinguish
+		 * between the two.
+		if ((ifp->if_capenable & mask) != mask)
+			features &= ~VIRTIO_NET_F_GUEST_CSUM;
+	if (ifp->if_capabilities & IFCAP_LRO) {
+		if ((ifp->if_capenable & IFCAP_LRO) == 0)
+	if (ifp->if_capabilities & IFCAP_VLAN_HWFILTER) {
+		if ((ifp->if_capenable & IFCAP_VLAN_HWFILTER) == 0)
+			features &= ~VIRTIO_NET_F_CTRL_VLAN;
+#endif
+	error = virtio_reinit(dev, features);
+	if (error)
+		device_printf(dev, "virtio reinit error %d\n", error);
+	return (error);
+#ifdef NOTUSED
+static void
+vtnet_init_rx_filters(struct vtnet_softc *sc)
+		/* Restore promiscuous and all-multicast modes. */
+		/* Restore filtered MAC addresses. */
+	if (ifp->if_capenable & IFCAP_VLAN_HWFILTER)
+		vtnet_rx_filter_vlan(sc);
+#endif
+static int
+vtnet_init_rx_queues(struct vtnet_softc *sc)
+	device_t dev;
+	int i, clsize, error;
+	 * Use the new cluster size if one has been set (via a MTU
+	 * change). Otherwise, use the standard 2K clusters.
+	 * BMV: It might make sense to use page sized clusters as
+	 * the default (depending on the features negotiated).
+	if (sc->vtnet_rx_new_clsize != 0) {
+		clsize = sc->vtnet_rx_new_clsize;
+		sc->vtnet_rx_new_clsize = 0;
+	} else
+	sc->vtnet_rx_clsize = clsize;
+	sc->vtnet_rx_nmbufs = VTNET_NEEDED_RX_MBUFS(sc, clsize);
+	/* The first segment is reserved for the header. */
+	KASSERT(sc->vtnet_rx_nmbufs < VTNET_MAX_RX_SEGS,
+	    ("%s: too many rx mbufs %d", __func__, sc->vtnet_rx_nmbufs));
+		/* Hold the lock to satisfy asserts. */
+		error = vtnet_rxq_populate(rxq);
+		if (error) {
+			    "cannot allocate mbufs for Rx queue %d\n", i);
+			return (error);
+	return (0);
+static int
+vtnet_init_tx_queues(struct vtnet_softc *sc)
+	int i;
+	return (0);
+static int
+vtnet_init_rxtx_queues(struct vtnet_softc *sc)
+	int error;
+	error = vtnet_init_rx_queues(sc);
+	if (error)
+		return (error);
+	error = vtnet_init_tx_queues(sc);
+	if (error)
+		return (error);
+	return (0);
+static void
+vtnet_set_active_vq_pairs(struct vtnet_softc *sc)
+	device_t dev;
+	int npairs;
+	if ((sc->vtnet_flags & VTNET_FLAG_MULTIQ) == 0) {
+		MPASS(sc->vtnet_max_vq_pairs == 1);
+		sc->vtnet_act_vq_pairs = 1;
+		return;
+#ifdef NOTUSED
+	/* BMV: Just use the maximum configured for now. */
+	if (vtnet_ctrl_mq_cmd(sc, npairs) != 0) {
+		    "cannot set active queue pairs to %d\n", npairs);
+		npairs = 1;
+	sc->vtnet_act_vq_pairs = npairs;
+#endif
+	return;
+static int
+vtnet_reinit(struct vtnet_softc *sc)
+	device_t dev;
+	int error;
+	/* Use the current MAC address. */
+	bcopy(IF_LLADDR(ifp), sc->vtnet_hwaddr, ETHER_ADDR_LEN);
+	vtnet_set_hwaddr(sc);
+	vtnet_set_active_vq_pairs(sc);
+#ifdef NOTUSED
+	ifp->if_hwassist = 0;
+	if (ifp->if_capenable & IFCAP_TXCSUM)
+		ifp->if_hwassist |= VTNET_CSUM_OFFLOAD;
+	if (ifp->if_capenable & IFCAP_TXCSUM_IPV6)
+		ifp->if_hwassist |= VTNET_CSUM_OFFLOAD_IPV6;
+	if (ifp->if_capenable & IFCAP_TSO4)
+		ifp->if_hwassist |= CSUM_TSO;
+	if (ifp->if_capenable & IFCAP_TSO6)
+		ifp->if_hwassist |= CSUM_TSO; /* No CSUM_TSO_IPV6. */
+		vtnet_init_rx_filters(sc);
+#endif
+	error = vtnet_init_rxtx_queues(sc);
+	if (error)
+		return (error);
+	vtnet_enable_interrupts(sc);
+	ifp->if_drv_flags |= IFF_DRV_RUNNING;
+	return (0);
+static void
+vtnet_init_locked(struct vtnet_softc *sc)
+	device_t dev;
+		return;
+	vtnet_stop(sc);
+	/* Reinitialize with the host. */
+	if (vtnet_virtio_reinit(sc) != 0)
+		goto fail;
+	if (vtnet_reinit(sc) != 0)
+		goto fail;
+	virtio_reinit_complete(dev);
+#ifdef NOTUSED
+	callout_reset(&sc->vtnet_tick_ch, hz, vtnet_tick, sc);
+#endif
+#ifdef RTEMS_VIRTIO_NET
+	/* start vtnet_daemon */
+	if ( sc->vtpci_softc->daemonTid == 0 ) {
+		sc->vtpci_softc->daemonTid = rtems_bsdnet_newproc( "VTNd",
4096, vtnet_daemon, sc );
+	sc->stat_ch = vtnet_timeout_running;
+#endif
+	return;
+fail:
+	vtnet_stop(sc);
+static void
+vtnet_init(void *xsc)
+	sc = xsc;
+#ifdef NOTUSED
+static void
+vtnet_free_ctrl_vq(struct vtnet_softc *sc)
+	vq = sc->vtnet_ctrl_vq;
+	 * The control virtqueue is only polled and therefore it should
+	 * already be empty.
+	    ("%s: ctrl vq %p not empty", __func__, vq));
+static void
+vtnet_exec_ctrl_cmd(struct vtnet_softc *sc, void *cookie,
+    struct sglist *sg, int readable, int writable)
+	KASSERT(sc->vtnet_flags & VTNET_FLAG_CTRL_VQ,
+	    ("%s: CTRL_VQ feature not negotiated", __func__));
+	if (!virtqueue_empty(vq))
+		return;
+	if (virtqueue_enqueue(vq, cookie, sg, readable, writable) != 0)
+		return;
+	 * Poll for the response, but the command is likely already
+	 * done when we return from the notify.
+	virtqueue_poll(vq, NULL);
+static int
+vtnet_ctrl_mac_cmd(struct vtnet_softc *sc, uint8_t *hwaddr)
+	struct virtio_net_ctrl_hdr hdr;
+	struct sglist_seg segs[3];
+	struct sglist sg;
+	uint8_t ack;
+	int error;
+	hdr.class = VIRTIO_NET_CTRL_MAC;
+	hdr.cmd = VIRTIO_NET_CTRL_MAC_ADDR_SET;
+	ack = VIRTIO_NET_ERR;
+	sglist_init(&sg, 3, segs);
+	error = 0;
+	error |= sglist_append(&sg, &hdr, sizeof(struct
virtio_net_ctrl_hdr));
+	error |= sglist_append(&sg, hwaddr, ETHER_ADDR_LEN);
+	error |= sglist_append(&sg, &ack, sizeof(uint8_t));
+	KASSERT(error == 0 && sg.sg_nseg == 3,
+	    ("%s: error %d adding set MAC msg to sglist", __func__, error));
+	vtnet_exec_ctrl_cmd(sc, &ack, &sg, sg.sg_nseg - 1, 1);
+	return (ack == VIRTIO_NET_OK ? 0 : EIO);
+static int
+vtnet_ctrl_mq_cmd(struct vtnet_softc *sc, uint16_t npairs)
+	struct sglist sg;
+	struct {
+		uint8_t pad1;
+		struct virtio_net_ctrl_mq mq;
+		uint8_t pad2;
+		uint8_t ack;
+	} s;
+	int error;
+	s.hdr.class = VIRTIO_NET_CTRL_MQ;
+	s.hdr.cmd = VIRTIO_NET_CTRL_MQ_VQ_PAIRS_SET;
+	s.mq.virtqueue_pairs = npairs;
+	s.ack = VIRTIO_NET_ERR;
+	error = 0;
+	error |= sglist_append(&sg, &s.hdr, sizeof(struct
+	error |= sglist_append(&sg, &s.mq, sizeof(struct
virtio_net_ctrl_mq));
+	error |= sglist_append(&sg, &s.ack, sizeof(uint8_t));
+	    ("%s: error %d adding MQ message to sglist", __func__, error));
+	vtnet_exec_ctrl_cmd(sc, &s.ack, &sg, sg.sg_nseg - 1, 1);
+	return (s.ack == VIRTIO_NET_OK ? 0 : EIO);
+static int
+vtnet_ctrl_rx_cmd(struct vtnet_softc *sc, int cmd, int on)
+	struct sglist sg;
+	struct {
+		uint8_t pad1;
+		uint8_t onoff;
+		uint8_t pad2;
+		uint8_t ack;
+	} s;
+	int error;
+	KASSERT(sc->vtnet_flags & VTNET_FLAG_CTRL_RX,
+	    ("%s: CTRL_RX feature not negotiated", __func__));
+	s.hdr.class = VIRTIO_NET_CTRL_RX;
+	s.hdr.cmd = cmd;
+	s.onoff = !!on;
+	error = 0;
+	error |= sglist_append(&sg, &s.onoff, sizeof(uint8_t));
+	    ("%s: error %d adding Rx message to sglist", __func__, error));
+static int
+vtnet_set_promisc(struct vtnet_softc *sc, int on)
+	return (vtnet_ctrl_rx_cmd(sc, VIRTIO_NET_CTRL_RX_PROMISC, on));
+static int
+vtnet_set_allmulti(struct vtnet_softc *sc, int on)
+	return (vtnet_ctrl_rx_cmd(sc, VIRTIO_NET_CTRL_RX_ALLMULTI, on));
+ * The device defaults to promiscuous mode for backwards compatibility.
+ * Turn it off at attach time if possible.
+static void
+vtnet_attach_disable_promisc(struct vtnet_softc *sc)
+	if ((sc->vtnet_flags & VTNET_FLAG_CTRL_RX) == 0) {
+		ifp->if_flags |= IFF_PROMISC;
+	} else if (vtnet_set_promisc(sc, 0) != 0) {
+		device_printf(sc->vtnet_dev,
+		    "cannot disable default promiscuous mode\n");
+static void
+vtnet_rx_filter(struct vtnet_softc *sc)
+	device_t dev;
+	if (vtnet_set_promisc(sc, ifp->if_flags & IFF_PROMISC) != 0)
+		device_printf(dev, "cannot %s promiscuous mode\n",
+		    ifp->if_flags & IFF_PROMISC ? "enable" : "disable");
+	if (vtnet_set_allmulti(sc, ifp->if_flags & IFF_ALLMULTI) != 0)
+		device_printf(dev, "cannot %s all-multicast mode\n",
+		    ifp->if_flags & IFF_ALLMULTI ? "enable" : "disable");
+static void
+vtnet_rx_filter_mac(struct vtnet_softc *sc)
+	struct vtnet_mac_filter *filter;
+	struct sglist_seg segs[4];
+	struct sglist sg;
+	struct ifaddr *ifa;
+	struct ifmultiaddr *ifma;
+	int ucnt, mcnt, promisc, allmulti, error;
+	uint8_t ack;
+	filter = sc->vtnet_mac_filter;
+	ucnt = 0;
+	mcnt = 0;
+	promisc = 0;
+	allmulti = 0;
+	/* Unicast MAC addresses: */
+	if_addr_rlock(ifp);
+	TAILQ_FOREACH(ifa, &ifp->if_addrhead, ifa_link) {
+		if (ifa->ifa_addr->sa_family != AF_LINK)
+			continue;
+		else if (memcmp(LLADDR((struct sockaddr_dl *)ifa->ifa_addr),
+		    sc->vtnet_hwaddr, ETHER_ADDR_LEN) == 0)
+			continue;
+		else if (ucnt == VTNET_MAX_MAC_ENTRIES) {
+			promisc = 1;
+			break;
+		bcopy(LLADDR((struct sockaddr_dl *)ifa->ifa_addr),
+		    &filter->vmf_unicast.macs[ucnt], ETHER_ADDR_LEN);
+		ucnt++;
+	if_addr_runlock(ifp);
+	if (promisc != 0) {
+		filter->vmf_unicast.nentries = 0;
+		if_printf(ifp, "more than %d MAC addresses assigned, "
+		    "falling back to promiscuous mode\n",
+		    VTNET_MAX_MAC_ENTRIES);
+	} else
+		filter->vmf_unicast.nentries = ucnt;
+	/* Multicast MAC addresses: */
+	if_maddr_rlock(ifp);
+	TAILQ_FOREACH(ifma, &ifp->if_multiaddrs, ifma_link) {
+		if (ifma->ifma_addr->sa_family != AF_LINK)
+			continue;
+		else if (mcnt == VTNET_MAX_MAC_ENTRIES) {
+			allmulti = 1;
+			break;
+		bcopy(LLADDR((struct sockaddr_dl *)ifma->ifma_addr),
+		    &filter->vmf_multicast.macs[mcnt], ETHER_ADDR_LEN);
+		mcnt++;
+	if_maddr_runlock(ifp);
+	if (allmulti != 0) {
+		filter->vmf_multicast.nentries = 0;
+		if_printf(ifp, "more than %d multicast MAC addresses "
+		    "assigned, falling back to all-multicast mode\n",
+	} else
+		filter->vmf_multicast.nentries = mcnt;
+	if (promisc != 0 && allmulti != 0)
+		goto out;
+	hdr.cmd = VIRTIO_NET_CTRL_MAC_TABLE_SET;
+	sglist_init(&sg, 4, segs);
+	error = 0;
+	error |= sglist_append(&sg, &filter->vmf_unicast,
+	    sizeof(uint32_t) + filter->vmf_unicast.nentries *
ETHER_ADDR_LEN);
+	error |= sglist_append(&sg, &filter->vmf_multicast,
+	    sizeof(uint32_t) + filter->vmf_multicast.nentries *
ETHER_ADDR_LEN);
+	KASSERT(error == 0 && sg.sg_nseg == 4,
+	    ("%s: error %d adding MAC filter msg to sglist", __func__,
error));
+	if (ack != VIRTIO_NET_OK)
+		if_printf(ifp, "error setting host MAC filter table\n");
+out:
+	if (promisc != 0 && vtnet_set_promisc(sc, 1) != 0)
+		if_printf(ifp, "cannot enable promiscuous mode\n");
+	if (allmulti != 0 && vtnet_set_allmulti(sc, 1) != 0)
+		if_printf(ifp, "cannot enable all-multicast mode\n");
+static int
+vtnet_exec_vlan_filter(struct vtnet_softc *sc, int add, uint16_t tag)
+	struct sglist sg;
+	struct {
+		uint8_t pad1;
+		uint16_t tag;
+		uint8_t pad2;
+		uint8_t ack;
+	} s;
+	int error;
+	s.hdr.class = VIRTIO_NET_CTRL_VLAN;
+	s.hdr.cmd = add ? VIRTIO_NET_CTRL_VLAN_ADD :
VIRTIO_NET_CTRL_VLAN_DEL;
+	s.tag = tag;
+	error = 0;
+	error |= sglist_append(&sg, &s.tag, sizeof(uint16_t));
+	    ("%s: error %d adding VLAN message to sglist", __func__,
error));
+static void
+vtnet_rx_filter_vlan(struct vtnet_softc *sc)
+	uint32_t w;
+	uint16_t tag;
+	int i, bit;
+	KASSERT(sc->vtnet_flags & VTNET_FLAG_VLAN_FILTER,
+	    ("%s: VLAN_FILTER feature not negotiated", __func__));
+	/* Enable the filter for each configured VLAN. */
+	for (i = 0; i < VTNET_VLAN_FILTER_NWORDS; i++) {
+		w = sc->vtnet_vlan_filter[i];
+		while ((bit = ffs(w) - 1) != -1) {
+			w &= ~(1 << bit);
+			tag = sizeof(w) * CHAR_BIT * i + bit;
+			if (vtnet_exec_vlan_filter(sc, 1, tag) != 0) {
+				    "cannot enable VLAN %d filter\n", tag);
+static void
+vtnet_update_vlan_filter(struct vtnet_softc *sc, int add, uint16_t tag)
+	int idx, bit;
+	idx = (tag >> 5) & 0x7F;
+	bit = tag & 0x1F;
+	if (tag == 0 || tag > 4095)
+		return;
+	if (add)
+		sc->vtnet_vlan_filter[idx] |= (1 << bit);
+	else
+		sc->vtnet_vlan_filter[idx] &= ~(1 << bit);
+	if (ifp->if_capenable & IFCAP_VLAN_HWFILTER &&
+	    vtnet_exec_vlan_filter(sc, add, tag) != 0) {
+		    "cannot %s VLAN %d %s the host filter table\n",
+		    add ? "add" : "remove", tag, add ? "to" : "from");
+static void
+vtnet_register_vlan(void *arg, struct ifnet *ifp, uint16_t tag)
+	if (ifp->if_softc != arg)
+		return;
+	vtnet_update_vlan_filter(arg, 1, tag);
+static void
+vtnet_unregister_vlan(void *arg, struct ifnet *ifp, uint16_t tag)
+		return;
+	vtnet_update_vlan_filter(arg, 0, tag);
+#endif
+static int
+vtnet_is_link_up(struct vtnet_softc *sc)
+	device_t dev;
+	uint16_t status;
+#ifdef NOTUSED
+	if ((ifp->if_capabilities & IFCAP_LINKSTATE) == 0)
+		status = VIRTIO_NET_S_LINK_UP;
+	else
+		status = virtio_read_dev_config_2(dev,
+		    offsetof(struct virtio_net_config, status));
+	return ((status & VIRTIO_NET_S_LINK_UP) != 0);
+#endif
+	return (1);
+#endif
+static void
+vtnet_update_link_status(struct vtnet_softc *sc)
+	int link;
+	link = vtnet_is_link_up(sc);
+	/* Notify if the link status has changed. */
+	if (link != 0 && sc->vtnet_link_active == 0) {
+		sc->vtnet_link_active = 1;
+#ifdef NOTUSED
+		if_link_state_change(ifp, LINK_STATE_UP);
+#endif
+	} else if (link == 0 && sc->vtnet_link_active != 0) {
+#ifdef NOTUSED
+		if_link_state_change(ifp, LINK_STATE_DOWN);
+#endif
+#ifdef NOTUSED
+static int
+vtnet_ifmedia_upd(struct ifnet *ifp)
+	struct vtnet_softc *sc;
+	struct ifmedia *ifm;
+	ifm = &sc->vtnet_media;
+	if (IFM_TYPE(ifm->ifm_media) != IFM_ETHER)
+		return (EINVAL);
+	return (0);
+static void
+vtnet_ifmedia_sts(struct ifnet *ifp, struct ifmediareq *ifmr)
+	ifmr->ifm_status = IFM_AVALID;
+	ifmr->ifm_active = IFM_ETHER;
+	if (vtnet_is_link_up(sc) != 0) {
+		ifmr->ifm_status |= IFM_ACTIVE;
+		ifmr->ifm_active |= VTNET_MEDIATYPE;
+	} else
+		ifmr->ifm_active |= IFM_NONE;
+#endif
+static void
+vtnet_set_hwaddr(struct vtnet_softc *sc)
+	device_t dev;
+	if (sc->vtnet_flags & VTNET_FLAG_CTRL_MAC) {
+#ifdef NOTUSED
+		if (vtnet_ctrl_mac_cmd(sc, sc->vtnet_hwaddr) != 0)
+			device_printf(dev, "unable to set MAC address\n");
+#endif
+	} else if (sc->vtnet_flags & VTNET_FLAG_MAC) {
+		virtio_write_device_config(dev,
+		    offsetof(struct virtio_net_config, mac),
+		    sc->vtnet_hwaddr, ETHER_ADDR_LEN);
+static void
+vtnet_get_hwaddr(struct vtnet_softc *sc)
+	device_t dev;
+	if ((sc->vtnet_flags & VTNET_FLAG_MAC) == 0) {
+		 * Generate a random locally administered unicast address.
+		 * It would be nice to generate the same MAC address across
+		 * reboots, but it seems all the hosts currently available
+		 * support the MAC feature, so this isn't too important.
+#ifdef NOTUSED
+		sc->vtnet_hwaddr[0] = 0xB2;
+		arc4rand(&sc->vtnet_hwaddr[1], ETHER_ADDR_LEN - 1, 0);
+#endif
+		sc->arpcom.ac_enaddr[ 0 ] = 0x08;
+		sc->arpcom.ac_enaddr[ 1 ] = 0x00;
+		sc->arpcom.ac_enaddr[ 2 ] = 0x27;
+		sc->arpcom.ac_enaddr[ 3 ] = 0x98;
+		sc->arpcom.ac_enaddr[ 4 ] = 0xe7;
+		sc->arpcom.ac_enaddr[ 5 ] = 0x0f;
+		bcopy(sc->arpcom.ac_enaddr, sc->vtnet_hwaddr,
ETHER_ADDR_LEN);
+#endif
+		return;
+	virtio_read_device_config(dev, offsetof(struct virtio_net_config,
mac),
+#ifdef NOTUSED
+static void
+vtnet_vlan_tag_remove(struct mbuf *m)
+	m->m_pkthdr.ether_vtag = ntohs(evh->evl_tag);
+	m->m_flags |= M_VLANTAG;
+	/* Strip the 802.1Q header. */
+	bcopy((char *) evh, (char *) evh + ETHER_VLAN_ENCAP_LEN,
+	    ETHER_HDR_LEN - ETHER_TYPE_LEN);
+	m_adj(m, ETHER_VLAN_ENCAP_LEN);
+static void
+vtnet_setup_rxq_sysctl(struct sysctl_ctx_list *ctx,
+    struct sysctl_oid_list *child, struct vtnet_rxq *rxq)
+	struct sysctl_oid *node;
+	struct sysctl_oid_list *list;
+	struct vtnet_rxq_stats *stats;
+	char namebuf[16];
+	snprintf(namebuf, sizeof(namebuf), "rxq%d", rxq->vtnrx_id);
+	node = SYSCTL_ADD_NODE(ctx, child, OID_AUTO, namebuf,
+	    CTLFLAG_RD, NULL, "Receive Queue");
+	list = SYSCTL_CHILDREN(node);
+	stats = &rxq->vtnrx_stats;
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "ipackets", CTLFLAG_RD,
+	    &stats->vrxs_ipackets, "Receive packets");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "ibytes", CTLFLAG_RD,
+	    &stats->vrxs_ibytes, "Receive bytes");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "iqdrops", CTLFLAG_RD,
+	    &stats->vrxs_iqdrops, "Receive drops");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "ierrors", CTLFLAG_RD,
+	    &stats->vrxs_ierrors, "Receive errors");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "csum", CTLFLAG_RD,
+	    &stats->vrxs_csum, "Receive checksum offloaded");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "csum_failed", CTLFLAG_RD,
+	    &stats->vrxs_csum_failed, "Receive checksum offload failed");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "rescheduled", CTLFLAG_RD,
+	    &stats->vrxs_rescheduled,
+	    "Receive interrupt handler rescheduled");
+static void
+vtnet_setup_txq_sysctl(struct sysctl_ctx_list *ctx,
+    struct sysctl_oid_list *child, struct vtnet_txq *txq)
+	struct vtnet_txq_stats *stats;
+	char namebuf[16];
+	snprintf(namebuf, sizeof(namebuf), "txq%d", txq->vtntx_id);
+	    CTLFLAG_RD, NULL, "Transmit Queue");
+	stats = &txq->vtntx_stats;
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "opackets", CTLFLAG_RD,
+	    &stats->vtxs_opackets, "Transmit packets");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "obytes", CTLFLAG_RD,
+	    &stats->vtxs_obytes, "Transmit bytes");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "omcasts", CTLFLAG_RD,
+	    &stats->vtxs_omcasts, "Transmit multicasts");
+	    &stats->vtxs_csum, "Transmit checksum offloaded");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "tso", CTLFLAG_RD,
+	    &stats->vtxs_tso, "Transmit segmentation offloaded");
+	SYSCTL_ADD_UQUAD(ctx, list, OID_AUTO, "collapsed", CTLFLAG_RD,
+	    &stats->vtxs_collapsed, "Transmit mbufs collapsed");
+	    &stats->vtxs_rescheduled,
+	    "Transmit interrupt handler rescheduled");
+static void
+vtnet_setup_queue_sysctl(struct vtnet_softc *sc)
+	device_t dev;
+	struct sysctl_ctx_list *ctx;
+	struct sysctl_oid *tree;
+	struct sysctl_oid_list *child;
+	int i;
+	dev = sc->vtnet_dev;
+	ctx = device_get_sysctl_ctx(dev);
+	tree = device_get_sysctl_tree(dev);
+	child = SYSCTL_CHILDREN(tree);
+		vtnet_setup_rxq_sysctl(ctx, child, &sc->vtnet_rxqs[i]);
+		vtnet_setup_txq_sysctl(ctx, child, &sc->vtnet_txqs[i]);
+static void
+vtnet_setup_stat_sysctl(struct sysctl_ctx_list *ctx,
+    struct sysctl_oid_list *child, struct vtnet_softc *sc)
+	struct vtnet_statistics *stats;
+	stats = &sc->vtnet_stats;
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "mbuf_alloc_failed",
+	    CTLFLAG_RD, &stats->mbuf_alloc_failed,
+	    "Mbuf cluster allocation failures");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_frame_too_large",
+	    CTLFLAG_RD, &stats->rx_frame_too_large,
+	    "Received frame larger than the mbuf chain");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_enq_replacement_failed",
+	    CTLFLAG_RD, &stats->rx_enq_replacement_failed,
+	    "Enqueuing the replacement receive mbuf failed");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_mergeable_failed",
+	    CTLFLAG_RD, &stats->rx_mergeable_failed,
+	    "Mergeable buffers receive failures");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_csum_bad_ethtype",
+	    CTLFLAG_RD, &stats->rx_csum_bad_ethtype,
+	    "Received checksum offloaded buffer with unsupported "
+	    "Ethernet type");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_csum_bad_ipproto",
+	    CTLFLAG_RD, &stats->rx_csum_bad_ipproto,
+	    "Received checksum offloaded buffer with incorrect IP
protocol");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_csum_bad_offset",
+	    CTLFLAG_RD, &stats->rx_csum_bad_offset,
+	    "Received checksum offloaded buffer with incorrect offset");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_csum_bad_proto",
+	    CTLFLAG_RD, &stats->rx_csum_bad_proto,
+	    "Received checksum offloaded buffer with incorrect protocol");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_csum_failed",
+	    CTLFLAG_RD, &stats->rx_csum_failed,
+	    "Received buffer checksum offload failed");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_csum_offloaded",
+	    CTLFLAG_RD, &stats->rx_csum_offloaded,
+	    "Received buffer checksum offload succeeded");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "rx_task_rescheduled",
+	    CTLFLAG_RD, &stats->rx_task_rescheduled,
+	    "Times the receive interrupt task rescheduled itself");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "tx_csum_bad_ethtype",
+	    CTLFLAG_RD, &stats->tx_csum_bad_ethtype,
+	    "Aborted transmit of checksum offloaded buffer with unknown "
+	    "Ethernet type");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "tx_tso_bad_ethtype",
+	    CTLFLAG_RD, &stats->tx_tso_bad_ethtype,
+	    "Aborted transmit of TSO buffer with unknown Ethernet type");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "tx_tso_not_tcp",
+	    CTLFLAG_RD, &stats->tx_tso_not_tcp,
+	    "Aborted transmit of TSO buffer with non TCP protocol");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "tx_csum_offloaded",
+	    CTLFLAG_RD, &stats->tx_csum_offloaded,
+	    "Offloaded checksum of transmitted buffer");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "tx_tso_offloaded",
+	    CTLFLAG_RD, &stats->tx_tso_offloaded,
+	    "Segmentation offload of transmitted buffer");
+	SYSCTL_ADD_UQUAD(ctx, child, OID_AUTO, "tx_task_rescheduled",
+	    CTLFLAG_RD, &stats->tx_task_rescheduled,
+	    "Times the transmit interrupt task rescheduled itself");
+static void
+vtnet_setup_sysctl(struct vtnet_softc *sc)
+	device_t dev;
+	SYSCTL_ADD_INT(ctx, child, OID_AUTO, "max_vq_pairs",
+	    CTLFLAG_RD, &sc->vtnet_max_vq_pairs, 0,
+	    "Maximum number of supported virtqueue pairs");
+	SYSCTL_ADD_INT(ctx, child, OID_AUTO, "act_vq_pairs",
+	    CTLFLAG_RD, &sc->vtnet_act_vq_pairs, 0,
+	    "Number of active virtqueue pairs");
+	vtnet_setup_stat_sysctl(ctx, child, sc);
+#endif
+static int
+vtnet_rxq_enable_intr(struct vtnet_rxq *rxq)
+	return (virtqueue_enable_intr(rxq->vtnrx_vq));
+static void
+vtnet_rxq_disable_intr(struct vtnet_rxq *rxq)
+	virtqueue_disable_intr(rxq->vtnrx_vq);
+static int
+vtnet_txq_enable_intr(struct vtnet_txq *txq)
+	return (virtqueue_postpone_intr(txq->vtntx_vq, VQ_POSTPONE_LONG));
+static void
+vtnet_txq_disable_intr(struct vtnet_txq *txq)
+	virtqueue_disable_intr(txq->vtntx_vq);
+static void
+vtnet_enable_rx_interrupts(struct vtnet_softc *sc)
+	int i;
+		vtnet_rxq_enable_intr(&sc->vtnet_rxqs[i]);
+static void
+vtnet_enable_tx_interrupts(struct vtnet_softc *sc)
+	int i;
+		vtnet_txq_enable_intr(&sc->vtnet_txqs[i]);
+static void
+vtnet_enable_interrupts(struct vtnet_softc *sc)
+	vtnet_enable_rx_interrupts(sc);
+	vtnet_enable_tx_interrupts(sc);
+static void
+vtnet_disable_rx_interrupts(struct vtnet_softc *sc)
+	int i;
+		vtnet_rxq_disable_intr(&sc->vtnet_rxqs[i]);
+static void
+vtnet_disable_tx_interrupts(struct vtnet_softc *sc)
+	int i;
+		vtnet_txq_disable_intr(&sc->vtnet_txqs[i]);
+static void
+vtnet_disable_interrupts(struct vtnet_softc *sc)
+	vtnet_disable_rx_interrupts(sc);
+	vtnet_disable_tx_interrupts(sc);
+#ifdef NOTUSED
+static int
+vtnet_tunable_int(struct vtnet_softc *sc, const char *knob, int def)
+	char path[64];
+	snprintf(path, sizeof(path),
+	    "hw.vtnet.%d.%s", device_get_unit(sc->vtnet_dev), knob);
+	TUNABLE_INT_FETCH(path, &def);
+	return (def);
+#endif
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/if_vtnetvar.h
b/c/src/lib/libbsp/i386/pc386/virtio/if_vtnetvar.h
new file mode 100644
index 0000000..5d2bd78
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/if_vtnetvar.h
@@ -0,0 +1,391 @@
+ * @file if_vtnetvar.h
+ * @brief Header for if_vtnet.c
+ * Authors: Jin-Hyun Kim <jinhyun at konkuk.ac.kr>,
+ *   and Hyun-Wook Jin <jinh at konkuk.ac.kr>, http://sslab.konkuk.ac.kr
+ * Ported from FreeBSD to RTEMS March 16
+ * http://www.rtems.org/license/LICENSE.NET
+ * Copyright (c) 2011, Bryan Venteicher <bryanv at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ *    notice unmodified, this list of conditions, and the following
+ *    disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/network/if_vtnetvar.h 255167
2013-09-03 02:28:31Z bryanv $
+#ifndef _IF_VTNETVAR_H
+#define _IF_VTNETVAR_H
+struct vtnet_softc;
+struct vtpci_softc;
+struct vtnet_statistics {
+	uint64_t	mbuf_alloc_failed;
+	uint64_t	rx_frame_too_large;
+	uint64_t	rx_enq_replacement_failed;
+	uint64_t	rx_mergeable_failed;
+	uint64_t	rx_csum_bad_ethtype;
+	uint64_t	rx_csum_bad_ipproto;
+	uint64_t	rx_csum_bad_offset;
+	uint64_t	rx_csum_bad_proto;
+	uint64_t	tx_csum_bad_ethtype;
+	uint64_t	tx_tso_bad_ethtype;
+	uint64_t	tx_tso_not_tcp;
+	 * These are accumulated from each Rx/Tx queue.
+	uint64_t	rx_csum_failed;
+	uint64_t	rx_csum_offloaded;
+	uint64_t	rx_task_rescheduled;
+	uint64_t	tx_csum_offloaded;
+	uint64_t	tx_tso_offloaded;
+	uint64_t	tx_task_rescheduled;
+struct vtnet_rxq_stats {
+	uint64_t	vrxs_ipackets;	/* if_ipackets */
+	uint64_t	vrxs_ibytes;	/* if_ibytes */
+	uint64_t	vrxs_iqdrops;	/* if_iqdrops */
+	uint64_t	vrxs_ierrors;	/* if_ierrors */
+	uint64_t	vrxs_csum;
+	uint64_t	vrxs_csum_failed;
+	uint64_t	vrxs_rescheduled;
+struct vtnet_rxq {
+	struct mtx		 vtnrx_mtx;
+	struct vtnet_softc	*vtnrx_sc;
+	struct virtqueue	*vtnrx_vq;
+	int			 vtnrx_id;
+	int			 vtnrx_process_limit;
+	struct vtnet_rxq_stats	 vtnrx_stats;
+#ifdef NOTUSED
+	struct taskqueue	*vtnrx_tq;
+	struct task		 vtnrx_intrtask;
+#endif
+	char			 vtnrx_name[16];
+} __aligned(CACHE_LINE_SIZE);
+#define VTNET_RXQ_LOCK(_rxq)	mtx_lock(&(_rxq)->vtnrx_mtx)
+#define VTNET_RXQ_UNLOCK(_rxq)	mtx_unlock(&(_rxq)->vtnrx_mtx)
+#define VTNET_RXQ_LOCK_ASSERT(_rxq)		\
+    mtx_assert(&(_rxq)->vtnrx_mtx, MA_OWNED)
+#define VTNET_RXQ_LOCK_ASSERT_NOTOWNED(_rxq)	\
+    mtx_assert(&(_rxq)->vtnrx_mtx, MA_NOTOWNED)
+struct vtnet_txq_stats {
+	uint64_t vtxs_opackets;	/* if_opackets */
+	uint64_t vtxs_obytes;	/* if_obytes */
+	uint64_t vtxs_omcasts;	/* if_omcasts */
+	uint64_t vtxs_csum;
+	uint64_t vtxs_tso;
+	uint64_t vtxs_collapsed;
+	uint64_t vtxs_rescheduled;
+struct vtnet_txq {
+	struct mtx		 vtntx_mtx;
+	struct vtnet_softc	*vtntx_sc;
+	struct virtqueue	*vtntx_vq;
+#ifndef VTNET_LEGACY_TX
+	struct buf_ring		*vtntx_br;
+#endif
+	int			 vtntx_id;
+	int			 vtntx_watchdog;
+	struct vtnet_txq_stats	 vtntx_stats;
+#ifdef NOTUSED
+	struct taskqueue	*vtntx_tq;
+	struct task		 vtntx_intrtask;
+#endif
+	struct task		 vtntx_defrtask;
+#endif
+	char			 vtntx_name[16];
+#define VTNET_TXQ_LOCK(_txq)	mtx_lock(&(_txq)->vtntx_mtx)
+#define VTNET_TXQ_TRYLOCK(_txq)	mtx_trylock(&(_txq)->vtntx_mtx)
+#define VTNET_TXQ_UNLOCK(_txq)	mtx_unlock(&(_txq)->vtntx_mtx)
+#define VTNET_TXQ_LOCK_ASSERT(_txq)		\
+    mtx_assert(&(_txq)->vtntx_mtx, MA_OWNED)
+#define VTNET_TXQ_LOCK_ASSERT_NOTOWNED(_txq)	\
+    mtx_assert(&(_txq)->vtntx_mtx, MA_NOTOWNED)
+#define VTNET_FLAG_SUSPENDED	 0x0001
+#define VTNET_FLAG_MAC		 0x0002
+#define VTNET_FLAG_CTRL_VQ	 0x0004
+#define VTNET_FLAG_CTRL_RX	 0x0008
+#define VTNET_FLAG_CTRL_MAC	 0x0010
+#define VTNET_FLAG_VLAN_FILTER	 0x0020
+#define VTNET_FLAG_TSO_ECN	 0x0040
+#define VTNET_FLAG_MRG_RXBUFS	 0x0080
+#define VTNET_FLAG_LRO_NOMRG	 0x0100
+#define VTNET_FLAG_MULTIQ	 0x0200
+#define VTNET_FLAG_EVENT_IDX	 0x0400
+struct vtnet_softc {
+	struct arpcom arpcom;
+	struct rtems_bsdnet_ifconfig *config;
+	struct vtpci_softc *vtpci_softc;
+	enum { vtnet_timeout_stopped, vtnet_timeout_running,
vtnet_timeout_stop_rq }
+	stat_ch;
+#endif
+	device_t		 vtnet_dev;
+	struct ifnet		*vtnet_ifp;
+	struct vtnet_rxq	*vtnet_rxqs;
+	struct vtnet_txq	*vtnet_txqs;
+	uint32_t		 vtnet_flags;
+	int			 vtnet_link_active;
+	int			 vtnet_hdr_size;
+	int			 vtnet_rx_process_limit;
+	int			 vtnet_rx_nmbufs;
+	int			 vtnet_rx_clsize;
+	int			 vtnet_rx_new_clsize;
+	int			 vtnet_if_flags;
+	int			 vtnet_act_vq_pairs;
+	int			 vtnet_max_vq_pairs;
+	struct virtqueue	*vtnet_ctrl_vq;
+#ifdef NOTUSED
+	struct vtnet_mac_filter	*vtnet_mac_filter;
+	uint32_t		*vtnet_vlan_filter;
+#endif
+	uint64_t		 vtnet_features;
+	struct vtnet_statistics	 vtnet_stats;
+#ifdef NOTUSED
+	struct callout		 vtnet_tick_ch;
+	struct ifmedia		 vtnet_media;
+	eventhandler_tag	 vtnet_vlan_attach;
+	eventhandler_tag	 vtnet_vlan_detach;
+#endif
+	struct mtx		 vtnet_mtx;
+	char			 vtnet_mtx_name[16];
+	char			 vtnet_hwaddr[ETHER_ADDR_LEN];
+ * Maximum number of queue pairs we will autoconfigure to.
+#define VTNET_MAX_QUEUE_PAIRS	8
+ * Additional completed entries can appear in a virtqueue before we can
+ * reenable interrupts. Number of times to retry before scheduling the
+ * taskqueue to process the completed entries.
+#define VTNET_INTR_DISABLE_RETRIES	4
+#ifdef NOTUSED
+ * Fake the media type. The host does not provide us with any real media
+ * information.
+#define VTNET_MEDIATYPE		 (IFM_ETHER | IFM_10G_T | IFM_FDX)
+#endif
+ * Number of words to allocate for the VLAN shadow table. There is one
+ * bit for each VLAN.
+#define VTNET_VLAN_FILTER_NWORDS	(4096 / 32)
+ * When mergeable buffers are not negotiated, the vtnet_rx_header structure
+ * below is placed at the beginning of the mbuf data. Use 4 bytes of pad to
+ * both keep the VirtIO header and the data non-contiguous and to keep the
+ * frame's payload 4 byte aligned.
+ * When mergeable buffers are negotiated, the host puts the VirtIO header
in
+ * the beginning of the first mbuf's data.
+#define VTNET_RX_HEADER_PAD	4
+struct vtnet_rx_header {
+	struct virtio_net_hdr	vrh_hdr;
+	char			vrh_pad[VTNET_RX_HEADER_PAD];
+} __packed;
+ * For each outgoing frame, the vtnet_tx_header below is allocated from
+ * the vtnet_tx_header_zone.
+struct vtnet_tx_header {
+	union {
+		struct virtio_net_hdr		hdr;
+		struct virtio_net_hdr_mrg_rxbuf	mhdr;
+	} vth_uhdr;
+	struct mbuf *vth_mbuf;
+ * The VirtIO specification does not place a limit on the number of MAC
+ * addresses the guest driver may request to be filtered. In practice,
+ * the host is constrained by available resources. To simplify this driver,
+ * impose a reasonably high limit of MAC addresses we will filter before
+ * falling back to promiscuous or all-multicast modes.
+#define VTNET_MAX_MAC_ENTRIES	128
+struct vtnet_mac_table {
+	uint32_t	nentries;
+	uint8_t		macs[VTNET_MAX_MAC_ENTRIES][ETHER_ADDR_LEN];
+} __packed;
+struct vtnet_mac_filter {
+	struct vtnet_mac_table	vmf_unicast;
+	uint32_t		vmf_pad; /* Make tables non-contiguous. */
+	struct vtnet_mac_table	vmf_multicast;
+#ifdef NOTUSED
+ * The MAC filter table is malloc(9)'d when needed. Ensure it will
+ * always fit in one segment.
+CTASSERT(sizeof(struct vtnet_mac_filter) <= PAGE_SIZE);
+#endif
+#define VTNET_TX_TIMEOUT	5
+#define VTNET_CSUM_OFFLOAD	(CSUM_TCP | CSUM_UDP | CSUM_SCTP)
+#define VTNET_CSUM_OFFLOAD_IPV6	(CSUM_TCP_IPV6 | CSUM_UDP_IPV6 |
CSUM_SCTP_IPV6)
+#define VTNET_CSUM_ALL_OFFLOAD	\
+    (VTNET_CSUM_OFFLOAD | VTNET_CSUM_OFFLOAD_IPV6 | CSUM_TSO)
+/* Features desired/implemented by this driver. */
+#ifdef NOTUSED
+#define VTNET_FEATURES \
+    (VIRTIO_NET_F_MAC			| \
+     VIRTIO_NET_F_STATUS		| \
+     VIRTIO_NET_F_CTRL_VQ		| \
+     VIRTIO_NET_F_CTRL_RX		| \
+     VIRTIO_NET_F_CTRL_MAC_ADDR		| \
+     VIRTIO_NET_F_CTRL_VLAN		| \
+     VIRTIO_NET_F_CSUM			| \
+     VIRTIO_NET_F_GSO			| \
+     VIRTIO_NET_F_HOST_TSO4		| \
+     VIRTIO_NET_F_HOST_TSO6		| \
+     VIRTIO_NET_F_HOST_ECN		| \
+     VIRTIO_NET_F_GUEST_CSUM		| \
+     VIRTIO_NET_F_GUEST_TSO4		| \
+     VIRTIO_NET_F_GUEST_TSO6		| \
+     VIRTIO_NET_F_GUEST_ECN		| \
+     VIRTIO_NET_F_MRG_RXBUF		| \
+     VIRTIO_NET_F_MQ			| \
+     VIRTIO_RING_F_EVENT_IDX		| \
+     VIRTIO_RING_F_INDIRECT_DESC)
+#endif
+  ( VIRTIO_NET_F_CSUM | \
+    VIRTIO_NET_F_HOST_UFO | \
+    VIRTIO_NET_F_MRG_RXBUF )
+#endif
+ * The VIRTIO_NET_F_HOST_TSO[46] features permit us to send the host
+ * frames larger than 1514 bytes.
+#define VTNET_TSO_FEATURES (VIRTIO_NET_F_GSO | VIRTIO_NET_F_HOST_TSO4 | \
+    VIRTIO_NET_F_HOST_TSO6 | VIRTIO_NET_F_HOST_ECN)
+ * The VIRTIO_NET_F_GUEST_TSO[46] features permit the host to send us
+ * frames larger than 1514 bytes. We do not yet support software LRO
+ * via tcp_lro_rx().
+#define VTNET_LRO_FEATURES (VIRTIO_NET_F_GUEST_TSO4 | \
+    VIRTIO_NET_F_GUEST_TSO6 | VIRTIO_NET_F_GUEST_ECN)
+#define VTNET_MAX_MTU		65536
+#define VTNET_MAX_RX_SIZE	65550
+ * Used to preallocate the Vq indirect descriptors. The first segment
+ * is reserved for the header.
+#define VTNET_MIN_RX_SEGS	2
+#define VTNET_MAX_RX_SEGS	34
+#define VTNET_MAX_TX_SEGS	34
+#ifdef NOTUSED
+ * Assert we can receive and transmit the maximum with regular
+ * size clusters.
+CTASSERT(((VTNET_MAX_RX_SEGS - 1) * MCLBYTES) >= VTNET_MAX_RX_SIZE);
+CTASSERT(((VTNET_MAX_TX_SEGS - 1) * MCLBYTES) >= VTNET_MAX_MTU);
+#endif
+ * Number of slots in the Tx bufrings. This value matches most other
+ * multiqueue drivers.
+#define VTNET_DEFAULT_BUFRING_SIZE	4096
+ * Determine how many mbufs are in each receive buffer. For LRO without
+ * mergeable descriptors, we must allocate an mbuf chain large enough to
+ * hold both the vtnet_rx_header and the maximum receivable data.
+#define VTNET_NEEDED_RX_MBUFS(_sc, _clsize)				\
+	((_sc)->vtnet_flags & VTNET_FLAG_LRO_NOMRG) == 0 ? 1 :		\
+	    howmany(sizeof(struct vtnet_rx_header) + VTNET_MAX_RX_SIZE,	\
+	        (_clsize))
+#define VTNET_CORE_MTX(_sc)		&(_sc)->vtnet_mtx
+#define VTNET_CORE_LOCK(_sc)		mtx_lock(VTNET_CORE_MTX((_sc)))
+#define VTNET_CORE_UNLOCK(_sc)		mtx_unlock(VTNET_CORE_MTX((_sc)))
+#define VTNET_CORE_LOCK_DESTROY(_sc)	mtx_destroy(VTNET_CORE_MTX((_sc)))
+#define VTNET_CORE_LOCK_ASSERT(_sc)		\
+    mtx_assert(VTNET_CORE_MTX((_sc)), MA_OWNED)
+#define VTNET_CORE_LOCK_ASSERT_NOTOWNED(_sc)	\
+    mtx_assert(VTNET_CORE_MTX((_sc)), MA_NOTOWNED)
+#define VTNET_CORE_LOCK_INIT(_sc) do {					\
+    snprintf((_sc)->vtnet_mtx_name, sizeof((_sc)->vtnet_mtx_name),	\
+        "%s", device_get_nameunit((_sc)->vtnet_dev));			\
+    mtx_init(VTNET_CORE_MTX((_sc)), (_sc)->vtnet_mtx_name,		\
+        "VTNET Core Lock", MTX_DEF);					\
+} while (0)
+#endif /* _IF_VTNETVAR_H */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio.c
b/c/src/lib/libbsp/i386/pc386/virtio/virtio.c
index 0000000..5a99122
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio.c
@@ -0,0 +1,291 @@
+ * @file virtio.c
+ * @brief
+ * are met:
+ *    disclaimer.
WARRANTIES
USE,
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/virtio.c 252707 2013-07-04
17:57:26Z bryanv $
+#define VTNET_LEGACY_TX
+#define RTEMS_VIRTIO_NET
+#include <rtems.h>
+#include <rtems/rtems_bsdnet.h>
+#include "virtio.h"
+#include "virtqueue.h"
+#include "virtio_pci.h"
+#ifdef NOTUSED
+static int virtio_modevent(module_t, int, void *);
+static const char *virtio_feature_name(uint64_t, struct virtio_feature_desc
+static struct virtio_ident {
+	uint16_t	devid;
+	const char	*name;
+} virtio_ident_table[] = {
+	{ VIRTIO_ID_NETWORK,	"Network"	}
+	{ VIRTIO_ID_BLOCK,	"Block"		},
+	{ VIRTIO_ID_CONSOLE,	"Console"	},
+	{ VIRTIO_ID_ENTROPY,	"Entropy"	},
+	{ VIRTIO_ID_BALLOON,	"Balloon"	},
+	{ VIRTIO_ID_IOMEMORY,	"IOMemory"	},
+	{ VIRTIO_ID_SCSI,	"SCSI"		},
+	{ VIRTIO_ID_9P,		"9P Transport"	},
+	{ 0, NULL }
+/* Device independent features. */
+static struct virtio_feature_desc virtio_common_feature_desc[] = {
+	{ VIRTIO_F_NOTIFY_ON_EMPTY,	"NotifyOnEmpty"	},
+	{ VIRTIO_RING_F_INDIRECT_DESC,	"RingIndirect"	},
+	{ VIRTIO_RING_F_EVENT_IDX,	"EventIdx"	},
+	{ VIRTIO_F_BAD_FEATURE,		"BadFeature"	},
+	{ 0, NULL }
+const char *
+virtio_device_name(uint16_t devid)
+	struct virtio_ident *ident;
+	for (ident = virtio_ident_table; ident->name != NULL; ident++) {
+		if (ident->devid == devid)
+			return (ident->name);
+	return (NULL);
+virtio_feature_name(uint64_t val, struct virtio_feature_desc *desc)
+	int i, j;
+	struct virtio_feature_desc *descs[2] = { desc,
+	    virtio_common_feature_desc };
+	for (i = 0; i < 2; i++) {
+		if (descs[i] == NULL)
+			continue;
+		for (j = 0; descs[i][j].vfd_val != 0; j++) {
+			if (val == descs[i][j].vfd_val)
+				return (descs[i][j].vfd_str);
+	return (NULL);
+#endif
+void
+virtio_describe(device_t dev, const char *msg,
+    uint64_t features, struct virtio_feature_desc *desc)
+#ifdef NOTUSED
+	struct sbuf sb;
+	uint64_t val;
+	char *buf;
+	const char *name;
+	int n;
+	if ((buf = malloc(512, M_TEMP, M_NOWAIT)) == NULL) {
+		device_printf(dev, "%s features: %#jx\n", msg, (uintmax_t)
features);
+		return;
+	sbuf_new(&sb, buf, 512, SBUF_FIXEDLEN);
+	sbuf_printf(&sb, "%s features: %#jx", msg, (uintmax_t) features);
+	for (n = 0, val = 1ULL << 63; val != 0; val >>= 1) {
+		 * BAD_FEATURE is used to detect broken Linux clients
+		 * and therefore is not applicable to FreeBSD.
+		if (((features & val) == 0) || val == VIRTIO_F_BAD_FEATURE)
+			continue;
+		if (n++ == 0)
+			sbuf_cat(&sb, " <");
+		else
+			sbuf_cat(&sb, ",");
+		name = virtio_feature_name(val, desc);
+		if (name == NULL)
+			sbuf_printf(&sb, "%#jx", (uintmax_t) val);
+		else
+			sbuf_cat(&sb, name);
+	if (n > 0)
+		sbuf_cat(&sb, ">");
+#if __FreeBSD_version < 900020
+	sbuf_finish(&sb);
+	if (sbuf_overflowed(&sb) == 0)
+#else
+	if (sbuf_finish(&sb) == 0)
+#endif
+		device_printf(dev, "%s\n", sbuf_data(&sb));
+	sbuf_delete(&sb);
+	free(buf, M_TEMP);
+#endif
+ * VirtIO bus method wrappers.
+#ifdef NOTUSED
+void
+virtio_read_ivar(device_t dev, int ivar, uintptr_t *val)
+	*val = -1;
+	BUS_READ_IVAR(device_get_parent(dev), dev, ivar, val);
+void
+virtio_write_ivar(device_t dev, int ivar, uintptr_t val)
+	BUS_WRITE_IVAR(device_get_parent(dev), dev, ivar, val);
+#endif
+uint64_t
+virtio_negotiate_features(device_t dev, uint64_t child_features)
+	return (VIRTIO_BUS_NEGOTIATE_FEATURES(device_get_parent(dev),
+	    child_features));
+int
+virtio_alloc_virtqueues(device_t dev, int flags, int nvqs,
+    struct vq_alloc_info *info)
+	return (VIRTIO_BUS_ALLOC_VIRTQUEUES(device_get_parent(dev), flags,
+	    nvqs, info));
+int
+virtio_setup_intr(device_t dev, enum intr_type type)
+	return (VIRTIO_BUS_SETUP_INTR(device_get_parent(dev), type));
+int
+virtio_with_feature(device_t dev, uint64_t feature)
+	return (VIRTIO_BUS_WITH_FEATURE(device_get_parent(dev), feature));
+void
+virtio_stop(device_t dev)
+	VIRTIO_BUS_STOP(device_get_parent(dev));
+int
+virtio_reinit(device_t dev, uint64_t features)
+	return (VIRTIO_BUS_REINIT(device_get_parent(dev), features));
+void
+virtio_reinit_complete(device_t dev)
+	VIRTIO_BUS_REINIT_COMPLETE(device_get_parent(dev));
+void
+virtio_read_device_config(device_t dev, bus_size_t offset, void *dst, int
len)
+	VIRTIO_BUS_READ_DEVICE_CONFIG(device_get_parent(dev),
+	    offset, dst, len);
+void
+virtio_write_device_config(device_t dev, bus_size_t offset, void *dst, int
len)
+	VIRTIO_BUS_WRITE_DEVICE_CONFIG(device_get_parent(dev),
+#ifdef NOTUSED
+static int
+virtio_modevent(module_t mod, int type, void *unused)
+	int error;
+	switch (type) {
+	case MOD_LOAD:
+	case MOD_QUIESCE:
+	case MOD_UNLOAD:
+	case MOD_SHUTDOWN:
+		error = 0;
+		break;
+	default:
+		error = EOPNOTSUPP;
+		break;
+	return (error);
+static moduledata_t virtio_mod = {
+	"virtio",
+	virtio_modevent,
+	0
+DECLARE_MODULE(virtio, virtio_mod, SI_SUB_DRIVERS, SI_ORDER_FIRST);
+MODULE_VERSION(virtio, 1);
+#endif
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio.h
b/c/src/lib/libbsp/i386/pc386/virtio/virtio.h
index 0000000..294cac4
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio.h
@@ -0,0 +1,255 @@
+ * @file virtio.h
+ * @brief Header for virtio.c
+ * This header is BSD licensed so anyone can use the definitions to
implement
+ * compatible drivers/servers.
+ * are met:
+ * 3. Neither the name of IBM nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED
+ * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
PARTICULAR
+ * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL IBM OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/virtio.h 252708 2013-07-04
17:59:09Z bryanv $
+#ifndef _VIRTIO_H_
+#define _VIRTIO_H_
+/* Some adaptation replacements for RTEMS */
+#define mtx_init(a,b,c,d)
+#define mtx_initialized(a) (1)
+#define mtx_destroy(a) do {} while(0)
+#define mtx_lock(a) do {} while(0)
+#define mtx_unlock(a) do {} while(0)
+#define mtx_assert(a,b) do {} while(0)
+#define howmany(x,y) (((x)+((y)-1))/(y))
+typedef uint32_t u_long;
+typedef int device_t;
+typedef uint32_t bus_size_t;
+typedef uint32_t vm_paddr_t;
+struct mtx { int dummy; };
+enum intr_type {
+	INTR_TYPE_NET = 4,
+	INTR_MPSAFE = 512
+#define CACHE_LINE_SHIFT 6
+#define CACHE_LINE_SIZE (1<<CACHE_LINE_SHIFT)
+#define M_ZERO 0
+#define MTX_DEF 0
+#define MIN(a,b) ((a)>(b)?(b):(a))
+#define device_get_parent(dev) (dev)
+#define device_printf(dev,format,args...) printk(format,## args)
+#define vtophys(m) (m)
+#define snprintf(buf, size, str,args...) sprintf(buf, str,## args)
+#define mb() asm volatile ( "lock; addl $0,0(%%esp) " ::: "memory" )
+#define rmb() mb()
+#define wmb() asm volatile ( "lock; addl $0, (%%esp)" ::: "memory", "cc" )
+#define VIRTIO_BUS_NEGOTIATE_FEATURES(dev, feature)
vtpci_negotiate_features(dev, feature)
+#define VIRTIO_BUS_ALLOC_VIRTQUEUES(dev, flags, nvqs, info)
vtpci_alloc_virtqueues(dev, flags, nvqs, info)
+#define VIRTIO_BUS_SETUP_INTR(dev, type) vtpci_setup_intr(dev, type)
+#define VIRTIO_BUS_WITH_FEATURE(dev, feature) vtpci_with_feature(dev,
feature)
+#define VIRTIO_BUS_STOP(dev) vtpci_stop(dev)
+#define VIRTIO_BUS_REINIT(dev, features) vtpci_reinit(dev, features)
+#define VIRTIO_BUS_REINIT_COMPLETE(dev) vtpci_reinit_complete(dev)
+#define VIRTIO_BUS_READ_DEVICE_CONFIG(dev,offset,dst,len)
vtpci_read_dev_config(dev,offset,dst,len)
+#define VIRTIO_BUS_WRITE_DEVICE_CONFIG(dev,offset,dst,len)
vtpci_write_dev_config(dev,offset,dst,len)
+#define VIRTIO_BUS_NOTIFY_VQ(dev, index) vtpci_notify_virtqueue(dev, index)
+#define KASSERT(exp,msg) do {\
+	if(!(exp)){\
+		printk msg;\
+		printk("\n");\
+} while(0)
+#define MPASS(exp) \
+	KASSERT((exp), ("Assertion %s failed at %s:%d", #exp, __FILE__,
__LINE__))
+#endif /* RTEMS_VIRTIO_NET */
+struct vq_alloc_info;
+/* VirtIO device IDs. */
+#define VIRTIO_ID_NETWORK	0x01
+#define VIRTIO_ID_BLOCK		0x02
+#define VIRTIO_ID_CONSOLE	0x03
+#define VIRTIO_ID_ENTROPY	0x04
+#define VIRTIO_ID_BALLOON	0x05
+#define VIRTIO_ID_IOMEMORY	0x06
+#define VIRTIO_ID_SCSI		0x08
+#define VIRTIO_ID_9P		0x09
+/* Status byte for guest to report progress. */
+#define VIRTIO_CONFIG_STATUS_RESET	0x00
+#define VIRTIO_CONFIG_STATUS_ACK	0x01
+#define VIRTIO_CONFIG_STATUS_DRIVER	0x02
+#define VIRTIO_CONFIG_STATUS_DRIVER_OK	0x04
+#define VIRTIO_CONFIG_STATUS_FAILED	0x80
+ * Generate interrupt when the virtqueue ring is
+ * completely used, even if we've suppressed them.
+#define VIRTIO_F_NOTIFY_ON_EMPTY (1 << 24)
+ * The guest should never negotiate this feature; it
+ * is used to detect faulty drivers.
+#define VIRTIO_F_BAD_FEATURE (1 << 30)
+ * Some VirtIO feature bits (currently bits 28 through 31) are
+ * reserved for the transport being used (eg. virtio_ring), the
+ * rest are per-device feature bits.
+#define VIRTIO_TRANSPORT_F_START	28
+#define VIRTIO_TRANSPORT_F_END		32
+ * Each virtqueue indirect descriptor list must be physically contiguous.
+ * To allow us to malloc(9) each list individually, limit the number
+ * supported to what will fit in one page. With 4KB pages, this is a limit
+ * of 256 descriptors. If there is ever a need for more, we can switch to
+ * contigmalloc(9) for the larger allocations, similar to what
+ * bus_dmamem_alloc(9) does.
+ * Note the sizeof(struct vring_desc) is 16 bytes.
+#define VIRTIO_MAX_INDIRECT ((int) (PAGE_SIZE / 16))
+ * VirtIO instance variables indices.
+#define VIRTIO_IVAR_DEVTYPE		1
+#define VIRTIO_IVAR_FEATURE_DESC	2
+#define VIRTIO_IVAR_VENDOR		3
+#define VIRTIO_IVAR_DEVICE		4
+#define VIRTIO_IVAR_SUBVENDOR		5
+#define VIRTIO_IVAR_SUBDEVICE		6
+struct virtio_feature_desc {
+	uint64_t	 vfd_val;
+	const char	*vfd_str;
+const char *virtio_device_name(uint16_t devid);
+void	 virtio_describe(device_t dev, const char *msg,
+	     uint64_t features, struct virtio_feature_desc *feature_desc);
+ * VirtIO Bus Methods.
+void	 virtio_read_ivar(device_t dev, int ivar, uintptr_t *val);
+void	 virtio_write_ivar(device_t dev, int ivar, uintptr_t val);
+uint64_t virtio_negotiate_features(device_t dev, uint64_t child_features);
+int	 virtio_alloc_virtqueues(device_t dev, int flags, int nvqs,
+	     struct vq_alloc_info *info);
+int	 virtio_setup_intr(device_t dev, enum intr_type type);
+int	 virtio_with_feature(device_t dev, uint64_t feature);
+void	 virtio_stop(device_t dev);
+int	 virtio_reinit(device_t dev, uint64_t features);
+void	 virtio_reinit_complete(device_t dev);
+ * Read/write a variable amount from the device specific (ie, network)
+ * configuration region. This region is encoded in the same endian as
+ * the guest.
+void	 virtio_read_device_config(device_t dev, bus_size_t offset,
+	     void *dst, int length);
+void	 virtio_write_device_config(device_t dev, bus_size_t offset,
+	     void *src, int length);
+/* Inlined device specific read/write functions for common lengths. */
+#define VIRTIO_RDWR_DEVICE_CONFIG(size, type)				\
+static inline type							\
+__CONCAT(virtio_read_dev_config_,size)(device_t dev,			\
+    bus_size_t offset)							\
+	type val;							\
+	virtio_read_device_config(dev, offset, &val, sizeof(type));	\
+	return (val);							\
+static inline void							\
+__CONCAT(virtio_write_dev_config_,size)(device_t dev,			\
+    bus_size_t offset, type val)					\
+	virtio_write_device_config(dev, offset, &val, sizeof(type));	\
+VIRTIO_RDWR_DEVICE_CONFIG(1, uint8_t);
+VIRTIO_RDWR_DEVICE_CONFIG(2, uint16_t);
+VIRTIO_RDWR_DEVICE_CONFIG(4, uint32_t);
+#undef VIRTIO_RDWR_DEVICE_CONFIG
+#define VIRTIO_READ_IVAR(name, ivar)					\
+static inline int							\
+__CONCAT(virtio_get_,name)(device_t dev)				\
+	uintptr_t val;							\
+	virtio_read_ivar(dev, ivar, &val);				\
+	return ((int) val);						\
+VIRTIO_READ_IVAR(device_type,	VIRTIO_IVAR_DEVTYPE);
+VIRTIO_READ_IVAR(vendor,	VIRTIO_IVAR_VENDOR);
+VIRTIO_READ_IVAR(device,	VIRTIO_IVAR_DEVICE);
+VIRTIO_READ_IVAR(subvendor,	VIRTIO_IVAR_SUBVENDOR);
+VIRTIO_READ_IVAR(subdevice,	VIRTIO_IVAR_SUBDEVICE);
+#undef VIRTIO_READ_IVAR
+#define VIRTIO_WRITE_IVAR(name, ivar)					\
+__CONCAT(virtio_set_,name)(device_t dev, void *val)			\
+	virtio_write_ivar(dev, ivar, (uintptr_t) val);			\
+VIRTIO_WRITE_IVAR(feature_desc,	VIRTIO_IVAR_FEATURE_DESC);
+#undef VIRTIO_WRITE_IVAR
+#endif /* _VIRTIO_H_ */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio_net.h
b/c/src/lib/libbsp/i386/pc386/virtio/virtio_net.h
index 0000000..f6604cd
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio_net.h
@@ -0,0 +1,218 @@
+ * @file virtio_net.h
implement
+ * are met:
LIMITED
PARTICULAR
CONSEQUENTIAL
STRICT
WAY
+ * SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/network/virtio_net.h 255111
2013-09-01 04:23:54Z bryanv $
+#ifndef _VIRTIO_NET_H
+#define _VIRTIO_NET_H
+/* The feature bitmap for virtio net */
+#define VIRTIO_NET_F_CSUM	0x00001 /* Host handles pkts w/ partial csum
+#define VIRTIO_NET_F_GUEST_CSUM 0x00002 /* Guest handles pkts w/ partial
csum*/
+#define VIRTIO_NET_F_MAC	0x00020 /* Host has given MAC address. */
+#define VIRTIO_NET_F_GSO	0x00040 /* Host handles pkts w/ any GSO type
+#define VIRTIO_NET_F_GUEST_TSO4	0x00080 /* Guest can handle TSOv4
in. */
+#define VIRTIO_NET_F_GUEST_TSO6	0x00100 /* Guest can handle TSOv6
in. */
+#define VIRTIO_NET_F_GUEST_ECN	0x00200 /* Guest can handle TSO[6] w/ ECN
in.*/
+#define VIRTIO_NET_F_GUEST_UFO	0x00400 /* Guest can handle UFO in. */
+#define VIRTIO_NET_F_HOST_TSO4	0x00800 /* Host can handle TSOv4 in. */
+#define VIRTIO_NET_F_HOST_TSO6	0x01000 /* Host can handle TSOv6 in. */
+#define VIRTIO_NET_F_HOST_ECN	0x02000 /* Host can handle TSO[6] w/ ECN in.
+#define VIRTIO_NET_F_HOST_UFO	0x04000 /* Host can handle UFO in. */
+#define VIRTIO_NET_F_MRG_RXBUF	0x08000 /* Host can merge receive buffers.
+#define VIRTIO_NET_F_STATUS	0x10000 /* virtio_net_config.status
available*/
+#define VIRTIO_NET_F_CTRL_VQ	0x20000 /* Control channel available */
+#define VIRTIO_NET_F_CTRL_RX	0x40000 /* Control channel RX mode support
+#define VIRTIO_NET_F_CTRL_VLAN	0x80000 /* Control channel VLAN filtering */
+#define VIRTIO_NET_F_CTRL_RX_EXTRA 0x100000 /* Extra RX mode control
support */
+#define VIRTIO_NET_F_GUEST_ANNOUNCE 0x200000 /* Announce device on network
+#define VIRTIO_NET_F_MQ		0x400000 /* Device supports RFS */
+#define VIRTIO_NET_F_CTRL_MAC_ADDR 0x800000 /* Set MAC address */
+#define VIRTIO_NET_S_LINK_UP	1	/* Link is up */
+struct virtio_net_config {
+	/* The config defining mac address (if VIRTIO_NET_F_MAC) */
+	uint8_t		mac[ETHER_ADDR_LEN];
+	/* See VIRTIO_NET_F_STATUS and VIRTIO_NET_S_* above */
+	uint16_t	status;
+	/* Maximum number of each of transmit and receive queues;
+	 * see VIRTIO_NET_F_MQ and VIRTIO_NET_CTRL_MQ.
+	 * Legal values are between 1 and 0x8000.
+	uint16_t	max_virtqueue_pairs;
+} __packed;
+ * This is the first element of the scatter-gather list.  If you don't
+ * specify GSO or CSUM features, you can simply ignore the header.
+#define VIRTIO_NET_HDR_F_NEEDS_CSUM	1	/* Use
csum_start,csum_offset*/
+#define VIRTIO_NET_HDR_F_DATA_VALID	2	/* Csum is valid */
+#define VIRTIO_NET_HDR_GSO_NONE		0	/* Not a GSO frame
+#define VIRTIO_NET_HDR_GSO_TCPV4	1	/* GSO frame, IPv4 TCP (TSO)
+#define VIRTIO_NET_HDR_GSO_UDP		3	/* GSO frame, IPv4 UDP (UFO)
+#define VIRTIO_NET_HDR_GSO_TCPV6	4	/* GSO frame, IPv6 TCP */
+#define VIRTIO_NET_HDR_GSO_ECN		0x80	/* TCP has ECN set */q
+struct virtio_net_hdr {
+	uint8_t	flags;
+	uint8_t gso_type;
+	uint16_t hdr_len;	/* Ethernet + IP + tcp/udp hdrs */
+	uint16_t gso_size;	/* Bytes to append to hdr_len per frame */
+	uint16_t csum_start;	/* Position to start checksumming from */
+	uint16_t csum_offset;	/* Offset after that to place checksum */
+ * This is the version of the header to use when the MRG_RXBUF
+ * feature has been negotiated.
+struct virtio_net_hdr_mrg_rxbuf {
+	uint16_t num_buffers;	/* Number of merged rx buffers */
+ * Control virtqueue data structures
+ * The control virtqueue expects a header in the first sg entry
+ * and an ack/status response in the last entry.  Data for the
+ * command goes in between.
+struct virtio_net_ctrl_hdr {
+	uint8_t class;
+	uint8_t cmd;
+} __packed;
+#define VIRTIO_NET_OK	0
+#define VIRTIO_NET_ERR	1
+ * Control the RX mode, ie. promiscuous, allmulti, etc...
+ * All commands require an "out" sg entry containing a 1 byte
+ * state value, zero = disable, non-zero = enable.  Commands
+ * 0 and 1 are supported with the VIRTIO_NET_F_CTRL_RX feature.
+ * Commands 2-5 are added with VIRTIO_NET_F_CTRL_RX_EXTRA.
+#define VIRTIO_NET_CTRL_RX	0
+#define VIRTIO_NET_CTRL_RX_PROMISC	0
+#define VIRTIO_NET_CTRL_RX_ALLMULTI	1
+#define VIRTIO_NET_CTRL_RX_ALLUNI	2
+#define VIRTIO_NET_CTRL_RX_NOMULTI	3
+#define VIRTIO_NET_CTRL_RX_NOUNI	4
+#define VIRTIO_NET_CTRL_RX_NOBCAST	5
+ * Control the MAC filter table.
+ * The MAC filter table is managed by the hypervisor, the guest should
+ * assume the size is infinite.  Filtering should be considered
+ * non-perfect, ie. based on hypervisor resources, the guest may
+ * received packets from sources not specified in the filter list.
+ * In addition to the class/cmd header, the TABLE_SET command requires
+ * two out scatterlists.  Each contains a 4 byte count of entries followed
+ * by a concatenated byte stream of the ETH_ALEN MAC addresses.  The
+ * first sg list contains unicast addresses, the second is for multicast.
+ * This functionality is present if the VIRTIO_NET_F_CTRL_RX feature
+ * is available.
+ * The ADDR_SET command requests one out scatterlist, it contains a
+ * 6 bytes MAC address. This functionality is present if the
+ * VIRTIO_NET_F_CTRL_MAC_ADDR feature is available.
+struct virtio_net_ctrl_mac {
+	uint32_t	entries;
+	uint8_t		macs[][ETHER_ADDR_LEN];
+} __packed;
+#define VIRTIO_NET_CTRL_MAC	1
+#define VIRTIO_NET_CTRL_MAC_TABLE_SET	0
+#define VIRTIO_NET_CTRL_MAC_ADDR_SET	1
+ * Control VLAN filtering
+ * The VLAN filter table is controlled via a simple ADD/DEL interface.
+ * VLAN IDs not added may be filtered by the hypervisor.  Del is the
+ * opposite of add.  Both commands expect an out entry containing a 2
+ * byte VLAN ID.  VLAN filtering is available with the
+ * VIRTIO_NET_F_CTRL_VLAN feature bit.
+#define VIRTIO_NET_CTRL_VLAN	2
+#define VIRTIO_NET_CTRL_VLAN_ADD	0
+#define VIRTIO_NET_CTRL_VLAN_DEL	1
+ * Control link announce acknowledgement
+ * The command VIRTIO_NET_CTRL_ANNOUNCE_ACK is used to indicate that
+ * driver has recevied the notification; device would clear the
+ * VIRTIO_NET_S_ANNOUNCE bit in the status field after it receives
+ * this command.
+#define VIRTIO_NET_CTRL_ANNOUNCE	3
+#define VIRTIO_NET_CTRL_ANNOUNCE_ACK	0
+ * Control Receive Flow Steering
+ * The command VIRTIO_NET_CTRL_MQ_VQ_PAIRS_SET enables Receive Flow
+ * Steering, specifying the number of the transmit and receive queues
+ * that will be used. After the command is consumed and acked by the
+ * device, the device will not steer new packets on receive virtqueues
+ * other than specified nor read from transmit virtqueues other than
+ * specified. Accordingly, driver should not transmit new packets on
+ * virtqueues other than specified.
+struct virtio_net_ctrl_mq {
+	uint16_t	virtqueue_pairs;
+} __packed;
+#define VIRTIO_NET_CTRL_MQ	4
+#define VIRTIO_NET_CTRL_MQ_VQ_PAIRS_SET		0
+#define VIRTIO_NET_CTRL_MQ_VQ_PAIRS_MIN		1
+#define VIRTIO_NET_CTRL_MQ_VQ_PAIRS_MAX		0x8000
+#endif /* _VIRTIO_NET_H */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.c
b/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.c
index 0000000..c9b7709
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.c
@@ -0,0 +1,1526 @@
+ * @file virtio_pci.c
+ * @brief Driver for the virtio PCI interface
+ * are met:
+ *    disclaimer.
WARRANTIES
USE,
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/pci/virtio_pci.c 255110
2013-09-01 04:20:23Z bryanv $
+/* Driver for the VirtIO PCI interface. */
+#ifdef __i386__
+#include <rtems.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <sys/mbuf.h>
+#include <sys/param.h>
+#include <pcibios.h>
+static struct vtpci_softc vtpci_softc;
+#define device_get_softc(dev) &vtpci_softc
+static uint8_t vtpci_read_config_1(struct vtpci_softc *sc, int offset){
+	uint8_t val;
+	inport_byte(sc->pci_io_base+offset, val);
+	return val;
+static uint16_t vtpci_read_config_2(struct vtpci_softc *sc, int offset){
+	uint16_t val;
+	inport_word(sc->pci_io_base+offset, val);
+	return val;
+static uint32_t vtpci_read_config_4(struct vtpci_softc *sc, int offset){
+	uint32_t val;
+	inport_long(sc->pci_io_base+offset, val);
+	return val;
+static void vtpci_write_config_1(struct vtpci_softc *sc, int offset,
uint8_t val){
+	outport_byte(sc->pci_io_base+offset, val);
+static void vtpci_write_config_2(struct vtpci_softc *sc, int offset,
uint16_t val){
+	outport_word(sc->pci_io_base+offset, val);
+static void vtpci_write_config_4(struct vtpci_softc *sc, int offset,
uint32_t val){
+	outport_long(sc->pci_io_base+offset, val);
+#endif
+#ifdef NOTUSED
+struct vtpci_interrupt {
+	struct resource		*vti_irq;
+	int			 vti_rid;
+	uint32_t		isr_number;
+	void			*vti_handler;
+struct vtpci_virtqueue {
+	struct virtqueue	*vtv_vq;
+	int			 vtv_no_intr;
+#endif
+#define VTPCI_FLAG_NO_MSI		0x0001
+#define VTPCI_FLAG_NO_MSIX		0x0002
+#define VTPCI_FLAG_LEGACY		0x1000
+#define VTPCI_FLAG_MSI			0x2000
+#define VTPCI_FLAG_MSIX			0x4000
+#define VTPCI_FLAG_SHARED_MSIX		0x8000
+#define VTPCI_FLAG_ITYPE_MASK		0xF000
+#ifdef NOTUSED
+struct vtpci_softc {
+	device_t			 vtpci_dev;
+	struct resource			*vtpci_res;
+	struct resource			*vtpci_msix_res;
+	uint64_t			 vtpci_features;
+	uint32_t			 vtpci_flags;
+	/* This "bus" will only ever have one child. */
+	device_t			 vtpci_child_dev;
+	struct virtio_feature_desc	*vtpci_child_feat_desc;
+	int				 vtpci_nvqs;
+	struct vtpci_virtqueue		*vtpci_vqs;
+	 * Ideally, each virtqueue that the driver provides a callback for
will
+	 * receive its own MSIX vector. If there are not sufficient vectors
+	 * available, then attempt to have all the VQs share one vector. For
+	 * MSIX, the configuration changed notifications must be on their
own
+	 * vector.
+	 * If MSIX is not available, we will attempt to have the whole
device
+	 * share one MSI vector, and then, finally, one legacy interrupt.
+	struct vtpci_interrupt		 vtpci_device_interrupt;
+	struct vtpci_interrupt		*vtpci_msix_vq_interrupts;
+	int				 vtpci_nmsix_resources;
+#endif
+#ifdef NOTUSED
+static int	vtpci_probe(device_t);
+static int	vtpci_detach(device_t);
+static int	vtpci_suspend(device_t);
+static int	vtpci_resume(device_t);
+static int	vtpci_shutdown(device_t);
+static void	vtpci_driver_added(device_t, driver_t *);
+static void	vtpci_child_detached(device_t, device_t);
+static int	vtpci_read_config_ivar(device_t, device_t, int, uintptr_t
+static int	vtpci_write_ivar(device_t, device_t, int, uintptr_t);
+static uint64_t	vtpci_negotiate_features(device_t, uint64_t);
+static int	vtpci_with_feature(device_t, uint64_t);
+static int	vtpci_alloc_virtqueues(device_t, int, int,
+		    struct vq_alloc_info *);
+static int	vtpci_setup_intr(device_t, enum intr_type);
+static void	vtpci_stop(device_t);
+static int	vtpci_reinit(device_t, uint64_t);
+static void	vtpci_reinit_complete(device_t);
+static void	vtpci_notify_virtqueue(device_t, uint16_t);
+static void	vtpci_read_dev_config(device_t, bus_size_t, void *, int);
+static void	vtpci_write_dev_config(device_t, bus_size_t, void *, int);
+static int	vtpci_alloc_msix(struct vtpci_softc *, int);
+static int	vtpci_alloc_msi(struct vtpci_softc *);
+static int	vtpci_alloc_intr_msix_pervq(struct vtpci_softc *);
+static int	vtpci_alloc_intr_msix_shared(struct vtpci_softc *);
+static int	vtpci_alloc_intr_msi(struct vtpci_softc *);
+static int	vtpci_setup_pervq_msix_interrupts(struct vtpci_softc *,
+		    enum intr_type);
+static int	vtpci_setup_msix_interrupts(struct vtpci_softc *,
+		    enum intr_type);
+static int	vtpci_register_msix_vector(struct vtpci_softc *, int,
+		    struct vtpci_interrupt *);
+static int	vtpci_set_host_msix_vectors(struct vtpci_softc *);
+static void	vtpci_release_child_resources(struct vtpci_softc *);
+static int	vtpci_vq_shared_intr_filter(void *);
+static void	vtpci_vq_shared_intr(void *);
+static int	vtpci_vq_intr_filter(void *);
+static void	vtpci_vq_intr(void *);
+#define vtpci_setup_msi_interrupt vtpci_setup_legacy_interrupt
+ * I/O port read/write wrappers.
+#define vtpci_read_config_1(sc, o)	bus_read_config_1((sc)->vtpci_res,
(o))
+#define vtpci_read_config_2(sc, o)	bus_read_config_2((sc)->vtpci_res,
(o))
+#define vtpci_read_config_4(sc, o)	bus_read_config_4((sc)->vtpci_res,
(o))
+#define vtpci_write_config_1(sc, o, v)	bus_write_1((sc)->vtpci_res, (o),
(v))
+#define vtpci_write_config_2(sc, o, v)	bus_write_2((sc)->vtpci_res, (o),
(v))
+#define vtpci_write_config_4(sc, o, v)	bus_write_4((sc)->vtpci_res, (o),
(v))
+#endif
+static int	vtpci_attach(device_t);
+static uint8_t	vtpci_get_status(device_t);
+static void	vtpci_set_status(device_t, uint8_t);
+static void	vtpci_describe_features(struct vtpci_softc *, const char *,
+		    uint64_t);
+static void	vtpci_probe_and_attach_child(struct vtpci_softc *);
+static int	vtpci_alloc_intr_legacy(struct vtpci_softc *);
+static int	vtpci_alloc_interrupt(struct vtpci_softc *, int, int,
+static int	vtpci_alloc_intr_resources(struct vtpci_softc *);
+static int	vtpci_setup_legacy_interrupt(struct vtpci_softc *,
+		    enum intr_type);
+static int	vtpci_setup_interrupts(struct vtpci_softc *, enum
intr_type);
+static int	vtpci_reinit_virtqueue(struct vtpci_softc *, int);
+static void	vtpci_free_interrupt(struct vtpci_softc *,
+static void	vtpci_free_interrupts(struct vtpci_softc *);
+static void	vtpci_free_virtqueues(struct vtpci_softc *);
+static void	vtpci_cleanup_setup_intr_attempt(struct vtpci_softc *);
+static void	vtpci_reset(struct vtpci_softc *);
+static void	vtpci_select_virtqueue(struct vtpci_softc *, int);
+static void	vtpci_legacy_intr(void *);
+static void	vtpci_config_intr(void *);
+#ifdef NOTUSED
+/* Tunables. */
+static int vtpci_disable_msix = 0;
+TUNABLE_INT("hw.virtio.pci.disable_msix", &vtpci_disable_msix);
+static device_method_t vtpci_methods[] = {
+	/* Device interface. */
+	DEVMETHOD(device_probe,			  vtpci_probe),
+	DEVMETHOD(device_attach,		  vtpci_attach),
+	DEVMETHOD(device_detach,		  vtpci_detach),
+	DEVMETHOD(device_suspend,		  vtpci_suspend),
+	DEVMETHOD(device_resume,		  vtpci_resume),
+	DEVMETHOD(device_shutdown,		  vtpci_shutdown),
+	/* Bus interface. */
+	DEVMETHOD(bus_driver_added,		  vtpci_driver_added),
+	DEVMETHOD(bus_child_detached,		  vtpci_child_detached),
+	DEVMETHOD(bus_read_config_ivar,		  vtpci_read_config_ivar),
+	DEVMETHOD(bus_write_ivar,		  vtpci_write_ivar),
+	/* VirtIO bus interface. */
+	DEVMETHOD(virtio_bus_negotiate_features,  vtpci_negotiate_features),
+	DEVMETHOD(virtio_bus_with_feature,	  vtpci_with_feature),
+	DEVMETHOD(virtio_bus_alloc_virtqueues,	  vtpci_alloc_virtqueues),
+	DEVMETHOD(virtio_bus_setup_intr,	  vtpci_setup_intr),
+	DEVMETHOD(virtio_bus_stop,		  vtpci_stop),
+	DEVMETHOD(virtio_bus_reinit,		  vtpci_reinit),
+	DEVMETHOD(virtio_bus_reinit_complete,	  vtpci_reinit_complete),
+	DEVMETHOD(virtio_bus_notify_vq,		  vtpci_notify_virtqueue),
+	DEVMETHOD(virtio_bus_read_device_config,  vtpci_read_dev_config),
+	DEVMETHOD(virtio_bus_write_device_config, vtpci_write_dev_config),
+	DEVMETHOD_END
+static driver_t vtpci_driver = {
+	"virtio_pci",
+	vtpci_methods,
+	sizeof(struct vtpci_softc)
+devclass_t vtpci_devclass;
+DRIVER_MODULE(virtio_pci, pci, vtpci_driver, vtpci_devclass, 0, 0);
+MODULE_VERSION(virtio_pci, 1);
+MODULE_DEPEND(virtio_pci, pci, 1, 1, 1);
+MODULE_DEPEND(virtio_pci, virtio, 1, 1, 1);
+static int
+vtpci_probe(device_t dev)
+	char desc[36];
+	const char *name;
+	if (pci_get_vendor(dev) != VIRTIO_PCI_VENDORID)
+		return (ENXIO);
+	if (pci_get_device(dev) < VIRTIO_PCI_DEVICEID_MIN ||
+	    pci_get_device(dev) > VIRTIO_PCI_DEVICEID_MAX)
+		return (ENXIO);
+	if (pci_get_revid(dev) != VIRTIO_PCI_ABI_VERSION)
+		return (ENXIO);
+	name = virtio_device_name(pci_get_subdevice(dev));
+	if (name == NULL)
+		name = "Unknown";
+	snprintf(desc, sizeof(desc), "VirtIO PCI %s adapter", name);
+	device_set_desc_copy(dev, desc);
+	return (BUS_PROBE_DEFAULT);
+#endif
+int rtems_vtpci_attach(
+  struct rtems_bsdnet_ifconfig *config,
+  struct vtpci_softc **xsc
+	struct vtpci_softc *sc;
+	int      error, i, ret;
+	uint32_t val32;
+	*xsc = &vtpci_softc;
+	sc = &vtpci_softc;
+	/* Parse NIC_NAME & Init structures */
+	if ( ( sc->unit_number =
+			rtems_bsdnet_parse_driver_name( config,
&sc->unit_name ) ) < 0 ) {
+		return 0;
+	/* Find device on pci bus */
+	int pbus, pdev, pfun;
+	for ( i = VIRTIO_PCI_DEVICEID_MIN; i < VIRTIO_PCI_DEVICEID_MAX; i++
+		ret = pci_find_device( VIRTIO_PCI_VENDORID, i,
sc->unit_number,
+		&pbus, &pdev, &pfun );
+		if ( ret == PCIB_ERR_SUCCESS ) {
+			sc->pci_signature = PCIB_DEVSIG_MAKE( pbus, pdev,
pfun );
+			break;
+	/* Get IO Address */
+	pcib_conf_read32( sc->pci_signature, PCI_BASE_ADDRESS_0, &val32 );
+	val32 &= PCI_BASE_ADDRESS_IO_MASK;
+	sc->pci_io_base = val32;
+	error = vtpci_attach(1);
+	return (error);
+#endif
+static int
+vtpci_attach(device_t dev)
+	device_t child;
+	int rid;
+	sc = device_get_softc(dev);
+	sc->vtpci_dev = dev;
+#ifdef NOTUSED
+	pci_enable_busmaster(dev);
+	rid = PCIR_BAR(0);
+	sc->vtpci_res = bus_alloc_resource_any(dev, SYS_RES_IOPORT, &rid,
+	    RF_ACTIVE);
+	if (sc->vtpci_res == NULL) {
+		device_printf(dev, "cannot map I/O space\n");
+		return (ENXIO);
+	if (pci_find_cap(dev, PCIY_MSI, NULL) != 0)
+		sc->vtpci_flags |= VTPCI_FLAG_NO_MSI;
+	if (pci_find_cap(dev, PCIY_MSIX, NULL) == 0) {
+		rid = PCIR_BAR(1);
+		sc->vtpci_msix_res = bus_alloc_resource_any(dev,
+		    SYS_RES_MEMORY, &rid, RF_ACTIVE);
+	if (sc->vtpci_msix_res == NULL)
+		sc->vtpci_flags |= VTPCI_FLAG_NO_MSIX;
+#endif
+#ifdef RTEMS_VIRTIO_NET
+	uint16_t val16;
+	pcib_conf_read16( sc->pci_signature, PCI_COMMAND, &val16 );
+	val16 |= PCI_COMMAND_MASTER;
+	pcib_conf_write16( sc->pci_signature, PCI_COMMAND, val16 );
+#endif
+	vtpci_reset(sc);
+	/* Tell the host we've noticed this device. */
+	vtpci_set_status(dev, VIRTIO_CONFIG_STATUS_ACK);
+#ifdef NOTUSED
+	if ((child = device_add_child(dev, NULL, -1)) == NULL) {
+		device_printf(dev, "cannot create child device\n");
+		vtpci_set_status(dev, VIRTIO_CONFIG_STATUS_FAILED);
+		vtpci_detach(dev);
+		return (ENOMEM);
+	sc->vtpci_child_dev = child;
+#endif
+	vtpci_probe_and_attach_child(sc);
+	return (0);
+#ifdef NOTUSED
+static int
+vtpci_detach(device_t dev)
+	device_t child;
+	int error;
+	if ((child = sc->vtpci_child_dev) != NULL) {
+		error = device_delete_child(dev, child);
+		if (error)
+			return (error);
+		sc->vtpci_child_dev = NULL;
+	vtpci_reset(sc);
+	if (sc->vtpci_msix_res != NULL) {
+		bus_release_resource(dev, SYS_RES_MEMORY, PCIR_BAR(1),
+		    sc->vtpci_msix_res);
+		sc->vtpci_msix_res = NULL;
+	if (sc->vtpci_res != NULL) {
+		bus_release_resource(dev, SYS_RES_IOPORT, PCIR_BAR(0),
+		    sc->vtpci_res);
+		sc->vtpci_res = NULL;
+	return (0);
+static int
+vtpci_suspend(device_t dev)
+	return (bus_generic_suspend(dev));
+static int
+vtpci_resume(device_t dev)
+	return (bus_generic_resume(dev));
+int
+vtpci_shutdown(device_t dev)
+	(void) bus_generic_shutdown(dev);
+	/* Forcibly stop the host device. */
+	vtpci_stop(dev);
+	return (0);
+static void
+vtpci_driver_added(device_t dev, driver_t *driver)
+static void
+vtpci_child_detached(device_t dev, device_t child)
+	vtpci_reset(sc);
+	vtpci_release_child_resources(sc);
+static int
+vtpci_read_config_ivar(device_t dev, device_t child, int index, uintptr_t
*result)
+	if (sc->vtpci_child_dev != child)
+		return (ENOENT);
+	switch (index) {
+	case VIRTIO_IVAR_DEVTYPE:
+	case VIRTIO_IVAR_SUBDEVICE:
+		*result = pci_get_subdevice(dev);
+		break;
+	case VIRTIO_IVAR_VENDOR:
+		*result = pci_get_vendor(dev);
+		break;
+	case VIRTIO_IVAR_DEVICE:
+		*result = pci_get_device(dev);
+		break;
+	case VIRTIO_IVAR_SUBVENDOR:
+		break;
+	default:
+		return (ENOENT);
+	return (0);
+static int
+vtpci_write_ivar(device_t dev, device_t child, int index, uintptr_t value)
+		return (ENOENT);
+	switch (index) {
+	case VIRTIO_IVAR_FEATURE_DESC:
+		sc->vtpci_child_feat_desc = (void *) value;
+		break;
+	default:
+		return (ENOENT);
+	return (0);
+#endif
+uint64_t
+vtpci_negotiate_features(device_t dev, uint64_t child_features)
+	uint64_t host_features, features;
+	host_features = vtpci_read_config_4(sc, VIRTIO_PCI_HOST_FEATURES);
+	vtpci_describe_features(sc, "host", host_features);
+	 * Limit negotiated features to what the driver, virtqueue, and
+	 * host all support.
+	features = host_features & child_features;
+	features = virtqueue_filter_features(features);
+	sc->vtpci_features = features;
+	vtpci_describe_features(sc, "negotiated", features);
+	vtpci_write_config_4(sc, VIRTIO_PCI_GUEST_FEATURES, features);
+	return (features);
+int
+vtpci_with_feature(device_t dev, uint64_t feature)
+	return ((sc->vtpci_features & feature) != 0);
+int
+vtpci_alloc_virtqueues(device_t dev, int flags, int nvqs,
+    struct vq_alloc_info *vq_info)
+	struct virtqueue *vq;
+	struct vtpci_virtqueue *vqx;
+	struct vq_alloc_info *info;
+	int idx, error;
+	uint16_t size;
+	if (sc->vtpci_nvqs != 0)
+#ifdef NOTUSED
+		return (EALREADY);
+#endif
+		return (EINVAL);
+#endif
+	if (nvqs <= 0)
+		return (EINVAL);
+	sc->vtpci_vqs = malloc(nvqs * sizeof(struct vtpci_virtqueue),
+	    M_DEVBUF, M_NOWAIT | M_ZERO);
+	if (sc->vtpci_vqs == NULL)
+		return (ENOMEM);
+	for (idx = 0; idx < nvqs; idx++) {
+		vqx = &sc->vtpci_vqs[idx];
+		info = &vq_info[idx];
+		vtpci_select_virtqueue(sc, idx);
+		size = vtpci_read_config_2(sc, VIRTIO_PCI_QUEUE_NUM);
+		error = virtqueue_alloc(dev, idx, size,
VIRTIO_PCI_VRING_ALIGN,
+		    0xFFFFFFFFUL, info, &vq);
+		if (error) {
+			    "cannot allocate virtqueue %d: %d\n", idx,
error);
+			break;
+		vtpci_write_config_4(sc, VIRTIO_PCI_QUEUE_PFN,
+		    virtqueue_paddr(vq) >> VIRTIO_PCI_QUEUE_ADDR_SHIFT);
+		vqx->vtv_vq = *info->vqai_vq = vq;
+		vqx->vtv_no_intr = info->vqai_intr == NULL;
+		sc->vtpci_nvqs++;
+	if (error)
+		vtpci_free_virtqueues(sc);
+	return (error);
+int
+vtpci_setup_intr(device_t dev, enum intr_type type)
+	int attempt, error;
+	for (attempt = 0; attempt < 5; attempt++) {
+		 * Start with the most desirable interrupt configuration and
+		 * fallback towards less desirable ones.
+		switch (attempt) {
+#ifdef NOTUSED
+		case 0:
+			error = vtpci_alloc_intr_msix_pervq(sc);
+			break;
+		case 1:
+			error = vtpci_alloc_intr_msix_shared(sc);
+			break;
+		case 2:
+			error = vtpci_alloc_intr_msi(sc);
+			break;
+		case 3:
+			error = vtpci_alloc_intr_legacy(sc);
+			break;
+#endif
+		case 0:
+			break;
+#endif
+		default:
+			    "exhausted all interrupt allocation
attempts\n");
+			return (ENXIO);
+		if (error == 0 && vtpci_setup_interrupts(sc, type) == 0)
+			break;
+		vtpci_cleanup_setup_intr_attempt(sc);
+#ifdef NOTUSED
+	if (bootverbose) {
+		if (sc->vtpci_flags & VTPCI_FLAG_LEGACY)
+			device_printf(dev, "using legacy interrupt\n");
+		else if (sc->vtpci_flags & VTPCI_FLAG_MSI)
+			device_printf(dev, "using MSI interrupt\n");
+		else if (sc->vtpci_flags & VTPCI_FLAG_SHARED_MSIX)
+			device_printf(dev, "using shared MSIX
interrupts\n");
+		else
+			device_printf(dev, "using per VQ MSIX
interrupts\n");
+#endif
+	return (0);
+void
+vtpci_stop(device_t dev)
+	vtpci_reset(device_get_softc(dev));
+int
+vtpci_reinit(device_t dev, uint64_t features)
+	int idx, error;
+	 * Redrive the device initialization. This is a bit of an abuse of
+	 * the specification, but VirtualBox, QEMU/KVM, and BHyVe seem to
+	 * play nice.
+	 * We do not allow the host device to change from what was
originally
+	 * negotiated beyond what the guest driver changed. MSIX state
should
+	 * not change, number of virtqueues and their size remain the same,
etc.
+	 * This will need to be rethought when we want to support migration.
+	if (vtpci_get_status(dev) != VIRTIO_CONFIG_STATUS_RESET)
+		vtpci_stop(dev);
+	 * Quickly drive the status through ACK and DRIVER. The device
+	 * does not become usable again until vtpci_reinit_complete().
+	vtpci_set_status(dev, VIRTIO_CONFIG_STATUS_DRIVER);
+	vtpci_negotiate_features(dev, features);
+	for (idx = 0; idx < sc->vtpci_nvqs; idx++) {
+		error = vtpci_reinit_virtqueue(sc, idx);
+		if (error)
+			return (error);
+#ifdef NOTUSED
+	if (sc->vtpci_flags & VTPCI_FLAG_MSIX) {
+		error = vtpci_set_host_msix_vectors(sc);
+		if (error)
+			return (error);
+#endif
+	return (0);
+void
+vtpci_reinit_complete(device_t dev)
+	vtpci_set_status(dev, VIRTIO_CONFIG_STATUS_DRIVER_OK);
+void
+vtpci_notify_virtqueue(device_t dev, uint16_t queue)
+	vtpci_write_config_2(sc, VIRTIO_PCI_QUEUE_NOTIFY, queue);
+static uint8_t
+vtpci_get_status(device_t dev)
+	return (vtpci_read_config_1(sc, VIRTIO_PCI_STATUS));
+static void
+vtpci_set_status(device_t dev, uint8_t status)
+	if (status != VIRTIO_CONFIG_STATUS_RESET)
+		status |= vtpci_get_status(dev);
+	vtpci_write_config_1(sc, VIRTIO_PCI_STATUS, status);
+void
+vtpci_read_dev_config(device_t dev, bus_size_t offset,
+	bus_size_t off;
+	uint8_t *d;
+	int size;
+	off = VIRTIO_PCI_CONFIG(sc) + offset;
+	for (d = dst; length > 0; d += size, off += size, length -= size) {
+		if (length >= 4) {
+			size = 4;
+			*(uint32_t *)d = vtpci_read_config_4(sc, off);
+		} else if (length >= 2) {
+			size = 2;
+			*(uint16_t *)d = vtpci_read_config_2(sc, off);
+		} else {
+			size = 1;
+			*d = vtpci_read_config_1(sc, off);
+void
+vtpci_write_dev_config(device_t dev, bus_size_t offset,
+	bus_size_t off;
+	uint8_t *s;
+	int size;
+	for (s = src; length > 0; s += size, off += size, length -= size) {
+			size = 4;
+			vtpci_write_config_4(sc, off, *(uint32_t *)s);
+			size = 2;
+			vtpci_write_config_2(sc, off, *(uint16_t *)s);
+		} else {
+			size = 1;
+			vtpci_write_config_1(sc, off, *s);
+static void
+vtpci_describe_features(struct vtpci_softc *sc, const char *msg,
+    uint64_t features)
+	device_t dev, child;
+	dev = sc->vtpci_dev;
+#ifdef NOTUSED
+	child = sc->vtpci_child_dev;
+	if (device_is_attached(child) && bootverbose == 0)
+		return;
+#endif
+	virtio_describe(dev, msg, features, sc->vtpci_child_feat_desc);
+static void
+vtpci_probe_and_attach_child(struct vtpci_softc *sc)
+#ifdef NOTUSED
+	if (child == NULL)
+		return;
+	if (device_get_state(child) != DS_NOTPRESENT)
+		return;
+	if (device_probe(child) != 0)
+		return;
+#endif
+#endif
+#ifdef NOTUSED
+	if (device_attach(child) != 0) {
+		vtpci_reset(sc);
+		/* Reset status for future attempt. */
+	} else {
+		VIRTIO_ATTACH_COMPLETED(child);
+#endif
+#ifdef NOTUSED
+static int
+vtpci_alloc_msix(struct vtpci_softc *sc, int nvectors)
+	device_t dev;
+	int nmsix, cnt, required;
+	/* Allocate an additional vector for the config changes. */
+	required = nvectors + 1;
+	nmsix = pci_msix_count(dev);
+	if (nmsix < required)
+		return (1);
+	cnt = required;
+	if (pci_alloc_msix(dev, &cnt) == 0 && cnt >= required) {
+		sc->vtpci_nmsix_resources = required;
+		return (0);
+	pci_release_msi(dev);
+	return (1);
+static int
+vtpci_alloc_msi(struct vtpci_softc *sc)
+	device_t dev;
+	int nmsi, cnt, required;
+	required = 1;
+	nmsi = pci_msi_count(dev);
+	if (nmsi < required)
+		return (1);
+	cnt = required;
+	if (pci_alloc_msi(dev, &cnt) == 0 && cnt >= required)
+		return (0);
+	return (1);
+static int
+vtpci_alloc_intr_msix_pervq(struct vtpci_softc *sc)
+	int i, nvectors, error;
+	if (vtpci_disable_msix != 0 ||
+	    sc->vtpci_flags & VTPCI_FLAG_NO_MSIX)
+		return (ENOTSUP);
+	for (nvectors = 0, i = 0; i < sc->vtpci_nvqs; i++) {
+		if (sc->vtpci_vqs[i].vtv_no_intr == 0)
+			nvectors++;
+	error = vtpci_alloc_msix(sc, nvectors);
+	if (error)
+		return (error);
+	sc->vtpci_flags |= VTPCI_FLAG_MSIX;
+	return (0);
+static int
+vtpci_alloc_intr_msix_shared(struct vtpci_softc *sc)
+	int error;
+		return (ENOTSUP);
+	error = vtpci_alloc_msix(sc, 1);
+	if (error)
+		return (error);
+	sc->vtpci_flags |= VTPCI_FLAG_MSIX | VTPCI_FLAG_SHARED_MSIX;
+	return (0);
+static int
+vtpci_alloc_intr_msi(struct vtpci_softc *sc)
+	int error;
+	/* Only BHyVe supports MSI. */
+	if (sc->vtpci_flags & VTPCI_FLAG_NO_MSI)
+		return (ENOTSUP);
+	error = vtpci_alloc_msi(sc);
+	if (error)
+		return (error);
+	sc->vtpci_flags |= VTPCI_FLAG_MSI;
+	return (0);
+#endif
+static int
+vtpci_alloc_intr_legacy(struct vtpci_softc *sc)
+	sc->vtpci_flags |= VTPCI_FLAG_LEGACY;
+	return (0);
+static int
+vtpci_alloc_interrupt(struct vtpci_softc *sc, int rid, int flags,
+    struct vtpci_interrupt *intr)
+#ifdef NOTUSED
+	struct resource *irq;
+	irq = bus_alloc_resource_any(sc->vtpci_dev, SYS_RES_IRQ, &rid,
flags);
+	if (irq == NULL)
+		return (ENXIO);
+	intr->vti_irq = irq;
+	intr->vti_rid = rid;
+#endif
+	uint8_t val8;
+	pcib_conf_read8( sc->pci_signature, PCI_INTERRUPT_LINE, &val8 );
+	intr->isr_number = val8;
+#endif
+	return (0);
+static int
+vtpci_alloc_intr_resources(struct vtpci_softc *sc)
+	struct vtpci_interrupt *intr;
+	int i, rid, flags, nvq_intrs, error;
+	rid = 0;
+#ifdef NOTUSED
+	flags = RF_ACTIVE;
+		flags |= RF_SHAREABLE;
+	else
+		rid = 1;
+#endif
+	 * For legacy and MSI interrupts, this single resource handles all
+	 * interrupts. For MSIX, this resource is used for the configuration
+	 * changed interrupt.
+	intr = &sc->vtpci_device_interrupt;
+	error = vtpci_alloc_interrupt(sc, rid, flags, intr);
+	if (error || sc->vtpci_flags & (VTPCI_FLAG_LEGACY | VTPCI_FLAG_MSI))
+		return (error);
+#ifdef NOTUSED
+	/* Subtract one for the configuration changed interrupt. */
+	nvq_intrs = sc->vtpci_nmsix_resources - 1;
+	intr = sc->vtpci_msix_vq_interrupts = malloc(nvq_intrs *
+	    sizeof(struct vtpci_interrupt), M_DEVBUF, M_NOWAIT | M_ZERO);
+	if (sc->vtpci_msix_vq_interrupts == NULL)
+		return (ENOMEM);
+	for (i = 0, rid++; i < nvq_intrs; i++, rid++, intr++) {
+		if (error)
+			return (error);
+#endif
+	return (0);
+static int
+vtpci_setup_legacy_interrupt(struct vtpci_softc *sc, enum intr_type type)
+	int error;
+#ifdef NOTUSED
+	error = bus_setup_intr(sc->vtpci_dev, intr->vti_irq, type, NULL,
+	    vtpci_legacy_intr, sc, &intr->vti_handler);
+#endif
+	error = rtems_interrupt_handler_install(
+		intr->isr_number,
+		NULL,
+		RTEMS_INTERRUPT_SHARED,
+		(rtems_interrupt_handler) vtpci_legacy_intr,
+		sc);
+	intr->vti_handler = vtpci_legacy_intr;
+#endif
+	return (error);
+#ifdef NOTUSED
+static int
+vtpci_setup_pervq_msix_interrupts(struct vtpci_softc *sc, enum intr_type
type)
+	int i, error;
+	intr = sc->vtpci_msix_vq_interrupts;
+	for (i = 0; i < sc->vtpci_nvqs; i++) {
+		vqx = &sc->vtpci_vqs[i];
+		if (vqx->vtv_no_intr)
+			continue;
+		    vtpci_vq_intr_filter, vtpci_vq_intr, vqx->vtv_vq,
+		    &intr->vti_handler);
+		if (error)
+			return (error);
+		intr++;
+	return (0);
+static int
+vtpci_setup_msix_interrupts(struct vtpci_softc *sc, enum intr_type type)
+	device_t dev;
+	int error;
+	error = bus_setup_intr(dev, intr->vti_irq, type, NULL,
+	    vtpci_config_intr, sc, &intr->vti_handler);
+	if (error)
+		return (error);
+	if (sc->vtpci_flags & VTPCI_FLAG_SHARED_MSIX) {
+		    vtpci_vq_shared_intr_filter, vtpci_vq_shared_intr, sc,
+	} else
+		error = vtpci_setup_pervq_msix_interrupts(sc, type);
+	return (error ? error : vtpci_set_host_msix_vectors(sc));
+#endif
+static int
+vtpci_setup_interrupts(struct vtpci_softc *sc, enum intr_type type)
+	int error;
+	type |= INTR_MPSAFE;
+	KASSERT(sc->vtpci_flags & VTPCI_FLAG_ITYPE_MASK,
+	    ("%s: no interrupt type selected %#x", __func__,
sc->vtpci_flags));
+	error = vtpci_alloc_intr_resources(sc);
+	if (error)
+		return (error);
+		error = vtpci_setup_legacy_interrupt(sc, type);
+#ifdef NOTUSED
+		error = vtpci_setup_msi_interrupt(sc, type);
+	else
+		error = vtpci_setup_msix_interrupts(sc, type);
+#endif
+	return (error);
+#ifdef NOTUSED
+static int
+vtpci_register_msix_vector(struct vtpci_softc *sc, int offset,
+	device_t dev;
+	uint16_t vector;
+	if (intr != NULL) {
+		/* Map from guest rid to host vector. */
+		vector = intr->vti_rid - 1;
+	} else
+		vector = VIRTIO_MSI_NO_VECTOR;
+	vtpci_write_config_2(sc, offset, vector);
+	/* Read vector to determine if the host had sufficient resources. */
+	if (vtpci_read_config_2(sc, offset) != vector) {
+		    "insufficient host resources for MSIX interrupts\n");
+		return (ENODEV);
+	return (0);
+static int
+vtpci_set_host_msix_vectors(struct vtpci_softc *sc)
+	struct vtpci_interrupt *intr, *tintr;
+	int idx, offset, error;
+	offset = VIRTIO_MSI_CONFIG_VECTOR;
+	error = vtpci_register_msix_vector(sc, offset, intr);
+	if (error)
+		return (error);
+	offset = VIRTIO_MSI_QUEUE_VECTOR;
+		if (sc->vtpci_vqs[idx].vtv_no_intr)
+			tintr = NULL;
+		else
+			tintr = intr;
+		error = vtpci_register_msix_vector(sc, offset, tintr);
+		if (error)
+			break;
+		 * For shared MSIX, all the virtqueues share the first
+		 * interrupt.
+		if ((sc->vtpci_flags & VTPCI_FLAG_SHARED_MSIX) == 0)
+			intr++;
+	return (error);
+#endif
+static int
+vtpci_reinit_virtqueue(struct vtpci_softc *sc, int idx)
+	int error;
+	uint16_t size;
+	vq = vqx->vtv_vq;
+	KASSERT(vq != NULL, ("%s: vq %d not allocated", __func__, idx));
+	error = virtqueue_reinit(vq, size);
+	if (error)
+		return (error);
+	return (0);
+static void
+vtpci_free_interrupt(struct vtpci_softc *sc, struct vtpci_interrupt *intr)
+	device_t dev;
+#ifdef NOTUSED
+	if (intr->vti_handler != NULL) {
+		bus_teardown_intr(dev, intr->vti_irq, intr->vti_handler);
+		intr->vti_handler = NULL;
+	if (intr->vti_irq != NULL) {
+		bus_release_resource(dev, SYS_RES_IRQ, intr->vti_rid,
+		    intr->vti_irq);
+		intr->vti_irq = NULL;
+		intr->vti_rid = -1;
+#endif
+	if( intr->isr_number != 0 ){
+		rtems_interrupt_handler_remove(
+			intr->isr_number,
+			NULL);
+#endif
+static void
+vtpci_free_interrupts(struct vtpci_softc *sc)
+	int i, nvq_intrs;
+	vtpci_free_interrupt(sc, &sc->vtpci_device_interrupt);
+	if (sc->vtpci_nmsix_resources != 0) {
+		sc->vtpci_nmsix_resources = 0;
+			for (i = 0; i < nvq_intrs; i++, intr++)
+				vtpci_free_interrupt(sc, intr);
+			free(sc->vtpci_msix_vq_interrupts, M_DEVBUF);
+			sc->vtpci_msix_vq_interrupts = NULL;
+#ifdef NOTUSED
+	if (sc->vtpci_flags & (VTPCI_FLAG_MSI | VTPCI_FLAG_MSIX))
+		pci_release_msi(sc->vtpci_dev);
+#endif
+	sc->vtpci_flags &= ~VTPCI_FLAG_ITYPE_MASK;
+static void
+vtpci_free_virtqueues(struct vtpci_softc *sc)
+	int idx;
+		vtpci_write_config_4(sc, VIRTIO_PCI_QUEUE_PFN, 0);
+		virtqueue_free(vqx->vtv_vq);
+		vqx->vtv_vq = NULL;
+	free(sc->vtpci_vqs, M_DEVBUF);
+	sc->vtpci_vqs = NULL;
+	sc->vtpci_nvqs = 0;
+#ifdef NOTUSED
+static void
+vtpci_release_child_resources(struct vtpci_softc *sc)
+	vtpci_free_interrupts(sc);
+#endif
+static void
+vtpci_cleanup_setup_intr_attempt(struct vtpci_softc *sc)
+	int idx;
+		vtpci_write_config_2(sc, VIRTIO_MSI_CONFIG_VECTOR,
+		    VIRTIO_MSI_NO_VECTOR);
+			vtpci_write_config_2(sc, VIRTIO_MSI_QUEUE_VECTOR,
+static void
+vtpci_reset(struct vtpci_softc *sc)
+	 * Setting the status to RESET sets the host device to
+	 * the original, uninitialized state.
+	vtpci_set_status(sc->vtpci_dev, VIRTIO_CONFIG_STATUS_RESET);
+static void
+vtpci_select_virtqueue(struct vtpci_softc *sc, int idx)
+	vtpci_write_config_2(sc, VIRTIO_PCI_QUEUE_SEL, idx);
+static void
+vtpci_legacy_intr(void *xsc)
+	int i;
+	uint8_t isr;
+	sc = xsc;
+	vqx = &sc->vtpci_vqs[0];
+	/* Reading the ISR also clears it. */
+	isr = vtpci_read_config_1(sc, VIRTIO_PCI_ISR);
+	if (isr & VIRTIO_PCI_ISR_CONFIG)
+		vtpci_config_intr(sc);
+	if (isr & VIRTIO_PCI_ISR_INTR) {
+#ifdef NOTUSED
+		for (i = 0; i < sc->vtpci_nvqs; i++, vqx++) {
+			if (vqx->vtv_no_intr == 0)
+				virtqueue_intr(vqx->vtv_vq);
+#endif
+	    rtems_bsdnet_event_send( sc->daemonTid, RTEMS_EVENT_1 );
+#endif
+#ifdef NOTUSED
+static int
+vtpci_vq_shared_intr_filter(void *xsc)
+	int i, rc;
+	rc = 0;
+	sc = xsc;
+			rc |= virtqueue_intr_filter(vqx->vtv_vq);
+	return (rc ? FILTER_SCHEDULE_THREAD : FILTER_STRAY);
+static void
+vtpci_vq_shared_intr(void *xsc)
+	int i;
+	sc = xsc;
+static int
+vtpci_vq_intr_filter(void *xvq)
+	int rc;
+	vq = xvq;
+	rc = virtqueue_intr_filter(vq);
+static void
+vtpci_vq_intr(void *xvq)
+	vq = xvq;
+	virtqueue_intr(vq);
+#endif
+static void
+vtpci_config_intr(void *xsc)
+	device_t child;
+	sc = xsc;
+#ifdef NOTUSED
+	if (child != NULL)
+		VIRTIO_CONFIG_CHANGE(child);
+#endif
+#endif /* __i386__ */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.h
b/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.h
new file mode 100644
index 0000000..c34708e
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio_pci.h
@@ -0,0 +1,166 @@
+ * @file virtio_pci.h
+ * @brief Header for virtio_pci.c
+ * Authors: Jin-Hyun Kim <jinhyun at konkuk.ac.kr>,
+ *   and Hyun-Wook Jin <jinh at konkuk.ac.kr>, http://sslab.konkuk.ac.kr
+ * Ported from FreeBSD to RTEMS March 16
+ * http://www.rtems.org/license/LICENSE.NET
+ * Copyright IBM Corp. 2007
+ * Authors:
+ *  Anthony Liguori  <aliguori at us.ibm.com>
implement
+ * are met:
LIMITED
PARTICULAR
CONSEQUENTIAL
STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY `
+ * SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/pci/virtio_pci.h 238360
2012-07-11 02:57:19Z grehan $
+#ifndef _VIRTIO_PCI_H
+#define _VIRTIO_PCI_H
+	int			 vtv_no_intr;
+#ifdef NOTUSED
+#endif
+	int unit_number;
+	char *unit_name;
+	int pci_signature;
+	uint32_t pci_io_base;
+	rtems_id daemonTid;
+#endif
+	int				 vtpci_nvqs;
will
own
+	 * vector.
device
+int rtems_vtpci_attach(struct rtems_bsdnet_ifconfig *config, struct
vtpci_softc **xsc);
+uint64_t vtpci_negotiate_features(device_t, uint64_t);
+int	vtpci_with_feature(device_t, uint64_t);
+int	vtpci_alloc_virtqueues(device_t, int, int,
+int	vtpci_setup_intr(device_t, enum intr_type);
+void vtpci_stop(device_t);
+int	vtpci_reinit(device_t, uint64_t);
+void vtpci_reinit_complete(device_t);
+void vtpci_notify_virtqueue(device_t, uint16_t);
+void vtpci_read_dev_config(device_t, bus_size_t, void *, int);
+void vtpci_write_dev_config(device_t, bus_size_t, void *, int);
+/* VirtIO PCI vendor/device ID. */
+#define VIRTIO_PCI_VENDORID	0x1AF4
+#define VIRTIO_PCI_DEVICEID_MIN	0x1000
+#define VIRTIO_PCI_DEVICEID_MAX	0x103F
+/* VirtIO ABI version, this must match exactly. */
+#define VIRTIO_PCI_ABI_VERSION	0
+ * VirtIO Header, located in BAR 0.
+#define VIRTIO_PCI_HOST_FEATURES  0  /* host's supported features (32bit,
RO)*/
+#define VIRTIO_PCI_GUEST_FEATURES 4  /* guest's supported features (32, RW)
+#define VIRTIO_PCI_QUEUE_PFN      8  /* physical address of VQ (32, RW) */
+#define VIRTIO_PCI_QUEUE_NUM      12 /* number of ring entries (16, RO) */
+#define VIRTIO_PCI_QUEUE_SEL      14 /* current VQ selection (16, RW) */
+#define VIRTIO_PCI_QUEUE_NOTIFY	  16 /* notify host regarding VQ
(16, RW) */
+#define VIRTIO_PCI_STATUS         18 /* device status register (8, RW) */
+#define VIRTIO_PCI_ISR            19 /* interrupt status register, reading
+				      * also clears the register (8, RO) */
+/* Only if MSIX is enabled: */
+#define VIRTIO_MSI_CONFIG_VECTOR  20 /* configuration change vector (16,
RW) */
+#define VIRTIO_MSI_QUEUE_VECTOR   22 /* vector for selected VQ
notifications
+					(16, RW) */
+/* The bit of the ISR which indicates a device has an interrupt. */
+#define VIRTIO_PCI_ISR_INTR	0x1
+/* The bit of the ISR which indicates a device configuration change. */
+#define VIRTIO_PCI_ISR_CONFIG	0x2
+/* Vector value used to disable MSI for queue. */
+#define VIRTIO_MSI_NO_VECTOR	0xFFFF
+ * The remaining space is defined by each driver as the per-driver
+ * configuration space.
+#define VIRTIO_PCI_CONFIG(sc) \
+    (((sc)->vtpci_flags & VTPCI_FLAG_MSIX) ? 24 : 20)
+ * How many bits to shift physical queue address written to QUEUE_PFN.
+ * 12 is historical, and due to x86 page size.
+#define VIRTIO_PCI_QUEUE_ADDR_SHIFT	12
+/* The alignment to use between consumer and producer parts of vring. */
+#define VIRTIO_PCI_VRING_ALIGN	4096
+#endif /* _VIRTIO_PCI_H */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtio_ring.h
b/c/src/lib/libbsp/i386/pc386/virtio/virtio_ring.h
index 0000000..3e780c5
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtio_ring.h
@@ -0,0 +1,180 @@
+ * @file virtio_ring.h
+ * Copyright Rusty Russell IBM Corporation 2007.
implement
+ * are met:
LIMITED
PARTICULAR
CONSEQUENTIAL
STRICT
WAY
+ * SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/virtio_ring.h 238360 2012-07-11
02:57:19Z grehan $
+#ifndef VIRTIO_RING_H
+#define	VIRTIO_RING_H
+/* This marks a buffer as continuing via the next field. */
+#define VRING_DESC_F_NEXT       1
+/* This marks a buffer as write-only (otherwise read-only). */
+#define VRING_DESC_F_WRITE      2
+/* This means the buffer contains a list of buffer descriptors. */
+#define VRING_DESC_F_INDIRECT	4
+/* The Host uses this in used->flags to advise the Guest: don't kick me
+ * when you add a buffer.  It's unreliable, so it's simply an
+ * optimization.  Guest will still kick if it's out of buffers. */
+#define VRING_USED_F_NO_NOTIFY  1
+/* The Guest uses this in avail->flags to advise the Host: don't
+ * interrupt me when you consume a buffer.  It's unreliable, so it's
+ * simply an optimization.  */
+#define VRING_AVAIL_F_NO_INTERRUPT      1
+/* VirtIO ring descriptors: 16 bytes.
+ * These can chain together via "next". */
+struct vring_desc {
+        /* Address (guest-physical). */
+        uint64_t addr;
+        /* Length. */
+        uint32_t len;
+        /* The flags as indicated above. */
+        uint16_t flags;
+        /* We chain unused descriptors via this, too. */
+        uint16_t next;
+struct vring_avail {
+        uint16_t flags;
+        uint16_t idx;
+        uint16_t ring[0];
+/* uint32_t is used here for ids for padding reasons. */
+struct vring_used_elem {
+        /* Index of start of used descriptor chain. */
+        uint32_t id;
+        /* Total length of the descriptor chain which was written to. */
+        uint32_t len;
+struct vring_used {
+        uint16_t flags;
+        uint16_t idx;
+        struct vring_used_elem ring[0];
+struct vring {
+	unsigned int num;
+	struct vring_desc *desc;
+	struct vring_avail *avail;
+	struct vring_used *used;
+/* The standard layout for the ring is a continuous chunk of memory which
+ * looks like this.  We assume num is a power of 2.
+ * struct vring {
+ *      // The actual descriptors (16 bytes each)
+ *      struct vring_desc desc[num];
+ *      // A ring of available descriptor heads with free-running index.
+ *      __u16 avail_flags;
+ *      __u16 avail_idx;
+ *      __u16 available[num];
+ *      __u16 used_event_idx;
+ *      // Padding to the next align boundary.
+ *      char pad[];
+ *      // A ring of used descriptor heads with free-running index.
+ *      __u16 used_flags;
+ *      __u16 used_idx;
+ *      struct vring_used_elem used[num];
+ *      __u16 avail_event_idx;
+ * NOTE: for VirtIO PCI, align is 4096.
+ * We publish the used event index at the end of the available ring, and
vice
+ * versa. They are at the end for backwards compatibility.
+#define vring_used_event(vr)	((vr)->avail->ring[(vr)->num])
+#define vring_avail_event(vr)	(*(uint16_t *)&(vr)->used->ring[(vr)->num])
+static inline int
+vring_size(unsigned int num, unsigned long align)
+	int size;
+	size = num * sizeof(struct vring_desc);
+	size += sizeof(struct vring_avail) + (num * sizeof(uint16_t)) +
+	    sizeof(uint16_t);
+	size = (size + align - 1) & ~(align - 1);
+	size += sizeof(struct vring_used) +
+	    (num * sizeof(struct vring_used_elem)) + sizeof(uint16_t);
+	return (size);
+static inline void
+vring_init(struct vring *vr, unsigned int num, uint8_t *p,
+    unsigned long align)
+        vr->num = num;
+        vr->desc = (struct vring_desc *) p;
+        vr->avail = (struct vring_avail *) (p +
+	    num * sizeof(struct vring_desc));
+        vr->used = (void *)
+	    (((unsigned long) &vr->avail->ring[num] + align-1) &
~(align-1));
+ * The following is used with VIRTIO_RING_F_EVENT_IDX.
+ * Assuming a given event_idx value from the other size, if we have
+ * just incremented index from old to new_idx, should we trigger an
+ * event?
+static inline int
+vring_need_event(uint16_t event_idx, uint16_t new_idx, uint16_t old)
+	return (uint16_t)(new_idx - event_idx - 1) < (uint16_t)(new_idx -
old);
+#endif /* VIRTIO_RING_H */
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtqueue.c
b/c/src/lib/libbsp/i386/pc386/virtio/virtqueue.c
index 0000000..1d07b76
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtqueue.c
@@ -0,0 +1,963 @@
+ * @file virqueue.c
+ * @brief Implements the virtqueue interface as basically described
+ * in the original VirtIO paper.
+ * Copyright (c) 2011, Bryan Venteicher <bryanv at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ *    notice unmodified, this list of conditions, and the following
+ *    disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/virtqueue.c 255166 2013-09-03
02:26:57Z bryanv $
+#include <rtems.h>
+#include <bsp.h>
+#include "virtio_ring.h"
+static uint16_t rtems_vq_ring_enqueue_segments(struct virtqueue *vq,
+	struct vring_desc *desc, uint16_t head_idx, struct mbuf *m_head,
+	int readable, int writable);
+#endif
+#define	VIRTQUEUE_FLAG_INDIRECT	 0x0001
+#define	VIRTQUEUE_FLAG_EVENT_IDX 0x0002
+struct vq_desc_extra {
+		void		  *cookie;
+		struct vring_desc *indirect;
+		vm_paddr_t	   indirect_paddr;
+		uint16_t	   ndescs;
+struct virtqueue {
+	device_t		 vq_dev;
+	char			 vq_name[VIRTQUEUE_MAX_NAME_SZ];
+	uint16_t		 vq_queue_index;
+	uint16_t		 vq_nentries;
+	uint32_t		 vq_flags;
+	int			 vq_alignment;
+	int			 vq_ring_size;
+	void			*vq_ring_mem;
+	void			*vq_ring_mem_orig;
+	int			 vq_max_indirect_size;
+	int			 vq_indirect_mem_size;
+	virtqueue_intr_t	*vq_intrhand;
+	void			*vq_intrhand_arg;
+	struct vring		 vq_ring;
+	uint16_t		 vq_free_cnt;
+	uint16_t		 vq_queued_cnt;
+	 * Head of the free chain in the descriptor table. If
+	 * there are no free descriptors, this will be set to
+	 * VQ_RING_DESC_CHAIN_END.
+	uint16_t		 vq_desc_head_idx;
+	 * Last consumed descriptor in the used table,
+	 * trails vq_ring.used->idx.
+	uint16_t		 vq_used_cons_idx;
+	struct vq_desc_extra vq_descx[10];
+ * The maximum virtqueue size is 2^15. Use that value as the end of
+ * descriptor chain terminator since it will never be a valid index
+ * in the descriptor table. This is used to verify we are correctly
+ * handling vq_free_cnt.
+#define VQ_RING_DESC_CHAIN_END 32768
+#define VQASSERT(_vq, _exp, _msg, ...)				\
+    KASSERT((_exp),("%s: %s - "_msg, __func__, (_vq)->vq_name,	\
+	##__VA_ARGS__))
+#define VQ_RING_ASSERT_VALID_IDX(_vq, _idx)			\
+    VQASSERT((_vq), (_idx) < (_vq)->vq_nentries,		\
+	"invalid ring index: %d, max: %d", (_idx),		\
+	(_vq)->vq_nentries)
+#define VQ_RING_ASSERT_CHAIN_TERM(_vq)				\
+    VQASSERT((_vq), (_vq)->vq_desc_head_idx ==			\
+	VQ_RING_DESC_CHAIN_END,	"full ring terminated "		\
+	"incorrectly: head idx: %d", (_vq)->vq_desc_head_idx)
+#ifdef NOTUSED
+static int	virtqueue_init_indirect(struct virtqueue *vq, int);
+static void	virtqueue_free_indirect(struct virtqueue *vq);
+static void	virtqueue_init_indirect_list(struct virtqueue *,
+		    struct vring_desc *);
+static uint16_t	vq_ring_enqueue_segments(struct virtqueue *,
+		    struct vring_desc *, uint16_t, struct sglist *, int,
int);
+static int	vq_ring_use_indirect(struct virtqueue *, int);
+static void	vq_ring_enqueue_indirect(struct virtqueue *, void *,
+#endif
+static void	vq_ring_init(struct virtqueue *);
+static void	vq_ring_update_avail(struct virtqueue *, uint16_t);
+static int	vq_ring_enable_interrupt(struct virtqueue *, uint16_t);
+static int	vq_ring_must_notify_host(struct virtqueue *);
+static void	vq_ring_notify_host(struct virtqueue *);
+static void	vq_ring_free_chain(struct virtqueue *, uint16_t);
+uint64_t
+virtqueue_filter_features(uint64_t features)
+	uint64_t mask;
+	mask = (1 << VIRTIO_TRANSPORT_F_START) - 1;
+	mask |= VIRTIO_RING_F_INDIRECT_DESC;
+	mask |= VIRTIO_RING_F_EVENT_IDX;
+	return (features & mask);
+int
+virtqueue_alloc(device_t dev, uint16_t queue, uint16_t size, int align,
+    vm_paddr_t highaddr, struct vq_alloc_info *info, struct virtqueue
**vqp)
+	int error;
+	*vqp = NULL;
+	error = 0;
+	if (size == 0) {
+		    "virtqueue %d (%s) does not exist (size is zero)\n",
+		    queue, info->vqai_name);
+		return (ENODEV);
+	} else if (!powerof2(size)) {
+		    "virtqueue %d (%s) size is not a power of 2: %d\n",
+		    queue, info->vqai_name, size);
+		return (ENXIO);
+	} else if (info->vqai_maxindirsz > VIRTIO_MAX_INDIRECT) {
+		device_printf(dev, "virtqueue %d (%s) requested too many "
+		    "indirect descriptors: %d, max %d\n",
+		    queue, info->vqai_name, info->vqai_maxindirsz,
+		    VIRTIO_MAX_INDIRECT);
+		return (EINVAL);
+	vq = malloc(sizeof(struct virtqueue) +
+	    size * sizeof(struct vq_desc_extra), M_DEVBUF, M_NOWAIT |
M_ZERO);
+	if (vq == NULL) {
+		device_printf(dev, "cannot allocate virtqueue\n");
+		return (ENOMEM);
+	vq->vq_dev = dev;
+	strlcpy(vq->vq_name, info->vqai_name, sizeof(vq->vq_name));
+	vq->vq_queue_index = queue;
+	vq->vq_alignment = align;
+	vq->vq_nentries = size;
+	vq->vq_free_cnt = size;
+	vq->vq_intrhand = info->vqai_intr;
+	vq->vq_intrhand_arg = info->vqai_intr_arg;
+	if (VIRTIO_BUS_WITH_FEATURE(dev, VIRTIO_RING_F_EVENT_IDX) != 0)
+		vq->vq_flags |= VIRTQUEUE_FLAG_EVENT_IDX;
+#ifdef NOTUSED
+	if (info->vqai_maxindirsz > 1) {
+		error = virtqueue_init_indirect(vq, info->vqai_maxindirsz);
+		if (error)
+			goto fail;
+	vq->vq_ring_size = round_page(vring_size(size, align));
+	vq->vq_ring_mem = contigmalloc(vq->vq_ring_size, M_DEVBUF,
+	    M_NOWAIT | M_ZERO, 0, highaddr, PAGE_SIZE, 0);
+#endif
+	vq->vq_ring_size = vring_size(size, align);
+	vq->vq_ring_mem = malloc(vq->vq_ring_size+align, M_DEVBUF,
M_NOWAIT);
+	vq->vq_ring_mem_orig = vq->vq_ring_mem;
+	if ( ( (unsigned long) vq->vq_ring_mem % align ) > 0 ) {
+		vq->vq_ring_mem =
+		(void *) ( (unsigned long) vq->vq_ring_mem +
+		( align - ( (unsigned long) vq->vq_ring_mem % align ) ) );
+#endif
+	if (vq->vq_ring_mem == NULL) {
+		    "cannot allocate memory for virtqueue ring\n");
+		error = ENOMEM;
+		goto fail;
+	vq_ring_init(vq);
+	virtqueue_disable_intr(vq);
+	*vqp = vq;
+fail:
+	if (error)
+		virtqueue_free(vq);
+	return (error);
+#ifdef NOTUSED
+static int
+virtqueue_init_indirect(struct virtqueue *vq, int indirect_size)
+	device_t dev;
+	struct vq_desc_extra *dxp;
+	int i, size;
+	dev = vq->vq_dev;
+	if (VIRTIO_BUS_WITH_FEATURE(dev, VIRTIO_RING_F_INDIRECT_DESC) == 0)
+		 * Indirect descriptors requested by the driver but not
+		 * negotiated. Return zero to keep the initialization
+		 * going: we'll run fine without.
+		if (bootverbose)
+			device_printf(dev, "virtqueue %d (%s) requested "
+			    "indirect descriptors but not negotiated\n",
+			    vq->vq_queue_index, vq->vq_name);
+		return (0);
+	size = indirect_size * sizeof(struct vring_desc);
+	vq->vq_max_indirect_size = indirect_size;
+	vq->vq_indirect_mem_size = size;
+	vq->vq_flags |= VIRTQUEUE_FLAG_INDIRECT;
+	for (i = 0; i < vq->vq_nentries; i++) {
+		dxp = &vq->vq_descx[i];
+		dxp->indirect = malloc(size, M_DEVBUF, M_NOWAIT);
+		if (dxp->indirect == NULL) {
+			device_printf(dev, "cannot allocate indirect
list\n");
+			return (ENOMEM);
+		dxp->indirect_paddr = vtophys(dxp->indirect);
+		virtqueue_init_indirect_list(vq, dxp->indirect);
+	return (0);
+static void
+virtqueue_free_indirect(struct virtqueue *vq)
+	int i;
+			break;
+		free(dxp->indirect, M_DEVBUF);
+		dxp->indirect = NULL;
+		dxp->indirect_paddr = 0;
+	vq->vq_flags &= ~VIRTQUEUE_FLAG_INDIRECT;
+	vq->vq_indirect_mem_size = 0;
+static void
+virtqueue_init_indirect_list(struct virtqueue *vq,
+    struct vring_desc *indirect)
+	int i;
+	bzero(indirect, vq->vq_indirect_mem_size);
+	for (i = 0; i < vq->vq_max_indirect_size - 1; i++)
+		indirect[i].next = i + 1;
+	indirect[i].next = VQ_RING_DESC_CHAIN_END;
+#endif
+int
+virtqueue_reinit(struct virtqueue *vq, uint16_t size)
+	int i;
+	if (vq->vq_nentries != size) {
+		device_printf(vq->vq_dev,
+		    "%s: '%s' changed size; old=%hu, new=%hu\n",
+		    __func__, vq->vq_name, vq->vq_nentries, size);
+		return (EINVAL);
+	/* Warn if the virtqueue was not properly cleaned up. */
+	if (vq->vq_free_cnt != vq->vq_nentries) {
+		    "%s: warning '%s' virtqueue not empty, "
+		    "leaking %d entries\n", __func__, vq->vq_name,
+		    vq->vq_nentries - vq->vq_free_cnt);
+	vq->vq_desc_head_idx = 0;
+	vq->vq_used_cons_idx = 0;
+	vq->vq_queued_cnt = 0;
+	vq->vq_free_cnt = vq->vq_nentries;
+	/* To be safe, reset all our allocated memory. */
+	bzero(vq->vq_ring_mem, vq->vq_ring_size);
+		dxp->cookie = NULL;
+		dxp->ndescs = 0;
+#ifdef NOTUSED
+		if (vq->vq_flags & VIRTQUEUE_FLAG_INDIRECT)
+#endif
+	vq_ring_init(vq);
+	return (0);
+void
+virtqueue_free(struct virtqueue *vq)
+		device_printf(vq->vq_dev, "%s: freeing non-empty virtqueue,
+		    "leaking %d entries\n", vq->vq_name,
+#ifdef NOTUSED
+		virtqueue_free_indirect(vq);
+#endif
+	if (vq->vq_ring_mem != NULL) {
+#ifdef NOTUSED
+		contigfree(vq->vq_ring_mem, vq->vq_ring_size, M_DEVBUF);
+#endif
+		free(vq->vq_ring_mem_orig, M_DEVBUF);
+#endif
+		vq->vq_ring_size = 0;
+		vq->vq_ring_mem = NULL;
+	free(vq, M_DEVBUF);
+vm_paddr_t
+virtqueue_paddr(struct virtqueue *vq)
+	return (vtophys(vq->vq_ring_mem));
+int
+virtqueue_size(struct virtqueue *vq)
+	return (vq->vq_nentries);
+int
+virtqueue_empty(struct virtqueue *vq)
+	return (vq->vq_nentries == vq->vq_free_cnt);
+int
+virtqueue_full(struct virtqueue *vq)
+	return (vq->vq_free_cnt == 0);
+void
+virtqueue_notify(struct virtqueue *vq)
+	/* Ensure updated avail->idx is visible to host. */
+	mb();
+	if (vq_ring_must_notify_host(vq))
+		vq_ring_notify_host(vq);
+int
+virtqueue_nused(struct virtqueue *vq)
+	uint16_t used_idx, nused;
+	used_idx = vq->vq_ring.used->idx;
+	nused = (uint16_t)(used_idx - vq->vq_used_cons_idx);
+	VQASSERT(vq, nused <= vq->vq_nentries, "used more than available");
+	return (nused);
+int
+virtqueue_intr_filter(struct virtqueue *vq)
+	if (vq->vq_used_cons_idx == vq->vq_ring.used->idx)
+		return (0);
+	return (1);
+void
+virtqueue_intr(struct virtqueue *vq)
+	vq->vq_intrhand(vq->vq_intrhand_arg);
+int
+virtqueue_enable_intr(struct virtqueue *vq)
+	return (vq_ring_enable_interrupt(vq, 0));
+int
+virtqueue_postpone_intr(struct virtqueue *vq, vq_postpone_t hint)
+	uint16_t ndesc, avail_idx;
+	avail_idx = vq->vq_ring.avail->idx;
+	ndesc = (uint16_t)(avail_idx - vq->vq_used_cons_idx);
+	switch (hint) {
+	case VQ_POSTPONE_SHORT:
+		ndesc = ndesc / 4;
+		break;
+	case VQ_POSTPONE_LONG:
+		ndesc = (ndesc * 3) / 4;
+		break;
+	case VQ_POSTPONE_EMPTIED:
+		break;
+	return (vq_ring_enable_interrupt(vq, ndesc));
+ * Note this is only considered a hint to the host.
+void
+virtqueue_disable_intr(struct virtqueue *vq)
+	if (vq->vq_flags & VIRTQUEUE_FLAG_EVENT_IDX) {
+		vring_used_event(&vq->vq_ring) = vq->vq_used_cons_idx -
+		    vq->vq_nentries - 1;
+	} else
+		vq->vq_ring.avail->flags |= VRING_AVAIL_F_NO_INTERRUPT;
+#ifdef NOTUSED
+int
+virtqueue_enqueue(struct virtqueue *vq, void *cookie, struct sglist *sg,
+	int needed;
+	uint16_t head_idx, idx;
+	needed = readable + writable;
+	VQASSERT(vq, cookie != NULL, "enqueuing with no cookie");
+	VQASSERT(vq, needed == sg->sg_nseg,
+	    "segment count mismatch, %d, %d", needed, sg->sg_nseg);
+	VQASSERT(vq,
+	    needed <= vq->vq_nentries || needed <= vq->vq_max_indirect_size,
+	    "too many segments to enqueue: %d, %d/%d", needed,
+	    vq->vq_nentries, vq->vq_max_indirect_size);
+	if (needed < 1)
+		return (EINVAL);
+	if (vq->vq_free_cnt == 0)
+		return (ENOSPC);
+	if (vq_ring_use_indirect(vq, needed)) {
+		vq_ring_enqueue_indirect(vq, cookie, sg, readable,
writable);
+		return (0);
+	} else if (vq->vq_free_cnt < needed)
+		return (EMSGSIZE);
+	head_idx = vq->vq_desc_head_idx;
+	VQ_RING_ASSERT_VALID_IDX(vq, head_idx);
+	dxp = &vq->vq_descx[head_idx];
+	VQASSERT(vq, dxp->cookie == NULL,
+	    "cookie already exists for index %d", head_idx);
+	dxp->cookie = cookie;
+	dxp->ndescs = needed;
+	idx = vq_ring_enqueue_segments(vq, vq->vq_ring.desc, head_idx,
+	    sg, readable, writable);
+	vq->vq_desc_head_idx = idx;
+	vq->vq_free_cnt -= needed;
+		VQ_RING_ASSERT_CHAIN_TERM(vq);
+	else
+		VQ_RING_ASSERT_VALID_IDX(vq, idx);
+	vq_ring_update_avail(vq, head_idx);
+	return (0);
+#endif
+int
+rtems_virtqueue_enqueue(struct virtqueue *vq, void *cookie,
+	int needed;
+	VQASSERT(vq,
+	if (needed < 1)
+		return (EINVAL);
+		return (ENOSPC);
+#ifdef NOTUSED
writable);
+		return (0);
+#endif
+	if (vq->vq_free_cnt < needed)
+#endif
+	idx = rtems_vq_ring_enqueue_segments(vq, vq->vq_ring.desc, head_idx,
+	    cookie, readable, writable);
+	else
+	return (0);
+#endif
+void *
+virtqueue_dequeue(struct virtqueue *vq, uint32_t *len)
+	struct vring_used_elem *uep;
+	void *cookie;
+	uint16_t used_idx, desc_idx;
+		return (NULL);
+	used_idx = vq->vq_used_cons_idx++ & (vq->vq_nentries - 1);
+	uep = &vq->vq_ring.used->ring[used_idx];
+	rmb();
+	// __asm __volatile("lock; addl $0,(%%esp)" : : : "memory", "cc")
+	desc_idx = (uint16_t) uep->id;
+	if (len != NULL)
+		*len = uep->len;
+	vq_ring_free_chain(vq, desc_idx);
+	cookie = vq->vq_descx[desc_idx].cookie;
+	VQASSERT(vq, cookie != NULL, "no cookie for index %d", desc_idx);
+	vq->vq_descx[desc_idx].cookie = NULL;
+	return (cookie);
+#ifdef NOTUSED
+void *
+virtqueue_poll(struct virtqueue *vq, uint32_t *len)
+	void *cookie;
+	while ((cookie = virtqueue_dequeue(vq, len)) == NULL)
+		cpu_spinwait();
+	return (cookie);
+#endif
+void *
+virtqueue_drain(struct virtqueue *vq, int *last)
+	void *cookie;
+	int idx;
+	cookie = NULL;
+	idx = *last;
+	while (idx < vq->vq_nentries && cookie == NULL) {
+		if ((cookie = vq->vq_descx[idx].cookie) != NULL) {
+			vq->vq_descx[idx].cookie = NULL;
+			/* Free chain to keep free count consistent. */
+			vq_ring_free_chain(vq, idx);
+		idx++;
+	*last = idx;
+	return (cookie);
+#ifdef NOTUSED
+void
+virtqueue_dump(struct virtqueue *vq)
+	if (vq == NULL)
+		return;
+	printf("VQ: %s - size=%d; free=%d; used=%d; queued=%d; "
+	    "desc_head_idx=%d; avail.idx=%d; used_cons_idx=%d; "
+	    "used.idx=%d; avail.flags=0x%x; used.flags=0x%x\n",
+	    vq->vq_name, vq->vq_nentries, vq->vq_free_cnt,
+	    virtqueue_nused(vq), vq->vq_queued_cnt, vq->vq_desc_head_idx,
+	    vq->vq_ring.avail->idx, vq->vq_used_cons_idx,
+	    vq->vq_ring.used->idx, vq->vq_ring.avail->flags,
+	    vq->vq_ring.used->flags);
+#endif
+static void
+vq_ring_init(struct virtqueue *vq)
+	struct vring *vr;
+	char *ring_mem;
+	int i, size;
+	ring_mem = vq->vq_ring_mem;
+	size = vq->vq_nentries;
+	vr = &vq->vq_ring;
+	vring_init(vr, size, ring_mem, vq->vq_alignment);
+	for (i = 0; i < size - 1; i++)
+		vr->desc[i].next = i + 1;
+	vr->desc[i].next = VQ_RING_DESC_CHAIN_END;
+static void
+vq_ring_update_avail(struct virtqueue *vq, uint16_t desc_idx)
+	uint16_t avail_idx;
+	 * Place the head of the descriptor chain into the next slot and
make
+	 * it usable to the host. The chain is made available now rather
than
+	 * deferring to virtqueue_notify() in the hopes that if the host is
+	 * currently running on another CPU, we can keep it processing the
new
+	 * descriptor.
+	avail_idx = vq->vq_ring.avail->idx & (vq->vq_nentries - 1);
+	vq->vq_ring.avail->ring[avail_idx] = desc_idx;
+	wmb();
+	vq->vq_ring.avail->idx++;
+	/* Keep pending count until virtqueue_notify(). */
+	vq->vq_queued_cnt++;
+#ifdef NOTUSED
+static uint16_t
+vq_ring_enqueue_segments(struct virtqueue *vq, struct vring_desc *desc,
+    uint16_t head_idx, struct sglist *sg, int readable, int writable)
+	struct sglist_seg *seg;
+	struct vring_desc *dp;
+	int i, needed;
+	uint16_t idx;
+	for (i = 0, idx = head_idx, seg = sg->sg_segs;
+	     i < needed;
+	     i++, idx = dp->next, seg++) {
+		VQASSERT(vq, idx != VQ_RING_DESC_CHAIN_END,
+		    "premature end of free desc chain");
+		dp = &desc[idx];
+		dp->addr = seg->ss_paddr;
+		dp->len = seg->ss_len;
+		dp->flags = 0;
+		if (i < needed - 1)
+			dp->flags |= VRING_DESC_F_NEXT;
+		if (i >= readable)
+			dp->flags |= VRING_DESC_F_WRITE;
+	return (idx);
+#endif
+static uint16_t
+rtems_vq_ring_enqueue_segments(struct virtqueue *vq, struct vring_desc
*desc,
+    uint16_t head_idx, struct mbuf *m_head, int readable, int writable)
+	struct mbuf *m;
+	int i, needed;
+	uint16_t idx;
+	for (i = 0, idx = head_idx, m = m_head; i < needed;
+		i++, idx = dp->next, m=m->m_next) {
+		dp = &desc[idx];
+		dp->addr = (uint64_t) m->m_data;
+		dp->len = m->m_len;
+		dp->flags = 0;
+	return (idx);
+#endif
+#ifdef NOTUSED
+static int
+vq_ring_use_indirect(struct virtqueue *vq, int needed)
+	if ((vq->vq_flags & VIRTQUEUE_FLAG_INDIRECT) == 0)
+		return (0);
+	if (vq->vq_max_indirect_size < needed)
+		return (0);
+	if (needed < 2)
+		return (0);
+	return (1);
+static void
+vq_ring_enqueue_indirect(struct virtqueue *vq, void *cookie,
+    struct sglist *sg, int readable, int writable)
+	int needed;
+	uint16_t head_idx;
+	VQASSERT(vq, needed <= vq->vq_max_indirect_size,
+	    "enqueuing too many indirect descriptors");
+	dp = &vq->vq_ring.desc[head_idx];
+	dxp->ndescs = 1;
+	dp->addr = dxp->indirect_paddr;
+	dp->len = needed * sizeof(struct vring_desc);
+	dp->flags = VRING_DESC_F_INDIRECT;
+	vq_ring_enqueue_segments(vq, dxp->indirect, 0,
+	vq->vq_desc_head_idx = dp->next;
+	vq->vq_free_cnt--;
+	else
+		VQ_RING_ASSERT_VALID_IDX(vq, vq->vq_desc_head_idx);
+#endif
+static int
+vq_ring_enable_interrupt(struct virtqueue *vq, uint16_t ndesc)
+	 * Enable interrupts, making sure we get the latest index of
+	 * what's already been consumed.
+		vring_used_event(&vq->vq_ring) = vq->vq_used_cons_idx +
ndesc;
+	else
+		vq->vq_ring.avail->flags &= ~VRING_AVAIL_F_NO_INTERRUPT;
+	mb();
+	 * Enough items may have already been consumed to meet our threshold
+	 * since we last checked. Let our caller know so it processes the
new
+	 * entries.
+	if (virtqueue_nused(vq) > ndesc)
+		return (1);
+	return (0);
+static int
+vq_ring_must_notify_host(struct virtqueue *vq)
+	uint16_t new_idx, prev_idx, event_idx;
+#ifdef NOTUSED
+		new_idx = vq->vq_ring.avail->idx;
+		prev_idx = new_idx - vq->vq_queued_cnt;
+		event_idx = vring_avail_event(&vq->vq_ring);
+		return (vring_need_event(event_idx, new_idx, prev_idx) !=
0);
+#endif
+	return ((vq->vq_ring.used->flags & VRING_USED_F_NO_NOTIFY) == 0);
+static void
+vq_ring_notify_host(struct virtqueue *vq)
+	VIRTIO_BUS_NOTIFY_VQ(vq->vq_dev, vq->vq_queue_index);
+static void
+vq_ring_free_chain(struct virtqueue *vq, uint16_t desc_idx)
+	VQ_RING_ASSERT_VALID_IDX(vq, desc_idx);
+	dp = &vq->vq_ring.desc[desc_idx];
+	dxp = &vq->vq_descx[desc_idx];
+	vq->vq_free_cnt += dxp->ndescs;
+	dxp->ndescs--;
+	if ((dp->flags & VRING_DESC_F_INDIRECT) == 0) {
+		while (dp->flags & VRING_DESC_F_NEXT) {
+			VQ_RING_ASSERT_VALID_IDX(vq, dp->next);
+			dp = &vq->vq_ring.desc[dp->next];
+			dxp->ndescs--;
+	VQASSERT(vq, dxp->ndescs == 0,
+	    "failed to free entire desc chain, remaining: %d", dxp->ndescs);
+	 * We must append the existing free chain, if any, to the end of
+	 * newly freed chain. If the virtqueue was completely used, then
+	 * head would be VQ_RING_DESC_CHAIN_END (ASSERTed above).
+	dp->next = vq->vq_desc_head_idx;
+	vq->vq_desc_head_idx = desc_idx;
diff --git a/c/src/lib/libbsp/i386/pc386/virtio/virtqueue.h
b/c/src/lib/libbsp/i386/pc386/virtio/virtqueue.h
index 0000000..9016f7d
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/virtio/virtqueue.h
@@ -0,0 +1,127 @@
+ * @file virqueue.h
+ * @brief
+ * are met:
+ *    disclaimer.
WARRANTIES
USE,
+ * $FreeBSD: release/10.0.0/sys/dev/virtio/virtqueue.h 255109 2013-09-01
04:16:43Z bryanv $
+#ifndef _VIRTIO_VIRTQUEUE_H
+#define _VIRTIO_VIRTQUEUE_H
+struct virtqueue;
+#ifdef NOTUSED
+struct sglist;
+#endif
+/* Support for indirect buffer descriptors. */
+#define VIRTIO_RING_F_INDIRECT_DESC	(1 << 28)
+/* Support to suppress interrupt until specific index is reached. */
+#define VIRTIO_RING_F_EVENT_IDX		(1 << 29)
+/* Device callback for a virtqueue interrupt. */
+typedef void virtqueue_intr_t(void *);
+ * Hint on how long the next interrupt should be postponed. This is
+ * only used when the EVENT_IDX feature is negotiated.
+typedef enum {
+	VQ_POSTPONE_SHORT,
+	VQ_POSTPONE_LONG,
+	VQ_POSTPONE_EMPTIED	/* Until all available desc are used. */
+} vq_postpone_t;
+#define VIRTQUEUE_MAX_NAME_SZ	32
+/* One for each virtqueue the device wishes to allocate. */
+struct vq_alloc_info {
+	char		   vqai_name[VIRTQUEUE_MAX_NAME_SZ];
+	int		   vqai_maxindirsz;
+	virtqueue_intr_t  *vqai_intr;
+	void		  *vqai_intr_arg;
+	struct virtqueue **vqai_vq;
+#define VQ_ALLOC_INFO_INIT(_i,_nsegs,_intr,_arg,_vqp,_str,...) do {	\
+	snprintf((_i)->vqai_name, VIRTQUEUE_MAX_NAME_SZ, _str,		\
+	    ##__VA_ARGS__);						\
+	(_i)->vqai_maxindirsz = (_nsegs);				\
+	(_i)->vqai_intr = (_intr);					\
+	(_i)->vqai_intr_arg = (_arg);					\
+	(_i)->vqai_vq = (_vqp);						\
+} while (0)
+uint64_t virtqueue_filter_features(uint64_t features);
+int	 virtqueue_alloc(device_t dev, uint16_t queue, uint16_t size,
+	     int align, vm_paddr_t highaddr, struct vq_alloc_info *info,
+	     struct virtqueue **vqp);
+void	*virtqueue_drain(struct virtqueue *vq, int *last);
+void	 virtqueue_free(struct virtqueue *vq);
+int	 virtqueue_reinit(struct virtqueue *vq, uint16_t size);
+int	 virtqueue_intr_filter(struct virtqueue *vq);
+void	 virtqueue_intr(struct virtqueue *vq);
+int	 virtqueue_enable_intr(struct virtqueue *vq);
+int	 virtqueue_postpone_intr(struct virtqueue *vq, vq_postpone_t hint);
+void	 virtqueue_disable_intr(struct virtqueue *vq);
+/* Get physical address of the virtqueue ring. */
+vm_paddr_t virtqueue_paddr(struct virtqueue *vq);
+int	 virtqueue_full(struct virtqueue *vq);
+int	 virtqueue_empty(struct virtqueue *vq);
+int	 virtqueue_size(struct virtqueue *vq);
+int	 virtqueue_nused(struct virtqueue *vq);
+void	 virtqueue_notify(struct virtqueue *vq);
+void	 virtqueue_dump(struct virtqueue *vq);
+#ifdef NOTUSED
+int	 virtqueue_enqueue(struct virtqueue *vq, void *cookie,
+	     struct sglist *sg, int readable, int writable);
+#endif
+int	rtems_virtqueue_enqueue(struct virtqueue *vq, void *cookie,
+#endif
+void	*virtqueue_dequeue(struct virtqueue *vq, uint32_t *len);
+void	*virtqueue_poll(struct virtqueue *vq, uint32_t *len);
+#endif /* _VIRTIO_VIRTQUEUE_H */
1.9.1
