[PATCH] pc386: Add virtio network driver
Tue May 31 11:05:09 UTC 2016
Hello Pavel,
On 30/05/16 15:57, Pavel Pisa wrote:
> Hello Jin-Hyun and Sebastian,
> On Monday 30 of May 2016 15:06:40 Sebastian Huber wrote:
>> >Wouldn't it make sense to use the libbsd for this network interface driver?
> my feeling is that from long run perspective is libBSD.
> But I think that virtio netwok included in basic RTEMS stack is very
> important which is based on assumption that there are more people
> who use and are familiar with RTEMS integrated stack than who
> started to use libBSD.
> So I personally like idea to include this option to the standard sources.
> I would like a little more if x86 specific part of virtio ends
> in c/src/lib/libbsp/i386/pc386/virtio, but common part which can
> be reused for other architectures and network driver specific part
> is placed in rtems/c/src/lib/libbsp/shared and rtems/c/src/libchip/network.
> It would worth to add x86 virtio to libBSD and even to lwIP
> to have option to test all these stacks under quite spread KVM
> based virtualization/test environment.
> But generally, I would like if the code can be accepted to mainline.
the x86 architecture is not really interesting for me. So, I am not
against a mainline integration. However, I think we reached a dead end
with the pc386 BSP. The RTEMS driver infrastructure is not capable
enough to deal with a plug-and-play architecture like x86.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
